Old 6th June 2019, 18:24   #6761  |  Link
StainlessS
StainlessS's Avatar
Non catastrophic bug, see EDIT here:- https://forum.doom9.org/showthread.p...45#post1876445
EDIT: to below.
OK got it G2K4. Nice bit of code you posted there,
if (sizeof(void*) == 8) // Test 64 on 64
easy when you know how.
EDIT: Yep, got that as well. thanx again boss.
I sometimes post sober.
Old 6th June 2019, 18:42   #6762  |  Link
Groucho2004
See here.
Groucho's Avisynth Stuff
Old 6th June 2019, 19:30   #6763  |  Link
Groucho2004
OK got it G2K4.
My point was that Zathor is aware of this as you can see a few posts down but decided to stick with the current implementation.
Old 12th June 2019, 15:24   #6764  |  Link
laurentje
Importing DV AVI causing warning and audio delay
I want to convert my dv avi-files (from my Pana GS500) to mkv-files. Therefore I use One-click function of Megui.
From the moment I drag the file name in the input-field into the field "Input" I get a "Warning" in the log.
See my log here (see attachment 1).
In the dialog screen I get the following (see attachment 2)
In the field Delay (Audio tap) you see a value of 2205360, which is wrong and should be 0.
When I go on (with the given value), finally the program produce an mkv and video and audio are not synchronized.
So I am thinking this is a bug, or I am doing something wrong with my dv avi-file? What is the best way to convert dv avi to mkv (avc)?
Any help is much appreciated.
PS
Afterwards I clicked on help and on that Wikipage on the first line I read: "The One Click Encoder aims to allow a single job configuration in one step, followed by a completed automated encode. It currently only works with MPEG-2 sources (in particular, DVDs)." So my file is not MPEG-2, it is dv avi. I should use other soft.
laurentje is offline   Reply With Quote
Old 13th June 2019, 07:46   #6765  |  Link
Just to have it mentioned: I know three different ways to use MeGUI. One is the manual use of the main tab to fill the queue, step by step.
But yes, for this rather simple task, VirtualDub2 may be just sufficient.
LigH is online now   Reply With Quote
Old 22nd June 2019, 11:30   #6766  |  Link
hello_hello
laurentje,
Try opening an AVI with MeGUI's MKV muxer, or with MKVToolNixGUI, repack the AVI as an MKV, then use that as the source. The problem will probably go away, although it's not ideal if you've got lots of AVIs to convert.
Old 11th July 2019, 20:31   #6767  |  Link
Barough
Barough's Avatar
MP4Box v0.8.0-rev8-g3fc6b0e17
x265 v3.1+7-147fb92c5ed5
Old 19th July 2019, 12:57   #6768  |  Link
Barough
Barough's Avatar
x264 0.158.2984 3759fcb
Old 19th July 2019, 13:42   #6769  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
Originally Posted by Barough View Post
Thanks , and Happy Friday!
LouieChuckyMerry is offline   Reply With Quote
Old 28th July 2019, 11:45   #6770  |  Link
Bazzu85
guys, I'm new here but using Megui from a while..
I'm noticing that the internal update is not fetching anything new..
for example I have x265 in version 2.9+1 with date 08/10/2018..
is normal to not have auto update?
Bazzu85 is offline   Reply With Quote
Old 28th July 2019, 17:54   #6771  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Bazzu85 View Post
...I have x265 in version 2.9+1 with date 08/10/2018..
MeGUI -> Options -> Extended -> Auto Update -> Use developement update server
Last stable release is from 12/2018, in development server x265 is 3.0+4 (LigH).
Or download latest versions at your risk
Old 28th July 2019, 20:54   #6772  |  Link
Bazzu85
thx for made it clear!
another question..
Having a mkv with 2 audio and 3 subs (italian forced, italian, english)
when muxing into the destination file sometimes I have a warning that says: Ignoring subtitle track as it is too small
this is correct because maybe the forced sub is an empty track..
the problem is that the results as no subs at all. the program ignore all the subs track and not only the one empy..
Old 29th July 2019, 02:58   #6773  |  Link
tebasuna51
tebasuna51's Avatar
Yes, seems than the error: Ignoring subtitle track as it is too small
abort all the subtitle management.
It is a bug for Zathor, maybe after holidays...
Old 29th July 2019, 11:58   #6774  |  Link
Barough
Barough's Avatar
MP4Box v0.8.0-rev41-gb78fe5fbe
https://github.com/gpac/gpac
x265 v3.1+10-459d3822c608
Old 31st July 2019, 19:16   #6775  |  Link
kuchikirukia
Would it be possible to prepend the One-Click's random working directory names with the job number so they're in some sort of order?
kuchikirukia is offline   Reply With Quote
Old 1st August 2019, 06:48   #6776  |  Link
Bazzu85
good, I 've to report the bug somewhere?
Old 1st August 2019, 09:28   #6777  |  Link
tebasuna51
tebasuna51's Avatar
Here is ok.
Old 9th August 2019, 16:21   #6778  |  Link
Octo-puss
Please add the possibility to close any windows with Esc key.
Octo-puss is offline   Reply With Quote
Old 18th August 2019, 03:58   #6779  |  Link
stax76
stax76's Avatar
Old 27th August 2019, 21:24   #6780  |  Link
pooksahib
Hi. If I have 2 videos of the same size and type, I'll use megui to create the script for the first video. The name given to the script will be in the form 'vid1.mp4.avs'.
For the 2nd video, I'll simply copy/paste the existing script and change the source. Sometimes, though, I'm careless and will call the pasted script 'vid2.avs' instead of 'vid2.mp4.avs'.
In that situation, as soon as I click 'start' a message pops up saying 'output file xxx already exists, do you want to overwrite?' Whether I say Yes or No, my source video gets deleted!
Is this a bug? Is there any way of aborting without deleting the source video? Thank you.
pooksahib is offline   Reply With Quote
