Old 7th September 2008, 00:52   #81  |  Link
doggyjumper
Refrasing my question
I managed to get external data from text using vbscript (through event command)
this date are 2 numbers I need to use to cut/tirm a clip .
How do I get that data into the funtion TRIM() ?
thanks
doggyjumper is offline   Reply With Quote
Old 7th September 2008, 01:23   #82  |  Link
subrom
hello,
Just wondered if the "264/DXVA/HD-Insane" profile in latest beta is broken? It seems to be passing "--me 4" to the command line of x264.exe and stops.
"D:\dvb\stax2\Settings\Applications\x264\x264.exe" --pass 2 --bitrate 6645 --stats "D:\dvb\movie\demux\movie_video1.stats" --level 4.1 --ref 4 --mixed-refs --bframes 3 --b-rdo --bime --weightb --direct auto --filter -1:-1 --subme 7 --trellis 2 --partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --vbv-bufsize 40000 --vbv-maxrate 50000 --me 4 --threads auto --progress --no-psnr --no-ssim --output "D:\dvb\movie\demux\movie_video1_EncoderOutput.264" "D:\dvb\movie\demux\movie_video1.avs"
x264 [error]: invalid argument: me = 4
When trying other profile "x264/DXVA/HD-HQ" it encodes fine.
subrom is offline   Reply With Quote
Old 8th September 2008, 20:02   #83  |  Link
realwarder
Subtitle error: An Inconvienient Truth
When I try and convert this to MP4 for playback on my PS3, I get this:
Error importing C:\INCONVENIENTTRUTH\VIDEO_TS\VTS_02_1.cc.utf16be.srt:lang=eng: Feature Not Supported
Error
MP4 muxing failed with exit code 1
Other conversions work without this error.
Log file is here:
http://www.2shared.com/file/3897011/...1_StaxRip.html
Any idea what's going wrong? Can I turn off subtitle processing or something?
Thanks!
realwarder is offline   Reply With Quote
Old 8th September 2008, 20:06   #84  |  Link
realwarder
The Fountain
When I try and convert "The Fountain" files, things don't work quite correctly. I do this by selecting the multiple VOB files, VTS_02_1.VOB-VTS_02_6.VOB however it appears that the DVD has an advertisement in the first part of the first 1GB VOB. The audio is then around 2 minutes out of sync with the video, as the video plays the advert and movie, whereas the audio just plays the movie audio.
Other tools have the same or similar issue, so it looks like something clever is being done on that disc...
Any ideas?
Thanks!
Old 12th September 2008, 03:50   #85  |  Link
Hero1711
Today I installed the lastest beta version (2008-08-28) and get this crash when trying to open a mp4 file (mkv is fine):
http://www.mediafire.com/?q2mined2crb
Then I uninstalled everything and installed version 1.1.1.0 (2008-07-10) but got the same error for mp4 files (mkv is fine).
I am using version 1.0.0.3 (2008-03-05). It is wroking fine with both mp4 and mkv.
Hero1711 is offline   Reply With Quote
Old 12th September 2008, 08:41   #86  |  Link
stax76
stax76's Avatar
@doggyjumper
It's more a support request than a bug, StaxRip might not be able to perform this task. I would create a dedicated thread asking how to solve the problem generally not necessarily using StaxRip, you have to tell about the exact source and target format (use MediaInfo or better upload samples) as well as the format of the cut list. People will also be interested in background information like how was the cut list created.
This seem to be a problem with Sharktooths profiles or with x264, please report it directly to the appropriate project.
This means MP4Box doesn't support the the format of the SRT file, please report it directly to the MP4Box project.
Difficult topic, please read here: http://forum.doom9.org/showthread.ph...ghlight=shrink
I can't reproduce it, what OS do you run? It's weird because it seems you don't have MP4Box installed and the code causing the crash should never be reached without MP4Box being installed. The external applications dialog for MP4Box should pop-up and if you don't install MP4Box there nothing should happen, if you install it properly it should demux.
Old 12th September 2008, 09:18   #87  |  Link
Hero1711
Ok, let's start from nothing (OS: Windows Vista Ultimate SP1 32bit Edition).
1. I install StaxRip Beta 2008-08-28.
2. Open a MP4 file.
3. StaxRip asks me to install AviSynth 2.5.7. I install AviSynth.
4. After that, a list of "Problematic Applications" appears:
AutoCrop (1.1)
BeSweet (1.5b31)
MediaInfo (0.7.7.2)
MKVtoolnix (2.2.0)
NeroAACEnc (1.1.34.2)
x264 (951)
5. I install them all and this box appears:
All required applications are installed properly. -> OK -> Close
6. Then this error appear:
StaxRip has crashed:
Object reference not set to an instance of an object. (OK Button)
7. And then:
A diagnostic files was saved on the desktop, please post this diagnostic file in the support forum! (OK Button)
P.S.: I solved the problem above by manually installing MP4Box.
I got this new error:
1. Open a MKV file.
2. Go through preparations.
3. Choose Profiles->Encoder->x264->Unrestricted->2passes Anime Toons.
4. Choose Profiles->Container->MP4.
5. Go through Crop and Check Filters steps.
6. At compressibility check step I got this error:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileNotFoundException: Could not find file 'F:\Cut\Test_new_CompCheck.264'.
File name: 'F:\Cut\Test_new_CompCheck.264'
   at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
   at System.IO.FileInfo.get_Length()
   at StaxRip.H264CmdlEncoder.RunCompCheck(String executable, String arguments, Boolean isErrorStream, String[] logValuesToSkip)
   at StaxRip.x264Encoder.RunCompCheck()
   at StaxRip.MainForm.lTip_Click()
   at StaxRip.MainForm._Lambda$__83(Object a0, EventArgs a1)
   at System.Windows.Forms.Control.OnClick(EventArgs e)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.Label.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.1434 (REDBITS.050727-1400)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
StaxRip
    Assembly Version: 1.1.1.0
    Win32 Version: 1.1.1.0
    CodeBase: file:///C:/Program%20Files/StaxRip/StaxRip.exe
Microsoft.VisualBasic
    Assembly Version: 8.0.0.0
    Win32 Version: 8.0.50727.1434 (REDBITS.050727-1400)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Stax
    Assembly Version: 1.0.0.0
    Win32 Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files/StaxRip/Stax.DLL
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.21022.8 built by: RTM
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Old 12th September 2008, 20:16   #88  |  Link
Bh4i
^i also get the error with the Anime profile when doing a compress. check. I dont have problems with the same file when doing a comp. check with other x264 profiles.
Im running the latest beta on WinXP Pro SP2
-edit-
Just tried the old version of StaxRip with the old x264 profiles: i dont have any problems with those.. im using the same file
Bh4i is offline   Reply With Quote
Old 13th September 2008, 04:24   #89  |  Link
stax76
stax76's Avatar
The problem was the profile uses the switch --psy-rd not yet supported by the x264 build StaxRip uses. I've now removed the switch from the default profiles like I've removed all other switches that require a patched x264 build. I've also improved error handling, it won't crash using a invalid switch but would rather show the output from x264. New beta online!
Old 13th September 2008, 08:47   #90  |  Link
Hero1711
Thank you very much for the new beta version. But I got this new error (using the latest beta 0913.0509), the audio is not converted into wav:
http://www.mediafire.com/?4niqcnyjj1f
Steps:
1. Open a MKV file.
5. Go through Crop, Check Filters, compressibility check steps.
6. Next -> Start! -> Error:
VirtualDub Error
Avisynth open failure:
DirectShowSource: couldn't open file F:\Cut\Test - ja-Japanese.aac:
No combination of filters could be found to render the stream.
(F:\Cut\Test - ja-Japanese_Decode.avs, line 3)
Old 13th September 2008, 11:25   #91  |  Link
stax76
stax76's Avatar
The message is clear, DirectShowSource failed to open the aac file, StaxRip uses dshow to decode aac but so far unfortunatelly it doesn't verify if a decoder is installed making it a bit harder for newbies, installing ffdshow should help.
Old 13th September 2008, 11:56   #92  |  Link
Hero1711
I had FFDShow Tryouts revision 2094 installed on my PC along with Combined Community Codec Pack already.
P.S.: Got the same error after installing standalone ffdshow r2033 downloaded from ffdshow tryouts home page.
Old 13th September 2008, 12:20   #93  |  Link
stax76
stax76's Avatar
Do you have aac decoding enabled in the ffdshow options?
Old 13th September 2008, 13:09   #94  |  Link
Bh4i
I assume the profiles in StaxRip are from Shartktooth, but i noticed that StaxRip misses some profiles.
Here is the complete list of Sharktoot's profiles: http://forum.doom9.org/showthread.php?t=139765
For example, the only option for anime/toon is: Unrestricted 2pass Anime Toons
If i click on codec configuration, i can see that this profile uses 16 reference frames... i dont think many ppl want to use that many ref. frames, cause it will be really slow. On my CPU (E6600 @ 2.4 Ghz) its only 4 fps.
If i look at Sharktooth's profiles, he also has some additional profiles, like:
- Unrestricted 2pass Anime_Toons Fast
- Unrestricted 2pass Anime_Toons Balanced
- Unrestricted 2pass Anime_Toons HQ
- Unrestricted 2pass Anime_Toons Extra Q.
- Unrestricted 2pass Anime_Toons Insane
Is there any particular reason u didnt include these ones?
Old 13th September 2008, 13:36   #95  |  Link
stax76
stax76's Avatar
Try the following:
In the profiles dialog delete all x264 profiles (use the delete key ;)
In the main menu select 'Tools/Import x264 Profiles...', in the file browser select all profiles you want to import
In the 'External Applications' dialog link to a patched x264 build, the one MeGUI is using for instance
Old 13th September 2008, 14:04   #96  |  Link
Hero1711
Sure. I can play aac files on Media Player Classic just fine (There is a FFDShow Audio Decoder icon on taskbar too).
Old 13th September 2008, 14:25   #97  |  Link
stax76
stax76's Avatar
At this point usually people will tell you that you've messed up your system by installing a codec pack, personally I don't believe codec packs are as bad as their reputation. I don't know what the problem is, I guess it's related to your dshow config or a bug in one of your dshow filters. You could try to fix this or create a audio profile supporting AAC as import using something like ffmpeg for instance or you could use a external transcoder to transcode the audio file manually. Hope it's not too much of a pain for you, StaxRip need some improvement in this area, problem is it's a rarely used feature.
Old 13th September 2008, 15:42   #98  |  Link
Bh4i
Try the following:
Thanks, that should do it
Old 13th September 2008, 16:58   #99  |  Link
Hero1711
Thanks, but StaxRip 1.0.0.3 works finely. It even cut softsub beautifully.
Old 13th September 2008, 17:55   #100  |  Link
Bh4i
Im getting this muxing error: MKV muxing failed with exit code 1
However, there are no problems with muxing or whatsoever. The final MKV file is created, and it seems it doesnt have any problems at all.
The problem is that because of this error, StaxRip doesnt continue with the next project file in "jobs".
Any idea what causes this error?
Diagnostic files: http://www.zshare.net/download/18712963c487d87c/
Log:
                    Opening source files
H:\New Folder\03\VTS_01_1.VOB
General
Complete name                    : H:\New Folder\03\VTS_01_1.VOB
Format                           : MPEG-PS
File size                        : 921 MiB
Duration                         : 21mn 30s
Overal bit rate                  : 5987 Kbps
Video
Format                           : MPEG Video
Format version                   : Version 2
Format profile                   : Main@Main
Format settings, Matrix          : Standard
Duration                         : 21mn 30s
Bit rate mode                    : Constant
Bit rate                         : 5187 Kbps
Nominal bit rate                 : 8000 Kbps
Width                            : 720 pixels
Height                           : 576 pixels
Display aspect ratio             : 4/3
Frame rate                       : 25.000 fps
Standard                         : PAL
Colorimetry                      : 4:2:0
Scan type                        : Interlaced
Scan order                       : Top Field First
Bits/(Pixel*Frame)               : 0.772
Audio
Format                           : AC-3
Format/Info                      : Audio Coding 3
Duration                         : 21mn 30s
Bit rate                         : 384 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Rear: L R, LFE
Sampling rate                    : 48.0 KHz
Video delay                      : -96ms
Text
Format                           : RLE
Format/Info                      : Run-length encoding
Video delay                      : -80ms
Menu
Format                           : DVD-Video
         Demux audio and index MPEG-2 using DGIndex
"H:\!Portable\StaxRip\Settings\Applications\DGIndex\DGIndex.exe"
-SD=| -IF=|H:\New Folder\03\VTS_01_1.VOB| -IA=2 -FO=0 -YR=1
-TN=1 -OM=2 -DRC=2 -DSD=0 -DSA=0 -OF=|H:\New Folder\03\VTS_01_1 temp files\VTS_01_1| -minimize -exit
Preparer: Demux audio and index MPEG-2 using DGIndex
Start:    16:19:32
End:      16:20:19
Duration: 00:00:47
                          Filters
MPEG2Source("H:\New Folder\03\VTS_01_1 temp files\VTS_01_1.d2v")
LoadCplugin("H:\!Portable\StaxRip\Settings\Applications\Yadif\yadif.dll") Yadif()
Crop(2,0,-2,-0)
FluxSmoothST(2)
BicubicResize(480,352,0,0.5)
                       Audio Encoding
"H:\!Portable\StaxRip\Settings\Applications\BeSweet\BeSweet.exe"
-core( -input "H:\New Folder\03\VTS_01_1 temp files\VTS_01_1 01 en-English 3_2ch 384Kbps DELAY -15ms.ac3"
-output "H:\New Folder\03\VTS_01_1 temp files\VTS_01_1 01 en-English 3_2ch 384Kbps DELAY -15ms_AudioOutput.mp4" )
-azid( -c normal -L -3db ) -ota( -d -15 -g max ) -bsn( -vbr 0.3 -2ch )
*  Nero Digital Audio Reference MPEG-4 & 3GPP Audio Encoder *
*  Copyright 2007 Nero AG                                   *
*  All Rights Reserved Worldwide                            *
*  Package build date: Aug  6 2007                          *
*  Package version:    1.1.34.2                             *
*  See -help for a complete list of available parameters.   *
Process0:05:01:777] transcoding ...
Pro
cessed 466 seconds...
21:26:929] transcoding ...
Visit DSPguru's Homepage at :
                                http://DSPguru.doom9.net/
                 Audio Encoding Statistics
Start:    17:57:40
End:      17:59:29
Duration: 00:01:48
Speed:    296 fps
Bitrate:  73,54 kbps
Video Bitrate: 575 -> 571
                            x264
"H:\!Portable\StaxRip\Settings\Applications\x264\x264.exe" --pass 1 --bitrate 571
--stats "H:\New Folder\03\VTS_01_1 temp files\VTS_01_1.stats" --bframes 5
--b-pyramid --direct auto --filter 1:1 --threads auto --progress --no-psnr --no-ssim
--subme 1 --partitions none --me dia --output NUL "H:\New Folder\03\VTS_01_1 temp files\VTS_01_1.avs"
avis [info]: 480x352 @ 25.00 fps (32269 frames)
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 Cache64
x264 [info]: slice I:379   Avg QP:22.09  size: 13546
x264 [info]: slice P:12870 Avg QP:24.45  size:  4667
x264 [info]: slice B:19020 Avg QP:25.44  size:  1231
x264 [info]: consecutive B-frames: 15.9% 20.5% 10.8% 13.2% 19.9% 19.6%
x264 [info]: mb I  I16..4: 32.4%  0.0% 67.6%
x264 [info]: mb P  I16..4: 22.1%  0.0%  0.0%  P16..4: 55.7%  0.0%  0.0%  0.0%  0.0%    skip:22.2%
x264 [info]: mb B  I16..4:  1.5%  0.0%  0.0%  B16..8: 21.7%  0.0%  0.0%  direct:16.8%  skip:60.0%  L0:33.9% L1:54.7% BI:11.4%
x264 [info]: final ratefactor: 22.57
x264 [info]: direct mvs  spatial:99.9%  temporal:0.1%
x264 [info]: kb/s:549.3
encoded 32269 frames, 39.91 fps, 549.34 kb/s
                      x264 Statistics
Start:    17:59:29
End:      18:12:58
Duration: 00:13:29
                      x264 Second Pass
"H:\!Portable\StaxRip\Settings\Applications\x264\x264.exe" --pass 2 --bitrate 571
--stats "H:\New Folder\03\VTS_01_1 temp files\VTS_01_1.stats" --ref 5 --mixed-refs
--bframes 5 --b-pyramid --bime --direct auto --filter 1:1 --subme 6 --trellis 1
--partitions p8x8,b8x8,i4x4,i8x8 --8x8dct --threads auto --progress --no-psnr --no-ssim
--output "H:\New Folder\03\VTS_01_1 temp files\VTS_01_1_EncoderOutput.264"
x264 [info]: slice I:379   Avg QP:20.22  size: 15468
x264 [info]: slice P:12870 Avg QP:22.48  size:  4910
x264 [info]: slice B:19020 Avg QP:24.00  size:  1214
x264 [info]: mb I  I16..4: 20.8% 36.9% 42.3%
x264 [info]: mb P  I16..4:  8.6%  8.5%  4.8%  P16..4: 40.4% 12.6%  7.6%  0.0%  0.0%    skip:17.5%
x264 [info]: mb B  I16..4:  1.3%  0.0%  0.0%  B16..8: 26.0%  1.5%  1.2%  direct:10.7%  skip:59.4%  L0:47.5% L1:42.0% BI:10.5%
x264 [info]: 8x8 transform  intra:35.7%  inter:57.6%
x264 [info]: direct mvs  spatial:95.4%  temporal:4.6%
x264 [info]: ref P L0  61.4% 15.9% 10.3%  6.2%  6.2%
x264 [info]: ref B L0  61.4% 18.8% 13.0%  6.8%
x264 [info]: ref B L1  89.0% 11.0%
x264 [info]: kb/s:571.1
encoded 32269 frames, 22.48 fps, 571.17 kb/s
                x264 Second Pass Statistics
Start:    18:12:58
End:      18:36:58
Duration: 00:23:59
                           Muxing
"H:\!Portable\MKVExtractGUI\mkvmerge.exe" -o "H:\New Folder\03\VTS_01_1.mkv"
--noaudio --nosubs --default-duration 0:25.000fps "H:\New Folder\03\VTS_01_1 temp files\VTS_01_1_EncoderOutput.264"
--aac-is-sbr 1:1 --language 1:eng --track-name "1:English"
--language 0:dut -s 0 "H:\New Folder\03\VTS_01_0.idx" --chapters "H:\New Folder\03\VTS_01 - Chapter Information - OGG.txt"
--engage keep_bitstream_ar_info
mkvmerge v2.2.0 ('Turn It On Again') built on Mar  4 2008 12:58:13
'H:\New Folder\03\VTS_01_1 temp files\VTS_01_1_EncoderOutput.264': Using the AVC/h.264 ES demultiplexer.
'H:\New Folder\03\VTS_01_1 temp files\VTS_01_1 01 en-English 3_2ch 384Kbps DELAY -15ms_AudioOutput.mp4': Using the Quicktime/MP4 demultiplexer.
Warning: vobsub_reader: 'H:\New Folder\03\VTS_01_0.idx', line 63: The line seems to be a subtitle entry
but the timecode was negative even after adding the track delay. Negative timecodes are not supported in Matroska. This entry will be skipped.
'H:\New Folder\03\VTS_01_0.idx': Using the VobSub subtitle reader (SUB file 'H:\New Folder\03\VTS_01_0.sub').
'H:\New Folder\03\VTS_01_1 temp files\VTS_01_1_EncoderOutput.264' track 0: Using the MPEG-4 part 10 ES video output module.
'H:\New Folder\03\VTS_01_1 temp files\VTS_01_1 01 en-English 3_2ch 384Kbps DELAY -15ms_AudioOutput.mp4' track 1: Using the AAC output module.
'H:\New Folder\03\VTS_01_0.idx' track 0: Using the VobSub subtitle output module (language: dut).
The file 'H:\New Folder\03\VTS_01_1.mkv' has been opened for writing.
The cue entries (the index) are being written...
Muxing took 6 seconds.
                           Error
bug, staxrip
