Old 12th March 2014, 22:20   #7801  |  Link
detroit1
I was trying to put an m2ts file into multiavchd and it was not going to keep the LPCM. It took a long time and when it finished, the file had no audio; just video
here is what it was saying in the multiavchd
[17:07:04] Detected video: ID#4113:V_MPEG-2 1920x1080, fps=29.970
[17:07:04] Encoding [LPCM] audio to AC3...
[17:07:04] eac3to refused to convert audio!
[17:07:04] Trying to demux audio...
[17:18:46] Parsing to NicAudio/aften (avisynth)...
[17:18:48] DELETE EXCEPTION: Should not touch file! (c:\multiavchd\_temp\multitemp-20140312\beating heart today show audio.m2ts.t2.ac3.mpa)
[17:18:48] Encoding to AC3 (second try)...
[17:18:48] All tries to demux/encode audio failed!
[17:18:48] Total of 2 tracks found in this file.
[17:18:48] Creating clip and playlist info (tsMuxeR)...
detroit1 is offline   Reply With Quote
Old 13th March 2014, 00:43   #7802  |  Link
detroit1
I also notice now that either multiavchd will pass thru the lpcm or it will fail to demux and when it finishes, the file will have no audio, just video
so now it is all or nothing.
I am using the latest version
Old 13th March 2014, 08:27   #7803  |  Link
von Suppé
von Suppé's Avatar
So there's no video with pcm at all that MultiAVCHD has demuxed and transcoded to AC3?
Old 13th March 2014, 11:47   #7804  |  Link
mariner
Originally Posted by DoctorM View Post
A heads up to anyone using the subtitle creator in multiAVCHD (and that goes for easySUP and goSUP), the default font Trebuchet MS doesn't support music notes (♪) and probably other symbols.
You may want to go with Arial Bold or Tahoma instead.
Really?
mariner is offline   Reply With Quote
Old 13th March 2014, 15:05   #7805  |  Link
detroit1
the last couple files I have tried with LPCM that failed ended up with no audio on the file at all. the eac failed to convert
then the files that worked passed thru and ended up with lpcm
Old 13th March 2014, 19:09   #7806  |  Link
detroit1
Ok I tried another file with LPCM 5.1 that converted to ac3
here is the before mediainfo
Format : BDAV
Format/Info : Blu-ray Video
File size : 600 MiB
Duration : 3mn 53s
Overall bit rate mode : Variable
Overall bit rate : 21.5 Mbps
Maximum Overall bit rate : 35.5 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=24
Codec ID : 27
Duration : 3mn 53s
Bit rate mode : Variable
Bit rate : 13.8 Mbps
Maximum bit rate : 20.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.221
Stream size : 383 MiB (64%)
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Menu ID : 1 (0x1)
Format : PCM
Format settings, Endianness : Big
Format settings, Sign : Signed
Muxing mode : Blu-ray
Codec ID : 128
Duration : 3mn 53s
Bit rate mode : Constant
Bit rate : 6 912 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Stream size : 193 MiB (32%)
Old 13th March 2014, 19:10   #7807  |  Link
detroit1
and here is the after media info after MULTIAVCHD. It is now only in ac3
File size : 405 MiB
Duration : 3mn 53s
Overall bit rate : 14.6 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Codec ID : 27
Duration : 3mn 53s
Bit rate : 13.6 Mbps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.219
Stream size : 378 MiB (93%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : 129
Duration : 3mn 53s
Bit rate : 384 Kbps
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 10.7 MiB (3%)
Old 14th March 2014, 05:30   #7808  |  Link
von Suppé
von Suppé's Avatar
I wonder if that is because the audiostream could not be demuxed.
I don't know what the problem is (if any) with the last file you posted. Both MultiAVCHD and the older tsMuxer it uses, have issues. I think a lot of people would like the creator of the tool to update it, but as I understand the forums didn't hear from him for a long time. Let's hope he is okay.
With media that don't work I'm afraid you have to do things manually. This can be quite some work though.
Old 14th March 2014, 11:11   #7809  |  Link
detroit1
keep in mind that some files pass thru the LPCM 5.1 fine and others don't. I can't figure out any explanation for this
I have mostly 29.97 frame rate files . This doesn't make any sense
Old 15th March 2014, 07:24   #7810  |  Link
von Suppé
von Suppé's Avatar
Yes, things can appear quite "not logical" sometimes. Of course there is a logical reason to the issue but sometimes we just don't know.
Now this is a leap in the dark, but can't you try to replace the tsmuxer.exe in MultiAVCHD's tool folder with the most recent one? Just a thought, don't really expect it to work...
Old 15th March 2014, 11:11   #7811  |  Link
detroit1
can you explain how to replace the tsmuxer in the folder?
that sounds like a good idea
Old 15th March 2014, 12:49   #7812  |  Link
Music Fan
Just download the last TSMuxer version, drag&drop it where the old one is (C:\multiAVCHD\tools on my pc) and accept the replacement. But copy first the old one, you may need to put it there again.
Music Fan is offline   Reply With Quote
Old 15th March 2014, 16:11   #7813  |  Link
detroit1
I did replace the tsmuxer in the avchd tools but when I tried a file, it did the same thing eac refused to convert and the when it finished, the file had no audio
I tried another file with lpcm 5.1 just now and that file passe thru quickly with no problem
I thought replacing the tsmuxer was a great idea but it did not change anything
I would love to try other methods as well
Old 15th March 2014, 16:27   #7814  |  Link
Music Fan
As a last resort, I believe you can replace the problematic title (without audio or with compressed audio while you don't want the sound to be compressed) with BDedit ;
http://www.videohelp.com/tools/BDedit
I don't know how it works but I know it can do many things and you could maybe find some tutorials.
Old 16th March 2014, 07:27   #7815  |  Link
von Suppé
von Suppé's Avatar
As far as MultiAVCHD handling things automatically concerned, I'm running out of options to.
The only way for some media is do demuxing, transcoding and maybe remuxing again manually. There are great, free tools at your disposal but you have to put in some effort.
Of course in each step there will always be issues and it takes time to get the hang of things.
Old 17th March 2014, 17:53   #7816  |  Link
molntuss
Where do you adjust the placement of added subtitles in multiAVCHD?
Everything worked perfectly for me adding a set of subtitles (.srt) but when I view the blu-ray in my Oppo the subtitles are too low. I can just barely see the upper tip of the the second line. I basically need to move them up a whole line.
Apologies of this has been covered extensively. I honestly tried to search to find out about this my best but I felt like I was looking for a needle in a haystack.
Thanks in advance.
molntuss is offline   Reply With Quote
Old 17th March 2014, 19:13   #7817  |  Link
Music Fan
I never tried to create sup from srt with multiAVCHD but all I can say is that Subtitle Edit does it very well ;
http://forum.doom9.org/showthread.php?t=162721
Open your srt, chose export, Blu-ray sup, try some settings, especially bottom margin and line height, then click on export all lines and open the sup in multiAVCHD as external subtitle or mux it into ts with TSMuxer and open the ts in multiAVCHD.
Old 17th March 2014, 19:26   #7818  |  Link
von Suppé
von Suppé's Avatar
... I was looking for a needle in a haystack.
Did you take a look @ the Subtitles & Audio tab?
There you can adjust about everything for text-based subs and preview the result in a window.
Old 17th March 2014, 19:40   #7819  |  Link
molntuss
Thanks for responding.
Yeah, I might be blind, but I only see sizing and a slider for horizontal alignment... Nothing for vertical alignment. Is it possible?
EDIT: I found it. It's called Offset, right next to font size. It's default to 45 and when I set it to 100 it worked.
Old 18th March 2014, 05:48   #7820  |  Link
von Suppé
von Suppé's Avatar
A lot of tv-sets have overscan. The picture is zoomed into for a few percent and projected. At least with old analog tv's this can be quite significant.
If your tv is a modern flatscreen maybe there is this option to disable overscan and see the full picture. Also various auto "zoom" or "screenfill" functions of widescreen tv's can have a negative effect.
avchd, blu-ray hd-dvd, mkv, multiavchd, re-author
