Old 3rd December 2018, 14:03   #28201  |  Link
Mark_Venture
Originally Posted by AmigaFuture View Post
I'm not "worried" about it, and I don't care for streaming. Because my newer HDTV plays MKV files from USB (with Subs, Chapters, etc), I do that often but I still prefer Menu driven BDs. I enjoy "themes" a lot. My LG BD590 Player also plays MKVs from USB and HD, but not with Chapters. I keep Records and CD Art because I loved them all of my life. I still prefer to see the Art when I pick through my Lossless collection (converted all CDs to Bin/Cue), but MKV, or at least I haven't tried it yet, doesn't show Images. Hmm...Now that I'm thinking about it, my HDTV might..instead of Thumbnails from a movie.
I'll check now..
that is where Kodi/SPMC/MrMC come in. They show me the art work, respect chapters and subtitles, etc.
I haven't tried ISO or Bin/Cue to see how they are handled.
Old 3rd December 2018, 14:04   #28202  |  Link
Mark_Venture
Cinavia survives any ripping process. BD standalone players are supposed to also detect Cinavia on ripped media files like MKV wrapped programs. But, as it turns out, not all manufacturers did. TVs are not subject to Cinavia detection, as the BD media is required to verify legality.
I get that. My LG Blu-ray players didn't/don't. Nor does the FireTV. It's why i use them for play back.
Old 7th December 2018, 01:59   #28203  |  Link
AmigaFuture
AmigaFuture's Avatar
Originally Posted by Ch3vr0n View Post
...and dvdcrap (my opinion) isn't the only thing that can remove it. So can AnyDVD+CloneBD, albeit at a cost to the audio.
Agreed from my tests from the help of a friend. DVDFab Does remove it... I haven't used the combo yet, but I know it does, in part because you typed so. But also read so.
Tested MKVs with my new burner and since it's writing correctly where my much older ASUS were failing, the older LG is still reading fine.
What was need? You guessed it. I'll get a new cheap BD/MKV player for BD discs...and pass the knowledge to my Family and much, much more. Maybe it'll inspire more firmware hackers?
Old 9th December 2018, 15:22   #28204  |  Link
Sharc
Framerate import problem for .mp4
I imported a couple of .mp4 files which were taken with a mobile phone. Source is 1920x1080p VFR as reported by MediaInfo. In fact the true video framerate appears to be CFR 29.97 or very close to it.
These files are imported in the pseudo folder as 1920x1080p23.976, and audio is out of sync. They are then encoded accordingly at 1920x1080p23.976 with audio out of sync.
Shouldn't these files be kept at the original framerate of 29.97 and encoded as 1920x1080i29.97, or even better as 1920x1080p29.97 with --fake-interlace?
I think the culprit is the pseudo VFR of the source.
Is there a setting/hidden option which I missed?
Edit:
I tried the various IMPORT_VFR_..... options in the .ini. It didn't help …
Old 9th December 2018, 20:31   #28205  |  Link
AmigaFuture
DVDFab 10.0.8.8+ does remove Cinavia. I was done before that version but..I'm not interested in getting the exact version. It looks and sounds like there isn't any degrading of audio is process.
@Sharc
Confirmed with my phone's video also.
Old 10th December 2018, 13:21   #28206  |  Link
musiclover
Does BD_RB have a setting to force the import of 25 fps sources to stay 25 fps and not get "upgraded" to 23.976 fps?
Old 10th December 2018, 13:26   #28207  |  Link
IMPORT_PAL_TO_FILM does that -- But the default is to keep 25fps as 25fps. You normally have to set this value in order to force the conversion. See HIDDENOPTS.TXT for details.
Old 10th December 2018, 16:19   #28208  |  Link
musiclover
I have IMPORT_PAL_TO_FILM=0 set in my ini. But BD_RB is still converting my 25fps source to 23.976fps.
Old 10th December 2018, 16:38   #28209  |  Link
Ch3vr0n
0 is the default. IMPORT_PAL_TO_FILM=n n = 0/1 - Default=0, if set to 1, imported 25fps video file sources are converted to 23.976, only if set to 1 should it convert. I'd post the log and if jdobbs wants them the .ifo & bup files in a zip file or something so he can analyze the structure
Old 10th December 2018, 18:24   #28210  |  Link
musiclover
The source is a 25fps .ts file. So no .ifo & .bup files are available
General
Complete name               : F:\Muse - 2018-09-21 Reeperbahn Festival, Hamburg.ts
Format                      : MPEG-TS
File size                   : 1.44 GiB
Duration                    : 1 h 4 min
Overall bit rate mode       : Variable
Overall bit rate            : 3 221 kb/s
Video
Menu ID                     : 1 (0x1)
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : Main@L3.1
Format settings             : CABAC / 2 Ref Frames
Format settings, CABAC      : Yes
Format settings, ReFrames   : 2 frames
Format settings, GOP        : M=1, N=50
Codec ID                    : 27
Bit rate mode               : Constant
Nominal bit rate            : 2 800 kb/s
Width                       : 1 280 pixels
Height                      : 720 pixels
Display aspect ratio        : 16:9
Frame rate                  : 25.000 FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.122
Audio
Menu ID                     : 1 (0x1)
Format                      : AAC LC
Format/Info                 : Advanced Audio Codec Low Complexity
Format version              : Version 4
Muxing mode                 : ADTS
Codec ID                    : 15-2
Bit rate mode               : Variable
Channel(s)                  : 2 channels
Channel layout              : L R
Sampling rate               : 48.0 kHz
Frame rate                  : 46.875 FPS (1024 SPF)
Compression mode            : Lossy
Delay relative to video     : -1 s 159 ms
Menu
Menu ID                     : 1 (0x1)
List                        : 256 (0x100) (AVC) / 257 (0x101) (AAC)
Service name                : Service01
Service provider            : FFmpeg
Service type                : digital television
[16:21:43] Importing TS: MUSE_-_2018-09-21_REEPERBAHN_FESTIVAL,_HAMBURG
  - Preparing TS for processing...
  - Collecting audio/video streams from source...
  - Building pseudo-BD source structure...
[16:23:50] Video import completed successfully.
[AudioAdjust]
00000=.TimeStretch(tempo = 23.976/25.0*100.0)
[ImportFile]
00000=F:\Muse - 2018-09-21 Reeperbahn Festival, Hamburg.ts
[Options]
VERSION=0.60.0.4
ENABLE_TEST=1
ENABLE_BLANKING=1
BLANK_THRESHOLD=0
ALTERNATE_BLURAY=0
; AUDIO_AMPLIFY=NORMALIZE
; KEEP_HD_LPCM=0
; AUTO_TWOPASSONLY=1
MIN_M2TS_SIZE=0
ENCODER=0
MODE=3
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
AUDIO_TO_KEEP=dut;eng;nld;und;
SUBS_TO_KEEP=dut;eng;nld;und;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=0
SD_TO_1080=0
IGNORE_3D=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
AUDIO_DRC=0
DECODER=0
AVCHD=0
REMOVE_WORKFILES=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
IVTC_PULLDOWN=0
FRIMSOURCE=0
COMPLETION_BEEP=0
OUTPUT_SBS=0
NEROAAC=1
SUPTITLE=1
PGSTOSRT=1
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=22000
MOVIEONLY_TYPE=1
ALTCRF=20
ALT_TARGET=850
ALT_CRF_TARGET=5000
ALTMETHOD=2
ALTAUTOCROP=1
TARGET_SIZE=22000
ASSUME_DVD_PAL=1
MENU_BACKGROUND=C:\BD Rebuilder\BD_Rebuilder\misc\menuback.jpg
MENU_AUDIO=C:\BD Rebuilder\BD_Rebuilder\tools\blankclip\blank.ac3
IMPORT_THRESHOLD=0
QUICK_PLAY_THRESHOLD=0
MENU_AUTO_BACKGROUND=1
MENU_AUTO_DVDAUDIO=1
MENU_PLAY_SEQUENTIAL=1
MENU_START_WITH_MENU=1
IMPORT_LIMIT_LANG=0
IMPORT_KEEP_PLAYALL=1
QUICK_PLAY_THRESHOLD=1
QUICK_EXTRAS=1
WIDE_PERCENT=100
WIDE_OFFSET=1
IMPORT_PREPARE_MKV=1
KEEP_HD_AUDIO=0
MENU_MAXITEMS=15
[Paths]
WORKING_PATH=F:\WORK\
NeroAACPath=C:\BD Rebuilder\NeroAACCodec-1.5.1\win32\neroAacEnc.exe
SupTitlePath=C:\BD Rebuilder\suptitle_v2.0.8_x86\SupTitle.dll
SOURCE_PATH=F:\WORK\IMPORTS\MUSE_-_2018-09-21_REEPERBAHN_FESTIVAL,_HAMBURG\
I can send you a clip of the offending file if it helps you
Old 11th December 2018, 03:55   #28211  |  Link
MrVideo
MrVideo's Avatar
PLEASE... when pasting text, CODE wrap it.
Old 11th December 2018, 03:58   #28212  |  Link
MrVideo
MrVideo's Avatar
Well, here's a new error I just ran into:
CreateMenu() 00076 4000
This was during Building Menu Structure. It was the 2nd menu of 2. All four files are there, but at the moment I do not know if the 2nd menu is valid.
JD, do you want a copy of the disc ISO of the DVD that BDRB was having trouble seeing all of the titles?
UPDATE: Nope, the resulting disc just started playing an episode and if I press "menu" on the remote, it skipped to another episode.
Old 11th December 2018, 08:45   #28213  |  Link
Sharc
I set it in the INI file manually. Plus, as I wrote, there are other titles on the disc that have a shorter time than the one BDRB missed.
I think you need to reread my postings. It is only BDRB that misses the title. DVDFab and VideoReDo have no problem seeing all of the titles.
Maybe a related problem:
I imported 18 short clips (.mp4), setting all import size thresholds to zero.
All 18 clips got imported and processed and were included in the Quick Menu, but surprisingly only 4 out of the 18 were shown in Stream Tab of BD-RB.
Old 11th December 2018, 10:25   #28214  |  Link
musiclover
Sorry, I didn't know how before. But I got there in the end.
Old 11th December 2018, 12:53   #28215  |  Link
MrVideo
MrVideo's Avatar
Instead of the word "PHP" use "code".
Old 11th December 2018, 13:20   #28216  |  Link
MrVideo
MrVideo's Avatar
Now that you mention it, the stream list only showed 1 of the 12 MKV files that it processed. They are all there though. I really haven't paid much attention to the stream list. Maybe I should, just to see if it is a pattern.
Old 11th December 2018, 15:05   #28217  |  Link
Maybe less than MIN_M2TS_SIZE or MIN_PLAYLIST_MINS?
Old 11th December 2018, 15:30   #28218  |  Link
MrVideo
MrVideo's Avatar
In my case, 11 of the items are 40+ minutes.
Old 11th December 2018, 16:22   #28219  |  Link
Sharc
Yep! In my case setting both to Zero solved it. Thanks.
Surprisingly though all items were imported, processed and burnt to the disc including the playlists; it was only on the Stream Tab where some were missing.
Btw. could you already duplicate the .mp4 framerate issue?
Old 11th December 2018, 16:29   #28220  |  Link
MrVideo
MrVideo's Avatar
Interesting. The M2TS is the default of 100MB and the other is set to 1 min. All 12 files in this case are above those values.
Another test disc I created has two 4GB+ files and again, only one.
I'll have to try setting both to zero to see what happens.
UPDATE: No difference. Only 1 of the 5 showed up.
