Old 8th April 2013, 19:03   #16901  |  Link
worknstiff
@ jdobbs RE: Zero Dark Thirty Quote: Well, I'm confused. I looked at the SUP stream that is in the backup and the forced_on_flag is very definitely set. So I have no idea why it isn't always displaying.
I just checked my backup copy (full backup BD25 using 0.43.04), and the subs are being played back correctly using TMT 5.0 (5.01.114), and also oppo 93. I did not have to manually select anything to get it to display.
Old 8th April 2013, 19:42   #16902  |  Link
I tested it and a full backup works for me too. I'm still trying to figure out why it isn't working on a movie-only backup. It seems to only "sometimes" work...
Old 8th April 2013, 23:43   #16903  |  Link
Sharc
All of a sudden DB-RB refuses to start. I get:
System Error &H80004023 (-2147467229).
I am on WIN7 64bit.
Inspect.exe reports all ok but
- WIN7 preferred AVC CODEC: Not Set correctly
Re-installing DB-RB, ffdshow, haali and system restart does not help.
Any suggestions?
It's weird. Same error occurs with DVDAuthorGUI and DVD_Rebuilder which both require mscomctl.ocx. Running REG_MSCOMCTL.BAT (as Administrator) in BD-RB does not help.
Possibly the problem came with the installation of Office 2013 which comes with ist own (newer?) mscomctl.ocx, or recent OS update. Does this make sense?
Old 8th April 2013, 23:55   #16904  |  Link
I guess it could, but it'd be very unusual for an updated OCX to not remain compatible.
Try opening a command window in administrator mode -- and cut/past the command from REG_MSCOMCTL.BAT into the window (or type it in). I seem to remember a report once in which that was the only way that person could get it to register.
But... if the problem is MSCOMCTL, you should get a very specific error message that tells you that.
You are using all the versions that are linked in the first post of this thread, right?
Old 9th April 2013, 22:35   #16905  |  Link
Sharc
This was it! I had to copy the mscomctl.ocx manually into the \system32\ and \SysWOW64\ directories, and then get it to register via the command window in administrator mode.
Old 10th April 2013, 19:25   #16906  |  Link
lauguru
as used or as AUDIO_AMPLIFY command type = "NORMALIZE"???
AUDIO_AMPLIFY=n
AUDIO_AMPLIFY="NORMALIZE"
AUDIO_AMPLIFY=NORMALIZE
thanks
lauguru is offline   Reply With Quote
Old 10th April 2013, 19:33   #16907  |  Link
AUDIO_AMPLIFY=n
thanks
The first one will work and so will the last one. This will work too:
AUDIO_AMPLIFY=N
Please note that with normalization enabled you will see a significant pause at the beginning of the audio encode as the stream is scanned for peaks.
Old 10th April 2013, 19:42   #16908  |  Link
lauguru
AUDIO_AMPLIFY=N
ok thanks
Old 11th April 2013, 22:07   #16909  |  Link
colinhunt
BD-RB 0.43.06
Title: Onibaba (Masters of Cinema)
Job: Full Backup
Affected files: 00004.m2ts, 00005.m2ts and 00009.m2ts
Source files have a resolution of 1440x1080 (23.976p) and an Aspect Ratio of 16:9.
On the backup, files have a resolution of 1440x1080 (23.976p) and an Aspect Ratio of 4:3. The image looks horizontally squashed.
[04.11.13] BD Rebuilder v0.43.06 (beta)
[17:24:55] Source:  ONIBABA_(1964)
  - Input BD size: 34,57 GB
  - Approximate total content: [02:29:42.932]
  - Target BD size: 23,63 GB
  - Windows Version: 6.1 [7601]
  - Quality: Highest (Very Slow), Two Pass
  - Output folder: U:\_ENCODES\
  - X264 Tweak(s) enabled    (<- --tune film only)
[17:24:56] PHASE ONE, Encoding
 - [17:24:56] Processing: VID_00002 (1 of 6)
 - [17:24:56] Extracting A/V streams [VID_00002]
 - [17:38:54] Reencoding video [VID_00002]
   - Rate/Length: 23,976fps, 147*432 frames
   - Bitrate: 25*291 Kbs
 - [17:38:54] Reencoding: VID_00002, Pass 1 of 2
 - [18:15:45] Reencoding: VID_00002, Pass 2 of 2
 - [20:53:27] Video Encode complete
 - [20:53:27] Processing audio tracks
   - Track 4352 (jpn): Reencoding audio to AC3...
   - Track 4353 (jpn): Reencoding audio to AC3...
 - [20:54:14] Multiplexing M2TS
 - [21:04:16] Processing: VID_00004 (2 of 6)
 - [21:04:16] Extracting A/V streams [VID_00004]
 - [21:04:36] Reencoding video [VID_00004]
   - Rate/Length: 23,976fps, 9*086 frames
   - Bitrate: 8*894 Kbs
 - [21:04:36] Reencoding: VID_00004, Pass 1 of 2
 - [21:05:52] Reencoding: VID_00004, Pass 2 of 2
 - [21:10:30] Video Encode complete
 - [21:10:30] Processing audio tracks
 - [21:10:32] Multiplexing M2TS
 - [21:10:41] Processing: VID_00005 (3 of 6)
 - [21:10:41] Extracting A/V streams [VID_00005]
 - [21:10:52] Reencoding video [VID_00005]
   - Rate/Length: 23,976fps, 3*367 frames
   - Bitrate: 10*877 Kbs
 - [21:10:52] Reencoding: VID_00005, Pass 1 of 2
 - [21:11:28] Reencoding: VID_00005, Pass 2 of 2
 - [21:13:50] Video Encode complete
 - [21:13:50] Processing audio tracks
 - [21:13:51] Multiplexing M2TS
 - [21:13:58] Processing: VID_00009 (4 of 6)
 - [21:13:58] Extracting A/V streams [VID_00009]
 - [21:15:58] Reencoding video [VID_00009]
   - Rate/Length: 23,976fps, 54*720 frames
   - Bitrate: 10*721 Kbs
 - [21:15:58] Reencoding: VID_00009, Pass 1 of 2
 - [21:25:59] Reencoding: VID_00009, Pass 2 of 2
 - [22:05:54] Video Encode complete
 - [22:05:55] Processing audio tracks
 - [22:05:55] Multiplexing M2TS
 - [22:06:54] Processing: VID_00011 (5 of 6)
 - [22:06:54] Extracting A/V streams [VID_00011]
 - [22:06:58] Reencoding video [VID_00011]
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 23,976fps, 240 frames
   - Bitrate: 19*915 Kbs
 - [22:06:58] Reencoding: VID_00011, Pass 1 of 2
 - [22:07:00] Reencoding: VID_00011, Pass 2 of 2
 - [22:07:03] Video Encode complete
 - [22:07:03] Processing audio tracks
 - [22:07:03] Multiplexing M2TS
 - [22:07:06] Processing: VID_00012 (6 of 6)
 - [22:07:06] Extracting A/V streams [VID_00012]
 - [22:07:11] Reencoding video [VID_00012]
   - Bitrate: 12*520 Kbs
 - [22:07:11] Reencoding: VID_00012, Pass 1 of 2
 - [22:07:13] Reencoding: VID_00012, Pass 2 of 2
 - [22:07:14] Video Encode complete
 - [22:07:14] Processing audio tracks
 - [22:07:15] Multiplexing M2TS
[22:07:18]PHASE ONE complete
[22:07:18]PHASE TWO - Rebuild Started
 - [22:07:18] Rebuilding BD file Structure
[22:13:24] - Encode and Rebuild complete
[22:13:24] JOB: ONIBABA_(1964) finished.
Old 12th April 2013, 01:03   #16910  |  Link
Wow. Is that a commercial disc? It's certainly a legal format, I have yet to have ever run across a 1440x1080 source. I'll have to create one and test it.
Old 12th April 2013, 19:10   #16911  |  Link
Racer
Is it actually possible to define something like an output folder for the .iso file and something like an Multiplexing folder.
I would do the following:
1) Extract from Movie (HDD) to Working folder (SSD)
2) Reencoding in Working folder (SSD)
3) Multiplexing from Working folder (SSD) to HDD
4) Create ISO File from HDD to SSD
If I do like this don't I get the best performance?
Racer is offline   Reply With Quote
Old 13th April 2013, 00:51   #16912  |  Link
Ch3vr0n
Here's an error for ya jdobbs.
[04/12/13] BD Rebuilder v0.43.06 (beta)
[22:12:49] Source: CONTRABAND_G53
- Input BD size: 37,65 GB
- Approximate total content: [02:36:43.268]
- Target BD size: 22,95 GB
- Windows Version: 6.0 [6002]
- Output folder: Z:\BDRB Rebuilds\
- Decoding/Frame serving: DGDecNV [2-way]
[22:12:49] PHASE ONE, Encoding
- [22:12:49] Processing: VID_00016 (1 of 33)
- [22:12:49] Extracting A/V streams [VID_00016]
- [22:13:00] Reencoding video [VID_00016]
- Rate/Length: 23,976fps, 1.416 frames
- Bitrate: 10.364 Kbs
- [22:13:00] Reencoding: VID_00016, Pass 1 of 1
- [22:13:33] Video Encode complete
- [22:13:33] Processing audio tracks
- [22:13:33] Multiplexing M2TS
- [22:13:39] Processing: VID_00017 (2 of 33)
- [22:13:39] Extracting A/V streams [VID_00017]
- [22:13:48] Reencoding video [VID_00017]
- [22:13:48] Reencoding: VID_00017, Pass 1 of 1
- [22:14:22] Video Encode complete
- [22:14:22] Processing audio tracks
- [22:14:22] Multiplexing M2TS
- [22:14:30] Processing: VID_00023 (3 of 33)
- [22:14:30] Extracting A/V streams [VID_00023]
- [22:41:29] Reencoding video [VID_00023]
- [22:41:29] Reencoding secondary video [TRK_02]
- Rate/Length: 23,976fps, 157.725 frames
- Bitrate: 18.837 Kbs
- [22:59:29] Reencoding: VID_00023, Pass 1 of 1
- [00:35:14] Video Encode complete
- [00:35:14] Processing audio tracks
- Track 4353 (eng): Keeping original audio
- Track 4357 (eng): Keeping original audio
- Track 6656 (eng): Keeping original audio
- [00:35:15] Multiplexing M2TS
- [00:56:47] Remuxing DTSX/IGS stream(s)
- [01:39:57] Processing: VID_00024 (4 of 33)
- [01:39:57] Extracting A/V streams [VID_00024]
- [01:40:07] Reencoding video [VID_00024]
- Rate/Length: 23,976fps, 333 frames
- Bitrate: 10.534 Kbs
- [01:40:07] Reencoding: VID_00024, Pass 1 of 1
- [01:40:18] Video Encode complete
- [01:40:18] Processing audio tracks
- [01:40:18] Multiplexing M2TS
- [01:40:21] Processing: VID_00025 (5 of 33)
- [01:40:21] Extracting A/V streams [VID_00025]
- [01:40:38] Reencoding video [VID_00025]
- Rate/Length: 23,976fps, 3.557 frames
- Bitrate: 10.498 Kbs
- [01:40:38] Reencoding: VID_00025, Pass 1 of 1
- [01:42:05] Video Encode complete
- [01:42:05] Processing audio tracks
- [01:42:05] Multiplexing M2TS
- [01:42:37] Processing: VID_00098 (6 of 33)
- [01:42:37] Reencoding video [VID_00098]
- Rate/Length: 23,976fps, 1.699 frames
- Bitrate: 6.646 Kbs
- [01:42:37] Reencoding: VID_00098, Pass 1 of 1
- [01:43:13] Video Encode complete
- [01:43:13] Processing audio tracks
- [01:43:13] Multiplexing M2TS
- [01:43:18] Processing: VID_00116 (7 of 33)
- [01:43:18] Extracting A/V streams [VID_00116]
- [01:43:27] Reencoding video [VID_00116]
- Rate/Length: 23,976fps, 1.233 frames
- Bitrate: 10.532 Kbs
- [01:43:27] Reencoding: VID_00116, Pass 1 of 1
- [01:43:59] Video Encode complete
- [01:43:59] Processing audio tracks
- [01:43:59] Multiplexing M2TS
- [01:44:05] Processing: VID_00117 (8 of 33)
- [01:44:05] Extracting A/V streams [VID_00117]
- [01:44:12] Reencoding video [VID_00117]
- Rate/Length: 23,976fps, 520 frames
- Bitrate: 10.505 Kbs
- [01:44:12] Reencoding: VID_00117, Pass 1 of 1
- [01:44:28] Video Encode complete
- [01:44:28] Processing audio tracks
- [01:44:28] Multiplexing M2TS
- [01:44:33] Processing: VID_00118 (9 of 33)
- [01:44:33] Extracting A/V streams [VID_00118]
- [01:44:42] Reencoding video [VID_00118]
- Rate/Length: 23,976fps, 1.280 frames
- [01:44:42] Reencoding: VID_00118, Pass 1 of 1
- [01:45:16] Video Encode complete
- [01:45:16] Processing audio tracks
- [01:45:16] Multiplexing M2TS
- [01:45:22] Processing: VID_00119 (10 of 33)
- [01:45:22] Extracting A/V streams [VID_00119]
- [01:45:30] Reencoding video [VID_00119]
- Rate/Length: 23,976fps, 780 frames
- Bitrate: 10.538 Kbs
- [01:45:30] Reencoding: VID_00119, Pass 1 of 1
- [01:45:51] Video Encode complete
- [01:45:51] Processing audio tracks
- [01:45:51] Multiplexing M2TS
- [01:45:55] Processing: VID_00120 (11 of 33)
- [01:45:55] Extracting A/V streams [VID_00120]
- [01:46:01] Reencoding video [VID_00120]
- Rate/Length: 23,976fps, 196 frames
- Bitrate: 10.502 Kbs
- [01:46:01] Reencoding: VID_00120, Pass 1 of 1
- [01:46:07] Video Encode complete
- [01:46:07] Processing audio tracks
- [01:46:07] Multiplexing M2TS
- [01:46:11] Processing: VID_00121 (12 of 33)
- [01:46:11] Extracting A/V streams [VID_00121]
- [01:46:41] Reencoding video [VID_00121]
- Rate/Length: 23,976fps, 255 frames
- Bitrate: 10.478 Kbs
- [01:46:41] Reencoding: VID_00121, Pass 1 of 1
- Encode failed. Aborting.
- BD-Rebuilder v0.43.06 (beta)
- FFDSHOW: 4422, Ok
- FFDSHOW MPEG2 set to "libmpeg2": Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
[01:46:41] - Failed video encode, aborted
running an x264 lavf encode now
Old 13th April 2013, 11:50   #16913  |  Link
TobiMan
I just ran into the same issue. Thanks for the hint. Maybe something with the latest MS Patchday?
TobiMan is offline   Reply With Quote
Old 13th April 2013, 13:48   #16914  |  Link
@Ch3vr0n
I'm guessing those errors are coming from DGDecNV. I'm confused, though, because the picture doesn't seem to match the log. One says it crashed during indexing, and the other looks like it tried to encode.
Let me know what happens when you use LAVF.
Old 13th April 2013, 18:45   #16915  |  Link
colinhunt
Sure is, part of the Masters of Cinema series. It's the second disc I've seen with files in that format.
Old 13th April 2013, 18:46   #16916  |  Link
Ch3vr0n
The lavf build went through normally. I'll run another dgenc this evening and let you know
Verstuurd van mijn HTC Sensation XE with Beats Audio Z715e met Tapatalk
** edit ** looks like it was a one-off fluke. Encoding video 17/33 atm and the problematicone was 12/33. Will add another update if the build goes through completely
** edit 2 ** One-off confirmed. DGenc rebuild ran just fine. guess you can forget about this one. If it ever happens again i'll let ya know. I did notice a small thing that's probably not relevant to the issue.
the LAVF build came out at 22.1GB while the DGenc build came out at 22.3GB. could you shed some light on this
Old 14th April 2013, 13:31   #16917  |  Link
Sharc
Originally Posted by colinhunt View Post
BD-RB 0.43.06
Job: Full Backup
Is your source anamorphic? If so, it should be encoded with --sar 4:3; you may try this via the tweak option in BD-RB.
Old 14th April 2013, 13:46   #16918  |  Link
There are limits to how accurate encoding can be. That's one of the reasons why I reserve a small size margin in the target. I assume the log shows they both were encoded with the same bitrate, right?
Old 14th April 2013, 16:53   #16919  |  Link
Ch3vr0n
Any way i can tell. Every so often i clean the bdrebuilder.log file in the temp directory. And it looks like i cleaned it between the lavf build & dgenc build.
** edit ** nvm, looks like i deleted that lavf image aswell cba to run another 6hr encode just for a few hundred MB
Old 14th April 2013, 18:32   #16920  |  Link
The encode bitrate is shown in the log just before the encode starts.
