Old 6th April 2012, 07:21   #681  |  Link
alzou
I see u make recode now... thanks a lot
alzou is offline   Reply With Quote
Old 14th May 2012, 21:47   #682  |  Link
Sirber
retired developer
Sirber's Avatar
yes and no.. I'm experimenting
Detritus Software
Sirber is offline   Reply With Quote
Old 18th July 2012, 02:55   #683  |  Link
edward666
Hello, one question i updated the programs (MP4box, mkvtool, ffmpeg, etc) drag, drop and replace, and at the last step when joining a file i get error, can i update the programs without this happening or should i just leave them as they are?. thanks...
edward666 is offline   Reply With Quote
Old 18th July 2012, 03:12   #684  |  Link
Sirber
retired developer
Sirber's Avatar
mp4 or mkv? to be safe update only ffmpeg.
Detritus Software
Old 18th July 2012, 05:59   #685  |  Link
jofori89
Nani miten da yo? Baka!!
jofori89's Avatar
what's the error information :\
jofori89 is offline   Reply With Quote
Old 19th July 2012, 01:47   #686  |  Link
edward666
Error with MKV
Merging files... error #2
and with MP4 the files says finished but in the output folder there is no file, its empty...
Old 16th May 2013, 21:54   #687  |  Link
Sirber
retired developer
Sirber's Avatar
I cannot say, maybe an error with the encoders and the muxer got an empty file. Try Recode from my website, it's a bit more updated with a simpler toolchain.
Detritus Software
aac, bencos, gui, webm, x264
