8th January 2017, 16:25 | #302 | Link | |
8th January 2017, 16:28 | #303 | Link | |
8th January 2017, 16:49 | #304 | Link | |
Can you please share command for x264 output with 2 pass encoding ? I need to capture these parameters in output mkv file ... subq=6: partitions=all:8x8dct:me=umh:frameref=5:bframes=3:b_pyramid=normal:weight_b |
8th January 2017, 16:59 | #305 | Link | |
Beyond Kawaii
--demuxer y4m --pass 1 --bitrate 3000 --stats "{sd}/{sn}.stats" --slow-firstpass --min-keyint 1 --b-adapt 1 --ref 5 --bframes 4 --vbv-init 1.0 --ratetol 100.0 --qcomp 0 --cplxblur 0 --qblur 0 --rc-lookahead 250 --aq-mode 2 --merange 64 --me tesa --subme 11 --partitions all --trellis 2 --no-dct-decimate --stitchable --direct auto --no-psy --no-progress - -o "{sd}/{sn}.mkv"
...desu! |
8th January 2017, 17:26 | #306 | Link | |
9th January 2017, 13:44 | #307 | Link | |
Failed to evaluate the script: Python exception: There is no attribute or namespace named fmtc Traceback (most recent call last): File "src\cython\vapoursynth.pyx", line 1491, in vapoursynth.vpy_evaluateScript (src\cython\vapoursynth.c:26905) File "C:/DVD/Sample.vpy", line 6, in video = core.d2v.Source(r'C:\DVD\Sample.d2v') File "C:\Program Files\Python35\lib\site-packages\havsfunc.py", line 943, in QTGMC bobbed = Bob(clip, 0, 0.5, TFF) File "C:\Program Files\Python35\lib\site-packages\havsfunc.py", line 4128, in Bob clip = core.std.SeparateFields(clip, tff).fmtc.resample(scalev=2, kernel='bicubic', a1=b, a2=c, interlaced=1, interlacedd=0) File "src\cython\vapoursynth.pyx", line 833, in vapoursynth.VideoNode.__getattr__ (src\cython\vapoursynth.c:16042) AttributeError: There is no attribute or namespace named fmtc I have following 64bit dll files in Vapoursynth plugins 64 folder : AddGrain, continuity, d2vsource, dctfilter, DFTTest, ffms2, FFT3DFilter, flash3kyuu_deband, KNLMeansCL, libawarpsharp2, libbifrost, libfftw3-3, libfftw3f-3, libfftw3l-3, libmvtools, libnnedi3, ReduceFlicker, scenechange, TDeintMod, temporalsoften, TNLMeans, vcmod, vs_sangnommod, vsavsreader & vslsmashsource. All these dll files have been copied to SysWOW64 as well as system32 folder. Here is my script : import vapoursynth as vs import adjust import havsfunc as haf core = vs.get_core() video = core.d2v.Source(r'C:\DVD\Sample.d2v') video = haf.QTGMC(video, Preset='Medium', TFF=True) video.set_output() Any help in getting QTGMC working would be highly appreciated... |
9th January 2017, 14:10 | #308 | Link |
1. Don't copy the filters in system32.
2. As the error msg shows, you are missing another plugin: fmtc Here's a nearly complete list of availible plugins: http://www.vapoursynth.com/doc/pluginlist.html You need fmtconv – High quality bitdepth, colorspace conversion and resizing
9th January 2017, 15:12 | #309 | Link | |
2017-01-09 19:40:43.605 Core freed but 4 filter instances still exist Core freed but 4 filter instances still exist Core freed but 1612800 bytes still allocated in framebuffers Core freed but 1612800 bytes still allocated in framebuffers What's this all about ? Thanks |
9th January 2017, 15:41 | #310 | Link | |
Beyond Kawaii
...desu! |
9th January 2017, 18:27 | #312 | Link |
Professional Code Monkey
The leak happens in a few rare error paths on nnedi3. It will be fixed soon.
10th January 2017, 02:57 | #313 | Link | |
Sent from my GT-N8000 using Tapatalk Last edited by Jindadil007; 10th January 2017 at 03:08. |
10th January 2017, 07:34 | #314 | Link |
From the python reference at the vapoursynth website (silicing a clip):
Select even numbered frames: video = clip[::2] Select odd numbered frames: video = clip[1::2] Also, from the SelectEvery function: Return even numbered frames, starting with 0: SelectEvery(clip=clip, cycle=2, offsets=0) Return odd numbered frames, starting with 1: SelectEvery(clip=clip, cycle=2, offsets=1) Remember Search is your fiend Last edited by VS_Fan; 10th January 2017 at 07:43. |
10th January 2017, 16:57 | #315 | Link | |
Sent from my GT-N8000 using Tapatalk |
10th January 2017, 17:02 | #316 | Link |
Pig on the wing
As far as I know, QTGMC has the option to output single-rate video. The FPSDivisor parameter controls the output. There's also the option to use some motion blur.
10th January 2017, 18:44 | #317 | Link |
I tried to run QTGMC with the latest version of havsfunc.py (9th november) from github and on Vapoursynth R35, but i get a "No attribute with the name focus2 exists" in relation to the line "return core.focus2.TemporalSoften2 etc" What could be the problem ? |
10th January 2017, 19:44 | #318 | Link |
http://forum.doom9.org/showthread.php?t=166769 and on the second page there is a 64bit version.
10th January 2017, 19:56 | #319 | Link | |
"No attribute with the name focus exists", related to core.focus.TemporalSoften :-S |
10th January 2017, 19:59 | #320 | Link |
For focus you need https://github.com/dubhater/vapoursynth-temporalsoften
