14th January 2020, 17:53 | #29161 | Link | |
15th January 2020, 13:11 | #29163 | Link |
From the first post of this thread:
Don't push bug resolution or keep asking for a fix. I will get to the reported bugs, but only when I can find the time. It appears that AUTOCROP is having issues finding the borders on your source. Since AUTOCROP is an external filter (developed by someone else) there's not a lot I can do about it. I'd suggest you just just set autocropping off in the ALTERNATE output dialog. Alternatively you could read info about autocrop at this link and possibly add it as a filter (using the SETUP dialog). That way you could experiment with some of its settings (like maybe the "threshold" or "sample" parameters) when you find sources that resize oddly. Remember, though, to disable the filter when you are trying to output to something other than ALTERNATE Last edited by jdobbs; 15th January 2020 at 13:54. |
15th January 2020, 15:32 | #29164 | Link |
BD Rebuilder v0.61.04
I have updated the first post of this thread with a link to the most recent version of BD-RB (v0.61.04). Changes for this release:
- Corrected an error in which IMPORT_PAL_TO_FILM was not working for UHD sources. - Fixed "Error 52" and failure when attempting to import a source that needed to be scanned for variable frame rate. Introduced in the v0.61.xx series. - Fixed an error in which the wrong PID was being assigned to Dolby Vision substreams on full backups, causing it to not playback correctly on machines supporting it when enabled. - Other minor corrections and cosmetic fixes. Last edited by jdobbs; 15th January 2020 at 18:17. |
15th January 2020, 22:20 | #29165 | Link | |
1. You go to the SETUP dialog (from the Settings menu). 2. Then click on "Use AVS Filters during encoding". 3. Within the editor dialog, just at the text: Crop(0,140,1920,800) 4. Save it. it happens on old movies, if recent movies I don't have the problem thank |
16th January 2020, 10:35 | #29170 | Link | |
Before you finish this improvement is there any option on bdrebuilder.ini file that stops processing after all m2ts demux so i can replace subtitles manually and then continue with the remux ? Also another question. Why is Dolby Vision HEVC file extracted on a 2nd run ? Why canīt it be extracted together with the other video/audio files ? TsMuxer limitation ? Last edited by FilipeAmadeuO; 16th January 2020 at 12:31. |
16th January 2020, 13:30 | #29172 | Link | |
Normally the Dolby HEVC file isn't extracted individually. The only time BD-RB extracts streams individually is if it encounters an error when trying to extract all tracks at once. |
16th January 2020, 13:44 | #29173 | Link | |
Any chance to demux all m2ts at once -> stop -> i replace subtitles manually -> remux all m2ts ? Or even better implement subtitle/dudio replacement directly on GUI Any way to check extraction errors ? On the log there is no error reported Last edited by FilipeAmadeuO; 16th January 2020 at 15:31. |
16th January 2020, 18:33 | #29174 | Link | |
My Sony X800M2 have no problem with HDR10 on UHD-discs made by BD-RB. The Sony can't play HDR10+. Which player can play HDR10+ discs? |
16th January 2020, 18:44 | #29176 | Link |
Life's clearer in 4K UHD
A good place to start would be to find which player manufacturer is a member of the HDR10+ alliance.
Suffice to say... You'll also need a TV that supports HDR10+ too! Cheers
16th January 2020, 18:47 | #29177 | Link | |
16th January 2020, 19:12 | #29179 | Link |
Elit Amans
Now the variable scan works, but another problem occurs with my testfile. After encode and finished job the runtime of the episode is approx half of what it should be. The other episodes doesn't experience this and one thing I can see is that the problem episode is 50fps and the others (working ones) is 25fps.
When I watch the encoded episode in mpc-be it reports correct length but video stops halfway in and audio continues. When I watch the build bluray in PowerDVD 18 it reports half length and stops altogether at the point. The pseudo build plays at 2x speed and have half length in PowerDVD 18 while the pseudo file plays at 2x speed and full lenght in mpc-be. Can one think that the problem comes when BD-RB builds the pseudo disc? Attached files is the two different clpi and mpls that differ from pseudo and final build and also the DGI file, if that helps in any way. Interesting to see that DGIndexNV 2053.0.0.119 X32 sees this: FPS 80000 / 1600 //LD System check: Code:
[01-16-20] Checking System Settings - BD-Rebuilder v0.61.04 - Windows Version: 6.2 [9200] - Working Path Free Space: 68,05GB - AVISYNTH Version: 2.6.0.5, Ok - LAVFILTERS: Ok - X264: Ok - X265: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [01-16-20] Systems Settings Check complete Code:
---------------------- [13:54:12] Importing MKV: PURE_(2019)_S01E01_-_EPISODE_1 - Preparing MKV for processing... - Scanning for Variable Frame Rate... - Collecting audio/video streams from source... - Building pseudo-BD source structure... [13:58:13] Video import completed successfully. ---------------------- [01-16-20] BD Rebuilder v0.61.04 [14:06:14] Source: PURE_(2019)_S01E01_-_EPISODE_1 - Input BD size: 2,18 GB - Approximate total content: [00:16:38.440] - Target BD size: 8,25 GB - Windows Version: 6.2 [9200] - Quality: Highest (Very Slow), Two Pass - Decoding/Frame serving: DGDecNV - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [14:06:14] PHASE ONE, Encoding - [14:06:14] Processing: VID_00000 (1 of 1) - [14:06:14] Extracting A/V streams [VID_00000] - [14:06:58] Reencoding video [VID_00000] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 50,000fps, 49 922 frames - Bitrate: 15 000 Kbs - [14:06:58] Reencoding: VID_00000, Pass 1 of 2 - [14:14:23] Reencoding: VID_00000, Pass 2 of 2 - [14:44:13] Video Encode complete - [14:44:13] Processing audio tracks - Track 4352 (eng): Keeping original audio - [14:44:13] Multiplexing M2TS [14:44:41]PHASE ONE complete [14:44:41]PHASE TWO - Rebuild Started - [14:44:41] Rebuilding BD file Structure [14:44:41] - Encode and Rebuild complete [14:44:42] JOB: PURE_(2019)_S01E01_-_EPISODE_1 finished. Code:
[Status] LABEL=PURE_(2019)_S01E01_-_EPISODE_1 VERSION=v0.61.04 SOURCE_SIZE=2338942220 SOURCE_VIDEO_SIZE=2338922496 TARGET_SIZE=8860467200 REDUCTION=3.78826040245157 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=deu;eng;ger;swe; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=all BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=-1 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=0 HEVC_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=1 REBUILD_COMPLETE=1 [00000] AUDIO=1 PGS=1 APULLDOWN=0 S1440=0 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=8860447476 RATE=15000 SPLITS=1 NSTART=27000000 NEND=71929800 NSIZE=2061348864 FLINK=0 MLINK=0 Code:
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500 --start-time=27000000 V_MPEG4/ISO/AVC, "W:\WORK\WORKFILES\VID_00000.AVS.264", fps=50, insertSEI, contSPS A_AC3, "W:\WORK\WORKFILES\00000.track_4352.AC3", lang=eng S_HDMV/PGS, "W:\WORK\WORKFILES\00000.track_4608.sup",lang=eng |
