Old 1st July 2010, 17:52   #1361  |  Link
rendez2k
rendez2k's Avatar
@rendez2k
thanks for sending the sample clip. It seems that the stuttering issue is caused by the 'convertfps=true' flag in the DirectShowSource call. Removing it, or using FFMpegSource, along with the NTSC->PAL 4% speed option on, video playback is smooth. Please confirm if it works for you as well.
As a matter of fact, 'convertfps=true' should be used when video framerate is variable (VFR). From the next release, I will add this flag only if it is really necessary.
Bye
Used FFMpegSource and it did indeed look much better. I'll run a full test.
I did however get "PROCESS ABORTED DURING DVD AUTHORING FINALIZATION!" at the end. Any ideas?
rendez2k is offline   Reply With Quote
Old 1st July 2010, 20:22   #1362  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Great news. You will get same results if you force DirectShowSource and remove the 'convertfps=true' option from the AviSynth script.
The authoring error is caused by a chapter flag positioned out of max time. Your small mkv has a chapter flag just at the very end. Using AssumeFPS, output time will be a little shorter than input time, so Muxman is complaining about that last chapter flag. Of course it is a situation to be handled, and in the final 2.3.1 release it will be fixed. Right now you can simply delete the last chapter flag (see Chapters tab).
Thanks for the test report
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 4th July 2010, 00:48   #1363  |  Link
whiskey
Drunken munky
Hi !
Small problem here, was trying to do some dvds using my mkv files for the 1st time today and I got issues with audio encoding, could somebody pinpoint the problem for me if possible ?
I've noticed this "Is There A Creator_1.ToFix.ac3" but not sure what does it mean ? Fixing bad frames ?
<2010-07-03 17:07:52>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 4
DVD Size: 4481/4480 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: Static Menu
Output Folder: E:\New folder
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 1
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
DVD Audio Language: EN - English
DVD Subs Language: EN - English
Chapters Interval: 5
Use Source Chapters: 0
DVD Burning Drive: F: TSSTcorp DVD+-RW TS-L632D DE04
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: D:\01 - Is There A Creator.mkv
Info: AVC - 3126 kbps - 1280x720 - DAR 1,778 - 29,97 fps (CFR) - Progressive - 44:32 minutes - 80092 frames
Audio 1: D:\01 - Is There A Creator.mkv
Info: AC3 - 384 kbps - CBR - 6ch - 48000Hz - 44:32 minutes - Internal
Subs:
[MediaInfoLib - v0.7.32]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("D:\01 - Is There A Creator.mkv", CacheFolder = "E:")
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("D:\01 - Is There A Creator.mkv", CacheFolder = "E:")
Video = Video.ConvertToYV12
Video = Video.Spline64Resize(720,480)
AudioDub(Video, Audio)
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 958,8 MB
HCenc Parameters: -ini "E:\DVD_0_Title_01_01 - Is There A Creator.HCenc.ini"
HCenc ini file:
*INFILE E:\DVD_0_Title_01_01 - Is There A Creator_1.avs
*AVSRELOAD
*OUTFILE E:\New folder\DVD_0_Title_01_01 - Is There A Creator.m2v
*LOGFILE E:\DVD_0_Title_01_01 - Is There A Creator.HCenc.log
*MAXBITRATE 9000
*BITRATE 3010
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*BIAS 30
*DC_PREC 8
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
<2010-07-03 18:12:25>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: E:\New folder\DVD_0_Title_01_01 - Is There A Creator.m2v (959,6 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 3033 kbps - 720x480 - DAR 1,778 - 29,97 fps (CFR) - Progressive (TFF) - 44:29 minutes - 80013 frames
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg Parameters: -i "D:\01 - Is There A Creator.mkv" -acodec copy "E:\New folder\DVD_0_Title_01_01 - Is There A Creator_1.ToFix.ac3"
<2010-07-03 18:28:04>
Problems encountered during Title 1 AUDIO encoding operations.
START (BACKUP) AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg Parameters: -i "D:\01 - Is There A Creator.mkv" -map 0:1 -y -vn -ac 6 -ar 48000 -ab 384k "E:\New folder\DVD_0_Title_01_01 - Is There A Creator_1.ac3"
<2010-07-03 18:28:14>
PROCESS ABORTED DURING TITLE 1 AUDIO (TRACK 1) ENCODING OPERATIONS.
CHECK LOG FILE <E:\NEW FOLDER\DVD_0.LOG> FOR MORE INFO.
Log file created by AVStoDVD Release 2.3.0
EDIT
I have discovered that FFmpeg
produces temporary log with errors on ac3 stream "non monotone timestamps" message , no idea what that means tho :S
whiskey is offline   Reply With Quote
Old 4th July 2010, 11:40   #1364  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@whiskey
your mkv has very probably a badly encoded audio track. Where did you get it?
Bye
MrC
AVStoDVD Homepage
Old 6th July 2010, 00:02   #1365  |  Link
Bellona
Hello MrC. I love your program.
I just wanted to report that when building menus from a template in an existing project file, AVStoDVD seems to reference "C:\Program Files\AVStoDVD" for the menu's assets, such as images, even if that wasn't the install directory. On 64-bit Windows, for example, the default install directory would be "C:\Program Files (x86)\AVStoDVD", but it's looking in the wrong directory for menu assets. When building a menu from scratch, it works as expected.
Bellona is offline   Reply With Quote
Old 6th July 2010, 00:58   #1366  |  Link
whiskey
Drunken munky
@whiskey
Bye
Problem solved ! Had to demux files encode ac3 to mp3 remux and then AVS did the job !
Old 9th July 2010, 15:33   #1367  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Bellona
That's quite strange because the code associated to that button does not contain reference to default Program Files folder. Are you sure the "C:\Program Files (x86)\AVStoDVD" is not reported in the a2d file you are trying to load?
@whiskey
good news! Be careful with unknow source files...
Bye
MrC
AVStoDVD Homepage
Old 9th July 2010, 15:46   #1368  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
AVStoDVD release 2.3.1 is out.
Change log (from release 2.3.0):
- Some bugs fixed
- Added 'DVD Subs Font' in 'Preferences'/'AuthoringBurning': allows change of font name, format and size for authored subs.
- Added 'Use PAL SpeedUp for NTSC-film to PAL' in 'Preferences'/'Encoding' (AssumeFPS("pal_film") is used instead of DGPulldown to upsize fps)
- Added 'Save general Settings at program Exit' in 'Preferences'/'Misc' ('DVD Size', 'Output Setup', 'Advanced Project Settings' can be stored in the Windows Registry)
- Added 'MSharpen' AviSynth filter (by Donald Graft) in 'Title Edit'/'AviSynth'
- Added 'ColorMatrix' AviSynth filter (by Wilbert & Tritical) in 'Title Edit'/'AviSynth'
- Added 'SubsExtension' option in 'Title Edit'/'Subtitles'
- Improved frame rate conversion ('convertfps=true' DSS flag only for VFR video). 'A2DSource.avsi' function updated accordingly.
- FFmpeg updated to r23107
Please report any comment/suggestion/bug as usual
Bye
MrC
AVStoDVD Homepage
Old 10th July 2010, 16:56   #1369  |  Link
nevragain
The ntsc reencoding bug seems to be resolved. Thanks very much for fixing the bug I encountered.
Ok I'm doing more testing and on my laptop the program seems to freeze when I attempt to edit the menu. I have set the firewall to allow both ffmpeg and avs2dvd full privileges. ffmpeg is just sitting there with no processor utilization.
nevragain is offline   Reply With Quote
Old 11th July 2010, 19:26   #1370  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
You're welcome!
Is this a new issue for 2.3.1 or same for previous releases?
Bye
MrC
AVStoDVD Homepage
Old 12th July 2010, 03:31   #1371  |  Link
8ternity
8ternity's Avatar
Hello, i've got an error from 2.3.0, 2.3.1, i install and uninstall everything and it's give me an error:
"Process aborted during 'Generate AviSynth script file' Section. Error code: 0"
I used avysinth and haali from other applications "ripbot264" and bd rebuilder and it works well but AVStoDVD can't convert an m2ts to DVD like i does in the past.
I have Windows 7 64bit edition, what i do wrong?
thanks.
QUESTION: i change windows 7 defaut notepad for Notepad2.exe version, did the avisynth generate script used notepad.exe ?
Old 12th July 2010, 14:56   #1372  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@8ternity
what about release 2.2.6 (you were using it here)?
Could you copy and paste here the log file?
Bye
MrC
AVStoDVD Homepage
Old 12th July 2010, 16:16   #1373  |  Link
Bellona
@Bellona
It was my fault. I had either codecs or a version of Haali that was causing Wavi/Aften to crash, and through the process of uninstalling and reinstalling software to find a solution, I ended up installing AVStoDVD to the wrong location, and from there made the A2D project, and later reinstalled it somewhere else. My A2D project file still had the old locations, of course.
Everything is working fine now, though.
Old 12th July 2010, 17:33   #1374  |  Link
Bellona
On an unrelated note, I found what might be an issue with 2.3.1.
When using DirectShowSource exclusively, the automatically generated script contains a syntax error. Here's an example script that gets generated:
Video = DirectShowSource("input", fps=23.976, convertfps=true,
audio=false)
Audio = DirectShowSource("input", video=false)
Video = Video.ConvertFPS("ntsc_video")
The video line is split apart, resulting in "audio=false)" to occupy a new line. It works fine if I manually edit the avisynth script.
Old 12th July 2010, 19:26   #1375  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@Bellona
thanks for the bug report. BTW, just to add more details, the error occurs only when DirectShowSource is selected AND input video framerate mode is not constant (i.e. VFR).
May I ask you why are you using DirectShowSource instead of A2DSource? Any issue with the latter?
Bye
MrC
AVStoDVD Homepage
Old 12th July 2010, 19:51   #1376  |  Link
Bellona
@Bellona
Bye
My VFR source is mostly 23.976 fps, with only some of it being 29.970 fps. I've found that importing it at 119.880 fps, and then using Donald Graft's FDecimate to 23.976 fps, and letting HCEnc apply pulldown worked the best of the things I've tried so far.
By setting it to use only DirectShowSource, it's easy to edit the automatically generated script. Here would be my example edit:
Video = DirectShowSource("input", fps=119.880, convertfps=true, audio=false)
Video = Video.FDecimate(23.976)
It works well in my case, but I'm open to suggestions of course. For everything else, I still use A2DSource and default settings.
Old 13th July 2010, 03:13   #1377  |  Link
8ternity
8ternity's Avatar
@8ternity
Bye
2.3.1 log
'22:03:12' AVStoDVD Release 2.3.1 loaded!
'22:03:12' AviSynth 2.5.8 is installed.
'22:03:12' ImgBurn is installed ("C:\Program Files (x86)\ImgBurn\ImgBurn.exe").
'22:03:12' MKVExtract is installed ("C:\Program Files (x86)\MKVtoolnix\mkvextract.exe").
'22:03:12' New AVStoDVD Project started!
'22:03:18' MediaInfoLib - v0.7.32 initialized.
'22:03:18' Title 1 "E:\BLURAY\Le Missionnaire FRENCH AC3 DVD9.AVCHD\BDMV\STREAM\00000.m2ts" added.
'22:03:28' AVStoDVD Project started.
'22:03:28' Process aborted during 'Generate AviSynth script file' Section. Error code: 0
and 2.2.6 try:
The conversion start well with AD2video; AC3 to 448kbps; and i found a difference in AVStoDVD from 2.2.6 to 2.3.1 is the 2.2.6 version has only one filter and 2.3.1 has two, you know the one AVS Resize filter, did you think is that option make the project defective?
Old 14th July 2010, 00:19   #1378  |  Link
8ternity
8ternity's Avatar
2.2.6;
Conversion Done after 1:47:09 hours;
NO AUDIO ON OUTPUT;
<2010-07-13 08:30:19>
START PROCESS
PROJECT SETTINGS
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Label: LE_NOUVEAU_PROTOCOLE
DVD Menu: No Menu
Output Folder: E:\DVD-TEMP
PREFERENCES
AVS Resize Filter: Lanczos4Resize
Video Resolution: 0
Video BitRate Level 1: 6000
Video Profile Level 2: 6000
DVD Audio Format: 0
DVD Audio BitRate: 448
Keep DVD Compliat Audio: 1
Normalize Audio: 0
DVD Audio Language: FR - French
DVD Subs Language: FR - French
Chapthers Interval: 5
Use Source Chapters: 1
DVD Burning Drive: F: HL-DT-ST BD-RE  WH08LS20 2.00
Save Log file: 1
Video: E:\DVD_PENDING\LE NOUVEAU PROTOCOLE.m2ts
Info: AVC - 4872 kbps - 1280x720 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 1:32:51 hours - 133582 frames
Audio: E:\DVD_PENDING\LE NOUVEAU PROTOCOLE.m2ts
Info: DTS - 1536 kbps - CBR - 48000Hz - 6ch - 1:32:51 hours
Subs:
[MediaInfoLib - v0.7.26]
AVISYNTH SCRIPT
Video = A2DVideoSource("E:\DVD_PENDING\LE NOUVEAU PROTOCOLE.m2ts", CacheFolder = "E:\Temp")
Audio = A2DAudioSource("E:\DVD_PENDING\LE NOUVEAU PROTOCOLE.m2ts", CacheFolder = "E:\Temp")
#Using DGPulldown to upsize FPS
Video = Video.Lanczos4Resize(720,480)
<2010-07-13 08:36:40>
Encoding Profile: HCenc OPV 1-pass
Target Video FileSize: 3337,8 MB
HCenc Parameters: -ini "E:\Temp\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.HCenc.ini"
HCenc ini file:
*INFILE E:\Temp\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.avs
*AVSRELOAD
*OUTFILE E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.m2v
*LOGFILE E:\Temp\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.HCenc.log
*MAXBITRATE 9000
*CQ_MAXBITRATE 2.654
*BITRATE 5026
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<2010-07-13 09:51:35>
Created File: E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.m2v (3529,1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5356 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 1:32:46 hours - 133450 frames
START TRANSCODING OPERATIONS
ReJig Parameters: -size 3337 -o "E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.ReJig.m2v" -i "E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.m2v" -auto -close -quiet
<2010-07-13 09:54:29>
END TRANSCODING OPERATIONS
Transcoding executed on File: E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.m2v (3336,8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5063 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive - 1:32:46 hours - 133450 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
<2010-07-13 10:13:19>
END PULLDOWN OPERATIONS
DGPulldown executed on File: E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.m2v (3336,8 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5058 kbps - 720x480 - DAR 1,778 - 23,976 fps (CFR) - Progressive (2:3 Pulldown) - 1:32:51 hours - 133581 frames
FFmpeg Parameters: -i "E:\DVD_PENDING\LE NOUVEAU PROTOCOLE.m2ts" -acodec copy "E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.ToFix.dts"
<2010-07-13 10:16:09>
END AUDIO ENCODING OPERATIONS
Created File: E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.dts (1002,3 MB)
OUTPUT AUDIO INFO: DTS - 1536 kbps - CBR - 48000Hz - 6ch - 1:32:48 hours
<2010-07-13 10:16:10>
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "E:\Temp\LE_NOUVEAU_PROTOCOLE_0_BatchMux.ini"
BatchMux ini file:
-d "E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0\VIDEO_TS"
-mxp "E:\Temp\LE_NOUVEAU_PROTOCOLE_0_MuxMan.mxp"
-l "E:\Temp\LE_NOUVEAU_PROTOCOLE_0_MuxMan.log"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio LOW
-v "E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.m2v"
-vidmode LB
-a1 "E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE.dts"
-a1lang fr
-cellfr "E:\Temp\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE_MuxMan.txt"
-progfr "E:\Temp\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE_MuxMan.txt"
-chapfr "E:\Temp\LE_NOUVEAU_PROTOCOLE_0_LE NOUVEAU PROTOCOLE_MuxMan.txt"
<2010-07-13 10:19:47>
END DVD AUTHORING OPERATIONS
Created Folder: E:\DVD-TEMP\LE_NOUVEAU_PROTOCOLE_0 (3407,6 MB)
<2010-07-13 10:19:48>
Log file created by AVStoDVD Release 2.2.6
Old 14th July 2010, 13:56   #1379  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@8ternity
release 2.2.6 had a known bug about DTS-HD audio tracks.
But, why are you using different sources: 'Le Missionnaire FRENCH AC3 DVD9' with 2.3.1 attempt and 'LE NOUVEAU PROTOCOLE.m2ts' with 2.2.6 attempt? This is creating a bit confusion, isn't it?
Could you please post the 2.3.1 project log file of 'Le Missionnaire FRENCH AC3 DVD9'? I mean the output log file not the input one.
Bye
MrC
AVStoDVD Homepage
Old 14th July 2010, 18:11   #1380  |  Link
nevragain
Bye
I don't know I have never used your program before on my laptop.
It does take a long time on my desktop but this is probably just because my desktop is quite old.
[IMG] code is Off
