Old 12th January 2020, 20:50   #3681  |  Link
outhud
Where should Vapoursynth plugins (.so) be placed by default on Linux (Ubuntu) so that they are auto-loaded?
Is there a way to print the autoload folder?
I've tried /usr/local/lib/ and /usr/lib/x86_64-linux-gnu/vapoursynth/ but it seems the modules are not being found.
outhud is offline   Reply With Quote
Old 12th January 2020, 20:56   #3682  |  Link
Richard1485
Originally Posted by PlazzTT View Post
I installed cython through pip.
Did you install it with pip3?
pip3 install cython
Old 12th January 2020, 21:02   #3683  |  Link
Are_
http://www.vapoursynth.com/doc/autoloading.html
Most probably in /usr/local/lib/vapoursynth in your case.
Are_ is offline   Reply With Quote
Old 14th January 2020, 14:46   #3684  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Originally Posted by Myrsloik View Post
Only trim, splice and raw pcm output from vspipe is planned for the first test version. There's however one little problem...
All existing audio sources suck so I'll probably have to improve FFMS2 first.
Feel free to start implementing audio plugins using the doodle1 branch. The API is conceptually stable (but tweaks will definitely be made).
Audio update:
A a best but slow audio source has been created so that's no longer a major problem (will still get some usefulness improvements over time).
Testing and debugging everything else is however taking longer than expected but audio will be fully supported by AVFS and VFW as well from the start and vspipe will be able to output wave64 headers.
Old 14th January 2020, 17:07   #3685  |  Link
Richard1485
^ Excellent news! Down the line, I hope that it might be possible to have an equivalent to AviSynth's Dissolve(), which affects video and audio.
Old 18th January 2020, 12:43   #3686  |  Link
stax76
stax76's Avatar
I'm not sure what's the focus of this thread because my question is about vs host application development.
There is a weird exception happening here:
    case WM_DESTROY:
        DiscardGraphicsResources();
        SafeRelease(&g_D2D_Factory);
        g_vsapi->freeNode(g_vsnode);
        vsscript_freeScript(g_vsscript);
        vsscript_finalize();
        PostQuitMessage(0);
        return 0;
Exception thrown at 0x00007FFAFC5B448D (vapoursynth.cp37-win_amd64.pyd) in VapourSynth Direct2D Rendering.exe: 0xC0000005: Access violation writing location 0x0000000000000000.
Weird thing is it crashes only inside WM_DESTROY and not when this code is executed before WM_DESTROY !
How can this issue be debugged?
Old 18th January 2020, 12:54   #3687  |  Link
Myrsloik
Myrsloik's Avatar
    case WM_DESTROY:
        PostQuitMessage(0);
        return 0;
It's with a trivial script (BlankClip only)?
Are there any restrictions on what you're allowed to do when handling a WM_DESTROY message? If not then I'd simply see what the call stack is in a debugger. Maybe there's a hint in there.
Old 18th January 2020, 13:06   #3688  |  Link
stax76
stax76's Avatar
I don't have debug symbols so on my side call stack don't help.
vapoursynth.cp37-win_amd64.pyd!00007ffb10a9448d()
vapoursynth.cp37-win_amd64.pyd!00007ffb10a97529()
vsscript.dll!00007ffb4d0a25c1()
VapourSynth Direct2D Rendering.exe!WndProc(HWND__ * hWnd, unsigned int message, unsigned __int64 wParam, __int64 lParam) Line 197
	at D:\Projekte\CPP\VapourSynth Direct2D Rendering\main.cpp(197)
[External Code]
VapourSynth Direct2D Rendering.exe!WndProc(HWND__ * hWnd, unsigned int message, unsigned __int64 wParam, __int64 lParam) Line 244
	at D:\Projekte\CPP\VapourSynth Direct2D Rendering\main.cpp(244)
[External Code]
[External Code]
[External Code]
VapourSynth Direct2D Rendering.exe!wWinMain(HINSTANCE__ * hInstance, HINSTANCE__ * hPrevInstance, wchar_t * lpCmdLine, int nCmdShow) Line 164
	at D:\Projekte\CPP\VapourSynth Direct2D Rendering\main.cpp(164)
[External Code]
I can try to compile VS to get debug symbols or maybe you can have a look if I upload the source code.
The script is very simple and works in any other application.
import os, sys
import vapoursynth as vs
core = vs.get_core()
sys.path.append(r'D:\Projekte\VB\staxrip\bin\Apps\Plugins\VS\Scripts')
core.std.LoadPlugin(r"D:\Projekte\VB\staxrip\bin\Apps\Plugins\both\ffms2\ffms2.dll")
clip = core.ffms2.Source(r'D:\Samples\test.mkv', cachefile=r'D:\Samples\test_temp\test.ffindex')
#clip = core.std.AssumeFPS(clip, None, 25, 1)
clip = core.std.FlipVertical(clip)
if clip.format.id == vs.RGB24:
    _matrix_in_s = 'rgb'
else:
    if clip.height > 576:
        _matrix_in_s = '709'
    else:
        _matrix_in_s = '470bg'
clip = clip.resize.Bicubic(matrix_in_s = _matrix_in_s, format = vs.COMPATBGR32)
clip.set_output()
It's a simple C++ classic Win32 GUI application, I'm not a expert in that and don't know about restrictions.
Old 18th January 2020, 13:18   #3689  |  Link
Myrsloik
Myrsloik's Avatar
Send me the code and I'll take look at it then.
Btw, debug symbols for vapoursynth.dll are included in the installer (look for vapoursynth.pdb). VSScript.dll has no code of interest at all and is pointless to bother with. If anything you need to compile the python module with debug symbols which I've never done so don't ask me how.
Old 18th January 2020, 13:55   #3690  |  Link
stax76
stax76's Avatar
Thanks for the help! I hope it's easy to find and fix.
http://www.mediafire.com/file/xgfjzt..._Rendering.zip
Old 19th January 2020, 19:06   #3691  |  Link
Jukus
Is it possible to read somewhere how to do detelecine using VS? I know there is documentation http://www.vapoursynth.com/doc/plugins/vivtc.html but still nothing is clear.
Jukus is offline   Reply With Quote
Old 19th January 2020, 22:16   #3692  |  Link
Myrsloik
Myrsloik's Avatar
Still looking at your code. Still not sure why it happens.
Old 20th January 2020, 12:22   #3693  |  Link
Boulder
Pig on the wing
Boulder's Avatar
It's basically the same procedure compared to Avisynth's TFM and TDecimate. You just have to use the VapourSynth syntax. IIRC the settings are pretty much the same for a regular IVTC operation.
Old 20th January 2020, 12:48   #3694  |  Link
Jukus
I have never used AviSynth.
Or tell me an analog of this code for VS
AnimeIVTC(2, bbob=5, extbob=MC_A_bob, mode22=false, aa=0)
Old 20th January 2020, 13:01   #3695  |  Link
Boulder
Pig on the wing
Boulder's Avatar
AnimeIVTC is a custom function, it's far from a normal IVTC. I don't know if there is an alternative one in VS.
Old 20th January 2020, 13:31   #3696  |  Link
Jukus
How to make detelecine in general? I even have a poor idea of what telecine is, what scripts and their settings should do to fix it.
Old 20th January 2020, 13:48   #3697  |  Link
Boulder
Pig on the wing
Boulder's Avatar
A simple IVTC happens for example with
clp = core.vivtc.VFM(clp, order=1)
clp = core.vivtc.VDecimate(clp)
You really need to learn the syntax and do some studying. Avisynth is probably easier to start with than VS.
Old 20th January 2020, 19:16   #3698  |  Link
Jukus
Everything is much worse and more complicated.
For some reason, I can’t unload the sample.
I tried to apply this code for my case, but just got an interlaced video.
The best result is obtained in this way:
clip = haf.QTGMC(clip, Preset='Very Slow', Sharpness=0.3, FPSDivisor=2, TFF=True)
clip = core.vivtc.VDecimate(clip, cycle=5)
At the same time, many frames with blends and even there is no consistency, that is 4 good frames, the next with blend, then 8 good frames, the next with blend, about 2 frames with blends in a row.
Srestore doesn't help.
I have no more ideas on what can be done and what is happening in this video.
Reading the documentation is useless without understanding what is going on in the video. And there is nothing to read about what types of videos exist and what can be done or not done with it. Even there are several types of telecine: HardTelecine, DoubleHardTelecine and I don’t know what else.
AviSynth is Windows only, I use Linux. Maybe I should use AviSynth with WIne, I don't know.
Old 20th January 2020, 19:27   #3699  |  Link
Boulder
Pig on the wing
Boulder's Avatar
If your source is anime, I can only wish you good luck with that. They are notoriously hard, or even impossible to restore without intense manual labour.
Old 20th January 2020, 19:51   #3700  |  Link
Jukus
No, it's a low-budget film from 2001-2004.
speed, vaporware, vapoursynth
