Old 22nd October 2018, 15:13   #27901  |  Link
Originally Posted by Max1984 View Post
I m try to UHD TO BD25 with menu encoding to.. menu /sub/video all fine. just sync in audio . plzz tell me best audio setting & how to fix it. thanx ..
I wish I knew. I've been struggling with that for almost a year now. That is why the UHD-BD function is considered "experimental" -- with a hope that someone catches something that might offer a solution.
Old 22nd October 2018, 21:34   #27902  |  Link
gonca
Any idea why that 10 second audio delay is introduced during the muxing
Old 22nd October 2018, 22:50   #27903  |  Link
I'd have to see it to know. But... if BD-RB inserts a delay, it is because there is that much of a difference between the Presentation Time Stamp (PTS) of the first video packet and the PTS of the first audio packet. My guess would be it is caused by the way you cut it -- but, as I said, I'd only know if I could test the clip itself.
Old 22nd October 2018, 22:53   #27904  |  Link
Just an update... I seem to be getting closer on the audio sync issue with UHD-BD -- at least based upon a small segment of a source I've been testing. I don't want to get too excited, though, as I've gotten to this point before only to find that the solution I implemented caused another problem when applied against a full movie. The unfortunate part is that it takes so long to encode, that it will usually take the better part of an entire day before I know whether it needs further tweaking. Then, if it does, there's another day to test that one!
Old 23rd October 2018, 00:00   #27905  |  Link
gonca
That 10 second delay was present on both the full disc import (UHD) which had a 83ms delay, according to MediaInfo, and on the clip import, which had a 0ms delay, according to MediaInfo.
Might this delay have something to do with the audio sync issue others are reporting
If you wish I can cut the clip one more time and post it somewhere for you
Old 23rd October 2018, 00:17   #27906  |  Link
No. The audio sync issues aren't related to that.
Old 23rd October 2018, 03:37   #27907  |  Link
MrVideo
MrVideo's Avatar
1. Import multiple files. It creates a pseudo-structure with multiple menu entries. Let it finish importing.
I suspect you mean to import into the batch queue.
2. From the mode menu, select the ALTERNATE method to be used (output format)
I'm guessing this step can be skipped if it was already set.
3. Go to the "Batch" tab.
4. Right-click on the queue area.
5. Select "Add multiple playlists to Queue"
6. From the list, choose the playlist(s) you want to output in the format you selected in step 2.
Well, at this point it is not as you expected. The first time I did this, only one of the three playlists was given. Knowing as to how you like to have options for minimum minutes, I went looking and found MIN_PLAYLIST_MINS. The default is 15, which explained the one item, which is 16 min+. So, I added the option and set it to "1". Now nothing shows up.
UPDATE: Now I am really confused. I removed the option and there is still nothing.
Old 23rd October 2018, 03:38   #27908  |  Link
AmigaFuture
AmigaFuture's Avatar
Then I'd appreciate it if you didn't post comments about DVD import not working -- like this:...especially about a function that has been working correctly for years. If you had a problem, I'm guessing it is something related to those particular DVDs... although I don't recall your specific bug report.
If I sound pissed... it's because I am.
Ack!! I should have removed the post. I'll do that next. It wasn't meant to come across the way it was read by you, and I understand why it seems as it was. Pardon for not being clearer and not removing it.
Old 23rd October 2018, 03:47   #27909  |  Link
AmigaFuture
Did you post over there, pointing out the error of his ways?
It's not me, there.
I edited my reply here.. I wasn't really annoyed or bothered THAT much, only commenting but I see how it WAS taken. Not my intent at all. Also had some personal stuff happening that I allowed to reflect some of my reply. Oops! I don't have any problems owning my own goofs.
@JD
Pardon, Boss. My reply should have been considered better and I accept the reason you became pissed. Respect!
Old 23rd October 2018, 04:35   #27910  |  Link
Originally Posted by AmigaFuture View Post
@JD
Ain't no big thing brother. Peace.
Old 23rd October 2018, 04:37   #27911  |  Link
No. I meant import into a pseudo-BD structure. Select "Import video files", select all the MKVs you want to import, and let it bring them in. Then when they have been imported, follow the rest of the instructions.
Old 23rd October 2018, 04:40   #27912  |  Link
AmigaFuture
Ehhhh...it matters to me. Appreciate the reply.
Old 23rd October 2018, 05:19   #27913  |  Link
AmigaFuture
I downloaded the new release. I haven't gotten to the Stargate DVDs yet. However, I figured I'd check "Role Models" BD..the Extra I typed about before. I see it's still the same. I'm not upset.
Making an MKV of the Extra..
[10/22/18] BD Rebuilder v0.60.04
[21:00:51] Source:  ROLE_MODELS_[UNRATED]_ANYDVD_(PROCESSED)_00100
  - Input BD size: 5.80 GB
  - Approximate total content: [00:49:49.819]
  - Windows Version: 6.1 [7601]
  - Mode: MKV, Intact Video, Intact Audio
  - Quality: High Quality (Default)
[21:00:54] PHASE ONE, Encoding
 - [21:00:54] Processing: VID_00361 (1 of 81)
 - [21:00:54] Extracting A/V streams [VID_00361]
 - [21:02:11] Reencoding video [VID_00361]
 - [21:02:11] Keeping original video (no reencode)
 - [21:02:11] Processing audio tracks
 - [21:02:11] Processing: VID_00362 (2 of 81)
 - [21:02:11] Extracting A/V streams [VID_00362]
 - [21:02:18] Reencoding video [VID_00362]
 - [21:02:18] Keeping original video (no reencode)
 - [21:07:41] Processing: VID_00441 (80 of 81)
 - [21:07:41] Extracting A/V streams [VID_00441]
 - [21:07:44] Reencoding video [VID_00441]
 - [21:07:44] Keeping original video (no reencode)
 - [21:07:44] Processing: VID_00442 (81 of 81)
 - [21:07:44] Extracting A/V streams [VID_00442]
 - [21:07:49] Reencoding video [VID_00442]
 - [21:07:49] Keeping original video (no reencode)
[21:07:49]PHASE ONE complete
[21:07:49]PHASE TWO - Rebuild Started
 - [21:07:49] Building ALTERNATE OUTPUT Structure
 - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta
 - Not enought buffer for parse video stream. Current frame num 0
[21:10:12] - Failed to REBUILD
I've re-ripped sevvvvveral times. Same result. If I make a BD of the extra, that goes well. When I play the resulting BD..there is an out of sync that happens as part of the multi-part extra. "Coffee Shop" is where the out of sync happens. If I make an MKV of that BD extra, the out of sync remains. If you want a log, that doesn't show any errors...I shall provide.
I don't remember which files you want to look at anymore. Remind me and I'll attach them.
Old 23rd October 2018, 06:01   #27914  |  Link
MrVideo
MrVideo's Avatar
Now you really have me confused. I'm trying to make MKV files from a DVD, as you've suggested, instead of using DVDFab.
I import into the Batch Queue from the DVD and select the three special features that I want made into MKVs. The result is as outlined in the post.
[22:08:17] Importing DVD: PRETTY_LITTLE_LIARS_SEASON1_D5
 - Processing DVD title [1 of 9 ]
   - Not kept, per user setting...
 - Processing DVD title [2 of 9 ]
 - Processing DVD title [3 of 9 ]
   - Collecting audio/video/subtitle streams...
   - Converting subtitles to BD format...
   - Multiplexing audio/video/subtitles...
 - Processing DVD title [4 of 9 ]
 - Processing DVD title [5 of 9 ]
 - Processing DVD title [6 of 9 ]
 - Processing DVD title [7 of 9 ]
 - Processing DVD title [8 of 9 ]
 - Processing DVD title [9 of 9 ]
 - Creating Quick-Play Menu...
   - Encoding menu background...
   - Building menu structure...
[22:09:43] DVD import completed successfully.
Old 23rd October 2018, 11:08   #27915  |  Link
Yeah, my mistake, I forgot you are importing DVDs. But... still the same answer. Don't use batch import, that was a bad assumption. Use "Import DVD(s)...". That will import the DVD into a BD structure and make it the current project. Importing to batch doesn't do that, and the settings in steps 2-6 wouldn't apply, since they only affect the current job. When the import is complete -- follow the remaining instructions:
7. Push the "Batch Backup" button.
You may want to clear the queue before you start now (to clear out the previous "Import to Batch" jobs.
You can save yourself some time by importing an entire season of DVDs at once. If you want to import multiple DVDs all at once, just put them all in a single folder, like this, for example:
Create a folder called "\MY_SERIES_SEASON1"
Then under that folder -- put folders containing each of the component DVDs, for example:
\MY_SERIES_SEASON1\MY_SERIES_SEASON1_D1
\MY_SERIES_SEASON1\MY_SERIES_SEASON1_D2
\MY_SERIES_SEASON1\MY_SERIES_SEASON1_D3
\MY_SERIES_SEASON1\MY_SERIES_SEASON1_D4
\MY_SERIES_SEASON1\MY_SERIES_SEASON1_D5
Then you could go to "Import DVD(s)" and select "\MY_SERIES_SEASON1" -- and it will import all the DVDs into a single BD structure. Then you can perform steps 2-7 and do the entire season at one time. Of course doing multiple discs at a time assumes you rip to your hard drive rather than reading directly from a DVD.
Old 23rd October 2018, 11:29   #27916  |  Link
I guess I'll need to pick up that disc to see if I can repeat the issue. Does this Amazon link appear to be the disc you are having the issue with?
Old 23rd October 2018, 13:17   #27917  |  Link
MrVideo
MrVideo's Avatar
Crap, I keep getting:
Run-time error '52':
Bad file name or number
I've even rebooted the computer. It isn't a problem reading the disc as it read previously. Plus, I'm currently copying the contents to the HDD.
UPDATE: You ready for this crap. The disc that I was using, a copy of the original, now has corruption errors reading two of the IFO files. I had to borrow an original disc because my personal copy was not readable. I made another copy and read from that to the HDD.
BDRB likes it.
But, after importing the DVD items that I wanted, the batch queue is empty. This is getting frustrating.
If I import to batch queue, the disc is listed in the batch queue, but as previously mentioned, the list is empty. So, I tried again, after clearing the batch queue, to just import the DVD, but nothing in the batch queue.
I took the original DVD over to the XP-64 box, same result,
Here is my INI:
[Options]
VERSION=0.60.0.4
ENCODER=0
MODE=3
TARGET_SIZE=23500
AUTO_BURN=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=0
SD_TO_1080=0
IGNORE_3D=1
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AUDIO_DRC=0
DECODER=2
AVCHD=1
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=0
SUPTITLE=0
PGSTOSRT=0
AUDIO_TRACK_LIMIT=10
SUBTITLE_TRACK_LIMIT=10
CUSTOM_TARGET_SIZE=23500
MENU_BACKGROUND=E:\BD-Rebuilder\PrettyLittleLiars\Season-1\PrettyLittleLiars_S1_D1_Bkg.jpg
MENU_AUDIO=E:\BD-Rebuilder\PrettyLittleLiars\Season-1\PrettyLittleLiars-opening_theme.ac3
IMPORT_THRESHOLD=0
QUICK_PLAY_THRESHOLD=0
MENU_AUTO_BACKGROUND=0
MENU_AUTO_DVDAUDIO=1
MENU_FORCE_QUICK=1
MENU_PLAY_SEQUENTIAL=0
MENU_START_WITH_MENU=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=1
IMPORT_VFR_SCAN=0
FORCE_NOENCODE=0
MENU_FONT=Century Gothic
MENU_FONT_BOLD=0
MENU_FONT_ITALIC=0
MENU_VERTICAL=500
MENU_HORIZONTAL=600
MENU_ACTIVE_COLOR=0xCFCFCF
MENU_CUSTOM_COLOR=
MENU_INACTIVE_COLOR=0x808080
MENU_BACKDROP_OPACITY=0
MENU_ROLLOVER=1
MENU_ITEMS_PAGE=6
MIN_PLAYLIST_MINS=1
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
IMPORT_VFR_FILM=0
IMPORT_VFR_DISABLE=0
IMPORT_NO_PULLDOWN=1
AVSFilter01=selectevery(2,0)
IMPORT_PREPARE_MKV=0
MOVIEONLY_TYPE=28
ALTCRF=23
ALT_TARGET=1024
ALT_CRF_TARGET=1024
ALTMETHOD=0
ALTAUTOCROP=0
[Paths]
WORKING_PATH=E:\BD-REBUILDER\WORK\
DGIndexNV=C:\Program Files (x86)\DGAVCDec
NV\DGIndexNV.exe
DGDecNV=C:\Program Files (x86)\DGAVCDecNV\DGDecodeNV.dll
[Batch]
MAIN_MPLS=.MPLS
MAIN_MPLS_ANGLE=0
FORCED_SUB=0
FORCED_AUD=0
AUDIO=
SUBS=
Old 23rd October 2018, 13:21   #27918  |  Link
MrVideo
MrVideo's Avatar
I have all of the Stargate DVDs. Remind me... what is the issue with them? Any particular season, or can I just test using S1-D1?
Old 23rd October 2018, 14:21   #27919  |  Link
BDRB likes it.
Please read and follow the instructions I gave exactly. When you import, it just imports. All you have then is a BD structure that contains everything you imported. Nothing is in the queue. The jobs aren't added to the queue until you complete steps 5 and 6.
Old 23rd October 2018, 16:29   #27920  |  Link
MrVideo
MrVideo's Avatar
The first time I imported the DVD, the single entry appeared in the batch queue. That is when I went looking for the minimum minutes thing, because only one of the three entries was there. I have to clue how that entry got there. That is what had me fooled.
Things are better now. One for you and one for me today.
BTW, when the importing was done, the stream list only showed one of the three items I imported. But all three are there being worked on.
