23rd December 2018, 13:42 | #6542 | Link | |
Lost my old account :(
Its best if you test it for yourself, and see what settings gives you the best results, but if you target that bitrate range I whould say that you might wanna turn it off. And btw, I think crf21 will end up at a much lower bitrate for most content if you dont us tune grain or something similar. I get arround those numbers with crf18. |
23rd December 2018, 16:46 | #6543 | Link | |
bframes=6:subme=3:rd=5:qcomp=0.75:no-sao:deblock=-2:-2 Last edited by nghiabeo20; 23rd December 2018 at 16:56. |
23rd December 2018, 16:59 | #6544 | Link |
Pig on the wing
The bitrate depends a huge deal on the content. Grainy or noisy stuff requires much more than some clean CGI content.
24th December 2018, 00:24 | #6545 | Link | |
24th December 2018, 04:17 | #6546 | Link |
Can anybody give any advice if there is any benefit by taking the following approaches? and is either one of the splitting methods preferred?
other than the obvious ability to parallelize the encoding task |
24th December 2018, 08:09 | #6547 | Link | |
When having the split a source for parallelizing the encoding I would prefer to split 'a video file based on the shots' since the source simply might have key frames placed in a fixed interval not caring about coding efficiency. That said splitting on key frames is easier. But splitting on key frames in respect to scenes and using the segmented encoding feature of x265 is probably the best easy to implement way. Ideally you wound split at the points where the encoder would want to set key frame for coding efficiency. |
24th December 2018, 23:28 | #6548 | Link | ||||
27th December 2018, 14:32 | #6550 | Link | |
Simplest solution: Code:
diff -r 537bba0b7fdc source/encoder/encoder.cpp --- a/source/encoder/encoder.cpp Thu Dec 27 11:56:52 2018 +0530 +++ b/source/encoder/encoder.cpp Thu Dec 27 14:25:51 2018 +0100 @@ -69,7 +69,7 @@ int doviProfileId; }DolbyVisionProfileSpec; -DolbyVisionProfileSpec dovi[] = +static DolbyVisionProfileSpec dovi[] = { { 1, 1, 1, 1, 1, 5, 1, 2, 2, 2, 50 }, { 1, 1, 1, 1, 1, 5, 0, 16, 9, 9, 81 }, diff -r 537bba0b7fdc source/x265.cpp --- a/source/x265.cpp Thu Dec 27 11:56:52 2018 +0530 +++ b/source/x265.cpp Thu Dec 27 14:25:51 2018 +0100 @@ -690,7 +690,7 @@ args[argCount++] = token; token = strtok(NULL, " "); } - args[argCount] = '\0'; + args[argCount] = NULL; CLIOptions cliopt; if (cliopt.parseZoneParam(argCount, args,param, i)) { |
27th December 2018, 15:46 | #6551 | Link | |
SuperVirus
^ Thanks for answering.
OUCH! :-/ So I will have to wait. Quote:
the old error message (something about "invalid conversion from char to char*") just went replaced with a new one :-/ |
28th December 2018, 07:36 | #6552 | Link | |
Thank you |
28th December 2018, 09:06 | #6554 | Link |
You will usually first use a preset, then a tuning (so the "animation" tuning will add 2 to the number of B frames of your preset); but if you also add an explicit bframes parameter later in the command line, it will supersede previously calculated values.
28th December 2018, 10:21 | #6555 | Link | ||
Looks like we have a new AQ mode in x265 2.9+28
28th December 2018, 12:57 | #6556 | Link |
Pig on the wing
Seems interesting. It would be nice to hear of the cases which this new method targets.
28th December 2018, 14:10 | #6557 | Link | |
Pig on the wing
28th December 2018, 19:42 | #6558 | Link | |
Herr
More info here, https://stackoverflow.com/questions/...ll-even-though Last edited by Forteen88; 28th December 2018 at 23:27. |
28th December 2018, 23:50 | #6559 | Link |
I found this statement about Intel C++:
*** If you want to link against the static OpenMP RTL, you must add /Qopenmp-link:static, which is a new switch for 11.0. So to produce a purely static executable, compile/link with /MT /Qopenmp-link:static *** |
29th December 2018, 00:25 | #6560 | Link |
Helenium(Easter)
@Ma
Thanks for the information. Without /Qopenmp, /MT should be fine. With /Qopenmp, /Qopenmp-link:static needs to be used to produce a purely static executable.
Monochrome Anomaly |
