26th January 2013, 18:40 | #7583 | Link |
Hello,
how can I get rid of the grey submenu in slide mode (Watch, learn, play enjoy) in the main menu? Not just the text (I know where to erase this) but the grey menu with frame. Thanks a lot. Kind regards QUEENFAN
Bye QUEENFAN Last edited by QUEENFAN; 26th January 2013 at 18:42. |
27th January 2013, 14:29 | #7584 | Link |
Build 771 - DownloadInFile fWrite: (RT) The andle is invalid. Line 132
Guys,
I recently got the above error on my 4.1 Build 770 install. Been working fine and nothing I've installed of late that I can think of. It does it when MultiBOOT.exe runs and then checks for a newer version. It then continues to give the error when amending a Project in anyway. I ran MultiUpdate manually and this updated to 4.1 Build 771. Once the updtae finishes, it runs the software without error. HOWEVER, if I run via MultiBOOT.exe as normal, the error still happens and editing doesn't work. Yet, if I run via MultiUPDATE (no update needed now!) it works fine and I can amend my Projects? Any ideas? Steve. Last edited by Griffith400; 27th January 2013 at 22:33. |
27th January 2013, 22:44 | #7585 | Link |
Hi, I would just like to ask if anyone has ever tried making a compilation with files, folders etc they are not allowed to access due to needing administrator access? I am having a problem with the compilation hanging at the 'renaming to FAT compatible filenames' part and I wonder if that could happen? Thanks.
28th January 2013, 00:51 | #7586 | Link | |
@Griffith400
Hi! Quote:
28th January 2013, 22:28 | #7587 | Link |
Hardly the fastest way to start the program while it runs off and checks for updates, downloads and then installs? Besides, that's what Dean's program tells you to start it with!
Was looking for a Linda more helpful answer to the problem to be honest. Cheers, Steve. |
29th January 2013, 11:50 | #7588 | Link |
Griffith, I had that problem a couple of years ago. It was with a differrent build but I think it fixed itself just by uninstall/reinstalling mAVCHD.
but it may be that a newer build was released and that solved it. Can't be sure now. |
31st January 2013, 04:14 | #7590 | Link |
I am authoring AVCHD on DVD-R media.
Can some one please confirm: Two folders BDMV and AVCHDTN created by multiAVCHD need to be placed/burn in DVD-R Root directory. "AVCHD Strict" needs to be checked in order to create DVD-R playable on most BD players. |
31st January 2013, 17:44 | #7591 | Link | |
Blu-ray has BDMV and CERTIFICATE folders only. I believe AVCHD has only BDMV. I have never kept the AVCHDTN folder or any other folders created by multiAVCHD. I would suggest testing a few different cases with DVD+RW for compatibility. |
1st February 2013, 12:31 | #7593 | Link |
I don't know. If no, you could maybe try with BDRebuilder : it can re-encode movies to fit a certain disc size, but I don't know if you can apply it to only one title and untouch others.
If yes, and if you need first to make authoring with MultiAVCHD, you can make this authoring without re-encoding and then re-encode one of the titles with BDRebuilder. Otherwise, you will have to calculate the bitrate needed to fit the disc and encode it with before opening it in MultiAVCHD. |
1st February 2013, 12:35 | #7594 | Link | |
I believe it was only useful for old Panasonic players which didn't support "out-of-mux" menus. Last edited by Music Fan; 1st February 2013 at 12:38. |
3rd February 2013, 01:07 | #7596 | Link | |
Elit Amans
Thanks.. will look into it.
3rd February 2013, 02:50 | #7597 | Link |
Hey guys, first time ever posting here so thanks for any help that may be given. I've read about the issues when trying to add audio with a static background for the menu page and how only BD and I believe AVCHD formats are capable of doing this in MultiAVCHD. My issue is I am creating a BD Disc format and I still can't get my audio to play on the main menu. I've used mp3 and ac3 audio formats to test. When I play the file from the BDMV folder on my computer the music plays, but when I burn to a blu ray disc and play in my PS3 or other Blu Ray player, the music doesn't play. Just wondering if anyone else has experienced this issue and what solutions there may be. Thanks for any help, it is appreciated.
9th February 2013, 01:35 | #7598 | Link |
Add chapters to MultiAVCHD-created HD-DVDs?
Does anyone know of a way to add chapters to the less-than-fully-compliant HD-DVDs that are created by MultiAVCHD?
13th February 2013, 06:23 | #7599 | Link |
Menus/Promo
Hey guys this is an awesome program and I would just like to raise a couple of questions about menus.
1) In the instructional thread there is a custom looking menu of Valkryie. I was wondering how, if I was able to make a background image like this, do I map the regions of the screen to buttons? 2) Is there any way to have the title menu be the top menu or first menu upon starting? 3) I would like to play a DTS/THX intro before both of my features. Is there any way to do this within MULTIAVCHD or would the files have to be re-encoded with the promos? Thanks! |
21st February 2013, 20:47 | #7600 | Link |
There seems to be a problem with subtitles on my Windows 8 Pro x64 (8GB RAM) as well as Win XP SP3 system. I get the following error:
-!!!subtitles may be incomplete! -!!! Error converting subtitles (java?) The newest JAVA is installed on my computer. Does anybody have a clue? Thanks a lot in advance for your help.
Bye QUEENFAN |
