Old 2nd November 2010, 18:42   #10001  |  Link
setarip_old
setarip_old's Avatar
@ftb32
It would be more helpful if you posted the entire log...
Old 2nd November 2010, 19:00   #10002  |  Link
ftb32
[11:21:51] BD Rebuilder v0.35.01 (beta)
- Source: SU21NNE1
- Input BD size: 36,56 GB
- Approximate total content: [03:05:58.538]
- Target BD size: 22,66 GB
- Windows Version: 6.1 [7600]
[11:21:52] PHASE ONE, Encoding
- [11:21:52] Extracting A/V streams [VID_00009]
- [11:34:37] Reencoding: VID_00009 (1 of 40)
- [11:34:37] Collecting video information
- Rate/Length: 23,976fps, 140.737 frames
- Bitrate: 12.089 Kbs
- [11:34:37] Reencoding: VID_00009, Pass 1 of 1
- [12:40:57] Video Encode complete
- [12:40:58] Reencoding audio tracks (if req'd)
- [12:40:58] Multiplexing M2TS
- [12:49:29] Extracting A/V streams [VID_00016]
- Error in attempt to extract audio/subs.
- Not enought buffer for parse video stream. Current frame num 1665
[12:49:32] - Failed to retrieve audio, aborted
ftb32 is offline   Reply With Quote
Old 2nd November 2010, 20:05   #10003  |  Link
john920
- Source: SU21NNE1
I had this issue with the new grindhouse, I had to remove hd audio and copy only one audio stream, then it worked. I'm not happy with this, but it did work
john920 is offline   Reply With Quote
Old 2nd November 2010, 23:47   #10004  |  Link
ftb32
Good friends and was an extra of 1,700 Kb remove that title, and send it to recode works well without problems.
Thanks..
Old 3rd November 2010, 01:24   #10005  |  Link
spinn
for those getting errors, have you tried to process in Safe Mode? I've found that my problems didn't show up if processed in Safe Mode. This is probably due to stray files left behind from uninstalls and reinstallations. I ran a registry cleaner from tweaknow, to remove any stray files and it seemed to have done the trick...so far.
spinn is offline   Reply With Quote
Old 3rd November 2010, 02:05   #10006  |  Link
8ternity
8ternity's Avatar
Hello jdobbs;
I would like to know if there is an solution relative the CINAVIA watermark about removing that?
- i've found over the net to rebuild the BD with an AACS protection back to the master to bypass the protection, but i can't found any thread about which software can add back an ACCS encryption.
Old 3rd November 2010, 02:46   #10007  |  Link
Originally Posted by 8ternity View Post
Hello jdobbs;
I'm sorry, but I just don't see what that has to do with this thread or BD Rebuilder? BD Rebuilder does not deal with encryption/decryption or protections in any way, shape, or form.
Please try to keep focused on the correct subject matter (Rule 3). There is an entire Doom9 subforum dedicated to decryption. Within that forum there is an entire thread dedicated to Cinavia.
Old 3rd November 2010, 02:55   #10008  |  Link
8ternity
8ternity's Avatar
No Problem! I just remember the topic title "BD Rebuilder Beta - Bug Reports Only "
Sorry
Old 3rd November 2010, 02:56   #10009  |  Link
Sorry
It's cool. I can't even count the number of times this thead has gone off topic...
Old 3rd November 2010, 15:41   #10010  |  Link
Originally Posted by SoniG View Post
Jdobbs : I've just rebuilt the PIXAR Shorts Vol.1 and I have another .mpls issue. This BD have original IN time at 10:00:000 instead of habitual 00:00:11.650, the rebuilded mpls have the OUT TIME set with 00:00:11.650 more than the original. It makes playing shorts 11s longer than its original and the original m2ts real duration and could cause issues on some players.
Not sure how that could happen. I have that disc. I'm looking at it now.
Old 3rd November 2010, 17:07   #10011  |  Link
Acerjen
Backing Up Cars
I am trying to backup Cars. It has failed three times in the same place. I have re-ripped it
and it still is having problems. I am using the latest beta. Here are my logs and other info.
If any other info is needed, please ask.
Inspect.exe
- Windows Version: 5.1 [2600]
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
- FFDSHOW AVC set to "ffmpeg-mt": Ok
- BD Rebuilder v0.35.0.1, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
BDRebuilder.ini
[Options]
MODE=0
ENCODE_QUALITY=0
ONEPASS_ENCODING=2
AUTO_QUALITY=1
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=0
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23450
TARGET_SIZE=23200
QUICK_EXTRAS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
[Paths]
SOURCE_PATH=O:\00 - BLU-RAY RIPS\CARS\
WORKING_PATH=O:\00 - BD REBUILDER\
Cars.ini
[Status]
LABEL=CARS
VERSION=v0.35.01 (beta)
SOURCE_SIZE=41371584140
SOURCE_VIDEO_SIZE=37594177536
TARGET_SIZE=24326963200
REDUCTION=.546615405439362
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
QUICK=0
ENCODE_STEP=4
COMPLETED=29
[00015]
AUDIO=1
PGS=
M2TS_TARGET=46933711
RATE=9393
NSTART=27000000
NEND=28588320
NSIZE=46516224
FLINK=0
MLINK=0
[00016]
AUDIO=1
PGS=
M2TS_TARGET=14370615
RATE=10234
NSTART=27000000
NEND=27447840
NSIZE=14739456
FLINK=0
MLINK=0
[00023]
AUDIO=1
PGS=
M2TS_TARGET=37157393
RATE=8715
NSTART=27000000
NEND=28350720
NSIZE=38952960
FLINK=0
MLINK=0
[00024]
AUDIO=1
PGS=
M2TS_TARGET=38033937
RATE=8932
NSTART=27000000
NEND=28350720
NSIZE=39100416
FLINK=0
MLINK=0
[00025]
AUDIO=1
PGS=
M2TS_TARGET=37258146
RATE=8740
NSTART=27000000
NEND=28350720
NSIZE=39014400
FLINK=0
MLINK=0
[00026]
AUDIO=1
PGS=
M2TS_TARGET=37654437
RATE=8838
NSTART=27000000
NEND=28350720
NSIZE=39272448
FLINK=0
MLINK=0
[00027]
AUDIO=1
PGS=
M2TS_TARGET=37338747
RATE=8760
NSTART=27000000
NEND=28350720
NSIZE=38928384
FLINK=0
MLINK=0
[00028]
AUDIO=1
PGS=
M2TS_TARGET=37362256
RATE=8765
NSTART=27000000
NEND=28350720
NSIZE=39032832
FLINK=0
MLINK=0
[00029]
AUDIO=1
PGS=
M2TS_TARGET=37130526
RATE=8708
NSTART=27000000
NEND=28350720
NSIZE=38713344
FLINK=0
MLINK=0
[00030]
AUDIO=1
PGS=
M2TS_TARGET=37624212
RATE=8830
NSTART=27000000
NEND=28350720
NSIZE=39284736
FLINK=0
MLINK=0
[00036]
AUDIO=1
PGS=1
M2TS_TARGET=576638147
RATE=9475
NSTART=27000000
NEND=46324800
NSIZE=555780096
FLINK=0
MLINK=0
[00037]
AUDIO=1
PGS=1
M2TS_TARGET=362025989
RATE=9351
NSTART=27000000
NEND=39306240
NSIZE=353544192
FLINK=0
MLINK=0
[00038]
AUDIO=1
PGS=1
M2TS_TARGET=328488956
RATE=8856
NSTART=27000000
NEND=38725920
NSIZE=315475968
FLINK=0
MLINK=0
[00039]
AUDIO=1
PGS=1
M2TS_TARGET=427847370
RATE=3080
NSTART=27000000
NEND=70332480
NSIZE=425705472
FLINK=0
MLINK=0
[00040]
AUDIO=1
PGS=1
M2TS_TARGET=143843847
RATE=3056
NSTART=27000000
NEND=41669280
NSIZE=143136768
FLINK=0
MLINK=0
[00041]
AUDIO=1
PGS=1
M2TS_TARGET=146490270
RATE=3071
NSTART=27000000
NEND=41863680
NSIZE=144728064
FLINK=0
MLINK=0
[00042]
AUDIO=1
PGS=1
M2TS_TARGET=137415859
RATE=2998
NSTART=27000000
NEND=41263200
NSIZE=137723904
FLINK=0
MLINK=0
[00043]
AUDIO=1
PGS=1
M2TS_TARGET=159675368
RATE=3015
NSTART=27000000
NEND=43485120
NSIZE=161402880
FLINK=0
MLINK=0
[00044]
AUDIO=1
PGS=1
M2TS_TARGET=73209872
RATE=3085
NSTART=27000000
NEND=34401600
NSIZE=72173568
FLINK=0
MLINK=0
[00045]
AUDIO=1
PGS=1
M2TS_TARGET=93148722
RATE=3008
NSTART=27000000
NEND=36639360
NSIZE=92891136
FLINK=0
MLINK=0
[00046]
AUDIO=1
PGS=1
M2TS_TARGET=193897516
RATE=3096
NSTART=27000000
NEND=46523520
NSIZE=193271808
FLINK=0
MLINK=0
[00047]
AUDIO=1
PGS=1
M2TS_TARGET=94643213
RATE=2814
NSTART=27000000
NEND=37404000
NSIZE=99182592
FLINK=0
MLINK=0
[00048]
AUDIO=1
PGS=1
M2TS_TARGET=42591293
RATE=2823
NSTART=27000000
NEND=31684320
NSIZE=43431936
FLINK=0
MLINK=0
[00049]
AUDIO=1
PGS=1
M2TS_TARGET=79355753
RATE=2794
NSTART=27000000
NEND=35782560
NSIZE=81156096
FLINK=0
MLINK=0
[00050]
AUDIO=1
PGS=1
M2TS_TARGET=42037156
RATE=2801
NSTART=27000000
NEND=31638240
NSIZE=42694656
FLINK=0
MLINK=0
[00051]
AUDIO=1
PGS=1
M2TS_TARGET=84003786
RATE=2788
NSTART=27000000
NEND=36324000
NSIZE=85954560
FLINK=0
MLINK=0
[00053]
AUDIO=1
PGS=
M2TS_TARGET=333452679
RATE=15993
NSTART=27000000
NEND=33770880
NSIZE=324765696
FLINK=0
MLINK=0
[00054]
AUDIO=1
PGS=
M2TS_TARGET=131814040
RATE=9701
NSTART=27000000
NEND=31328640
NSIZE=132476928
FLINK=0
MLINK=0
[00055]
AUDIO=1
PGS=
M2TS_TARGET=207925574
RATE=9919
NSTART=27000000
NEND=33685920
NSIZE=199680000
FLINK=0
MLINK=0
[00060]
AUDIO=1111
PGS=111
M2TS_TARGET=15969521632
RATE=7789
continued next post
Acerjen is offline   Reply With Quote
Old 3rd November 2010, 17:08   #10012  |  Link
Acerjen
BDReuilder.txt (Log)
[22:23:07] BD Rebuilder v0.35.01 (beta)
  - Source:  CARS
  - Input BD size: 38.53 GB
  - Approximate total content: [03:35:49.536]
  - Target BD size: 22.66 GB
[22:23:07] PHASE ONE, Encoding
 - [22:23:07] Extracting A/V streams [VID_00015]
 - [22:23:14] Reencoding: VID_00015 (1 of 34)
 - [22:23:14] Collecting video information
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 23.976fps, 847 frames
   - Bitrate: 9,393 Kbs
 - [22:23:14] Reencoding: VID_00015, Pass 1 of 1
 - [22:23:26] Video Encode complete
 - [22:23:26] Reencoding audio tracks (if req'd)
 - [22:23:26] Multiplexing M2TS
 - [22:23:28] Extracting A/V streams [VID_00016]
 - [22:23:31] Reencoding: VID_00016 (2 of 34)
 - [22:23:31] Collecting video information
   - Rate/Length: 23.976fps, 239 frames
   - Bitrate: 10,234 Kbs
 - [22:23:31] Reencoding: VID_00016, Pass 1 of 1
 - [22:23:34] Video Encode complete
 - [22:23:34] Reencoding audio tracks (if req'd)
 - [22:23:34] Multiplexing M2TS
 - [22:23:35] Extracting A/V streams [VID_00023]
 - [22:23:41] Reencoding: VID_00023 (3 of 34)
 - [22:23:41] Collecting video information
   - Rate/Length: 23.976fps, 720 frames
   - Bitrate: 8,715 Kbs
 - [22:23:41] Reencoding: VID_00023, Pass 1 of 1
 - [22:23:49] Video Encode complete
 - [22:23:49] Reencoding audio tracks (if req'd)
 - [22:23:49] Multiplexing M2TS
 - [22:23:52] Extracting A/V streams [VID_00024]
 - [22:23:58] Reencoding: VID_00024 (4 of 34)
 - [22:23:58] Collecting video information
   - Bitrate: 8,932 Kbs
 - [22:23:58] Reencoding: VID_00024, Pass 1 of 1
 - [22:24:12] Video Encode complete
 - [22:24:12] Reencoding audio tracks (if req'd)
 - [22:24:12] Multiplexing M2TS
 - [22:24:14] Extracting A/V streams [VID_00025]
 - [22:24:21] Reencoding: VID_00025 (5 of 34)
 - [22:24:21] Collecting video information
   - Bitrate: 8,740 Kbs
 - [22:24:21] Reencoding: VID_00025, Pass 1 of 1
 - [22:24:29] Video Encode complete
 - [22:24:29] Reencoding audio tracks (if req'd)
 - [22:24:29] Multiplexing M2TS
 - [22:24:31] Extracting A/V streams [VID_00026]
 - [22:24:38] Reencoding: VID_00026 (6 of 34)
 - [22:24:38] Collecting video information
   - Bitrate: 8,838 Kbs
 - [22:24:38] Reencoding: VID_00026, Pass 1 of 1
 - [22:24:46] Video Encode complete
 - [22:24:46] Reencoding audio tracks (if req'd)
 - [22:24:46] Multiplexing M2TS
 - [22:24:49] Extracting A/V streams [VID_00027]
 - [22:24:55] Reencoding: VID_00027 (7 of 34)
 - [22:24:55] Collecting video information
   - Bitrate: 8,760 Kbs
 - [22:24:55] Reencoding: VID_00027, Pass 1 of 1
 - [22:25:03] Video Encode complete
 - [22:25:03] Reencoding audio tracks (if req'd)
 - [22:25:03] Multiplexing M2TS
 - [22:25:06] Extracting A/V streams [VID_00028]
 - [22:25:12] Reencoding: VID_00028 (8 of 34)
 - [22:25:12] Collecting video information
   - Bitrate: 8,765 Kbs
 - [22:25:12] Reencoding: VID_00028, Pass 1 of 1
 - [22:25:21] Video Encode complete
 - [22:25:21] Reencoding audio tracks (if req'd)
 - [22:25:21] Multiplexing M2TS
 - [22:25:23] Extracting A/V streams [VID_00029]
 - [22:25:29] Reencoding: VID_00029 (9 of 34)
 - [22:25:29] Collecting video information
   - Bitrate: 8,708 Kbs
 - [22:25:29] Reencoding: VID_00029, Pass 1 of 1
 - [22:25:38] Video Encode complete
 - [22:25:38] Reencoding audio tracks (if req'd)
 - [22:25:38] Multiplexing M2TS
 - [22:25:40] Extracting A/V streams [VID_00030]
 - [22:25:46] Reencoding: VID_00030 (10 of 34)
 - [22:25:46] Collecting video information
   - Bitrate: 8,830 Kbs
 - [22:25:46] Reencoding: VID_00030, Pass 1 of 1
 - [22:25:54] Video Encode complete
 - [22:25:54] Reencoding audio tracks (if req'd)
 - [22:25:54] Multiplexing M2TS
 - [22:25:57] Extracting A/V streams [VID_00036]
 - [22:27:21] Reencoding: VID_00036 (11 of 34)
 - [22:27:21] Collecting video information
   - Rate/Length: 23.976fps, 10,297 frames
   - Bitrate: 9,475 Kbs
 - [22:27:21] Reencoding: VID_00036, Pass 1 of 1
 - [22:30:59] Video Encode complete
 - [22:30:59] Reencoding audio tracks (if req'd)
 - [22:30:59] Multiplexing M2TS
 - [22:31:22] Extracting A/V streams [VID_00037]
 - [22:32:15] Reencoding: VID_00037 (12 of 34)
 - [22:32:15] Collecting video information
   - Rate/Length: 23.976fps, 6,557 frames
   - Bitrate: 9,351 Kbs
 - [22:32:15] Reencoding: VID_00037, Pass 1 of 1
 - [22:34:30] Video Encode complete
 - [22:34:30] Reencoding audio tracks (if req'd)
 - [22:34:30] Multiplexing M2TS
 - [22:34:44] Extracting A/V streams [VID_00038]
 - [22:35:32] Reencoding: VID_00038 (13 of 34)
 - [22:35:32] Collecting video information
   - Rate/Length: 23.976fps, 6,248 frames
   - Bitrate: 8,856 Kbs
 - [22:35:32] Reencoding: VID_00038, Pass 1 of 1
 - [22:37:50] Video Encode complete
 - [22:37:50] Reencoding audio tracks (if req'd)
 - [22:37:50] Multiplexing M2TS
 - [22:38:03] Extracting A/V streams [VID_00039]
 - [22:39:09] Reencoding: VID_00039 (14 of 34)
 - [22:39:09] Collecting video information
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 28,860 frames
   - Bitrate: 3,080 Kbs
 - [22:39:09] Reencoding: VID_00039, Pass 1 of 1
 - [22:41:04] Video Encode complete
 - [22:41:04] Reencoding audio tracks (if req'd)
 - [22:41:04] Multiplexing M2TS
 - [22:41:22] Extracting A/V streams [VID_00040]
 - [22:41:43] Reencoding: VID_00040 (15 of 34)
 - [22:41:43] Collecting video information
   - Rate/Length: 29.970fps, 9,770 frames
   - Bitrate: 3,056 Kbs
 - [22:41:43] Reencoding: VID_00040, Pass 1 of 1
 - [22:42:20] Video Encode complete
 - [22:42:20] Reencoding audio tracks (if req'd)
 - [22:42:20] Multiplexing M2TS
 - [22:42:26] Extracting A/V streams [VID_00041]
 - [22:42:48] Reencoding: VID_00041 (16 of 34)
 - [22:42:48] Collecting video information
   - Rate/Length: 29.970fps, 9,900 frames
   - Bitrate: 3,071 Kbs
 - [22:42:48] Reencoding: VID_00041, Pass 1 of 1
 - [22:43:27] Video Encode complete
 - [22:43:27] Reencoding audio tracks (if req'd)
 - [22:43:27] Multiplexing M2TS
 - [22:43:34] Extracting A/V streams [VID_00042]
 - [22:43:54] Reencoding: VID_00042 (17 of 34)
 - [22:43:54] Collecting video information
   - Rate/Length: 29.970fps, 9,500 frames
   - Bitrate: 2,998 Kbs
 - [22:43:54] Reencoding: VID_00042, Pass 1 of 1
 - [22:44:29] Video Encode complete
 - [22:44:29] Reencoding audio tracks (if req'd)
 - [22:44:29] Multiplexing M2TS
 - [22:44:35] Extracting A/V streams [VID_00043]
 - [22:44:59] Reencoding: VID_00043 (18 of 34)
 - [22:44:59] Collecting video information
   - Rate/Length: 29.970fps, 10,980 frames
   - Bitrate: 3,015 Kbs
 - [22:44:59] Reencoding: VID_00043, Pass 1 of 1
 - [22:45:39] Video Encode complete
 - [22:45:39] Reencoding audio tracks (if req'd)
 - [22:45:39] Multiplexing M2TS
 - [22:45:46] Extracting A/V streams [VID_00044]
 - [22:45:57] Reencoding: VID_00044 (19 of 34)
 - [22:45:57] Collecting video information
   - Rate/Length: 29.970fps, 4,930 frames
   - Bitrate: 3,085 Kbs
 - [22:45:57] Reencoding: VID_00044, Pass 1 of 1
 - [22:46:18] Video Encode complete
 - [22:46:18] Reencoding audio tracks (if req'd)
 - [22:46:18] Multiplexing M2TS
 - [22:46:21] Extracting A/V streams [VID_00045]
 - [22:46:35] Reencoding: VID_00045 (20 of 34)
 - [22:46:35] Collecting video information
   - Rate/Length: 29.970fps, 6,420 frames
   - Bitrate: 3,008 Kbs
 - [22:46:35] Reencoding: VID_00045, Pass 1 of 1
 - [22:46:58] Video Encode complete
 - [22:46:58] Reencoding audio tracks (if req'd)
 - [22:46:58] Multiplexing M2TS
 - [22:47:03] Extracting A/V streams [VID_00046]
 - [22:47:33] Reencoding: VID_00046 (21 of 34)
 - [22:47:33] Collecting video information
   - Rate/Length: 29.970fps, 13,003 frames
   - Bitrate: 3,096 Kbs
 - [22:47:33] Reencoding: VID_00046, Pass 1 of 1
 - [22:48:26] Video Encode complete
 - [22:48:26] Reencoding audio tracks (if req'd)
 - [22:48:26] Multiplexing M2TS
 - [22:48:34] Extracting A/V streams [VID_00047]
 - [22:48:48] Reencoding: VID_00047 (22 of 34)
 - [22:48:48] Collecting video information
   - Rate/Length: 29.970fps, 6,930 frames
   - Bitrate: 2,814 Kbs
 - [22:48:48] Reencoding: VID_00047, Pass 1 of 1
 - [22:49:08] Video Encode complete
 - [22:49:08] Reencoding audio tracks (if req'd)
 - [22:49:08] Multiplexing M2TS
 - [22:49:13] Extracting A/V streams [VID_00048]
 - [22:49:20] Reencoding: VID_00048 (23 of 34)
 - [22:49:20] Collecting video information
   - Rate/Length: 29.970fps, 3,120 frames
   - Bitrate: 2,823 Kbs
 - [22:49:20] Reencoding: VID_00048, Pass 1 of 1
 - [22:49:29] Video Encode complete
 - [22:49:29] Reencoding audio tracks (if req'd)
 - [22:49:29] Multiplexing M2TS
 - [22:49:31] Extracting A/V streams [VID_00049]
 - [22:49:43] Reencoding: VID_00049 (24 of 34)
 - [22:49:43] Collecting video information
   - Rate/Length: 29.970fps, 5,850 frames
   - Bitrate: 2,794 Kbs
 - [22:49:43] Reencoding: VID_00049, Pass 1 of 1
 - [22:49:59] Video Encode complete
 - [22:49:59] Reencoding audio tracks (if req'd)
 - [22:49:59] Multiplexing M2TS
 - [22:50:03] Extracting A/V streams [VID_00050]
 - [22:50:10] Reencoding: VID_00050 (25 of 34)
 - [22:50:10] Collecting video information
   - Rate/Length: 29.970fps, 3,090 frames
   - Bitrate: 2,801 Kbs
 - [22:50:10] Reencoding: VID_00050, Pass 1 of 1
 - [22:50:19] Video Encode complete
 - [22:50:19] Reencoding audio tracks (if req'd)
 - [22:50:19] Multiplexing M2TS
 - [22:50:21] Extracting A/V streams [VID_00051]
 - [22:50:34] Reencoding: VID_00051 (26 of 34)
 - [22:50:34] Collecting video information
   - Rate/Length: 29.970fps, 6,210 frames
   - Bitrate: 2,788 Kbs
 - [22:50:34] Reencoding: VID_00051, Pass 1 of 1
 - [22:50:52] Video Encode complete
 - [22:50:52] Reencoding audio tracks (if req'd)
 - [22:50:52] Multiplexing M2TS
 - [22:50:57] Extracting A/V streams [VID_00053]
 - [22:51:45] Reencoding: VID_00053 (27 of 34)
 - [22:51:45] Collecting video information
   - Rate/Length: 23.976fps, 3,608 frames
   - Bitrate: 15,993 Kbs
 - [22:51:45] Reencoding: VID_00053, Pass 1 of 1
 - [22:53:05] Video Encode complete
 - [22:53:05] Reencoding audio tracks (if req'd)
 - [22:53:05] Multiplexing M2TS
 - [22:53:17] Extracting A/V streams [VID_00054]
 - [22:53:38] Reencoding: VID_00054 (28 of 34)
 - [22:53:38] Collecting video information
   - Rate/Length: 23.976fps, 2,307 frames
   - Bitrate: 9,701 Kbs
 - [22:53:38] Reencoding: VID_00054, Pass 1 of 1
 - [22:54:19] Video Encode complete
 - [22:54:19] Reencoding audio tracks (if req'd)
 - [22:54:19] Multiplexing M2TS
 - [22:54:24] Extracting A/V streams [VID_00055]
 - [22:54:56] Reencoding: VID_00055 (29 of 34)
 - [22:54:56] Collecting video information
   - Rate/Length: 23.976fps, 3,563 frames
   - Bitrate: 9,919 Kbs
 - [22:54:56] Reencoding: VID_00055, Pass 1 of 1
 - [22:56:08] Video Encode complete
 - [22:56:08] Reencoding audio tracks (if req'd)
 - [22:56:08] Multiplexing M2TS
 - [22:56:16] Extracting A/V streams [VID_00060]
 - [23:35:29] Reencoding: VID_00060 (30 of 34)
 - [23:35:29] Collecting video information
   - Rate/Length: 23.976fps, 167,736 frames
   - Bitrate: 7,789 Kbs
 - [23:35:29] Reencoding: VID_00060, Pass 1 of 1
 - [00:53:09] Video Encode complete
 - [00:53:09] Reencoding audio tracks (if req'd)
 - [00:53:09] Multiplexing M2TS
 - Error in attempt to multiplex: MUX_00060.meta
 - Pes packet len too large ( >100Mb). Bad stream or invalid codec speciffed.
[01:01:43] - Failed to build structure, aborted
Any help is greatly appreciated. Thanks in advance.
Magpowerzip
Old 3rd November 2010, 18:01   #10013  |  Link
What kinds of audio does it show for VID_00060?
Old 3rd November 2010, 18:28   #10014  |  Link
Acerjen
It shows the following audio for VID_0060
AUD_001 LPCM, Multi-Ch, English
AUD_002 AC3, Multi-Ch, English
AUD_003 AC3, Stereo, English
AUD_004 AC3, Stereo, English
Magpowerzip
Old 3rd November 2010, 18:54   #10015  |  Link
Magpowerzip
Can you look in the working folder (WORKFILES) and tell me how many .WAV files exist for 00060?
Old 3rd November 2010, 19:16   #10016  |  Link
Acerjen
I deleted the WORKFILES directory and started encoding another film. I will re-do it again today and get back with you this evening. Thanks for your help.
magpowerzip
Old 3rd November 2010, 21:46   #10017  |  Link
magpowerzip
Thanks. I just wanted to see if there were multiple parts (.WAV files) so determine if that could be the root of the problem.
Old 3rd November 2010, 21:47   #10018  |  Link
@SoniG
Can you give me some more information as to where to look for the problem? I completed the encode, and everything seems to look right to me.
Old 4th November 2010, 04:08   #10019  |  Link
Acerjen
I re-did Cars and there are 2 WAV files created for VID_00060.
They are as follows:
00060.track_4352.1
00060.track_4352.2
Magpowerzip
Old 4th November 2010, 04:30   #10020  |  Link
00060.track_4352.1
00060.track_4352.2
Magpowerzip
They do have .WAV on the end, right?
