Old 28th January 2020, 20:15   #21  |  Link
blublub
Originally Posted by MeteorRain View Post
For high core count cpu I'd reduce frame threads to 1 and pools to 12 and do chunked encoding (half-half) or parallel encoding (2 at a time).
I believe less threads = less waste on threading for x265, so I always use less threads and run more processes.
Besides, I already have the software infrastructure to do chunked encoding, and mux them later. Encoded GOPs can be joined later, so chunked encoding is basically zero cost to me.
higher frame-threads will degrade quality, however x265 default is 6 for HCC CPUs so anything below won't hurt quality significantly.
From my understanding the parameter "pools" has no impact on quality. It is by default set to max number of available Hyperthreading cores
blublub is offline   Reply With Quote
Old 29th January 2020, 17:06   #22  |  Link
benwaggoner
Well, setting --pools to limit to a single NUMA socket will reduce the threads available, and so may reduce frame-threads. And generally doesn't slow things down that much; the overhead of using multiple cores seems to reduce the speed benefit of using them pretty significantly in my testing. Even at 8K, using a second core on a 2x18/36 Xeon system is maybe 20% faster than a second, and I generally just set up different encodes for each socket (ala --pools "+.-" and "-,+"
Ben Waggoner
My Compression Book
Old 29th January 2020, 17:16   #23  |  Link
blublub
Hi
I only have 1 Socket iny my TR 3960x.
I currently don't know if x265 detects it as 1 or 2 Numa nodes.
However increasing pools from default/auto 48 to 64 does help with CPU utilization and speed - although it's not stuck at 100%, but at least 85 to 95 which is better than 75% average with the auto setting.
In the end it al comes down to:
Scaling isn't optimal above 12c CPUs and
If one just encodes one job a 16c and 32t is the optimal CPU / bang for the buck here with a 3950x as the higher cost of a 24c CPU isn't worth it at the moment
A 24c CPU makes sense if one encodes more than one job in parallel or uses distributed encoding
Old 29th January 2020, 18:01   #24  |  Link
Most likely your 3960x is seen as single numa node (Run EncodingServer.exe and look for line [SYSTEM] NUMA Nodes = 1). Only 3990x will be divided into two virtual numa nodes in OS.
Old 29th January 2020, 19:25   #25  |  Link
MeteorRain
結城有紀
Just so you know that I wasn't talking about loss of quality, but a waste of computing resource. Single threaded application works more efficient than multi threaded application in terms of work per computing resource. (i.e. 2x single threaded app works more efficient than 1x 2 threads app.) So I like balancing the threads count and processes count to not introducing too much trouble while not introducing too much waste.
In my personal use case I found it a good balance to run 4-6 threads for x265 and another 2-4 threads for AviSynth.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 29th January 2020, 19:33   #26  |  Link
MeteorRain
結城有紀
Also don't forget that, half of the CPU threads are SMT. So if you wisely use half of the CPU threads (i.e. 16 threads, each per 16 physical cores) you'll see 50% CPU utilization but underneath you are already using 80% of your CPU capacity. Pushing it to 100% CPU utilization will get you at most 25% more speed from 50% utilization before any extra threading loss.
Projects
Old 2nd February 2020, 17:02   #27  |  Link
sonyzz
current settings are more like that for 1080p video on 4c 8t i7 cpu:
wpp / ctu=32 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=2 / tu-inter-depth=2 / me=3 / subme=5 / merange=57 / rect / no-amp / max-merge=3 / temporal-mvp / no-early-skip / rskip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=250 / min-keyint=23 / scenecut=40 / rc-lookahead=30 / lookahead-slices=4 / bframes=8 / bframe-bias=0 / b-adapt=2 / ref=4 / limit-refs=2 / limit-modes / weightp / weightb / aq-mode=3 / qg-size=32 / aq-strength=0.80 / cbqpoffs=0 / crqpoffs=0 / rd=4 / psy-rd=0.70 / rdoq-level=2 / psy-rdoq=1.00 / log2-max-poc-lsb=8 / limit-tu=0 / no-rd-refine / signhide / deblock=1:1 / no-sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=crf / crf=22.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ipratio=1.40 / pbratio=1.30
sonyzz is offline   Reply With Quote
3900x, 3950x, hevc, ryzen, x265
