Old 27th August 2018, 23:10   #581  |  Link
MeteorRain
結城有紀
Please disregard my last post.
I was poking around the registry and figured out this.
D:\encode\VirtualDubMod\VirtualDubMod.exe.ApplicationCompany
Please suggest one. I haven't come up with a good one yet.
So I went to check the VDM 0.1a source code, and it was there \VirtualDubMod-source_0.1a\VirtualDub.rc, VALUE "CompanyName", "Please suggest one. I haven't come up with a good one yet.\0".
Removing that line broke the context menu.
Then I went back to Google, and found this post.
Hope this helps.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 28th August 2018, 10:28   #582  |  Link
shekh
Have you seen this post? https://forum.doom9.org/showthread.p...11#post1836511
This is how I entered "openwith" association for myself on Win7.
In vdmod VersionInfo there is empty CompanyName. I don't believe this is different from not having CompanyName at all.
From what I see, adding "CompanyName" field provides extra line of information when I open "Choose program" dialog, but nothing else.
VirtualDub2
Old 28th August 2018, 21:40   #583  |  Link
MeteorRain
結城有紀
I did, and actually I spent quite a few minutes without luck. I even tried both the global config (HKCR) and local config (HKCU IIRC) and no luck.
After I found out the information above, I used a resource hacker tool to inject the CompanyName into the binaries, and immediately (without any restart or reboot of anything) it appeared on the open with list. If you don't believe me, that's fine At very least I can inject the field into the binary by myself.
By the way, just saying that I'm using Windows 10, not 7. Things might have changed since.
Projects
Old 28th August 2018, 23:42   #584  |  Link
shekh
Great, I prepared to ask you to check this, but you already did
Is the empty string "" enough for CompanyName? Otherwise I need to decide something meaningful for it
VirtualDub2
Old 29th August 2018, 02:36   #585  |  Link
MeteorRain
結城有紀
Empty string or single space does not work. A dot "." works. Still it might be better to put meaningful string like "VD2" or w/e you like.
Projects
Old 31st August 2018, 11:22   #586  |  Link
18fps
Would it be possible to add a dpx option to the Export / Image sequence... form?
18fps is offline   Reply With Quote
Old 31st August 2018, 11:36   #587  |  Link
shekh
Maybe, don't know much about dpx. Why is it needed? Is there some software which does not like tiff?
Also it is possible to setup external profile to export dpx, did you consider that?
VirtualDub2
Old 31st August 2018, 11:44   #588  |  Link
18fps
Mostly because in film it's the standard, so it's useful if you have to give back the work (to the colleagues or the laboratory) after you've modified it in VirtualDub2. How the external profile works?
Old 31st August 2018, 12:24   #589  |  Link
shekh
https://gist.github.com/shekh/c28db6...4e14fbe6c1369b
first you need to modify command line to point to actual ffmpeg.exe
then Options->External encoders->Import...
now you can use File->Export->Using external encoder...
VirtualDub2
Old 31st August 2018, 13:04   #590  |  Link
18fps
Thank you!
Old 31st August 2018, 18:37   #591  |  Link
poisondeathray
For the dpx vprof it should be -pix_fmt gbrp10le . Tested the input/output diff and it matches
You can add -start_number 0 if you want to start at zero (ffmpeg normally starts image sequence exports at "one" )
Old 10th September 2018, 08:07   #592  |  Link
GillesH
Hello,
How to open a MOV clip in an AVS script with VirtualDub2 ?
I want to test this principle WITHOUT QuickTime installed. Is it possible ?
I give below the characteristics of my MOV Clip. It is not a simple H264/MOV.
This MOV Clip opens very well directly in VirtualDub2, but I want to do the same with an AVS script.
I suppose :
LoadVirtualdubPlugin(" ? .vdplugin", " ? ")
? = "MOV Clip Source"
I tested FFMS2 in script AVS and it works fine with this MOV Clip, but the indexing principle slowed the opening of the clip.
I would just like to use the VirtualDub2 FFMPEG vdplugin(s) in an AVS script to decode this type of MOV Clip.
Here are the MOV Clip MetaData / MediaInfo
General :
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 0000.02 (qt )
Writing application : Lavf57.25.100
IsTruncated : Yes
Video :
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=13
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Thanks for your advices. Merci.
GillesH is offline   Reply With Quote
Old 10th September 2018, 09:35   #593  |  Link
Groucho2004
I'd use LAV Filters and DSS2Mod.
Groucho's Avisynth Stuff
Old 10th September 2018, 10:21   #594  |  Link
I would use L-SMASH Works (LSMASHSource.dll) as AviSynth native plugin and use LSMASHVideoSource() because MOV is an ISO Media container, and the L-SMASH splitter can use the keyframe index chunk inside the MOV file.
I see no reason why anyone would try to use a VirtualDub2 input plugin in AviSynth, I am not even sure if that is possible at all (LoadVirtualDubPlugin loads video filter plugins = *.vdf, not input plugins).
Old 10th September 2018, 10:24   #595  |  Link
Groucho2004
So would I but the indexing time seems to be an issue so I suggested DSS2 to get around that.
Old 10th September 2018, 10:52   #596  |  Link
LwLibavVideoSource creates an index file. LSMASHVideoSource does not, it uses the index inside the MOV, because MOV is an ISO Media container format.
Old 10th September 2018, 13:10   #597  |  Link
Groucho2004
Didn't know that. I should have read your post properly.
Old 10th September 2018, 14:23   #598  |  Link
StainlessS
StainlessS's Avatar
Yep, LSMASHVideoSource works great with ISO media, (in a work-in-progress function), is the first attempted source filter for any clip with below extensions.
Function IsISOFileName(String s) {
    s=RT_GetFileExtension(s)
    Return(s==".mov"||s==".mp4"||s==".m4v"||s==".3gp"||s==".3g2"||s==".mj2"||s==".dvb"||s==".dcf"||s==".m21")
Snippet
    if(!c.IsClip) {
        if(Prefer<=1) {
            If(IsISOFileName(Ext)) {
                FLGS=RT_BitSet(FLGS,0)
                c = LSMASHVideoSource(vFN) RT_DebugF("LSMASHVideoSource Succeeds:",name=myName)
                if(!SepAud) {
                    FLGS=RT_BitSet(FLGS,1)
                    try{
                        c=AudioDubEx(c,LSMASHAudioSource(vFN))
                        RT_DebugF("LSMASHAudioSource Succeeds:",name=myName)
                    } catch(msg) {
                        RT_DebugF("LSMASHAudioSource Fails:- '%s'",msg,name=myName)
EDIT: There is also a Try/Catch around above snippet.
I sometimes post sober.
Old 10th September 2018, 14:32   #599  |  Link
GillesH
Thank you for your ideas. It's very nice!
I knew these possibilities.
With LSMASHVideoSource, I have a Avisynth crash: "Avisynth: breakpoint at 0x005D0E80"
This is probably related to the type of Apple Codec.
But I find it a pity not to use techniques that are always updated, like FFMPEG.
And since VirtualDub2 uses this technique, why not use it for AVS scripts.
When you open a Clip MP4 or MOV/Apple with VirtualDub2, there is no indexing, it's OK and it's fast.
Why not use these plugins for an AVS script ? Especially the avlib-1.vdplugin which must manage the MOV Apple.
I test again FFMS2 WITHOUT indexing. But I have not done all the tests yet. FFMS2 is probably the closest to the FFMPEG decoders.
Thanks again for your advice. Merci.
Old 10th September 2018, 14:36   #600  |  Link
StainlessS
StainlessS's Avatar
Groucho, "Breakpoint", does that suggest some kind of debug version LSMash ? (EDIT: or even Avisynth)
EDIT: What versions of LSmash and Avisynth are you using ?
