17th September 2015, 19:02 | #1701 | Link | |
Professional Code Monkey
Definitely sounds like a 16bit bug in one filter.
17th September 2015, 19:10 | #1702 | Link |
Pig on the wing
But basically it doesn't make sense to try contrasharpening 16-bit clips?
17th September 2015, 20:06 | #1703 | Link | |
lut = [] for y in lut_range: for x in lut_range: lut.append(clamp(0, expr(x, y), vmax)) return self.core.std.Lut2(c1, c2, lut=lut, planes=planes) |
17th September 2015, 20:07 | #1704 | Link |
I'm Siri
Replace lut2 with expr
Edit: too slow Edit2: lut stuff needs to initialize before running, and that would burn your poor machine up if the bit depth is too high, basically it works fine on low bit depth clips Expr doesn't need to initialize, it executes the RPN on each pixel at runtime, it's the right tool to work around high bit depth pixel manipulations, it works even at 96 bits input (32 bits float input x3) Last edited by feisty2; 17th September 2015 at 20:26. |
18th September 2015, 05:08 | #1705 | Link |
Pig on the wing
Yes, it seems to work fine. Funny that there's at least three versions of contrasharpening out and I end up picking the wrong one
19th September 2015, 22:02 | #1707 | Link |
R28 test4. Now works with (and prefers) per user python installations. Expr has also had several big fixes (ternary operator, crashes and so on) so give it a try again. Log, pow and maybe exp is probably not working properly. Everything else should be working though so try it out.
On the positive size Expr can now have up to 26 inputs, x-z, a-w. Expr correctness and speed comparisons welcome.
20th September 2015, 02:51 | #1708 | Link |
The following script works via VSScipt, but fails when directly executed from python3.5 command.
Using Python3.5 on windows, vapoursynth git latest. Both of 32bit/64bit result in the same. Error: Code:
Traceback (most recent call last): File "Baloon.issue.vpy", line 5, in <module> last = core.std.FrameEval(last, lambda n, c=last: c) File "src\cython\vapoursynth.pyx", line 1360, in vapoursynth.Function.__call__ (build\temp.win32-3.5\Release\pyrex\vapoursynth.c:24919) vapoursynth.Error: FrameEval: Internal environment id not set. Report this function wrapper creation error. Code:
import vapoursynth as vs core = vs.get_core() last = core.lsmas.LibavSMASHSource('baloon-pops.mp4') last = core.std.FrameEval(last, lambda n, c=last: c) last.set_output() |
20th September 2015, 11:53 | #1709 | Link |
Is current git supposed to compile with gcc? I was about to give new expr a try but no luck.
Loads of: Code:
/var/tmp/portage/media-libs/vapoursynth-9999/work/vapoursynth-9999/src/core/jitasm.h:1935:11: error: expected ‘)’ before ‘const’ /var/tmp/portage/media-libs/vapoursynth-9999/work/vapoursynth-9999/src/core/jitasm.h:1935:10: error: expected ‘;’ at end of member declaration void and(const Reg8& dst, const Imm8& imm) {AppendInstr(I_AND, 0x80, E_SPECIAL, Imm8(4), RW(dst), imm);} ^ /var/tmp/portage/media-libs/vapoursynth-9999/work/vapoursynth-9999/src/core/jitasm.h:1935:28: error: expected unqualified-id before ‘const’ void and(const Reg8& dst, const Imm8& imm) {AppendInstr(I_AND, 0x80, E_SPECIAL, Imm8(4), RW(dst), imm);} ^ Last edited by Are_; 20th September 2015 at 12:00. |
20th September 2015, 12:00 | #1710 | Link | |
22nd September 2015, 21:35 | #1711 | Link |
Another test version. This one should have a fully working Expr with no bugs at all. It also fixes the issue nu774 reported that was introduced in the test versions.
This version is also compiled with some extra checks to see if any plugins trigger them. Report any that do. R28 test5
22nd September 2015, 22:14 | #1712 | Link |
Some speed comparasions:
r27 Code:
finesharp-lut Output 2001 frames in 29.26 seconds (68.38 fps) Output 2001 frames in 30.64 seconds (65.31 fps) Output 2001 frames in 32.25 seconds (62.05 fps) Average fps for finesharp-lut: 65.24 finesharp Output 2001 frames in 56.01 seconds (35.73 fps) Output 2001 frames in 55.35 seconds (36.15 fps) Output 2001 frames in 54.97 seconds (36.40 fps) Average fps for finesharp: 36.09 psharpen Output 2001 frames in 40.66 seconds (49.21 fps) Output 2001 frames in 41.05 seconds (48.74 fps) Output 2001 frames in 41.24 seconds (48.52 fps) Average fps for psharpen: 48.82 Code:
finesharp Output 2001 frames in 47.69 seconds (41.95 fps) Output 2001 frames in 46.86 seconds (42.70 fps) Output 2001 frames in 47.46 seconds (42.16 fps) Average fps for finesharp: 42.27 psharpen Output 2001 frames in 28.09 seconds (71.24 fps) Output 2001 frames in 27.21 seconds (73.53 fps) Output 2001 frames in 26.59 seconds (75.25 fps) Average fps for psharpen: 73.34 Last edited by Are_; 23rd September 2015 at 01:32. |
23rd September 2015, 00:15 | #1713 | Link |
Interesting comparison. But where can I find psharpen for vs?
I think I can make it even faster by combining several expr calls. At least finesharp is kinda inefficient in that eay.
23rd September 2015, 00:40 | #1714 | Link | |
23rd September 2015, 01:27 | #1715 | Link |
Sorry, I somehow f..... up the test, speed is a little better, results updated. psharpen.py
23rd September 2015, 12:09 | #1716 | Link | |
Angel of Night
I can'y get assvapour to do anything at all, and as far as I can tell I'm using it right:
import vapoursynth as vs core = vs.get_core() std = core.std vid = core.lsmas.LWLibavSource(r'C:\train\karaoke\work\Rilo Kiley - Portions for Foxes.mkv') subs = core.assvapour.AssRender(vid,r'Rilo Kiley - Portions for Foxes.ass') subs[0] = core.resize.Bicubic(subs[0], format=vid.format.id) vid = std.MaskedMerge(vid, subs[0], subs[1]) vid.set_output() Edit: Also attempted Quote:
23rd September 2015, 13:08 | #1717 | Link | |
Try: (untested) Code:
core.avs.LoadPlugin(r'vsfilter_avs.dll') subs = core.avs.vsfilter.TextSub(vid,r'Rilo Kiley - Portions for Foxes.ass') |
23rd September 2015, 13:27 | #1718 | Link | |
23rd September 2015, 14:22 | #1720 | Link | |
Angel of Night
I'm cranky now because I tested with both r27 and r28t5 and neither showed. Now they do and I don't know why. Sigh. Computers, man. |
