Old 24th January 2023, 05:25   #301  |  Link
Hat3L0v3
Hat3L0v3's Avatar
Originally Posted by kedautinh12 View Post
Ok, i use this fftw3.3.10 and didn't had error (you can copy all x64 .dll to system32)
https://drive.google.com/file/d/1PF9...w?usp=drivesdk
If error still exist, try search: add or remove program -> unistall all vc++ version and install abbodi1406's vc++ again
Don't understand why you think fftw3 .dll`s are the problem. I deleted all of them, its still crashing.
scanned disc C with AlternateStreamView show nothing except some torrent files.
I delete manually all vc++ that was installed on pc and run depan again - still crashing.
Guess I need delete avs+ 3.7.3 r3825 and go back for 3.7.2 stable version.
upd. After installing avs+ 3.7.2 stable start getting Access Violation error, not a crash.
Hat3L0v3 is offline   Reply With Quote
Old 24th January 2023, 05:55   #302  |  Link
StainlessS
StainlessS's Avatar
Have a look at your Windows Event Logs.
(Right Click "My PC" (or whatever its called {I'm not currently on Windows}, and click on Manage)
I sometimes post sober.
Old 24th January 2023, 06:59   #303  |  Link
Hat3L0v3
Hat3L0v3's Avatar
you mean Event Viewer ? and what I need looking for?
upd. I download FullEventLogView, but it doesn't show anything new when I recreating Access Violation error.
Old 27th January 2023, 15:24   #304  |  Link
Hat3L0v3
Hat3L0v3's Avatar
Sorry guys, my bad. There was nothing wrong with setup or .dll
I just didn't know that Depan require data from DePanEstimate in order to work correctly. So it crashed avsp every time. Usually filters lead to the place if something goes wrong. Didn't expect such behavior.
So I'll go run some tests to find settings that works better for me. Because stab3 helps me with shakings on static scenes (where backgound static and character (or something) are shaking) but also ruin another static scenes where there's no shaking (by making background follow character movement so all scene start shaking for exampe). So it takes me alot of time to watch and trim manually whole episode and apply stab3 only on scenes where it needed.
Old 27th January 2023, 15:40   #305  |  Link
kedautinh12
I was said you about DePanEstimate.dll but you won't notice it
https://forum.doom9.org/showthread.p...91#post1981691
Old 27th January 2023, 16:04   #306  |  Link
pinterf
The dlls were perfectly fine. The avs script did not pass the result of DepanEstimate to Depan. Depan was called without any parameters.
pinterf is offline   Reply With Quote
