Old 26th May 2013, 22:28   #17321  |  Link
sytyguy
No, he's saying something is wrong when running it over a LAN, but running it locally it runs fine.
sytyguy is offline   Reply With Quote
Old 26th May 2013, 22:28   #17322  |  Link
Inwards
@Inwards
Are you saying that you tested 44.09 over a network and 44.03 locally, and therefore the problem is 44.09 and not your network.
And a log like Ch3vr0n said would be nice
No, I tested 44.09 over the network and locally. 44.03 I tested over the network only.
Inwards is offline   Reply With Quote
Old 26th May 2013, 22:43   #17323  |  Link
gonca
You'll have to provide the info Ch3vr0n mentioned, as there are not no other reports coming in about this
Old 27th May 2013, 19:24   #17324  |  Link
Starfiresg1
Starfiresg1's Avatar
While doing a SBS-backup of Wreck it Ralph 3D I've run into a small problem:
Apparently the re-encoding of the video is skipped if the input size is smaller than the target. In my case I had set the target as BD-25 and BDR reported the input size of 21.17 GB. After reducing the target size the video re-encode happens as expected. I would think that a video re-encode is always needed (regardless of the input and target size) if it's a 3D-conversion to SBS (or any other 3D-format)?
Starfiresg1 is offline   Reply With Quote
Old 27th May 2013, 22:40   #17325  |  Link
Hmm... it definitely should be. I though I had that covered. I'll go back an do some testing.
Old 28th May 2013, 00:25   #17326  |  Link
Winenut
Didn't know it existed? I've personally mentioned it to you twice. I even posted my results using v0.44.09.
My original post was on 5/19. Release 44.09 shows as coming out 2 days later on 5/21.
And sorry. I did notice your reference to 44.09 (earlier), but then forgot about it. At the tme, you didn't indicate what the changes were in 44.09, and so I had no reason to believe it would solve my problem. And the change log didn't seem to indicate any significant changes that might affect the problem I was having, except perhaps the new version of H264. And then later, when I noticed the issue was opencl.ddl, it didn't seem a change to H264 would have any impact.
Then later, I saw 44.09 on Videohelp.com, and figured it was worth a try. Particularly since by then, you knew my problem was opencl.dll and reiterated your recomendation for 44.09.
In any case 44.09 is working fine...for a number of titles I've tried.
Question is...since opencl.dll seems to serve to enable multi-threading of background tasks (for both CPU, and optionally the GPU), why don't you need to use that anymore. Did H264 change so much that it's not needed anymore? And if so, why was it still included with 44.09.
Thanks again for your help, and sorry to be such a nuisance.
Steve
Winenut is offline   Reply With Quote
Old 28th May 2013, 00:53   #17327  |  Link
Steve
There was a bug in the older version of X264 that made it fail on systems that didn't have opencl as a video capability (even when that capability wasn't being used). The opencl.dll file was a dummy stub that was created for no other purpose than to keep X264 from failing. The newer version of X264 was corrected -- so the dummy file "opencl.dll" is no longer needed.
Old 28th May 2013, 01:06   #17328  |  Link
soneca
Jdobbs,
It would be possible to include a depth control for subtitles in 3D?
In the title "Flying Swords of Dragon Gate" subtitles were "stuck" in the picture, deep, hurting a little reading.
I'll do some more tests, apparently subtitle depth may vary depending on the movie.
Old 28th May 2013, 04:48   #17329  |  Link
Originally Posted by soneca View Post
Jdobbs,
BD-RB does the subtitles consistently across all movies, so the depth doesn't vary from this end. But I can easily add a hidden option that can change the depth.
Old 28th May 2013, 05:18   #17330  |  Link
soneca
Surely, BD-RB does not change the depth but it seems that the result varies slightly depending on the source.
Old 28th May 2013, 22:36   #17331  |  Link
colinhunt
Note that some 3D Blu-rays will have (if they don't already) dynamic 3D subtitles, i.e. ones that move in X and Z axis according to the depth and convergence of the scene.
Old 29th May 2013, 00:31   #17332  |  Link
soneca
As subtitles found in "Avatar" for example?
Old 29th May 2013, 01:04   #17333  |  Link
Inwards
Here is the failed log of an ISO mounted over the network
[05/28/13] BD Rebuilder v0.44.09 (beta)
[18:34:54] Source:  FIRE_AND_ICE
  - Input BD size: 28.47 GB
  - Approximate total content: [02:14:36.067]
  - Target BD size: 22.95 GB
  - Windows Version: 6.1 [7601]
[18:34:55] PHASE ONE, Encoding
 - [18:34:55] Processing: VID_00000 (1 of 7)
 - [18:34:55] Extracting A/V streams [VID_00000]
 - [18:44:27] Reencoding video [VID_00000]
   - Rate/Length: 23.976fps, 117,436 frames
   - Bitrate: 30,882 Kbs
 - [18:44:27] Reencoding: VID_00000, Pass 1 of 1
 - [19:08:12] Video Encode complete
 - [19:08:12] Processing audio tracks
 - [19:08:12] Multiplexing M2TS
 - [19:09:47] Processing: VID_00001 (2 of 7)
 - [19:09:47] Extracting A/V streams [VID_00001]
 - [19:10:04] Reencoding video [VID_00001]
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 24,330 frames
   - Bitrate: 3,932 Kbs
 - [19:10:04] Reencoding: VID_00001, Pass 1 of 1
 - [19:10:40] Video Encode complete
 - [19:10:40] Processing audio tracks
 - [19:10:40] Multiplexing M2TS
 - [19:10:46] Processing: VID_00002 (3 of 7)
 - [19:10:46] Extracting A/V streams [VID_00002]
 - [19:10:58] Reencoding video [VID_00002]
   - Rate/Length: 29.970fps, 14,417 frames
   - Bitrate: 3,930 Kbs
 - [19:10:58] Reencoding: VID_00002, Pass 1 of 1
 - [19:11:18] Video Encode complete
 - [19:11:18] Processing audio tracks
 - [19:11:18] Multiplexing M2TS
 - [19:11:22] Processing: VID_00003 (4 of 7)
 - [19:11:22] Extracting A/V streams [VID_00003]
 - [19:11:40] Reencoding video [VID_00003]
   - Rate/Length: 29.970fps, 25,358 frames
   - Bitrate: 3,919 Kbs
 - [19:11:40] Reencoding: VID_00003, Pass 1 of 1
 - [19:12:14] Video Encode complete
 - [19:12:14] Processing audio tracks
 - [19:12:14] Multiplexing M2TS
 - [19:12:18] Processing: VID_00004 (5 of 7)
 - [19:12:18] Extracting A/V streams [VID_00004]
 - [19:12:35] Reencoding video [VID_00004]
   - Rate/Length: 29.970fps, 23,545 frames
   - Bitrate: 3,929 Kbs
 - [19:12:35] Reencoding: VID_00004, Pass 1 of 1
 - [19:13:07] Video Encode complete
 - [19:13:07] Processing audio tracks
 - [19:13:07] Multiplexing M2TS
 - [19:13:11] Processing: VID_00005 (6 of 7)
 - [19:13:11] Extracting A/V streams [VID_00005]
 - [19:13:22] Reencoding video [VID_00005]
   - Rate/Length: 23.976fps, 1,810 frames
   - Bitrate: 29,312 Kbs
 - [19:13:23] Reencoding: VID_00005, Pass 1 of 1
 - [19:13:45] Video Encode complete
 - [19:13:45] Processing audio tracks
 - [19:13:45] Multiplexing M2TS
 - [19:13:49] Processing: VID_00016 (7 of 7)
 - [19:13:49] Extracting A/V streams [VID_00016]
 - [19:13:52] Reencoding video [VID_00016]
   - Rate/Length: 29.970fps, 900 frames
   - Bitrate: 2,376 Kbs
 - [19:13:52] Reencoding: VID_00016, Pass 1 of 1
  - Encode failed.  Aborting.
  - BD-Rebuilder v0.44.09 (beta)
  - FFDSHOW: 4422, Ok
  - WIN7 preferred AVC CODEC:  Ok
  - WIN7 preferred VC-1 CODEC:  Ok
  - WIN7 preferred MPEG2 CODEC:  Ok
  - FFDSHOW MPEG2 set to "libavcodec":  Ok
  - FFDSHOW AVC set to "libavcodec":  Ok
  - AnyDVD settings check: Ok.
  - X264:  Ok
  - AFTEN:  Ok
  - FAAC:  Ok
  - MP4BOX:  Ok
  - WAVI:  Ok
  - TSMUXER:  Ok
[19:13:53] - Failed video encode, aborted
...and here's the resumed log with the locally mounted ISO:
[19:59:38] Source:  FIRE_AND_ICE
- Resuming from previously started job.
[19:59:40] PHASE ONE, Encoding
 - [19:59:40] Processing: VID_00016 (7 of 7)
 - [19:59:40] Reencoding video [VID_00016]
 - [19:59:40] Reencoding: VID_00016, Pass 1 of 1
 - [19:59:41] Video Encode complete
 - [19:59:41] Processing audio tracks
 - [19:59:41] Multiplexing M2TS
[19:59:44]PHASE ONE complete
[19:59:44]PHASE TWO - Rebuild Started
 - [19:59:44] Rebuilding BD file Structure
[19:59:47] - Encode and Rebuild complete
[19:59:47] JOB: FIRE_AND_ICE finished.
Old 29th May 2013, 01:19   #17334  |  Link
omegaman7
omegaman7's Avatar
Mmmm, I haven't had two computers networked to each other for some time. Local ISO mounting, I don't believe I've ever had a problem. Over a network though? Wish I had a secondary PC powerful enough to make the attempt Part time work sucks...
Old 29th May 2013, 01:44   #17335  |  Link
The problem is that there are too many variables -- and almost all of them are outside of BD-RB. The bottom line: if it were truly mounted and working correctly, BD-RB wouldn't be able to tell the difference -- and it would work exactly the same either way. The fact that it works when mounted locally tells me the issue is outside of BD-RB and falls somewhere in the network abstraction.
Old 29th May 2013, 01:48   #17336  |  Link
omegaman7
omegaman7's Avatar
I don't recall having many network issues on XP. Windows 7 seems to have issues maintaining an indefinite connection. It's as though it needs to refresh for certain processes. Thereby causing an issue. I burned discs over the network on XP, I'd never trust it with '7', and I love 7. Just my own observations. Really haven't done much networking with 7 though. THere is likely something I overlooked.
Old 29th May 2013, 02:15   #17337  |  Link
I do encodes using the network all the time. But I don't mount an ISO remotely. I rip to hard drive and share it.
Old 29th May 2013, 02:40   #17338  |  Link
omegaman7
omegaman7's Avatar
I'm sure I will play with it more down the road. Just gotta win the lottery or something LOL!!! Nah, I should go full time within the year. Then I'll be VERY comfortable. I hope :S
Old 29th May 2013, 10:33   #17339  |  Link
lauguru
hello jdobbs
one question
http://mewiki.project357.com/wiki/X264_Settings
for codec h264 Values available: ultrafast, superfast, veryfast, faster, fast, medium, slow, slower, veryslow, placebo.
with that command, you activate "placebo"?
ENCODE_QUALITY=4 is very slow (ultra high quality)
if so it could activate the option "placebo" in the next version of bdrebuilder?thks
lauguru is offline   Reply With Quote
Old 29th May 2013, 23:56   #17340  |  Link
soneca
ENCODE_QUALITY=4 = preset slower
Placebo = waste of time and energy for nothing.
