Old 21st December 2008, 13:38   #21  |  Link
magnop
I'm working on something and will post the results later.
Windows executable (gui) that will let you:
* fix wrong clpi info generated by tsmuxer
* convert to 8.3 filenames
* generate avchd folder, containing multiple tracks (as kaid script does)
Dean
Great!
magnop is offline   Reply With Quote
Old 21st December 2008, 20:07   #22  |  Link
b66pak
b66pak's Avatar
i can't wait to see a win solution!
_
b66pak is offline   Reply With Quote
Old 21st December 2008, 22:32   #23  |  Link
n0mag!c
use 'r'
n0mag!c's Avatar
I'm working on ... Windows executable (gui) that will let you:
This would be great, especially if it will support up to about 50 titles, including splitted titles by TsMuxer.
n0mag!c is offline   Reply With Quote
Old 22nd December 2008, 15:07   #24  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
A little update...
I'm ready with the 'command-line' portion of the program.
So far, so good. It has a limit of up-to 999 .m2ts/.cpli/.mpls segments.
Something interesting happened...
I have some files encoded at AVC High@5.1 profile, which wouldn't play until now.
I made a compilation of 4 tracks:
1: 1920x1080p
2: 1280x720p
3: 1920x1080i (High@5.1)
4: 1280x576p
They all show and play (consecutively), show subtitles and everything. (Of course track#4 shows green bars )
Will post again later.
Dean
GUI Features:
* Select multiple .mkv files to add to AVCHD-multi structure (.srt subtites and embeded ones will be added)
* Select multiple AVCHD/Blu-Ray-Disk folders to add to AVCHD-multi structure
* Select folder, containing multiple AVCHD/Blu-Ray compliant folders:
--- GUI is searching for BMVD\index.bmv*, so AVCHD name is not mandatory, nor 8.3 naming
--- i.e. you may name the folders: My_birthday, test_movie, presentation, hdtvtest, etc...
--- it is important that they have BDMV subfolder and all playlists/clipinfo-files inside
* All clip-inf files are fixed
* GUI processes all selected files and compiles them in a single AVCHD/Blu-Ray format folder,
--- providing Track# selection in player menu
--- overall .m2ts files count should not exceed 1000
Old 23rd December 2008, 01:03   #25  |  Link
~bT~
н∂-ƒαиαтι¢
^ dude, that is awesome! i cant wait
~bT~ is offline   Reply With Quote
Old 23rd December 2008, 18:29   #26  |  Link
deank
deank's Avatar
:) a present for you
Here is the initial version:
The thread of multiAVCHD is http://forum.doom9.org/showthread.ph...44#post1228044.
Please post your questions, comments and requests there.
Old 23rd December 2008, 18:41   #27  |  Link
zoner
Thanks ALOT! Exactly what i needed
I just got 2 questions: 1. What the current beta can do?
2. Why is it 112MB? :S
EDIT: The torrent doesn't seem to work, dont know why...
zoner is offline   Reply With Quote
Old 23rd December 2008, 21:07   #28  |  Link
deank
deank's Avatar
Request
If someone could test the program with a stand-alone BD player and share their experience it would be great.
Thanks beforehand.
Dean
Old 23rd December 2008, 21:36   #29  |  Link
Deepstar
its a great Tool!
Insert a option, that you can move, instead copy the Files. If you have multiple AVCHD Folders on a USB HDD, there is no need to have the same m2ts Files twice.
Deepstar
Deepstar is offline   Reply With Quote
Old 23rd December 2008, 22:15   #30  |  Link
n0mag!c
use 'r'
n0mag!c's Avatar
Support for more than 10 titles is badly needed!
Can you add nested menu items? This will solves the problem.
Old 24th December 2008, 01:38   #31  |  Link
deank
deank's Avatar
Originally Posted by Deepstar View Post
its a great Tool!
Deepstar
It's just a beta, programmed in couple of hours... Everyone is pulling me away from the computer, so I wasn't able to do everything I wanted...
Next release will include:
copy/move option
re-arrange selected folders list (up/down/delete)
10 titles were just for a test - next version will be unlimited in titles/tracks number
Dean
Old 24th December 2008, 06:33   #32  |  Link
Krawhitham
Tested on 6 episodes
Page one works (1-5)
Page two (6-10) all link to episode #1
Krawhitham is offline   Reply With Quote
Old 24th December 2008, 11:20   #33  |  Link
deank
deank's Avatar
Are you sure about this?
While playing a title (from 1 to 5) can you select directly title 6 from your player's navigation menu?
The default for all titles is 1, so all 10 point to #1. If you correctly loaded 6 folders, then title 6 should point to folder 6, not 1.
What player did you test it on?
Dean
Old 24th December 2008, 12:53   #34  |  Link
zoner
Something is wierd i loaded 3 eps named 1 ,2 ,3 and in another case a b & c
and in each time ep2 was 1 on the menu, ep3 was 2 on the menu and ep1 was 3 on the menu.
this is correct for both folder labels, to make it in order i had to hexedit the mpls files.
how does your GUI determines the order of the files?
Old 24th December 2008, 13:36   #35  |  Link
deank
deank's Avatar
Do you add folders one by one, or you select a folder that contains these 3 subfolders?
If folders are added one by one - no sorting is performed.
If you select a folder, that contains other AVCHD folders - their order is shown in the MAIN tab of the program.
Old 24th December 2008, 15:14   #36  |  Link
deank
deank's Avatar
Quick update...
I uploaded a new version (EXE only)...
See it in the previous post with the screenshot..
Added up/down/delete/clear buttons to arrange folder list before creating multiavchd folder.
For now... MKV files are imported, but SKIPPED while processing... Will add functionality later.
Executable only (for updating purposes): multiavchd.exe
Old 24th December 2008, 15:33   #37  |  Link
zoner
Well, i just tried the new update and i sorted the same folder as a, b & c
but somehow its still gets it wrong i dont know why...
so i always finding b on 1 slot on the menu, c on #2 on the menu and a on #3 slot on the menu
Old 24th December 2008, 16:20   #38  |  Link
musky5789
how to change your menu
great prog mate,
Theres just one thing that needs to be added,
how can i put my custom menus ive made with scenarist?
I have replaced the mts files, and the menu comes up with my menu, but the buttons are not there
musky5789 is offline   Reply With Quote
Old 24th December 2008, 17:31   #39  |  Link
deank
deank's Avatar
@zoner: I just uploaded the fixed exe... the previous update was for gui buttons and stuff.. not fixing wrong clips...
@musky5789:
It is not that easy... replacing .mts files is the easiest step.
movieobj.bdm contains little programs, that tell your player what to do with all playlists/videos/etc...
without proper changes to movieobj.bdm your menus won't come up the way you want.
for now you'll be stuck with my menu
later i will see what could be done.
Old 24th December 2008, 18:17   #40  |  Link
Krawhitham
Dean
Cyberlink Power Dvd
Buttons 1-5 launches titles 1-5 (EP 1-5)
Button 6 launches title 7 (ep1)
Button 7 launches title 7 (ep1)
Button 8 launches title 8 (ep1)
Button 9 launches title 9 (ep1)
Button 10 launches title 10 (ep1)
If I select to goto title 6 it plays title 7 plus when title 5 is finished title 7 starts
avchd, menu, mkv, ps3, tsmuxer
