Old 16th September 2010, 00:53   #201  |  Link
Zathor
Originally Posted by vitali5000 View Post
It is a problem when I try to make resize with 1920x1080 to 720x400, there was no such problem earlier.
With 32 bit version resize to720x400 works fine.
So the error occurs if you open the avs script in MeGUI? Or at which point does it occur? Post your avs script.
Old 17th September 2010, 01:21   #202  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
i updated mediainfo.dll (x64 version) again. please check if it works.
Sharktooth is offline   Reply With Quote
Old 17th September 2010, 13:12   #203  |  Link
Whimick
I am trying to encode some media into Xvid, how ever I encounter the following error:
[Error] Log
-[Information] Versions
--[Information] MeGUI Version : 0.3.5.12 x64
--[Information] OS : Windows Vista Premium Edition x64 SP2 (6.0.131072.6002)
--[Information] Latest .Net Framework installed : 4.0 (4.0.30319)
--[Information] Avisynth Version : 2.5.8.5
-[Information] Log for job1 (idx, First Light.mpg -> First Light.d2v)
--[Information] [17/09/2010 12:32:23] Started handling job
--[Information] [17/09/2010 12:32:23] Preprocessing
--[Information] Job commandline: "C:\Program Files\MEGUI 64\tools\dgindex\dgindex.exe" -SD=< -AIF=<E:\First Light.mpg< -OF=<C:\Users\Michael\Videos\MeGUI\First Light< -FO=0 -exit -hide -OM=1 -TN=c0
--[Information] [17/09/2010 12:32:24] Indexing started
--[Information] Standard output stream
--[Information] Standard error stream
--[Information] [17/09/2010 12:33:40] Running auto force film
---[Information] Film percentage: -1
--[Information] [17/09/2010 12:33:41] Postprocessing
---[Information] Deleting intermediate files
----[Information] [17/09/2010 12:33:43] Successfully deleted E:\First Light.log
--[Information] [17/09/2010 12:33:43] Job completed
-[Information] AutoEncode job generation log
--[Information] Desired Size : 700 MB
--[Information] Split Size : null
--[Information] Eliminating duplicate filenames
---[Information] Video output file: C:\Users\Michael\Videos\MeGUI\First Light.avi
---[Information] Muxed output file: C:\Users\Michael\Videos\MeGUI\First Light-muxed.avi
---[Information] Encodable audio stream 0: C:\Users\Michael\Videos\MeGUI\First Light Tc0 L2 2ch 48 256 DELAY 0ms_new.mp2
-[Information] Log for job1 (audio, First Light Tc0 L2 2ch 48 256 DELAY 0ms.mp2 -> First Light Tc0 L2 2ch 48 256 DELAY 0ms_new.mp2)
--[Information] [17/09/2010 12:34:09] Started handling job
--[Information] [17/09/2010 12:34:09] Preprocessing
--[Information] Avisynth script
---[NoImage] DirectShowSource("C:\Users\Michael\Videos\MeGUI\First Light Tc0 L2 2ch 48 256 DELAY 0ms.mp2")
---[NoImage] EnsureVBRMP3Sync()
---[NoImage] 32==Audiobits(last)?ConvertAudioTo16bit(last):last
---[NoImage] return last
--[Information] Commandline used: -i - -y -acodec mp2 -ab 256k "{0}"
--[Information] [17/09/2010 12:34:09] Encoding started
--[Information] [17/09/2010 12:34:09] Encode thread started
--[Information] [17/09/2010 12:34:09] Avisynth script environment opened
--[Information] [17/09/2010 12:34:10] Script loaded
--[Information] Output Decoder
---[Information] Channels: 2
---[Information] Bits per sample: 16
---[Information] Sample rate: 48000
--[Information] Commandline: C:\Program Files\MEGUI 64\tools\ffmpeg\ffmpeg.exe -i - -y -acodec mp2 -ab 256k "C:\Users\Michael\Videos\MeGUI\First Light Tc0 L2 2ch 48 256 DELAY 0ms_new.mp2"
--[Information] [17/09/2010 12:34:11] Encoder process started
--[Information] Output from encoder via stderr
---[NoImage] FFmpeg version SVN-r22941, Copyright (c) 2000-2010 the FFmpeg developers
---[NoImage] built on Apr 22 2010 06:18:44 with gcc 4.4.2
---[NoImage] configuration: --cross-prefix=x86_64-w64-mingw32- --cc=ccache-x86_64-w64-mingw32-gcc --extra-cflags='-Dstrtod=__strtod' --arch=x86_64 --target-os=mingw32 --enable-runtime-cpudetect --enable-avisynth --enable-gpl --enable-version3 --enable-bzlib --enable-libgsm --enable-libfaad --enable-pthreads --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libmp3lame --enable-libopenjpeg --enable-libxvid --enable-libschroedinger --enable-libx264 --enable-libopencore_amrwb --enable-libopencore_amrnb
---[NoImage] libavutil 50.14. 0 / 50.14. 0
---[NoImage] libavcodec 52.66. 0 / 52.66. 0
---[NoImage] libavformat 52.61. 0 / 52.61. 0
---[NoImage] libavdevice 52. 2. 0 / 52. 2. 0
---[NoImage] libswscale 0.10. 0 / 0.10. 0
---[NoImage] [wav @ 00000000002DA3E0]max_analyze_duration reached
---[NoImage] [wav @ 00000000002DA3E0]Estimating duration from bitrate, this may be inaccurate
---[NoImage] Input #0, wav, from 'pipe:':
---[NoImage] Duration: N/A, bitrate: 1536 kb/s
---[NoImage] Stream #0.0: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
---[NoImage] Output #0, mp2, to 'C:\Users\Michael\Videos\MeGUI\First Light Tc0 L2 2ch 48 256 DELAY 0ms_new.mp2':
---[NoImage] Metadata:
---[NoImage] encoder : Lavf52.61.0
---[NoImage] Stream #0.0: Audio: mp2, 48000 Hz, 2 channels, s16, 256 kb/s
---[NoImage] Stream mapping:
---[NoImage] Stream #0.0 -> #0.0
---[NoImage] video:0kB audio:147482kB global headers:0kB muxing overhead 0.000000%
--[Information] [17/09/2010 12:35:32] Postprocessing
--[Information] [17/09/2010 12:35:32] Job completed
-[Error] Log for job2 (video, First Light.avs -> )
--[Information] [17/09/2010 12:35:32] Started handling job
--[Information] [17/09/2010 12:35:32] Preprocessing
---[Information] Bitrate calculation for video
----[Information] Desired size after subtracting audio: 566553.2265625KBs
----[Information] Calculated desired bitrate: 983.4309513921261177268296818kbit/s
--[Information] Job commandline: "C:\Program Files\MEGUI 64\tools\xvid_encraw\xvid_encraw.exe" -i "C:\Users\Michael\Videos\MeGUI\First Light.avs" -pass1 "C:\Users\Michael\Videos\MeGUI\First Light.stats" -bitrate 983 -kboost 100 -chigh 30 -clow 15 -overhead 0 -turbo -max_key_interval 250 -nopacked -lumimasking -imin 1 -pmin 1 -bvhq -bquant_ratio 162 -bquant_offset 0 -bmin 1 -par 3200:3159 -threads 1
--[Information] [17/09/2010 12:35:33] Encoding started
--[Error] An error occurred: Usage : xvid_encraw [OPTIONS]
--[Information] Standard output stream: xvid_encraw - raw mpeg4 bitstream encoder written by Christoph Lampert 2002-2003
---[NoImage] xvid_encraw built at 03:19:12 on Oct 25 2009
---[NoImage] Input options:
---[NoImage] -i string : input filename (stdin)
---[NoImage] -type integer: input data type (yuv=0, pgm=1, avi/avs=2)
---[NoImage] -w integer: frame width ([1.2048])
---[NoImage] -h integer: frame height ([1.2048])
---[NoImage] -csp string : colorspace of raw input file i420, yv12 (default)
---[NoImage] -frames integer: number of frames to encode
---[NoImage] Output options:
---[NoImage] -dump : save decoder output
---[NoImage] -save : save an Elementary Stream file per frame
---[NoImage] -o string : save an Elementary Stream for the complete sequence
---[NoImage] -avi string: save an AVI file for the complete sequence
---[NoImage] -mkv string: save a MKV file for the complete sequence
---[NoImage] BFrames options:
---[NoImage] -max_bframes integer: max bframes (2)
---[NoImage] -bquant_ratio integer: bframe quantizer ratio (150)
---[NoImage] -bquant_offset integer: bframe quantizer offset (100)
---[NoImage] Rate control options:
---[NoImage] -framerate float : target framerate (25.0)
---[NoImage] -bitrate [integer] : target bitrate in kbps (700)
---[NoImage] -size integer : target size in kilobytes
---[NoImage] -single : single pass mode (default)
---[NoImage] -cq float : single pass constant quantizer
---[NoImage] -pass1 [filename] : twopass mode (first pass)
---[NoImage] -full1pass : perform full first pass
---[NoImage] -pass2 [filename] : twopass mode (2nd pass)
---[NoImage] -zq starting_frame float : bitrate zone; quant
---[NoImage] -zw starting_frame float : bitrate zone; weight
---[NoImage] -max_key_interval integer : maximum keyframe interval (300)
---[NoImage] Single Pass options:
---[NoImage] -reaction integer : reaction delay factor (16)
---[NoImage] -averaging integer : averaging period (100)
---[NoImage] -smoother integer : smoothing buffer (100)
---[NoImage] Second Pass options:
---[NoImage] -kboost integer : I frame boost (10)
---[NoImage] -kthresh integer : I frame reduction threshold (1)
---[NoImage] -kreduction integer : I frame reduction amount (20)
---[NoImage] -ostrength integer : overflow control strength (5)
---[NoImage] -oimprove integer : max overflow improvement (5)
---[NoImage] -odegrade integer : max overflow degradation (5)
---[NoImage] -chigh integer : high bitrate scenes degradation (0)
---[NoImage] -clow integer : low bitrate scenes improvement (0)
---[NoImage] -overhead integer : container frame overhead (24)
---[NoImage] -vbvsize integer : use vbv buffer size
---[NoImage] -vbvmax integer : vbv max bitrate
---[NoImage] -vbvpeak integer : vbv peak bitrate over 1 second
---[NoImage] Other options
---[NoImage] -noasm : do not use assembly optmized code
---[NoImage] -turbo : use turbo presets for higher encoding speed
---[NoImage] -quality integer : quality ([0..6]) (6)
---[NoImage] -vhqmode integer : level of R-D optimizations ([0..4]) (1)
---[NoImage] -bvhq : use R-D optimizations for B-frames
---[NoImage] -qpel : use quarter pixel ME
---[NoImage] -gmc : use global motion compensation
---[NoImage] -qtype integer : quantization type (H263:0, MPEG4:1) (0)
---[NoImage] -qmatrix filename : use custom MPEG4 quantization matrix
---[NoImage] -interlaced [integer] : interlaced encoding (BFF:1, TFF:2) (1)
---[NoImage] -nopacked : Disable packed mode
---[NoImage] -noclosed_gop : Disable closed GOP mode
---[NoImage] -masking [integer] : HVS masking mode (None:0, Lumi:1, Variance:2) (0)
---[NoImage] -stats : print stats about encoded frames
---[NoImage] -ssim [integer] : prints ssim for every frame (accurate: 0 fast: 4) (2)
---[NoImage] -ssim_file filename : outputs the ssim stats into a file
---[NoImage] -debug : activates xvidcore internal debugging output
---[NoImage] -vop_debug : print some info directly into encoded frames
---[NoImage] -nochromame : Disable chroma motion estimation
---[NoImage] -notrellis : Disable trellis quantization
---[NoImage] -imin integer : Minimum I Quantizer (1..31) (2)
---[NoImage] -imax integer : Maximum I quantizer (1..31) (31)
---[NoImage] -bmin integer : Minimum B Quantizer (1..31) (2)
---[NoImage] -bmax integer : Maximum B quantizer (1..31) (31)
---[NoImage] -pmin integer : Minimum P Quantizer (1..31) (2)
---[NoImage] -pmax integer : Maximum P quantizer (1..31) (31)
---[NoImage] -drop integer : Frame Drop Ratio (0..100) (0)
---[NoImage] -start integer : Starting frame number
---[NoImage] -threads integer : Number of threads
---[NoImage] -progress [integer] : Show progress updates every n frames (10)
---[NoImage] -par integer[:integer] : Set Pixel Aspect Ratio.
---[NoImage] 1 = 1:1
---[NoImage] 2 = 12:11 (4:3 PAL)
---[NoImage] 3 = 10:11 (4:3 NTSC)
---[NoImage] 4 = 16:11 (16:9 PAL)
---[NoImage] 5 = 40:33 (16:9 NTSC)
---[NoImage] other = custom (width:height)
---[NoImage] -help : prints this help message
---[NoImage] NB: You can define 64 zones repeating the -z[qw] option as needed.
--[Information] [17/09/2010 12:35:33] Job completed
Can any one advise me as to what is wrong
Many Thanks.
Whimick
Whimick is offline   Reply With Quote
Old 17th September 2010, 16:56   #204  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
what preset you used? coz it seems the xvid_encraw commandline is wrong.
Old 17th September 2010, 17:19   #205  |  Link
Whimick
Thanks for the reply.
I.ve tried a number of profiles and they all have the same error
Old 17th September 2010, 18:10   #206  |  Link
vitali5000
if i open *.dgi project 1920x1080 and make Resize to 720x400
http://img840.imageshack.us/img840/1903/74891822.jpg
vitali5000 is offline   Reply With Quote
Old 17th September 2010, 20:00   #207  |  Link
Zathor
Please click not on "Preview AVS Script", instead save the avs file and open the file with another tool like VirtualDub or MPC-HC. Do you get the same error?
Old 17th September 2010, 20:26   #208  |  Link
Whimick
I have had a closer look at my problem, and I believe it is caused by the versiion of avisynth64 I tried to install.
My question now is which version of avisynth64 should I use with my AMD processor and how should it be installed for it to work.
Can any one help.
Whimick
Old 17th September 2010, 22:20   #209  |  Link
vitali5000
With 32 bit version MeGUI - resize to 720x400 works fine.
Old 17th September 2010, 23:14   #210  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
mediainfo_0_7_35-2_x64 buged
@anybody who experienced problems with the x64 MediaInfo DLL
Please try the DLL's from here (preferably all DLL's from both packages) and tell me if there is any difference between them:
(1) http://www.mediafire.com/file/oicwcr....x64.Test-1.7z
(2) http://www.mediafire.com/file/sb8rvh....x64.Test-2.7z
Note: It will probably be necessary to rename 'MediaInfo.whatever.dll' to 'MediaInfo.dll' in order to test them with an existing application.
Old 18th September 2010, 09:20   #211  |  Link
vitali5000
LoRd_MuldeR
I already wrote, after update there is no this problem, a problem exceptional in the resize to 720x400
, If I do 1280x720 that all works perfectly.
And With 32 bit version MeGUI - resize to 720x400 works fine.
Old 18th September 2010, 09:35   #212  |  Link
Zathor
As said before - please open the avs file in another tool like VirtualDub or MPC-HC (of course the x64 builds of these tools). I assume at the moment that the problem is the avisynth build you are using.
Old 18th September 2010, 09:43   #213  |  Link
vitali5000
AviSynth 2.5.8
http://sourceforge.net/projects/avis...Synth%202.5.8/
And
Version from 3/15/2010:
64 bit Avisynth 2.5.8 w/multithreading
http://forum.doom9.org/showthread.ph...05#post1374605
Old 18th September 2010, 10:06   #214  |  Link
vitali5000
I ask to apologise for my inattentiveness.
Featured Release 4/16/2010
+ Resize artifacting fixed
+ Horizontal resize code re-written to use SSE registers
+ Worth noting, often used functions Temporal Soften, Merge, etc have been tweaked for a decent speed gain
+ Bug found, fixed in memory copy routine, again
+ Universal binary, no longer need to distinguish between AMD and Intel builds
+ Optimized BitBlt memory copy Routine
+ Started implementation of SSE3/4 specific instructions when supported processor is detected
+ Removed most code paths intended to support CPU's without mmx/iSSE
+ Resize functions reworked to take advantage of extra registers available when processor is in 64bit mode
The problems was decided by the installation Avisynth64 built on 4/16/2010
I thank all for the help, you have very much helped me.
Old 18th September 2010, 11:15   #215  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR
I'm only interested in the MediaInfo.dll (x64 version) related crash. What you describe now isn't related to MediaInfo.
Please download the MediaInfo DLL's from my previous post and tell me which of those (if any) can reproduce the problem described here.
Old 18th September 2010, 13:32   #216  |  Link
Whimick
Hello,
Today I installed avisynth64_amd_3-19-10, onto my Amd Vista64 system. And prepared a sample MPG and tried to encode it to Xvid with Mod 16.
I them tried to encode it and this error happened:
-[Information] [18/09/2010 13:15:40] Encoding started
-[Error] An error occurred: xvid [error]: Avisynth open failure:
--[NoImage] Trying to retrieve width and height from input header
--[NoImage] xvid [info]: Avisynth detected
I then opened the avs file in VirtualDub64 with out any problems.
Any idear what I have done wrong.
Whimick
Old 20th September 2010, 14:14   #217  |  Link
pa7han
1th try with x64 bit, when I tried to create my d2v file, I get this error
but than when I want to close the megui, I get the following errors
Old 20th September 2010, 14:29   #218  |  Link
Zathor
Try starting MeGUI with admin permissions or move the folder to another location outside of "program files" e.g. c:\MeGUI.
Old 20th September 2010, 19:57   #219  |  Link
zanuda
zanuda's Avatar
crash
After last update
Problem signature:
Problem Event Name: APPCRASH
Application Name: x264_64.exe
Application Version: 0.0.0.0
Application Timestamp: 4c967cd5
Fault Module Name: TIVTC.dll
Fault Module Version: 1.0.5.0
Fault Module Timestamp: 4b9c46b6
Exception Code: c0000005
Exception Offset: 0000000000038d30
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1049
Additional Information 1: f956
Additional Information 2: f956f825d7fb560972e0baef5941ff9f
Additional Information 3: fda4
Additional Information 4: fda4e8ffb1432ccf8b4b3d112206ad97
zanuda is offline   Reply With Quote
Old 20th September 2010, 19:59   #220  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
"Fault Module Name: TIVTC.dll"
