26th April 2019, 10:36 | #41 | Link | |
Lost my old account :(
Sounds a bit odd that you lose a lot of detail at crf16 though (unless you are using a fast preset). Mind sharing settings and some samples? Last edited by excellentswordfight; 26th April 2019 at 10:44. |
2nd May 2019, 11:11 | #43 | Link |
The cult of personality
how much time does it take to finish your encode? I have an ATOM 2750 CPU dedicated server (yes I know it is not suited for encoding) and it is so slow. I wonder what affordable cpu I could use\buy to suit hevc 1080p encodes? any suggestions?
3rd May 2019, 09:17 | #45 | Link | |
There is very little information that suggest that Ryzen3 will do much to increase general performance in a significant way. However there are two things that are very promising for the target group on this forum. AVX-performance and probably an 16C/32T mainstream modell. Last edited by excellentswordfight; 3rd May 2019 at 09:19. |
3rd May 2019, 17:47 | #47 | Link |
In this case yes, with the improved AVX performance of Ryzen3 they should give a nice pump in price/performance over the current offering for encoding. But if money isnt a big issue, and you think that you are fine with 16threads, 9900k isnt a bad option. It will still be fast, and probably faster then ryzen3 thread for thread. But I'm pretty sure we will get an 12c/24t chip that is priced under 9900k.
17th September 2019, 13:34 | #49 | Link |
I don't wanna start new topic for small question, so I decided ask for help here.
I'm encoding 4k HDR > 1080p HDR with preset Slower, CRF 12-13 with output bitrate 16-17mbps. And my question is how much --merange and --ctu affects to quality? For example: --ctu 64 --merange 57 (2.5fps) --ctu 32 --merange 26 (2.83fps) +13% speed Avg QP is the same, output file size almost the same (428.2mb vs 428.5mb). Is it worth spending 13% speed? Ps: I have i5-9400f 6 core cpu, so just lowering --ctu don't give me boost on speed, all boost from lowering --merange. My full settings: --level-idc 51 --sar 1:1 --colorprim 9 --colormatrix 9 --transfer 16 --range limited --master-display "G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,1)" --max-cll "0,0" --hdr --hdr-opt --hrd --chromaloc 2 --repeat-headers --min-luma 0 --max-luma 1023 --no-cutree --no-sao --selective-sao 0 --no-open-gop --no-b-pyramid --no-strong-intra-smoothing --vbv-bufsize 160000 --vbv-maxrate 160000 --min-keyint 23 --keyint 240 --ipratio 1.30 --pbratio 1.20 --deblock -3:-3 --qcomp 0.65 --aq-mode 2 --aq-strength 0.8 --psy-rd 2 --psy-rdoq 2 --rd 4 --limit-refs 3 --bframes 8 --rc-lookahead 60 --subme 5 --me star --ctu 32 --merange 26 --max-merge 4 Last edited by redbtn; 17th September 2019 at 13:50. |
24th September 2019, 20:37 | #50 | Link | |
And most 4K content can wind up using 64x64 CTUs. It's probably a bigger deal at lower bitrates. |
24th September 2019, 22:13 | #51 | Link |
Derek Prestegard IRL
I found that restricting CTU does improve speed a lot and can improve sharpness with lower resolution content... BUT this sharpness improvement was only visible when doing frame by frame comparison AND it came at the cost of more blocking in motion which was significantly more visible in ordinary viewing.
My tests are always done using single pass capped VBR set up for adaptive streaming, so take that with a grain of salt, but I found leaving CTU and merange alone gave me the best results. I found preset slow to be quite tolerable in all cases. |
25th September 2019, 06:01 | #52 | Link |
Pig on the wing
I would definitely use CTU 64 at 1080p and above, also the new HME method to improve the search range with a smaller impact on performance. At 1080p or higher resolutions, CTU 64 should already cause enough work for the encoder to utilize the CPU much better than at 720p or lower so there should be no need to go to CTU 32.
27th September 2019, 02:38 | #53 | Link | |
Thank you all for response.
Or I need lower merange like 32 for compensate impact HME on speed? I still don't understand actually how HME works and better way to use it. Last edited by redbtn; 27th September 2019 at 03:33. |
27th September 2019, 03:46 | #54 | Link | |
You then scale the motion vector from the 1/4th resolution, and search around it at full resolution. |
27th September 2019, 04:57 | #55 | Link | |
Pig on the wing
Although I don't know which way it works -- from full to low resolution or the other way around. This description, http://homepages.inf.ed.ac.uk/rbf/CV...stimation.html , shows level 0 as one with the full resolution. Then the description of the patch has this information: This patch does the following: 1) Perform level-0 ME 2) Use the MVs as predictor for next level ME 3) Restrict full-search within a range when HME is enabled In these cases, it would be really nice to have a clear explanation in the docs
27th September 2019, 10:57 | #56 | Link | |
I'm worried about this http://forum.doom9.org/showthread.php?p=1881016 Is it relevant to the option --refine-mv which is changed to 1 by default for now? I've done some tests: --merange 57 --no-hme 2.21fps --merange 57 --hme umh, umh, star 1.74 fps --merange 40 --hme umh, umh, star 1.90 fps --merange 32 --hme umh, umh, star 1.96 fps --merange 26 --hme umh, umh, star 2.04 fps So, 27% between HME off and HME on with same merange. Well, the question is what is better, --merange 57 --no-hme or --merange 26 --hme, cuz defference in speed between them not so much Last edited by redbtn; 27th September 2019 at 11:25. |
27th September 2019, 12:09 | #57 | Link |
Pig on the wing
In theory, HME is higher quality even if you use merange 26 (because the effective merange is much higher than that). But if you need to know for sure, you need to test. It could well be that in a normal live action video, you can't tell the difference between the two.
EDIT: the message in that link is one reason why I would like to see the devs explain things a bit, like what kind of material they have tested etc.
30th September 2019, 18:54 | #58 | Link | |
My gut is a smaller range with HME is probably optimal at fixed encoding time, but it'll be somewhat content dependent. HME is probably more useful to improve perf @ quality than anything else. |
30th September 2019, 20:04 | #59 | Link | ||
I ask cuz my speed for now is 1-1.1 fps and i don't wanna go much lower than 1.0 fps I'll do some tests with PSNR and SSIM tomorrow. Last edited by redbtn; 30th September 2019 at 20:13. |
handbrake, hevc, x265 |
