13th February 2017, 16:05 | #121 | Link |
The only time when this option can possibly make a difference is when the input is a WAV file which has extra data chunks (like a cover artwork) AFTER the main WAV data. WAV files which have been created as intermediate temporary WAV files (or WAV streams when using a pipe) will never have these extra chunks after the WAV data, so the "ignorelength" parameter will not make any difference in this case.
Cheers manolito |
14th February 2017, 18:06 | #122 | Link |
Maybe a mod can split this off into a new thread if it's in the way here, but because I didn't know the hack was a hack until very recently, I played around a little more.
From a GUI perspective again, where the audio is always decoded by the GUI, a couple of encoders seem to assume "ignore length" for stdin and don't have an "ignore length" option (that I could find). They were LAME and MusePack. I'm not sure about the latter but for LAME stdin seems to assume the hack unless you specifically tell it the input is raw. FFmpeg's "ignore length" probably fits into the above category too, simply because it's not well documented. For the encoders with an "ignore length" option, many still seem to apply the same rule for stdin. The following encoders produced output files with the correct number of samples either way. FDKAAC, FFmpeg, FhGAC, Flac, Ogg, Opus, QAAC, WMAEncode. The only anomaly I found there was the Flac file size was slightly larger without it's version of "ignore length" in the command line, yet according to foobar2000 the bitrate, sample count, and audio md5 were the same. The encoders that failed without it were Aften, ffdcaenc, NeroAAC, and WavPack. Fortunately though, encoders either exited with an error or they encoded normally, there seemed to be no middle ground, so from that perspective it's a good thing. Not being able to encode with Nero if I used stdin without "ignore length" (a temporary input wave file worked fine) I tried with Audacity to see what would happen, but I must have been using the wrong incantation, because the progress meter would get to the halfway point each time and Audacity would stop responding, but I'm quite interested to learn why NeroAAC just exits with an error for foobar2000 if I use stdin without "ignore length", if it'll encode for Audacity, however I need to find out why it's not working at all first (I had an older Audacity installed so I upgraded to the latest but the result was the same). The command line for Audacity I'm using: "C:\Program Files\foobar2000\encoders\neroAacEnc.exe" -q 0.40 -ignorelength -if - -of %f Last edited by hello_hello; 14th February 2017 at 18:11. |
19th February 2017, 20:57 | #123 | Link |
Software Developer
FWIW, here is a new Test version with Python bindings included:
https://sourceforge.net/projects/mul...L.zip/download
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 14th April 2017 at 21:17. |
14th April 2017, 21:07 | #124 | Link | |
Software Developer
Dynamic Audio Normalizer v2.10
• https://github.com/lordmulder/Dynami...eases/tag/2.10 • https://www.mediafire.com/folder/flr...dio_Normalizer • https://bitbucket.org/muldersoft/dyn...izer/downloads Quote:
12th June 2017, 04:37 | #125 | Link |
Hello.
I've been experimenting with FFmpeg's dynaudnorm filter recently (on movies), and the results are good. However, the loud parts (music, effects) are sometimes slightly louder than the quiet parts (dialogue). My goal is to get a completely constant volume, with no need to raise and lower the volume at all. What options and settings should I use in order to achieve this goal? |
12th June 2017, 15:51 | #126 | Link | |
Software Developer
Secondly, it is possible that the "quiet" part is shortly after a "loud" part and the filter takes a moment to adapt. Keep in mind that the filter adapts slowly and smoothly, in order to avoid nasty "volume pumping" effect. Anyway, you can try using a smaller Gaussian filter window size (default: 31) to make the filter adapter faster. Finally, it is possible that the "quiet" part simply has more dynamics compared to the "loud" part. What it means is that the "quiet" part contains a few signal peaks that prevent it from being amplified even further (without clipping), even though the average amplitude is relatively low. In this case you can give RMS mode a try. Or you can try adding some input compression. Or both See also: http://muldersoft.com/docs/dyauno_re...#configuration
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 12th June 2017 at 16:04. |
13th June 2017, 04:14 | #127 | Link | ||
Since I'm not going to check this options for every movie, what I'm looking for is the best general settings to cover these options.
input compression - tried it already, and it causes FFmpeg to freeze right at the beginning. (I use rogerdpack version for XP.) |
15th June 2017, 22:52 | #128 | Link |
kolamorx,
Try just reducing the frame size. For ffmpeg: -af dynaudnorm=f=150 or even f=75 and g=11 if it doesn't result in too much "pumping". Edit see post #133 regarding the compression option and a newer version of ffmpeg (XP friendly) Last edited by hello_hello; 16th June 2017 at 22:31. |
16th June 2017, 01:48 | #129 | Link | |
Software Developer
So, if you get "freeze" with FFmpeg and DynAudNorm when input compression is enabled, I suggest you try it with the "standalone" version of DynAudNorm: https://github.com/lordmulder/Dynami...eleases/latest If you can re-produce the "freeze" with that, please send my a sample file and your exact options. Otherwise, please send a bug-report to the FFmpeg developers.
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 16th June 2017 at 02:30. |
16th June 2017, 12:28 | #131 | Link | |
edit: To answer my own question after going through the thread: https://ffmpeg.org/ffmpeg-filters.html#dynaudnorm
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 16th June 2017 at 13:43. |
16th June 2017, 22:30 | #133 | Link | |
I tested with the following ffmpeg command line myself and it works fine using this version of ffmpeg, which is probably more recent than the version you're using and it runs on XP. -af dynaudnorm=f=75:g=11:s=12 |
17th June 2017, 10:11 | #134 | Link |
If you have trouble getting the desired results with DynAudNorm you can try the "Loudnorm" filter which comes with current versions of FFmpeg, Muxson wrote a nicle little GUI for it:
http://www.muxson.com/winloud Cheers manolito |
17th June 2017, 21:07 | #135 | Link | |
Any other suggestions for general settings? |
23rd June 2017, 04:20 | #136 | Link |
@LoRd_MuldeR
I have a sound in float format, in which the range is higher than [-1.0, +1.0]. DynamicAudioNormalizer (FFmpeg implementation) can reduce the sound level to [-1.0, +1.0]?
MPC-BE 1.7.0 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource Last edited by v0lt; 23rd June 2017 at 04:23. |
23rd June 2017, 19:24 | #138 | Link |
Retried Guesser
From the ffmpeg source, it looks like all audio filtering is done at double-precision floating point, with nominal +1/-1 range - but no clipping outside that range. FFmpeg dynaudnorm default peak volume is 0.95 (-0.4 dB on a +1/-1 scale). It looks to me like it'll normalize any input range without problems; you'll have to try it for yourself though.
29th July 2017, 20:12 | #139 | Link | |
What should I do in this case? Last edited by kolamorx; 29th July 2017 at 20:19. |
29th July 2017, 21:15 | #140 | Link | |
Software Developer
Apart from that, you can try the "--compress" option of the DynamicAudioNormalizer. See the manual for details...
