Old 8th February 2021, 10:18   #4281  |  Link
lansing
Originally Posted by feisty2 View Post
no, it sends the collected messages TO stderr BY USING vsapi->logMessage(), read the documentation of vaporsynth's C API. any string passed to logMessage() already automatically appears in vsedit, you don't need any extra stuff.
So the chain would be like this?
collected messages -> dummy vs filter -> inside dummy vs filter -> logMessage()
Old 8th February 2021, 10:20   #4282  |  Link
feisty2
I'm Siri
feisty2's Avatar
yes,,,
If I got new ideas, will post here: https://github.com/IFeelBloated
feisty2 is offline   Reply With Quote
Old 8th February 2021, 10:31   #4283  |  Link
lansing
yes,,,
Thanks, I'll work on it.
Old 10th February 2021, 10:34   #4284  |  Link
feisty2
I'm Siri
feisty2's Avatar
@Myrsloik
should I release *frameData instantly if an exception is thrown from the arAllFramesReady branch? or should I just leave it unhandled and expect it gets deleted when getFrame() is invoked again with arError?
basically, this
try {
    if (auto& ResourceHandle = reinterpret_cast<ResourceType*&>(*frameData); activationReason == arInitial)
        ResourceHandle = new auto{ FilterInstance->AcquireResources(...) };
    else if (activationReason == arAllFramesReady) {
        auto ManagedResourceHandle = std::unique_ptr<ResourceType>{ ResourceHandle };
        auto GeneratedFrame = FilterInstance->DrawFrame(*ManagedResourceHandle, ...);
        // if DrawFrame() throws an exception, *ResourceHandle is instantly released
        // by the destructor of std::unique_ptr
        return GeneratedFrame.ReleaseOwnership();
    else if (activationReason == arError)
        delete ResourceHandle;
        // possible double-free here?
    return nullptr;
catch (RuntimeError& ErrorMessage) {
    FrameContext.RaiseError(ErrorMessage);
    return nullptr;
or this
try {
        auto GeneratedFrame = FilterInstance->DrawFrame(*ResourceHandle, ...);
        // no leak if DrawFrame() throws an exception
        // *ResourceHandle will be released later from the arError branch
    return nullptr;
    return nullptr;
Old 10th February 2021, 10:39   #4285  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
@Myrsloik
basically, this
You can't get an "exception" or error in arAllFramesReady. All frames are already successfully produced so I'm not sure what you're asking. And if there is an error arAllFramesReady won't be called, only arError, so obviously you should free the frameData there.
Old 10th February 2021, 10:49   #4286  |  Link
feisty2
I'm Siri
feisty2's Avatar
the exception is thrown from the user defined function DrawFrame() when for instance, a required frame property is missing from the input (basically any situation that involves setFilterError() in a C plugin).
Old 10th February 2021, 11:02   #4287  |  Link
feisty2
I'm Siri
feisty2's Avatar
oh I see, I think I kinda get it now, so arError indicates error getting an input frame, not error in an attempt to generate an output frame, is that right?
Old 10th February 2021, 11:22   #4288  |  Link
Myrsloik
Myrsloik's Avatar
Exactly!
Old 11th February 2021, 07:32   #4289  |  Link
lansing
I have created a dummy filter and passed in a list from the script to the filter, but I couldn't figure out the right syntax to retrieve it in C.
script
core.vsedit.Logger(["message 1", "message 2"])
dummy.c
static void VS_CC logger(VSMap* in, VSMap* out, void *userData, VSCore* core, const VSAPI* vsapi) {
    char messages[] = vsapi->propGetData(in, "name", 0, NULL);
    int i = 0;
    while (messages[i]) {
        vsapi->logMessage("WARNING", messages[i]);
        i++;
VS_EXTERNAL_API(void) VapourSynthPluginInit(VSConfigPlugin configFunc, VSRegisterFunction registerFunc, VSPlugin* plugin) {
    configFunc("com.vsedit.logger", "vsedit", "VapourSynth Logger", VAPOURSYNTH_API_VERSION, 1, plugin);
    registerFunc("Logger", "name:data[]", &logger, 0, plugin);
I couldn't get this to compile.
Old 11th February 2021, 09:06   #4290  |  Link
feisty2
I'm Siri
feisty2's Avatar
auto logger(auto in, auto, auto, auto, auto vsapi) {
    for (auto x : Range{ vsapi->propNumElements(in, "name") })
        vsapi->logMessage(VSMessageType::mtWarning, vsapi->propGetData(in, "name", x, nullptr));
Old 11th February 2021, 09:28   #4291  |  Link
feisty2
I'm Siri
feisty2's Avatar
apparently you're not very familiar with C constructs, you cannot initialize a char array from a pointer (note that string literals are of type const char[N], not const char*, an array type can decay to a pointer type, but arrays and pointers are distinct entities). it's better if you just avoid C stuff all together.
Old 11th February 2021, 09:44   #4292  |  Link
lansing
Yes C is confusing to me, it gave me a headache even trying to do simple thing like converting int to string.
Old 11th February 2021, 17:07   #4293  |  Link
lansing
I got the dummy filter printing messages now, but for some reason the logging module is not catching warnings on evaluation
import logging
class MessageAbsorber(logging.Handler):
    def __init__(self, message_container):
        logging.Handler.__init__(self)
        self.messageContainer = message_container
    def emit(self, message_record):
        self.messageContainer += [message_record.getMessage()]
WarningMessages = []
logging.captureWarnings(True)
logging.getLogger('py.warnings').addHandler(MessageAbsorber(WarningMessages))
def get_warnings():
    return WarningMessages
import vapoursynth as vs
core = vs.get_core()
core2 = vs.get_core()
core3 = vs.get_core()
clip = core.dgdecodenv.DGSource(r'video.dgi')
clip.set_output()
core.vsedit.Logger(get_warnings())
The same codes worked on PyCharm, but in vseditor, I'm getting error about the WarningMessages list still being empty. It will print if I passed in a list core.vsedit.Logger(["message1", "message2"])
Update: I think the reason for this is because vs disabled the warnings so they aren't even logged.
Old 12th February 2021, 13:20   #4294  |  Link
feisty2
I'm Siri
feisty2's Avatar
@Myrsloik
Does the flags field of the VSVideoInfo object passed to setVideoInfo() partially determine the cache mode of the output node (along with the flags argument passed to createFilter()), or is it simply ignored?
Old 12th February 2021, 13:27   #4295  |  Link
Myrsloik
Myrsloik's Avatar
@Myrsloik
It's simply ignored and is filled out with the flags passed to createFilter()
Old 18th February 2021, 03:02   #4296  |  Link
lansing
What is the correct scenario for use of setting max cache size? I have a 1080i source with QTGMC(Preset='Medium'), setting max cache size to 4000 MB will give me a "script exceeded memory limit" warning, raising it to 12,000 MB will clear the warning, but there is no difference in speed on benchmark at 41 fps.
Old 23rd February 2021, 12:29   #4297  |  Link
feisty2
I'm Siri
feisty2's Avatar
add these 2 lines
import logging
import warnings
    def __init__(self, MessageContainer):
        self.MessageContainer = MessageContainer
    def emit(self, MessageRecord):
        self.MessageContainer += [MessageRecord.getMessage()]
warnings.simplefilter('always')
# user script goes here
core.vsedit.PrintWarnings(WarningMessages)
Old 28th February 2021, 17:44   #4298  |  Link
feisty2
I'm Siri
feisty2's Avatar
@Myrsloik
could you add
const char* getPluginName(VSPlugin*);
const char* getPluginNamespace(VSPlugin*);
const char* getPluginIdentifier(VSPlugin*);
const char* getPluginFunctionArguments(VSPlugin*, const char* functionName);
to APIv3? so the instantiation of a single plugin object or plugin func object can get rid of the super expensive getPlugins() or getFunctions()
Old 8th March 2021, 20:44   #4299  |  Link
Jukus
I got some strange BD with almost 100 m2ts files and they are not in chronological order.
Is there any way to parse such a disc for VS?
Jukus is offline   Reply With Quote
Old 8th March 2021, 21:47   #4300  |  Link
ChaosKing
Maybe this mpls reader can help https://github.com/HomeOfVapourSynth...Synth-ReadMpls
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
speed, vaporware, vapoursynth
