Old 12th July 2018, 16:08   #41  |  Link
foxyshadis
ангел смерти
foxyshadis's Avatar
Originally Posted by MysteryX View Post
There are indeed risks with downloading DLLs from unknown sources. However, one needs to do special work to run code in a DLL, it won't happen automatically, and most viruses within DLLs will be auto-detected by a good anti-virus.
Running a Python script by double-clicking on a file (for users who may not even know what VapourSynth is), however, can seriously limit the adaptation of VapourSynth. If that's the reason FFMPEG hasn't added native support for it, then I fully understand. In a business or production environment, have to be *VERY* careful where the scripts are coming from and where they are running. I don't think many people realize that. I also don't think Kaspersky will scan the Python raw script for malicious code.
I would say that this, combined with the lack of audio support, are the 2 things most limiting the adaptation of VapourSynth.
In Avisynth, all you have to do is get someone to load your DLL by saying it does something cool, and it turns out that pretty much everyone would. You can't even inspect that without being an expert programmer/reverser.
Old 12th July 2018, 16:30   #42  |  Link
ChaosKing
And If you are really evil you could try to overwrite files with http://avisynth.nl/index.php/ImageWriter
Old 12th July 2018, 18:22   #43  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
I see a clear difference between having security risks on a development machine for someone using Avisynth/VapourSynth and downloading various DLLs, compared to a production server using FFMPEG without any awareness of what VapourSynth/Avisynth even are.
If you take risks on your local machine, that's one thing.
If a server environment is at risk simply by using FFMPEG because it auto-loads a risky script engine (without admin awareness), that's something else.
MysteryX is offline   Reply With Quote
Old 28th February 2019, 02:28   #44  |  Link
poisondeathray
Using Wolfberry's FFMpeg build with vpy support , direct vapoursynth input is about 50% speed compared to vspipe to the same ffmpeg . I would have expected marginally faster for direct vpy demuxer. Script is just QTGMC . I tried specifying different ffmpeg -threads values as an input argument. Any ideas, or am I doing something wrong? Could it be a cache issue ?
https://forum.doom9.org/showthread.p...31#post1866931
vspipe --y4m input.vpy - | "ffmpeg" -f yuv4mpegpipe -i - -an -f null NUL
"ffmpeg" -f vapoursynth -i input.vpy -an -f null NUL
EDIT #1: but another test of just reading a MP4 video with lsmash (no other filters, just source filter), direct vapoursynth is about 1.4-1.5x faster than vspipe to ffmpeg
EDIT #2: tested other source filters too lsmash, ffms2, other file types (mpeg2, avc); pretty consistent observation - direct read with only source filter is faster, but as soon as you add any additional filter in script (not just QTGMC, it can be anything like a denoiser, or even a simple resize only) it becomes slower than vspipe method at about 50% speed
Is it specific to this ffmpeg build, or do other people get different results with their own build ?
Old 8th March 2019, 14:12   #45  |  Link
qyot27
qyot27's Avatar
Post #26 in this thread linked to a copy of it on pastebin.
I think I'll probably have to switch to it also, since I could never seem to get the official implementation to cross-compile right, despite following the steps provided earlier to get the Python lib encapsulated correctly.
Old 27th April 2019, 15:59   #46  |  Link
poisondeathray
Thanks Wolfberry ; does this recent one have wm4 or Stephen patch ?
Old 28th April 2019, 03:32   #47  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
I'm sure this build uses Stephen's implementation, but I haven't done any tests.
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 28th April 2019, 05:10   #48  |  Link
poisondeathray
Some quick tests - in terms of speed wise it seems to be working as expected
Why isn't Stephen implementation the official one ?
Old 28th April 2019, 22:50   #49  |  Link
Pat357
Unfortunately I can't help you with this specific issue, but I have a request :
could you consider to make a new FFMS2 compile with the libaom decoder replaced by dav1d ?
On relative simple scripts, the just decoding from AV1 takes a lot of CPU with libaom, while dav1d is at least 4x faster on modern CPU's.
With the following videos, I can't get even real-time speed when using liboam :
https://www.elecard.com/storage/vide..._13.9mbps.webm
https://www.elecard.com/storage/vide..._22.7mbps.webm
Pat357 is offline   Reply With Quote
Old 28th April 2019, 23:31   #50  |  Link
poisondeathray
[url
https://www.elecard.com/storage/video/Stream3_AV1_4K_13.9mbps.webm[/url]
Wolfberry posted ffms2 builds with libdav1d in the other thread
https://forum.doom9.org/showthread.php?t=176198
FFMS2:
ffmpeg 4.2-dev N-93683-g163bb087f8
libdav1d 0.2.2-0d7aa95d
libopenjpeg 2.3.1
mbedTLS 2.16.1
Old 29th April 2019, 00:06   #51  |  Link
qyot27
qyot27's Avatar
You mean like the builds I released in January and March of this year?
Old 30th April 2019, 02:52   #52  |  Link
hydra3333
... since I could never seem to get the official implementation to cross-compile right, despite following the steps provided earlier to get the Python lib encapsulated correctly.
ffmpeg-4.2-dev-N-93696-g45048ece81-win64-static
ffmpeg version N-93696-g45048ece81 Copyright (c) 2000-2019 the FFmpeg developers
built with gcc 9.0.1 (Built by Wolfberry) 20190426 (prerelease)
configuration: --enable-amf --enable-avisynth --enable-bzlib --enable-cuda --enable-d3d11va --enable-ffnvcodec --enable-frei0r --enable-gray --enable-iconv --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libcdio
--enable-libdav1d --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libgme --enable-liblensfun --enable-libmfx --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-librubberband
--enable-libsnappy --enable-libsoxr --enable-libsrt --enable-libssh --enable-libtesseract --enable-libvidstab --enable-libvmaf --enable-libvpx --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg
--enable-libzmq --enable-lzma --enable-nvdec --enable-nvenc --enable-opencl --enable-opengl --enable-openssl --enable-pthreads --enable-sdl2 --enable-vapoursynth --enable-zlib --enable-gpl --enable-version3
Would it be possible to post the build scripts ? That'd likely help the many.
hydra3333 is offline   Reply With Quote
Old 30th April 2019, 11:39   #53  |  Link
richardpl
That build is unsafe for using.
richardpl is offline   Reply With Quote
Old 30th April 2019, 12:00   #54  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
Do you mean the auto-detection of .vpy extension?
That's in the original implementation found at post #26
I can try revert that part to the official implementation by wm4.
Or do you mean something else?
If you feel unsafe then don't use it. It's simple
Monochrome Anomaly
Old 30th April 2019, 17:27   #55  |  Link
Pat357
Why is that ?
Old 4th May 2019, 11:12   #56  |  Link
hydra3333
Thanks !
Old 4th May 2019, 16:49   #57  |  Link
sl1pkn07
Pajas Mentales...
that patch is safe to push to upstream?
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline   Reply With Quote
Old 4th May 2019, 23:17   #58  |  Link
Pat357
@Wolfberry
Your latest FFmpeg build N-93755-ga5387f983d (20190504) seems to be broken for me.
If I do "ffplay -i "d:\path.to\a.mkv", I get the normal text output on screen, but the window that should show the video is white with the typical "windows wait" icon that stays there for about 5 seconds after the window closes.
The 5 seconds seems to be interdependent from the video-length: same for a 20s fragment or a full film (90-210min).
Also Avisynth scripts or VS scripts produce the same scenario, even when I specify "ffplay -f vapoursynth -i a.vpy"
Your previous version N-93696-g45048ece81 posted from 2019-04-30 is working perfect.
I have VS R45 installed on my system (not port.)
From my Windows log I have :
Foutbucket 1498974882443012356, type 4
Naam van gebeurtenis: APPCRASH
Antwoord: Niet beschikbaar
Id van CAB-bestand: 0
Handtekening van probleem:
P1: ffplay.exe
P2: 0.0.0.0
P3: 00000000
P4: msvcrt.dll
P5: 7.0.17134.1
P6: 5cbba6fd
P7: c0000005
P8: 000000000005cc53
P9:
P10:
Last edited by Pat357; 4th May 2019 at 23:48. Reason: attached windows-log info : appcrash
Old 5th May 2019, 15:00   #59  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
After some investigation, the culprit was LTO.
I saw there are some improvements in LTO optimizations in GCC 9, so I decided to give it a try.
It turns out that LTO was still more or less broken for ffmpeg, at least in MinGW.
Monochrome Anomaly
Old 12th May 2019, 16:23   #60  |  Link
stax76
stax76's Avatar
Thanks for the built. Any idea what could be wrong here?
C:\Users\frank\Desktop>C:\Users\frank\Daten\Projekte\VB\staxrip\bin\Apps\Encoders\ffmpeg\ffmpeg.exe -i "C:\Users\frank\Daten\Misc\Video Samples\test_temp\test.vpy" -c:v libx264 -an -y -hide_banner "C:\Users\frank\Daten\Misc\Video Samples\test_temp\test_out.mkv"
C:\Users\frank\Daten\Misc\Video Samples\test_temp\test.vpy: Invalid data found when processing input
import os
import sys
ScriptPath = 'C:/Users/frank/Daten/Projekte/VB/staxrip/bin/Apps/Plugins/VS/Scripts'
sys.path.append(os.path.abspath(ScriptPath))
import vapoursynth as vs
core = vs.get_core()
core.std.LoadPlugin(r"C:\Users\frank\Daten\Projekte\VB\staxrip\bin\Apps\Plugins\vs\vslsmashsource\vslsmashsource.dll")
clip = core.lsmas.LibavSMASHSource(r"C:\Users\frank\Daten\Misc\Video Samples\test.mp4")
clip.set_output()
General
CompleteName             : C:\Users\frank\Daten\Misc\Video Samples\test.mp4
Format/String            : MPEG-4
Format_Profile           : Base Media
CodecID/String           : isom (isom/iso2/avc1/mp41)
FileSize/String          : 60.9 MiB
Duration/String          : 2 min 49 s
OverallBitRate/String    : 3 007 kb/s
Encoded_Application/String: Lavf57.19.100
Video
ID/String                : 1
Format/String            : AVC
Format/Info              : Advanced Video Codec
Format_Profile           : High@L4
Format_Settings          : CABAC / 3 Ref Frames
Format_Settings_CABAC/String: Yes
Format_Settings_RefFrames/String: 3 frames
CodecID                  : avc1
CodecID/Info             : Advanced Video Coding
BitRate/String           : 2 876 kb/s
Width/String             : 1 920 pixels
Height/String            : 1 080 pixels
DisplayAspectRatio/String: 16:9
FrameRate_Mode/String    : Variable
FrameRate/String         : 23.976 (24000/1001) FPS
FrameRate_Minimum/String : 23.974 FPS
FrameRate_Maximum/String : 23.981 FPS
ColorSpace               : YUV
ChromaSubsampling/String : 4:2:0
BitDepth/String          : 8 bits
ScanType/String          : Progressive
Bits-(Pixel*Frame)       : 0.058
StreamSize/String        : 58.2 MiB (96%)
colour_range             : Limited
colour_primaries         : BT.709
transfer_characteristics : BT.709
matrix_coefficients      : BT.709
Codec configuration box  : avcC
Audio
ID/String                : 2
Format/String            : AAC LC
Format/Info              : Advanced Audio Codec Low Complexity
CodecID                  : mp4a-40-2
BitRate_Mode/String      : Constant
BitRate/String           : 126 kb/s
Channel(s)/String        : 2 channels
ChannelLayout            : L R
SamplingRate/String      : 44.1 kHz
FrameRate/String         : 43.066 FPS (1024 SPF)
Compression_Mode/String  : Lossy
StreamSize/String        : 2.54 MiB (4%)
Default/String           : Yes
AlternateGroup/String    : 1
