Old 12th May 2019, 16:25   #61  |  Link
stax76
stax76's Avatar
Same error using ffms2 as src filter.
edit:
I missed using : -f vapoursynth
Old 12th May 2019, 16:45   #62  |  Link
stax76
stax76's Avatar
The built works very well and it's really helpful being able to open vpy with ffmpeg.
I wonder if mpv can open vpy too? I tried it a few days before but couldn't get it working.
Old 14th May 2019, 20:19   #63  |  Link
stax76
stax76's Avatar
@Wolfberry
I would like to suggest using --enable-libmp3lame in the next built.
Old 15th May 2019, 16:55   #64  |  Link
stax76
stax76's Avatar
@Wolfberry
Thanks for the new built. There is an issue, I'm not able to use this command line:
ffmpeg.exe -f vapoursynth -i C:\test.vpy -c:v libx265 -an -y -hide_banner C:\test.mkv
The problem seem to be arbitrary because sometimes it works and it happens only with x265 and not with x264.
Old 16th May 2019, 19:59   #65  |  Link
Revan654
Revan654's Avatar
@Wolfberry
from what I read there been some changes to x265 ffmpeg encoder.
If all else fails you could just do this:
"C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" -y "to\your\VS\Script.vpy" - | "x265.exe" [Options] -
I know it defeats the purpose of using ffmpeg internal encoder, but cmd line might help come up with proper cmdline.
I know this code works with x265, NVEnc, and mpv player.
Revan654 is offline   Reply With Quote
Old 16th May 2019, 20:02   #66  |  Link
Revan654
Revan654's Avatar
Unless something has changed, It's Not possible. I've tried to get it to work last year, Every single test failed. It would just refuse to open file or just crash the program.
However using the following line will play back the vpy script in mpv, It will lack the ability to properly scrub the file forward or back.
"C:\Program Files (x86)\VapourSynth\core64\vspipe.exe" -y "to\your\VS\Script.vpy" - | "mpv.exe" [Options] -
This was the basic set to the script:
import os
import sys
ScriptPath = 'Path/to/your/VS/Scripts/Filters'
sys.path.append(os.path.abspath(ScriptPath))
import vapoursynth as vs
core = vs.get_core()
core.std.LoadPlugin(r"SourceFilterHere|I'm Using DGIndexNV")
clip = core.dgdecodenv.DGSource(r"C:\to\your\Source\File.mkv")
clip.set_output()
However Potplayer can open vpy script and play it back.
Old 18th May 2019, 03:34   #67  |  Link
_Al_
clip could be output to mpv player right from script itself using output() and using subprocess modul. VSEdit might need clip.set_output() at the end.
from vapoursynth import core
import subprocess
clip = core.avisource.AVISource(r'C:\video.avi')
#import shutil
#mpv = shutil.which('mpv')
mpv = r'C:\tools\mpv.exe'
mpv_cmd = [mpv, '-']
process = subprocess.Popen(mpv_cmd, stdin=subprocess.PIPE)
file_handle=process.stdin
clip.output(file_handle, y4m = True)
process.communicate()
_Al_ is offline   Reply With Quote
Old 19th May 2019, 08:44   #68  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
Yes, I am able to reproduce it.
I adjusted the LAVF patches for x265 and it seems to be better, can you confirm?
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 19th May 2019, 13:13   #69  |  Link
stax76
stax76's Avatar
@Wolfberry
It's either fixed or improved, didn't happen in a couple of test runs, much appreciated, thanks.
Old 23rd May 2019, 21:16   #70  |  Link
unix
I tried to use Wolfberry FFmpeg Builds but I couldn't encode, did I missed something?
vpy script:
import os
import sys
src = core.ffms2.Source(source='dcr.mkv').std.AssumeFPS(fpsnum=24000,fpsden=1001).std.Trim(60,75)
src.set_output()
ffmpeg.exe -f vapoursynth -i TEST.vpy -c:v libx264 -an test1.mkv
unix is offline   Reply With Quote
Old 23rd May 2019, 22:19   #71  |  Link
stax76
stax76's Avatar
Try with the most simple script, meaning only the source filter, what does ffmpeg output?
Old 24th May 2019, 07:59   #72  |  Link
unix
But my script so simple
src = core.ffms2.Source(source='drc.mkv')
src.set_output()
Still I didn't get any output file!!!
Old 24th May 2019, 12:26   #73  |  Link
stax76
stax76's Avatar
There is no output so it could be the same problem I had before. Since you are using relative paths, are you sure all files can be found? Does it work with a real input file (mkv)?
Old 24th May 2019, 17:19   #74  |  Link
unix
All files are in the same folder which is VapourSynth64Portable
src = core.ffms2.Source(source='C:/Users//Desktop/VapourSynth64Portable/cdl.mkv')
src.set_output()
I tried with avi as well, but there's no output, also I used ffplay but nothing happens!
ffplay.exe -f vapoursynth -i test.vpy
Old 24th May 2019, 17:43   #75  |  Link
jackoneill
unsigned int
jackoneill's Avatar
Originally Posted by Wolfberry View Post
VapourSynth and VSScript are now statically linked into ffmpeg.
By the way, did you need to patch VapourSynth to accomplish this?
Buy me a "coffee" and/or hire me to write code!
jackoneill is offline   Reply With Quote
Old 24th May 2019, 18:22   #76  |  Link
ChaosKing
I think VS needs to be installed. ffmpeg & ffplay are working fine.
Tested with: ffplay.exe -f vapoursynth -i 'D:\test.vpy'
Old 24th May 2019, 22:50   #77  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
I use gendef and dlltool to generate delay-import libraries from official VapourSynth and Python dlls, so no patch is needed.
What I mean by static is that ffmpeg will not require extra dlls at startup.
Portable VapourSynth should also works since this is the only one I tested.
I just extracted VapourSynth64-Portable-R45, python-3.7.3-embed-amd64 and ffmpeg to the same directory and use that as a testing environment.
Monochrome Anomaly
Old 25th May 2019, 08:40   #78  |  Link
unix
Thank you Wolfberry.
By the way using direct vapoursynth method is it faster than vspipe to ffmpeg, or it depends on the filters that using?
Old 28th May 2019, 08:24   #79  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
Usually the native vapoursynth demuxer is faster than piping, but different implementation of the demuxer can have a impact on speed, see post #47 and #48 for details.
Monochrome Anomaly
Old 31st May 2019, 05:39   #80  |  Link
qyot27
qyot27's Avatar
Since I've now hammered out the kinks (hopefully), I'm able to answer this based on actually cross-compiling VapourSynth instead of using gendef on Windows dlls.
Not really. Most of the weirdness is in how to handle Python (it still needs to be gendeffed, et al.). VapourSynth itself has only three issues at play here:
  • src/vsscript/vsscript.cpp has an include of Windows.h that trips up cross-compiles due to case sensitivity.
  • No matter what I tried, I couldn't force NASM to recognize the multilib MinGW-w64 environment and actually compile 32-bit objects, so I have to force-override the Makefile to compile the correct object format.
  • The Requires.private invocation of python in vapoursynth-script.pc screws up FFmpeg's configure tests; Libs.private does work as expected.
  • A possible fourth issue is whether there's a case for including -lstdc++ in the .pc file's Libs(.private) stuff (it's not a problem when a bunch of other external libraries are enabled, since one/several of them pull in -lstdc++, but a 'simple' build of FFmpeg with VapourSynth and AviSynth as the only enabled external libraries fails unless --extra-libs is used to provide libstdc++ as detailed way earlier in this thread). Or whether a Cflags.private entry should be added for pkgconf users so -DVS_CORE_EXPORTS can be used only in the case of static linking. Essentially, this 'point' basically is just bikeshedding.
The entire process is documented here (link goes directly to the VapourSynth section of the guide):
https://github.com/qyot27/mpv/blob/e...ious.txt#L4396
One distinction is that when I'd tested with using gendef to handle VapourSynth too, I could get FFmpeg to link to it, but mpv refused to link to libavformat. gendeffing only Python and then cross-compiling VapourSynth like any other library results in both FFmpeg and mpv being able to link to it (importantly, mpv being able to directly play back scripts this way).
32-bit and 64-bit FFmpeg and mpv with static VapourSynth
Said binaries include *both* VS demuxers. The upstream demuxer is still 'vapoursynth', and the other one is 'vapoursynth_alt'. It's easy to tell them apart because they return different data types as input: '-f vapoursynth' returns wrapped_avframe, '-f vapoursynth_alt' returns rawvideo. The upstream demuxer also doesn't honor relative file paths across directories (in just FFMS2? maybe in general?), while the alt demuxer does.
