16th September 2016, 14:47 | #24891 | Link |
Hi guys
I have a problem and do not know why this happens, not the entire structure of bluray appears if selected BD25 full backup, missing the extras and have selected rebuilder.ini MIN_M2TS_SIZE = 5 (output bd25 fullbluray structure) however if I select output BD5 / 9, if the entire structure, I can do to release the complete structure appears BD25 full backup? (output bd5/9 structure) I make a video/capture showing what I try to explain. https://mega.nz/#!hItjVSiD!RUWieNP_C...W9EdvX4uLLtdUQ |
16th September 2016, 15:12 | #24892 | Link |
BD-RB will keep small M2TS files intact when outputting to BD-25/50. This is because they are too small to reduce size by any meaningful amount -- and to reencode them is a waste of time. By default files under 100MB are not reencoded, but you can adjust that value with the hidden option MIN_M2TS_SIZE. There are also other considerations that might result in some streams not being encoded (for the sake of expediency).
But... when outputting to BD-5/9 (DVD media) you don't have that option because the bitrate used for Blu-Ray is higher than a DVD can handle. So BD-RB has to reencode them (regardless of size). Last edited by jdobbs; 16th September 2016 at 15:17. |
16th September 2016, 15:50 | #24893 | Link | |
16th September 2016, 16:08 | #24894 | Link | |
Of course they are.
16th September 2016, 17:54 | #24895 | Link | |
What I'd suggest, if your Mac's HDD has the free space is create a Windows Partition which would give you full access to the Graphics Board and other hardware (which means full speed). Anyway, if you're cool with basic functionality and Okay speeds while using Mac OS, then enjoy. I don't post logs here of any errors because as JDobbs typed..no support and that's understandable. So your own experiences and willingness to debug is what you have to rely on unless you reproduce the error with a real machine.
17th September 2016, 15:17 | #24896 | Link |
@ lauguru; RE: however if I select output BD5 / 9, if the entire structure, I can do to release the complete structure appears BD25 full backup?
I always use the Movie & Menu's (Auto Blank Extras) mode to see all the tiny bits and pieces of the Blu-ray when trying to see what I can reasonably blank without killing the menu or some little extra I'd like to keep. I output to a 50,000 MB size and let BD Rebuilder create a folder. I then move this to another hard drive and feed it to back to BD Rebuilder as a FULL backup and a 23350 custom size. This results in a better sized Blu-ray than when I attempt to do it on the first rebuild. Takes about 25-30 minutes longer but it usually results in a lot better sized disk and seems to play better because it jumps over all the previously blanked parts more smoothly. This is especially good when you have a disk that repeatedly over or under sizes. |
18th September 2016, 16:25 | #24898 | Link | |
although you put BD50 output and FORCE_ENCODE=1, extras not appear on the log list, it seems that only the movie was recoded, although they were added to fullbd without recoding
allways 23,8gb (24315mb output) output 23750mb and result 23,2 gb Quote:
