23rd July 2017, 15:13 | #3561 | Link |
Maybe auto one processes for each C/C++ filter(auto switch 32bit if 64bit not available) and auto adjustment prefetch and keep frames cache, can temporarily solve the multi-threaded problem until a new method appears.
colorbars(width = 1920, height = 1080, pixel_type = "yv12") src = last mcdn = src.kf_MCDegrainN(clip c, int "tr") rfs(src, mcdn, mappings="[1000 2000] [3000 4000]") #Remap Frames function kf_MCDegrainN(clip c, int "tr") { tr = default(tr, 6) super = MSuper(levels=0) multi_vec = MAnalyse(super, multi=true, delta=tr) c.MDeGrainN(super, multi_vec, tr) return last } Code:
colorbars(width = 1920, height = 1080, pixel_type = "yv12") src = last #1 processes prefetch 16 keep 14 #export last, src #pass mcdn = src.kf_MCDegrainN(clip c, int "tr") function kf_MCDegrainN(clip c, int "tr") { tr = default(tr, 6) super = MSuper(levels=0) #2 processes prefetch 14 keep 12 #export super #pass last, c multi_vec = MAnalyse(super, multi=true, delta=tr) #3 processes prefetch 12 keep 10 #export multi_vec #pass last, c, super c.MDeGrainN(super, multi_vec, tr) #4 processes prefetch 10 keep 8 #export last #pass return last } rfs(src, mcdn, mappings="[1000 2000] [3000 4000]") #Remap Frames #5 processes prefetch 8 keep 6 #export last Code:
MP_Pipeline(""" SetMemoryMax(500) colorbars(width = 1920, height = 1080, pixel_type = "yv12") src = last ### export clip:src ### prefetch: 14,12 ### ### SetMemoryMax(500) c = src super = MSuper(levels=0) ### export clip:c, super ### pass clip:src ### prefetch: 12,10 ### ### SetMemoryMax(500) multi_vec = MAnalyse(super, multi=true, delta=tr) ### export clip:multi_vec ### pass clip:src, c, super ### prefetch: 10,8 ### ### SetMemoryMax(500) mcdn = c.MDeGrainN(super, multi_vec, tr) ### export clip:mcdn ### pass clip:src ### prefetch: 8,6 ### ### SetMemoryMax(500) rfs(src, mcdn, mappings="[1000 2000] [3000 4000]") #Remap Frames """) Last edited by edcrfv94; 23rd July 2017 at 15:16. |
23rd July 2017, 15:31 | #3562 | Link |
yes, Unfortunately
I wish someone did these changes https://github.com/SAPikachu/MP_Pipe...ment-269108878
See My Avisynth Stuff |
13th August 2017, 05:18 | #3563 | Link |
hi pinterf
when you back can you check this, I didn't note it before since I use mpp(MP_Pipeline) most of the time and by using mpp it seems to work! edit: this one too https://forum.doom9.org/showpost.php...postcount=2709 since you will touch the autoload things edit2: this one too https://forum.doom9.org/showthread.p...12#post1814912
See My Avisynth Stuff Last edited by real.finder; 13th August 2017 at 09:33. |
1st September 2017, 12:02 | #3565 | Link |
AddAutoLoadDir behavior changed
Hello everyone,
Since AVS+ 2502 the AddAutoLoadDir behavior changed. Before this version, I could add 32bits and 64 bits DLLs (in two different folders) and AviSynth would load the correct ones depending on the environment it's working on. Because I currently must use an old x86 software and ffmpeg x64 at the same time from the same script. Now it fires an error (cannot load DLL...) and stops there. That a real issue for me since I generate an AVS+ script that should work in 32bits *and* 64bits and that I don't use the AVS+ default plugins dir (we have in-house developments). In other word, this change in behavior breaks everything that was working quite well until now I looked for a way of having conditionnal loading, but I couldn't find a variable that returns the current environment. Another way would be to add an optional argument to AddAutoLoadDir like "errors=false". Am I missing something there ? BTW I'm the technical director of a cable/DSL French TV channel and we've been using AviSynth and AVS+ for 9 years to generate our on-air & VOD/catch-up video graphics I must say you're doing an awesome work. Last year I was thinking about ditching AVS because we had a lot of issues relating to memory management, HD, ffmpeg and QuickTime, but AVS+ saved it demo => http://www.youtube.com/watch?v=ZbHMMxTcgec |
1st September 2017, 12:21 | #3566 | Link | |
A possible solution for this could be to modify the AddAutoLoadDir() functionality so the bitness check is omitted on the script level. This way, only the "hard coded" auto-load directories to which the registry entries point will be checked. Last edited by Groucho2004; 1st September 2017 at 12:38. |
1st September 2017, 13:30 | #3567 | Link | |
From version r2487 there is a new script function: int GetProcessInfo([int type = 0]) Without parameter or type==0 the current bitness of Avisynth DLL is returned (32 or 64) With type=1 the function can return a bit more detailed info: -1: error, can't establish 0: 32 bit DLL on 32 bit OS 1: 32 bit DLL on 64 bit OS (WoW64 process) 2: 64 bit DLL Usage: LoadPlugin(GetProcessInfo == 32 ? "This32.dll" : "This64.dll") |
1st September 2017, 13:54 | #3568 | Link | |
(GetProcessInfo == 32) ? AddAutoLoadDir("32BitplugsDir") : AddAutoLoadDir("64BitplugsDir") |
1st September 2017, 15:05 | #3569 | Link | |
I read a few months ago that a function to return the bitness was added, but I couldn't find it in the documentation. So it works now, time to deploy r2508 BTW I still didn't activate MT because I found some bugs. I suppose I can do bug reports here ? (it usually takes time because I do full reports with sample files) |
2nd September 2017, 14:43 | #3571 | Link |
Last OT posts moved to https://forum.doom9.org/showthread.php?t=174847
3rd September 2017, 17:25 | #3572 | Link |
I must be doing something wrong because I don't see any change with or without Prefetch(8). Speed,number of threads and memory consumption is identical.
script Code:
#MT Import("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\Scripts\MTmodes.avs") #VideoSource video=DirectShowSource("E:\_Video_Samples\mkv\drive_video_10min.mkv",audio=false).ConvertToYV12(matrix="rec709") #Crop video=Crop(video,0,140,-0,-140) #Denoise Loadplugin("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\mvtools\mvtools2.dll") super=MSuper(video,pel=2) fv1=MAnalyse(super,isb=false,delta=1,overlap=4) bv1=MAnalyse(super,isb=true,delta=1,overlap=4) fv2=MAnalyse(super,isb=false,delta=2,overlap=4) bv2=MAnalyse(super,isb=true,delta=2,overlap=4) video=MDegrain2(video,super,bv1,fv1,bv2,fv2,thSAD=400) return video prefetch(8) Code:
AVSMeter 2.2.6 (x86) AviSynth+ 0.1 (r2508, MT, i386) (0.1.0.0) Loading script... Number of frames: 14751 Length (hh:mm:ss.ms): 00:10:15.117 Frame width: 1920 Frame height: 800 Framerate: 23.981 (10000/417) Colorspace: YV12 Frame (current | last): 144 | 14750 FPS (cur | min | max | avg): 1.985 | 1.946 | 4.142 | 2.407 Memory usage (phys | virt): 287 | 336 MiB Thread count: 37 CPU usage (current | average): 8% | 6% Time (elapsed | estimated): 00:01:00.231 | 01:42:07.361 Code:
AVSMeter 2.2.6 (x86) AviSynth+ 0.1 (r2508, MT, i386) (0.1.0.0) Loading script... Number of frames: 14751 Length (hh:mm:ss.ms): 00:10:15.117 Frame width: 1920 Frame height: 800 Framerate: 23.981 (10000/417) Colorspace: YV12 Frame (current | last): 144 | 14750 FPS (cur | min | max | avg): 1.981 | 1.945 | 4.097 | 2.401 Memory usage (phys | virt): 287 | 336 MiB Thread count: 37 CPU usage (current | average): 7% | 6% Time (elapsed | estimated): 00:01:00.384 | 01:42:22.926
3rd September 2017, 17:41 | #3574 | Link | |
#MT Import("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\Scripts\MTmodes.avs") #VideoSource video=DirectShowSource("E:\_Video_Samples\mkv\drive_video_10min.mkv",audio=false).ConvertToYV12(matrix="rec709") #Crop video=Crop(video,0,140,-0,-140) #Denoise Loadplugin("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\mvtools\mvtools2.dll") super=MSuper(video,pel=2) fv1=MAnalyse(super,isb=false,delta=1,overlap=4) bv1=MAnalyse(super,isb=true,delta=1,overlap=4) fv2=MAnalyse(super,isb=false,delta=2,overlap=4) bv2=MAnalyse(super,isb=true,delta=2,overlap=4) video=MDegrain2(video,super,bv1,fv1,bv2,fv2,thSAD=400) video=prefetch(video,8) return video
4th September 2017, 10:07 | #3575 | Link |
@Mod
Posts #3576 and onwards should be moved to the fft3dfilter thread. |
5th September 2017, 05:54 | #3577 | Link |
Soul Architect
With the latest version of Avisynth+, I'm still unable to open script files names containing international character in MPC-HC; but the same files open fine in VirtualDub.
I thought this had been solved? Here's an example of file name: おどるポンポコリン.mp4 |
5th September 2017, 15:20 | #3579 | Link |
Source: 3840x2160 AVC
CPU: E5-2690 (8C/16T) RAM: 64 GiB OS: Win7 x64 Avisynth+: r2508 x86 Code:
#MT Import("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\Scripts\MTmodes.avs") #VideoSource video=DirectShowSource("E:\_Video_Samples\mp4\UHD_0035.MP4",audio=false).ConvertToYV12(matrix="rec709") #Resize video=Spline36Resize(video,1920,1080).Sharpen(0.2) #Denoise Loadplugin("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\mvtools\mvtools2.dll") super=MSuper(video,pel=2) fv1=MAnalyse(super,isb=false,delta=1,overlap=4) bv1=MAnalyse(super,isb=true,delta=1,overlap=4) fv2=MAnalyse(super,isb=false,delta=2,overlap=4) bv2=MAnalyse(super,isb=true,delta=2,overlap=4) video=MDegrain2(video,super,bv1,fv1,bv2,fv2,thSAD=400) #Prefetch video=Prefetch(video,X) #Return return video Code:
8 Threads AVSMeter 2.2.6 (x86) AviSynth+ 0.1 (r2508, MT, i386) (0.1.0.0) Loading script... Number of frames: 420 Length (hh:mm:ss.ms): 00:00:14.014 Frame width: 1920 Frame height: 1080 Framerate: 29.970 (5000000/166833) Colorspace: YV12 Frames processed: 420 (0 - 419) FPS (min | max | average): 0.581 | 472300 | 10.53 Memory usage (phys | virt): 1609 | 1800 MiB Thread count: 45 CPU usage (average): 52% Time (elapsed): 00:00:39.880 ------------------------------------------------------- 14 Threads AVSMeter 2.2.6 (x86) AviSynth+ 0.1 (r2508, MT, i386) (0.1.0.0) Loading script... Number of frames: 420 Length (hh:mm:ss.ms): 00:00:14.014 Frame width: 1920 Frame height: 1080 Framerate: 29.970 (5000000/166833) Colorspace: YV12 Frames processed: 420 (0 - 419) FPS (min | max | average): 0.181 | 566759 | 12.38 Memory usage (phys | virt): 1784 | 1984 MiB Thread count: 51 CPU usage (average): 89% Time (elapsed): 00:00:33.925 ------------------------------------------------------- 15 Threads AVSMeter 2.2.6 (x86) AviSynth+ 0.1 (r2508, MT, i386) (0.1.0.0) Loading script... Number of frames: 420 Length (hh:mm:ss.ms): 00:00:14.014 Frame width: 1920 Frame height: 1080 Framerate: 29.970 (5000000/166833) Colorspace: YV12 Frames processed: 420 (0 - 419) FPS (min | max | average): 0.196 | 472300 | 7.495 Memory usage (phys | virt): 1826 | 2016 MiB Thread count: 52 CPU usage (average): 57% Time (elapsed): 00:00:56.034 ------------------------------------------------------- 16 Threads AVSMeter 2.2.6 (x86) AviSynth+ 0.1 (r2508, MT, i386) (0.1.0.0) Loading script... Number of frames: 420 Length (hh:mm:ss.ms): 00:00:14.014 Frame width: 1920 Frame height: 1080 Framerate: 29.970 (5000000/166833) Colorspace: YV12 Frames processed: 420 (0 - 419) FPS (min | max | average): 0.170 | 566760 | 6.253 Memory usage (phys | virt): 1850 | 2045 MiB Thread count: 53 CPU usage (average): 39% Time (elapsed): 00:01:07.169
5th September 2017, 16:17 | #3580 | Link |
Atak_Snajpera,
What happens if you get virtual memory use over 2048MiB ?
