Old 15th October 2009, 00:03   #81  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Originally Posted by schweinsz View Post
btw: I can not get to the picture and the video you post.
Sorry, I don't understand. You can't download it?
EDIT: if so - try this...
By the way, with Haali renderer this is not really a problem. At first I just not realized that DiAVC outputs only YV12. Haali accepts only YUY2, so I just need additional transform filter.
Keiyakusha is offline   Reply With Quote
Old 15th October 2009, 01:18   #82  |  Link
schweinsz
Yes, I can't download it. I get it now from your new address. Thank you very much.
schweinsz is offline   Reply With Quote
Old 15th October 2009, 06:25   #83  |  Link
Astrophizz
Good news, I did some test on longer clips (I had been using ~30 second ones before) and DiAVC is the fastest for me! This is really impressive.
I get the blinking too and videos start out green (Haali renderer). Seeking causes the image to freeze also.
Astrophizz is offline   Reply With Quote
Old 15th October 2009, 08:11   #84  |  Link
Avish
Avish's Avatar
64-bit XP is not supported yet, right?? Coz MPC-HC just hangs when I try to play anything with DiAVC.
i7-2600 | GA-B75-D3V | Tempest EVO | VX450 & XMS3 16GB | SanDisk Extreme 120GB | U2311H | MK520 | MSI GTX750 Ti Gaming | CM Hyper 212+ | APC 1KVA | Xonar DG | SoundSticks III | Win 7 x64
Avish is offline   Reply With Quote
Old 15th October 2009, 09:15   #85  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Can't get it work under win7. Every app that trying to use it just hangs so I even can't construct any graph...
works for me only w/ the madVR or VMR9 as renderer...
Old 15th October 2009, 09:16   #86  |  Link
schweinsz
Yes, there is only 32-bit version now. I must re-code all assembly code for 64-bit version in future.
Old 15th October 2009, 09:32   #87  |  Link
Kurtnoise
Kurtnoise's Avatar
@schweinsz : any chance to add lossless contents support in diAVC ?
Old 15th October 2009, 10:17   #88  |  Link
schweinsz
Adding lossless contents support is not a complex task. But I'll start work on it after all other more important tasks are finished, such as improving the speed, filter bug fix, compatibility, 64-bit version, etc.
Old 15th October 2009, 10:22   #89  |  Link
Dark Shikari
x264 developer
Dark Shikari's Avatar
Adding 64-bit assembly is a huge task, especially if you don't intend to do what x264 does and use a 32-bit/64-bit abstraction system. Lossless is a couple hours at most by comparison.
Also, note there are two lossless modes: the old one (profile_idc=144) and the new one (profile_idc=244). Old one is just replacing dct with a direct subtraction, while the new one involves some pixel prediction and thus is slightly trickier.
Old 15th October 2009, 10:32   #90  |  Link
schweinsz
After I finish the DiAVC, I'll do some works to improve the x264.
I know this, but that only add some intra-prediction function, and replace some function pointer of intra-prediction.
Old 15th October 2009, 10:43   #91  |  Link
Dark Shikari
x264 developer
I was referring to the system for having both types of assembly; if you have to copy/paste all the assembly to get 32-bit and 64-bit versions it gets quite messy.
Yup, it's not too complicated.
Old 15th October 2009, 11:10   #92  |  Link
schweinsz
Yes, I have understanded you. I will code all 64-bit assembly code to get fastest speed. Actually the 64-bit have more things to do because we can take a full use of the 64-bit general register.
Old 15th October 2009, 11:15   #93  |  Link
Dark Shikari
x264 developer
But on WIN64 you have the atrocious API that requires callee-save xmm6-xmm15, which seriously limits what you can do (since if you can get a 10 cycle speedup by using 8 more registers, you've probably lost performance because of the loads/stores...).
Old 15th October 2009, 11:26   #94  |  Link
schweinsz
But on WIN64 you have the atrocious API that requires callee-save xmm5-xmm15, which seriously limits what you can do (since if you can get a 10 cycle speedup by using 8 more registers, you've probably lost performance because of the loads/stores...).
Oh, VERY bad news for me. Thank you very much. I don't know this limitation ever.
Old 15th October 2009, 11:35   #95  |  Link
Dark Shikari
x264 developer
The Windows 64-bit API is very weird and you should do some research on it before you start writing assembly code.
You should look at common/x86/x86inc.asm in x264; it contains macros for handling of the three calling conventions (32-bit, 64-bit, win64). Win64 is extremely weird and is completely incompatible with all other 64-bit calling conventions (which use the standard one).
In addition to the callee-save XMM registers, it also has a different general-purpose register calling convention, probably just to annoy people.
And the above is a typo, it's xmm6-xmm15 that are callee-save.
Old 17th October 2009, 18:30   #96  |  Link
squid_80
The most annoying thing is the exception handling restrictions - if you touch the stack pointer you are supposed to set up a frame pointer, have properly formed epilogs/prologs and make sure the special exception handling data is included in the binary. (I say "supposed to" because it will still run without it but if an exception/crash happens the app will be immediately terminated, even if an exception handler is meant to catch it.)
MS gets the middle finger for keeping rsi/rdi non-volatile as well.
squid_80 is offline   Reply With Quote
Old 18th October 2009, 18:22   #97  |  Link
schweinsz
The DiAVC is designed to prevent from debugging by the use of "exception handle".
Old 29th October 2009, 09:32   #98  |  Link
schweinsz
Which splitter can split the dmb contents in http://samples.mplayerhq.hu/V-codecs/h264/dmb/? I found that those bitstreams crash the haali media splitter.
Old 30th October 2009, 00:07   #99  |  Link
slavickas
I'm Shpongled
slavickas's Avatar
you may try MPC-HC splitter, though havent tested those files myself
slavickas is offline   Reply With Quote
Old 3rd November 2009, 09:14   #100  |  Link
schweinsz
Where can I get some H.264 bitstreams with mbaff and weighted prediction? The jm can't produce the bitstreams.
avc, diavc, fastest decoder, h.264, software
