Old 1st June 2016, 12:35   #24281  |  Link
Tenker
I need at the end of the conversion ONLY * .H264 file.
@jdobbs
I find your software super
and want for converting video files into one * .H264 fixed bit rate of
- 10000 kbps avg Bitrate
- and without creating the BD structure
So I need at the end of the conversion ONLY * .H264 file.
Can I edit something to achieve this?
Thank you and best regards
tenker
FOUND -> but how do I change the bit rate to 10000 kbps?
Found -> ...\BD_Rebuilder\Misc\alternate.txt
Tenker is offline   Reply With Quote
Old 1st June 2016, 15:42   #24282  |  Link
Sharc
@jdobbs
My source disc has 1 feature (37GB) and 1 Extra (5GB)
I selected "full backup" with "Use Quicker for Extras" (QUICK_EXTRAS=1 in the .ini). Nevertheless the Extra gets encoded 2-pass like the feature.
Did you change anything, or do I miss something?
Old 1st June 2016, 16:09   #24283  |  Link
omegaman7
omegaman7's Avatar
@jdobbs
I've seen that happen several times. Haven't been bothered enough to say something.
Old 1st June 2016, 16:09   #24284  |  Link
BD-RB does it's best to try and identify extras -- but it's not perfect. There's no "I'm an extra" flag anywhere on a BD disc. There are a few things it looks at -- and a 5GB threshold is one of them.
Old 1st June 2016, 16:15   #24285  |  Link
omegaman7
omegaman7's Avatar
Perhaps you could implement a way so that we can intervene. A check-mark for instance.
Certainly no rush on it here. Seems like it's been mentioned before, but due to certain complexities, it was more a back burner idea
Old 1st June 2016, 16:17   #24286  |  Link
gamete
@jdobbs why can not you reply to me ?
gamete is offline   Reply With Quote
Old 1st June 2016, 17:19   #24287  |  Link
Sharc
I understand. In my case it is probably due to the 5GB Extra, which is indeed quite big for an Extra.
P.S.
The improved CRF prediction works very well, and so does the kick-in for a 2nd pass when the CRF encode - in very rare cases - happens to exceed the target size. Very nice!
Old 1st June 2016, 17:40   #24288  |  Link
I replied several times -- but it seemed that every time I replied it resulted in you asking two more questions. I gave up. You have 11 posts of questions in the last two pages of his thread. In fact, this is the third time you've asked this question.
Old 1st June 2016, 17:46   #24289  |  Link
gamete
I asked you if my setting in FFDshow are correct
I have not received a reply
Thanks anyway
http://forum.doom9.org/showpost.php?...ostcount=24266
Old 1st June 2016, 17:48   #24290  |  Link
Thanks anyway
And that was a follow-up to about 5 or 6 earlier questions -- to all of which I had responded.
Old 1st June 2016, 17:54   #24291  |  Link
gamete
You have reply at this post
http://forum.doom9.org/showthread.ph...66#post1768966
In this post i asked you if the setting of FFDSHOW is correct
Old 1st June 2016, 22:59   #24293  |  Link
gonca
@Lathe
(I always leave the keep HD audio checked for Blu-rays anyway)
deselect this option and see if it speeds things up
Old 2nd June 2016, 01:08   #24294  |  Link
Lathe
Lathe's Avatar
@Lathe
Hmmm, interesting idea... I might try that. Thanks!
Old 2nd June 2016, 04:36   #24295  |  Link
@Lathe
I don't see why it would?
Old 2nd June 2016, 05:29   #24296  |  Link
MrVideo
MrVideo's Avatar
I do not see how it would either. The audio is just copied (when not doing DTS-HD -> AC3), the video is what is getting recoded.
Old 2nd June 2016, 06:56   #24297  |  Link
gamete
Have i set correctly FFDSHOW ?
http://www.imagestime.com/imageshow....itmap.jpg.html
for win7 i must set VC1 "libavcodec" like a mpeg2 or wm9 ?
Old 2nd June 2016, 09:26   #24298  |  Link
varekai
I think your good to go! Your settings looks just fine.
Time to let BDRB do it's magic.
Here's images from my setup in Win7
http://imgur.com/a/7qbJc
Old 2nd June 2016, 10:47   #24299  |  Link
gonca
Keeping the HD Audio leaves less space for video, and BD_RB might be using a higher quality setting (slower) for the encoding
Old 2nd June 2016, 10:52   #24300  |  Link
gamete
But jdobbs write
"If you installed HAALI/FFDSHOW< Setup VC-1 decoding in the same way you did MPEG-2 in step 2B. For Vista or Windows 7+ using "Video Decoder Configuration" -- select "wmv9".
So for win7 i must set VC1 "libavcodec" like a mpeg2 or wm9 ?
THANKS
