6th July 2016, 23:14 | #14461 | Link |
Hello Atak! One of the PC is not detecting/demuxing the audio track(DTS) but the other is working perfectly.
I use the same version of ffdshow both. I recently installed Windows 7 on that machine, you have any idea what could be wrong? Code:
Audio ID : 2 Format : DTS Format/Info : Digital Theater Systems Mode : 16 Format settings, Endianness : Big Codec ID : A_DTS Duration : 54 min Bit rate mode : Constant Bit rate : 1 509 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 spf) Bit depth : 24 bits Compression mode : Lossy Stream size : 585 MiB (24%) Language : English Default : Yes Forced : No |
7th July 2016, 10:26 | #14462 | Link |
Rename source file to something simpler without those special characters in file path.
7th July 2016, 12:59 | #14463 | Link |
The source file is simple, no special characters.
D:\BLU-RAY\2.True.Blood.1ª.Temporada\2_THE_FIRST_TASTE.mkv And occasionally RipBot264 loads slowly, as if the HD was too slow, have you seen this happen? |
7th July 2016, 13:00 | #14464 | Link | |
I do not like this weird "a"
12th July 2016, 22:12 | #14467 | Link |
please help:
DirectShowSource: couldn't open file D:\2015-02-08_08.25.33_00006.avi: The source filter for this file could not be loaded. (C:\Temp\RipBot264temp\job1\getinfo.avs, line 2) renaming file did not help... what needs to be done to make it working again? getinfo.avs Code:
video=DirectShowSource("D:\2015-02-08_08.25.33_00006.avi",audio=false).ConvertToYV12() LoadPlugin("C:\Program Files (x86)\RipBot264\tools\AviSynth plugins\NicAudio\NicAudio.dll") audio=RaWavSource("C:\Temp\RipBot264temp\job1\audio.wav",1) AudioDub(video,audio) WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Framecount") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Framerate") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioRate") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioChannels") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","AudioLength") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Width") WriteFile("C:\Temp\RipBot264temp\job1\info.txt","Height ") Trim(0,-1) Code:
General Complete name : D:\2015-02-08_08.25.33_00006.avi Format : AVI Format/Info : Audio Video Interleave File size : 1.35 GiB Duration : 1 min Overall bit rate : 176 Mb/s Writing library : VirtualDub build 35576/release Video ID : 0 Format : HuffYUV Format version : Version 2 Codec ID : FFVH Duration : 1 min Bit rate : 166 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 25.000 FPS Color space : YUV Chroma subsampling : 4:2:2 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 3.210 Stream size : 1.28 GiB (95%) Audio ID : 1 Format : PCM Format settings, Endianness : Little Format settings, Sign : Signed Codec ID : 00001000-0000-0100-8000-00AA00389B71 Duration : 1 min Bit rate mode : Constant Bit rate : 9 216 kb/s Channel(s) : 6 channels Channel positions : Front: L C R, Side: L R, LFE Sampling rate : 48.0 kHz Bit depth : 32 bits Stream size : 72.5 MiB (5%) Alignment : Aligned on interleaves Interleave, duration : 40 ms (1.01 video frame) Interleave, preload duration : 500 ms |
13th July 2016, 14:13 | #14468 | Link |
make sure that this is enabled for HuffYUV.
Alternatively switch to UTVideo while exporting from VirtualDUB.
14th July 2016, 11:23 | #14470 | Link |
Distributed encoding fix-around
I'm having problem with permissions on Windows 10 for distributed encoding. After some searching i found fix-around for this problem: i'm running batch file: Code:
@echo off echo Starting of auto re-share dir :CheckDir timeout 1 > nul if not exist "\\COMPUTER_NAME\RipBot264temp" goto ShareDir goto CheckDir :ShareDir echo Directory re-shared !! net share RipBot264temp=C:\Temp\RipBot264temp /GRANT:Wszyscy,FULL goto CheckDir "Wszyscy" must be changed for your Windows language. After running this batch, RipBot264 works OK on Windows 10 x64. |
15th July 2016, 12:11 | #14471 | Link | |
if not exist "\\%userdomain%\RipBot264temp" goto ShareDir The file also has to be called with admin rigths to avoid permission errors Last edited by userx; 15th July 2016 at 12:15. |
15th July 2016, 14:07 | #14472 | Link |
I'm surprised that some Windows do not understand "EVERYONE" group. I don't know why but my polish Windows 7 has no issues with english word "EVERYONE" in net share command. It looks like that from some political reasons M$ in german and french versions removed support for universal "EVERYONE" name and they use local alternatives like "Jeder" or "Tout le monde".
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 15th July 2016 at 14:13. |
15th July 2016, 14:41 | #14473 | Link |
Registered Loser
You are better off using the SID of everyone: S-1-1-0
https://support.microsoft.com/en-us/kb/243330 However, it will be a bit more difficult to code that into a batch file. Code:
set MySid=S-1-1-0 for /f "delims= " %%a in ('"wmic path win32_account where SID='%MySid%' get name"') do ( if not "%%a"=="Name" ( set myvar=%%a goto :loop_end ) ) :loop_end net share RipBot264temp=C:\Temp\RipBot264temp /GRANT:%myvar%,FULL |
15th July 2016, 20:50 | #14475 | Link | |
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
15th July 2016, 22:52 | #14476 | Link | |||
It seems this can be sorted by using PsGetSid from sysinternals. This will spit out the correct "translation" on the used OS language. From there u can use the proper "translation" in the net share Dutch: Quote:
19th July 2016, 07:59 | #14477 | Link |
Hi Atak,
To change the subject, I recently swapped out my GTX 680 for an AMD R9 290 with a Artic Cooler system installed, and I used Ripbot for the 1st time since doing that, today. The 1st encode went thru with no problems, but then I enabled the OpenCL Acceleration option, and then all sorts of problems started, the AMD driver would stop working, which caused Ripbot to stop, also after the monitor came out of sleep, Ripbot had stopped, so I re started everything with the OpenCL disabled, and it was stable again. Running Windows 8.1, and the very latest Crimson drivers for the 290. Is there something I'm missing here ??? edit:- I think I may have found a reason for this behavior...there are "remnant's" of nVidia drivers on the system. Your opinion would be welcome. Last edited by burt123; 19th July 2016 at 13:37. Reason: more info |
19th July 2016, 13:51 | #14478 | Link |
Is r9 290 a new one or used? I assume it is a second hand card. Check temperatures during OpenCL strest test in AIDA. You may also check VRAM usage during encoding with x264 (opencl acceleration enabled).
19th July 2016, 14:22 | #14480 | Link | |
Well, before I changed from the standard 1 fan heatsink assembly to the 3 fan Artic Cooler, it use to run in excess of 90 C when enable on a different PC. With the Artic Cooler it now runs at least 20 C cooler. OK, I will run a couple of AIDA tests, and let you know, but I really think what might fix it, is a fresh setup of Windows, the current setup is pretty old (a couple of years) UPDATE:- OK, have cleaned out all the nVidia drivers, etc, installed the very latest AMD drivers, and everything's sweet 290 temps are around the mid 60's C under 100 load. (coolish day, tho), but would be running at over 90 C with standard heatsink Last edited by burt123; 20th July 2016 at 04:54. Reason: Update |
