Old 9th June 2018, 08:20   #441  |  Link
sdml
It's just ffmpeg disappears from process list and log says: Error Number of encoded frames does not match the source. Support of high bit depth is good, but can we get some switch to choose avs4x26x or ffmpeg?
sdml is offline   Reply With Quote
Old 9th June 2018, 11:06   #442  |  Link
Zathor
Could you please provide a full log? I have to see OS, AViSynth version, script used, ...
Old 9th June 2018, 11:15   #443  |  Link
imsrk48
imsrk48's Avatar
#Suggestion Please add multi tracks selection in DirectShowStream
Sent from my P4 using Tapatalk
imsrk48 is offline   Reply With Quote
Old 8th September 2018, 13:55   #444  |  Link
thecrowler
#Bug - MediaInfo.dll (x64) v18.08 causes an unhandled error
#Bug - MediaInfo.dll (x64) v18.08 causes an unhandled error in HD Stream Extractor (MeGUI 2872 x64).
Everything works fine with the old 18.05 MediaInfo.dll x64 (using "obsolete_mediainfo-18.05-64.7z" from "update_cache" folder).
thecrowler is offline   Reply With Quote
Old 9th February 2019, 11:44   #445  |  Link
Glarioo
Audio out of sync
Movie duration is 2:19:10.542
After job 3 (dgi) duration is duration 2:19:19.892?
[Information] Log
-[Information] Versions
--[Information] MeGUI: 2908 x64
--[Information] MeGUI Debug Data: available
--[Information] Update Check: development update server
--[Information] System Information
---[Information] Operating System: Windows 10 Pro 1803 x64 (10.0.17134.523)
---[Information] .NET Framework: 4.0 (4.0.0.0)
---[Information] .NET Framework: 4.7 (4.7.03056)
---[Information] Redistributables
----[Information] Microsoft Visual C++ 2010 x64: 10.0.40219
----[Information] Microsoft Visual C++ 2010 x86: 10.0.40219
----[Information] Microsoft Visual C++ 2012 x64: 11.0.61030
----[Information] Microsoft Visual C++ 2012 x86: 11.0.61030
----[Information] Microsoft Visual C++ 2013 x64: 12.0.30501
----[Information] Microsoft Visual C++ 2013 x86: 12.0.30501
----[Information] Microsoft Visual C++ 2017 x64: 14.14.26405
----[Information] Microsoft Visual C++ 2017 x86: 14.10.25017
---[Information] DPI: 100% (96/96)
---[Information] Monitor 1
----[Information] Resolution: 1920x1080
----[Information] Primary Screen: True
--[Information] Component Information
---[Information] Haali Media Splitter: 1.13.138.14 (14-04-2013)
---[Information] Haali DSS2: (14-04-2013)
---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
---[Information] MediaInfo: 18.05.0.0 (08-05-2018)
---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
---[Information] 7z: 9.20 (18-11-2010)
--[Information] AviSynth Information
---[Information] AviSynth Wrapper
----[Information] Version: 1.0.2847.0
----[Information] Date: 06-05-2018
----[Information] Interface: 3
----[Information] AviSynth Status: ignored as portable build is forced
---[Information] AviSynth portable
----[Information] File Version: 0.1
----[Information] File Date: 02-07-2018
----[Information] File Name: AviSynth+ 0.1 (r2728, MT, x86_64)
----[Information] File Path: c:\users\gebruiker\documents\blu ray\megui-2896-64\avisynth.dll
----[Information] AviSynth Version: AviSynth+ 0.1 (r2728, MT, x86_64)
----[Information] AviSynth+: true
----[Information] AviSynth MT: true
----[Information] AviSynth Status: active
-[Information] Update detection
--[Information] [9/02/2019 8:56:45] Using cached update config and server: http://megui.tmebi.de/test/
--[Information] [9/02/2019 8:56:45] No package requires an update
-[Information] OneClick
--[Information] [9/02/2019 9:01:45] MediaInfo
---[Information] File: G:\BLU_RAY (G)\NIET_SCHIETEN\BDMV\PLAYLIST\00000.mpls
---[Information] [9/02/2019 9:01:45] Blu-ray playlist detected. Getting information from eac3to.
---[Information] eac3toInfo
----[Information] [9/02/2019 9:01:45] Input: G:\BLU_RAY (G)\NIET_SCHIETEN\BDMV\PLAYLIST\00000.mpls
----[Information] [9/02/2019 9:01:45] Arguments: "G:\BLU_RAY (G)\NIET_SCHIETEN\BDMV\PLAYLIST\00000.mpls"
----[Information] [9/02/2019 9:01:45] 1) 00000.mpls, 00000.m2ts, 2:19:11
----[Information] [9/02/2019 9:01:46] - Chapters, 8 chapters
----[Information] [9/02/2019 9:01:46] - h264/AVC, 1080p24 (16:9)
----[Information] [9/02/2019 9:01:46] - DTS Master Audio, Dutch, multi-channel, 48kHz
----[Information] [9/02/2019 9:01:46] Feature Retrieval Completed
----[Information] [9/02/2019 9:01:46] Arguments: "G:\BLU_RAY (G)\NIET_SCHIETEN\BDMV\PLAYLIST\00000.mpls" 1) -progressnumbers
----[Information] [9/02/2019 9:01:47] M2TS, 1 video track, 1 audio track, 2 subtitle tracks, 2:19:11, 24p
----[Information] [9/02/2019 9:01:47] 1: Chapters, 8 chapters
----[Information] [9/02/2019 9:01:47] 2: h264/AVC, 1080p24 (16:9)
----[Information] [9/02/2019 9:01:47] 3: DTS Master Audio, Dutch, 5.1 channels, 24 bits, 48kHz
----[Information] [9/02/2019 9:01:48] (core: DTS, 5.1 channels, 1509kbps, 48kHz)
----[Information] [9/02/2019 9:01:48] 4: Subtitle (PGS), Dutch
----[Information] [9/02/2019 9:01:48] 5: Subtitle (PGS), Dutch
----[Information] [9/02/2019 9:01:48] v02 The video framerate is correct, but rather unusual.
----[Information] [9/02/2019 9:01:48] Stream Retrieval Completed
---[Information] General
----[Information] Format: Blu-ray Playlist
----[Information] FileSize: 314
----[Information] PlayTime: 02:19:10.541
---[Information] Video
----[Information] ID: 2
----[Information] CodecID: 27
----[Information] Format: AVC
----[Information] FormatInfo: Advanced Video Codec
----[Information] Width: 1920
----[Information] Height: 1080
----[Information] FrameCount: 200413
----[Information] FrameRate: 24.000
----[Information] Duration: 02:19:10.542
----[Information] ScanType: Progressive
----[Information] Bits Depth: 8
----[Information] AspectRatio: 1.778
----[Information] AspectRatioString: 16:9
----[Information] PixelAspectRatio: 1.000
----[Information] Delay: 600000.000
----[Information] Source: 00000.m2ts
---[Information] Audio
----[Information] ID: 3
----[Information] StreamOrder: 3
----[Information] CodecID: 134
----[Information] Format: DTS
----[Information] FormatInfo: Digital Theater Systems
----[Information] FormatProfile: MA / Core
----[Information] Muxing Mode: Stream extension
----[Information] SamplingRate: 48000
----[Information] SamplingRateString: 48.0 kHz
----[Information] Channels: 6
----[Information] ChannelsString: 6 channels
----[Information] ChannelPositionsString2: 3/2/0.1
----[Information] BitRateMode: VBR / CBR
----[Information] Language: nl
----[Information] LanguageString: Dutch
---[Information] Text
----[Information] ID: 4608
----[Information] StreamOrder: 4
----[Information] CodecID: 144
----[Information] Format: PGS
----[Information] ID: 4609
----[Information] StreamOrder: 5
---[Information] Chapters
----[Information] 00:00:00.000: Chapter 1
----[Information] 00:13:27.083: Chapter 2
----[Information] 00:34:45.541: Chapter 3
----[Information] 00:55:16.416: Chapter 4
----[Information] 01:15:55.166: Chapter 5
----[Information] 01:36:05.041: Chapter 6
----[Information] 01:56:41.000: Chapter 7
----[Information] 02:15:15.291: Chapter 8
----[Information] 02:19:10.500: Chapter 9
--[Information] [9/02/2019 9:03:00] Video: G:\BLU_RAY (G)\NIET_SCHIETEN\BDMV\PLAYLIST\00000.mpls
--[Information] [9/02/2019 9:03:00] Audio: G:\BLU_RAY (G)\NIET_SCHIETEN\BDMV\PLAYLIST\00000.mpls ([3] - DTS - 6 channels / 48.0 kHz / Dutch)
--[Information] [9/02/2019 9:03:00] Subtitle: G:\BLU_RAY (G)\NIET_SCHIETEN\BDMV\PLAYLIST\00000.mpls ([5] - PGS / Dutch / PGS-Origineel)
--[Information] [9/02/2019 9:03:00] Subtitle: G:\BLU_RAY (G)\NIET_SCHIETEN\BDMV\PLAYLIST\00000.mpls ([4] - PGS / Dutch)
-[Information] Log for job1 (ext, 00000.mpls -> btc4rech.pqp)
--[Information] [9/02/2019 9:04:24] Started handling job
--[Information] [9/02/2019 9:04:24] Preprocessing
--[Information] [9/02/2019 9:04:24] Job command line: "C:\Users\Gebruiker\Documents\Blu Ray\MeGUI-2896-64\tools\eac3to\eac3to.exe" "G:\BLU_RAY (G)\NIET_SCHIETEN\BDMV\PLAYLIST\00000.mpls" 2:"G:\BDRB_Work\btc4rech.pqp\00000.mkv" 3:"G:\BDRB_Work\btc4rech.pqp\00000 - [1][0] Dutch.dts" -core 5:"G:\BDRB_Work\btc4rech.pqp\00000 - [1][1] Dutch.sup" 4:"G:\BDRB_Work\btc4rech.pqp\00000 - [2][0] Dutch.sup" -progressnumbers
--[Information] [9/02/2019 9:04:24] Process started
--[Information] [9/02/2019 9:04:24] Standard output stream
---[Information] [9/02/2019 9:04:25] M2TS, 1 video track, 1 audio track, 2 subtitle tracks, 2:19:11, 24p
---[Information] [9/02/2019 9:04:25] 1: Chapters, 8 chapters
---[Information] [9/02/2019 9:04:25] 2: h264/AVC, 1080p24 (16:9)
---[Information] [9/02/2019 9:04:25] 3: DTS Master Audio, Dutch, 5.1 channels, 24 bits, 48kHz
---[Information] [9/02/2019 9:04:25] (core: DTS, 5.1 channels, 1509kbps, 48kHz)
---[Information] [9/02/2019 9:04:25] 4: Subtitle (PGS), Dutch
---[Information] [9/02/2019 9:04:25] 5: Subtitle (PGS), Dutch
---[Information] [9/02/2019 9:04:25] v02 The video framerate is correct, but rather unusual.
---[Information] [9/02/2019 9:04:25] a03 Extracting audio track number 3...
---[Information] [9/02/2019 9:04:25] a03 Extracting DTS core...
---[Information] [9/02/2019 9:04:25] s05 Extracting subtitle track number 5...
---[Information] [9/02/2019 9:04:25] v02 Extracting video track number 2...
---[Information] [9/02/2019 9:04:25] s04 Extracting subtitle track number 4...
---[Information] [9/02/2019 9:04:25] v02 Muxing video to Matroska...
---[Information] [9/02/2019 9:04:25] a03 Creating file "G:\BDRB_Work\btc4rech.pqp\00000 - [1][0] Dutch.dts"...
---[Information] [9/02/2019 9:04:29] s04 Creating file "G:\BDRB_Work\btc4rech.pqp\00000 - [2][0] Dutch.sup"...
---[Information] [9/02/2019 9:06:34] s05 Creating file "G:\BDRB_Work\btc4rech.pqp\00000 - [1][1] Dutch.sup"...
---[Information] [9/02/2019 9:06:47] Added fps value (24) to MKV header.
---[Information] [9/02/2019 9:06:47] Video track 2 contains 200413 frames.
---[Information] [9/02/2019 9:06:47] Subtitle track 5 contains 54 captions.
---[Information] [9/02/2019 9:06:47] Subtitle track 4 contains 1275 captions.
---[Information] [9/02/2019 9:06:47] eac3to processing took 2 minutes, 22 seconds.
---[Information] [9/02/2019 9:06:47] Done.
--[Information] [9/02/2019 9:04:24] Standard error stream
--[Information] [9/02/2019 9:06:47] Postprocessing
--[Information] [9/02/2019 9:06:47] Job completed
-[Information] Log for job2 (idx, 00000.mkv -> NIET_SCHIETEN_00000.dgi)
--[Information] [9/02/2019 9:06:47] Started handling job
--[Information] [9/02/2019 9:06:47] Preprocessing
--[Information] [9/02/2019 9:06:47] Job command line: "C:\Users\Gebruiker\Documents\Blu Ray\MeGUI-2896-64\tools\dgindexnv\dgindexnv.exe" -i "G:\BDRB_Work\btc4rech.pqp\00000.mkv" -o "G:\BDRB_Work\btc4rech.pqp\NIET_SCHIETEN_00000.dgi" -h
--[Information] [9/02/2019 9:06:47] Process started
--[Information] [9/02/2019 9:06:47] Standard output stream
---[Information] [9/02/2019 9:06:47] Project
--[Information] [9/02/2019 9:06:47] Standard error stream
--[Information] [9/02/2019 9:08:33] MediaInfo
---[Information] File: G:\BDRB_Work\btc4rech.pqp\NIET_SCHIETEN_00000.dgi
---[Information] Indexed file: G:\BDRB_Work\btc4rech.pqp\00000.mkv
----[Information] Format: Matroska
----[Information] FileSize: 18268517337
----[Information] PlayTime: 02:19:10.542
----[Information] ID: 1
----[Information] StreamOrder: 0
----[Information] CodecID: V_MPEG4/ISO/AVC
----[Information] FrameRateMode: CFR
----[Information] FrameRateModeString: Constant
----[Information] Delay: 0
----[Information] Default: No
----[Information] Forced: No
--[Information] [9/02/2019 9:08:33] Postprocessing
--[Information] [9/02/2019 9:08:33] Job completed
-[Information] Log for job3 (oneclick, 00000.mkv -> )
--[Information] [9/02/2019 9:08:33] Started handling job
--[Information] [9/02/2019 9:08:33] Preprocessing
--[Information] [9/02/2019 9:08:33] Processing thread started
--[Information] [9/02/2019 9:08:33] Desired size:
--[Information] [9/02/2019 9:08:33] Split size:
--[Information] [9/02/2019 9:08:35] Aspect ratio: 16:9 (1.778)
--[Information] [9/02/2019 9:08:35] Target device: Default
--[Information] [9/02/2019 9:08:36] Input resolution: 1920x1080
--[Information] [9/02/2019 9:08:36] Desired maximum width: 1920
--[Information] [9/02/2019 9:08:36] Output resolution: 1920x1080
--[Information] [9/02/2019 9:08:37] Automatic deinterlacing: False
--[Information] [9/02/2019 9:08:38] Generated AviSynth script
---[NoImage] global MeGUI_darx = 16
---[NoImage] global MeGUI_dary = 9
---[NoImage] LoadPlugin("C:\Users\Gebruiker\Documents\Blu Ray\MeGUI-2896-64\tools\dgindexnv\DGDecodeNV.dll")
---[NoImage] DGSource("G:\BDRB_Work\btc4rech.pqp\NIET_SCHIETEN_00000.dgi")
---[NoImage] ConvertBits(8)
---[NoImage] #deinterlace
---[NoImage] #crop
---[NoImage] #resize
---[NoImage] #denoise
--[Information] [9/02/2019 9:08:39] resolution: 1920x1080
--[Information] [9/02/2019 9:08:39] frame rate: 24000/1001
--[Information] [9/02/2019 9:08:39] frames: 200413
--[Information] [9/02/2019 9:08:39] length: 02:19:18.892
--[Information] [9/02/2019 9:08:39] aspect ratio: 16:9 (1.778)
--[Information] [9/02/2019 9:08:39] color space: YV12
--[Information] [9/02/2019 9:08:39] qpf file created: G:\BDRB_Work\btc4rech.pqp\NIET_SCHIETEN_00000.qpf
--[Information] [9/02/2019 9:08:40] Eliminating duplicate filenames
---[Information] [9/02/2019 9:08:40] Video output file: G:\BDRB_Work\btc4rech.pqp\00000_Video.264
---[Information] [9/02/2019 9:08:40] Muxed output file: G:\04_FILMS\NIET_SCHIETEN_00000.mkv
---[Information] [9/02/2019 9:08:40] Encodable audio stream 0: G:\BDRB_Work\btc4rech.pqp\00000 - [1][0] Dutch_audio.ac3
--[Information] [9/02/2019 9:08:40] Postprocessing
--[Information] [9/02/2019 9:08:40] Job completed
-[Information] Log for job1 (audio, 00000 - [1][0] Dutch.dts -> 00000 - [1][0] Dutch_audio.ac3)
--[Information] [9/02/2019 9:08:40] Started handling job
--[Information] [9/02/2019 9:08:40] Preprocessing
--[Information] [9/02/2019 9:08:40] MediaInfo
---[Information] File: G:\BDRB_Work\btc4rech.pqp\00000 - [1][0] Dutch.dts
----[Information] FileSize: 1575114320
----[Information] PlayTime: 02:19:10.507
----[Information] BitRateMode: CBR
----[Information] [9/02/2019 9:08:41] The language information is not available for this track. The default MeGUI language has been selected.
--[Information] [9/02/2019 9:08:41] Trying to open the file with LWLibavAudioSource()
--[Information] [9/02/2019 9:08:47] Successfully opened the file with LWLibavAudioSource()
--[Information] [9/02/2019 9:08:52] AviSynth script
Old 9th February 2019, 11:48   #446  |  Link
Glarioo
Log Part 2
---[NoImage] ClearAutoloadDirs()
---[NoImage] AddAutoloadDir("C:\Users\Gebruiker\Documents\Blu Ray\MeGUI-2896-64\tools\avs\plugins")
---[NoImage] LoadPlugin("C:\Users\Gebruiker\Documents\Blu Ray\MeGUI-2896-64\tools\lsmash\LSMASHSource.dll")
---[NoImage] LWLibavAudioSource("G:\BDRB_Work\btc4rech.pqp\00000 - [1][0] Dutch.dts")
---[NoImage] # detected channels: 6
---[NoImage] # detected channel positions: 3/2/0.1
---[NoImage] 32==Audiobits(last)?ConvertAudioTo16bit(last):last
---[NoImage] return last
--[Information] [9/02/2019 9:08:52] Command line used: -i - -y -acodec ac3 -ab 640k "{0}"
--[Information] [9/02/2019 9:08:52] AviSynth script environment opened
--[Information] [9/02/2019 9:08:58] Script loaded
--[Information] [9/02/2019 9:08:58] Output Decoder
---[Information] [9/02/2019 9:08:58] Channels: 6
---[Information] [9/02/2019 9:08:58] Bits per sample: 16
---[Information] [9/02/2019 9:08:58] Sample rate: 48000
--[Information] [9/02/2019 9:08:58] Job command line: C:\Users\Gebruiker\Documents\Blu Ray\MeGUI-2896-64\tools\ffmpeg\ffmpeg.exe -i - -y -acodec ac3 -ab 640k "G:\BDRB_Work\btc4rech.pqp\00000 - [1][0] Dutch_audio.ac3"
--[Information] [9/02/2019 9:08:58] Process started
--[Information] [9/02/2019 9:08:58] Standard output stream
--[Information] [9/02/2019 9:08:58] Standard error stream
---[Information] [9/02/2019 9:08:58] ffmpeg version 4.1 Copyright (c) 2000-2018 the FFmpeg developers
---[Information] [9/02/2019 9:08:58] built with gcc 8.2.1 (GCC) 20181017
---[Information] [9/02/2019 9:08:58] configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-libxvid --enable-libaom --enable-libmfx --enable-amf --enable-ffnvcodec --enable-cuvid --enable-d3d11va --enable-nvenc --enable-nvdec --enable-dxva2 --enable-avisynth
---[Information] [9/02/2019 9:08:58] libavutil 56. 22.100 / 56. 22.100
---[Information] [9/02/2019 9:08:58] libavcodec 58. 35.100 / 58. 35.100
---[Information] [9/02/2019 9:08:58] libavformat 58. 20.100 / 58. 20.100
---[Information] [9/02/2019 9:08:58] libavdevice 58. 5.100 / 58. 5.100
---[Information] [9/02/2019 9:08:58] libavfilter 7. 40.101 / 7. 40.101
---[Information] [9/02/2019 9:08:58] libswscale 5. 3.100 / 5. 3.100
---[Information] [9/02/2019 9:08:58] libswresample 3. 3.100 / 3. 3.100
---[Information] [9/02/2019 9:08:58] libpostproc 55. 3.100 / 55. 3.100
---[Information] [9/02/2019 9:08:58] Guessed Channel Layout for Input Stream #0.0 : 5.1
---[Information] [9/02/2019 9:08:58] Input #0, w64, from 'pipe:':
---[Information] [9/02/2019 9:08:58] Duration: N/A, bitrate: 4608 kb/s
---[Information] [9/02/2019 9:08:58] Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, 5.1, s16, 4608 kb/s
---[Information] [9/02/2019 9:08:58] Stream mapping:
---[Information] [9/02/2019 9:08:58] Stream #0:0 -> #0:0 (pcm_s16le (native) -> ac3 (native))
---[Information] [9/02/2019 9:08:58] Output #0, ac3, to 'G:\BDRB_Work\btc4rech.pqp\00000 - [1][0] Dutch_audio.ac3':
---[Information] [9/02/2019 9:08:58] Metadata:
---[Information] [9/02/2019 9:08:58] encoder : Lavf58.20.100
---[Information] [9/02/2019 9:08:58] Stream #0:0: Audio: ac3, 48000 Hz, 5.1, fltp, 640 kb/s
---[Information] [9/02/2019 9:08:58] encoder : Lavc58.35.100 ac3
---[Information] [9/02/2019 9:10:07] video:0kB audio:652385kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000%
--[Information] [9/02/2019 9:10:07] MediaInfo
---[Information] File: G:\BDRB_Work\btc4rech.pqp\00000 - [1][0] Dutch_audio.ac3
----[Information] Format: AC-3
----[Information] FileSize: 668042240
----[Information] PlayTime: 02:19:10.528
----[Information] FormatInfo: Audio Coding 3
----[Information] [9/02/2019 9:10:07] The language information is not available for this track. The default MeGUI language has been selected.
--[Information] [9/02/2019 9:10:07] Postprocessing
--[Information] [9/02/2019 9:10:07] Job completed
-[Information] Log for job2 (video, NIET_SCHIETEN_00000.avs -> )
--[Information] [9/02/2019 9:10:07] Started handling job
--[Information] [9/02/2019 9:10:07] Preprocessing
--[Information] [9/02/2019 9:10:07] AviSynth input script
---[NoImage] #crop
--[Information] [9/02/2019 9:10:09] resolution: 1920x1080
--[Information] [9/02/2019 9:10:09] frame rate: 24000/1001
--[Information] [9/02/2019 9:10:09] frames: 200413
--[Information] [9/02/2019 9:10:09] length: 02:19:18.892
--[Information] [9/02/2019 9:10:09] aspect ratio (avs): 16:9 (1.778)
--[Information] [9/02/2019 9:10:09] color space: YV12
--[Information] [9/02/2019 9:10:09] Job command line: "C:\Users\Gebruiker\Documents\Blu Ray\MeGUI-2896-64\tools\x264\x264.exe" --level 4.1 --preset slow --pass 1 --bitrate 12073 --stats "G:\BDRB_Work\btc4rech.pqp\00000_Video.stats" --keyint 240 --min-keyint 24 --vbv-bufsize 50000 --vbv-maxrate 50000 --me umh --qpfile "G:\BDRB_Work\btc4rech.pqp\NIET_SCHIETEN_00000.qpf" --sar 1:1 --frames 200413 --output NUL "G:\BDRB_Work\btc4rech.pqp\NIET_SCHIETEN_00000.avs"
--[Information] [9/02/2019 9:10:09] Process started
--[Information] [9/02/2019 9:10:09] Standard output stream
--[Information] [9/02/2019 9:10:09] Standard error stream
---[Information] [9/02/2019 9:10:10] avs [info]: 1920x1080p 1:1 @ 24000/1001 fps (cfr)
---[Information] [9/02/2019 9:10:10] x264 [info]: using SAR=1/1
---[Information] [9/02/2019 9:10:10] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
---[Information] [9/02/2019 9:10:10] x264 [info]: profile Main, level 4.1, 4:2:0, 8-bit
---[Information] [9/02/2019 9:27:26] x264 [info]: frame I:2477 Avg QP: 8.36 size:233988
---[Information] [9/02/2019 9:27:26] x264 [info]: frame P:56760 Avg QP:11.26 size:105195
---[Information] [9/02/2019 9:27:26] x264 [info]: frame B:141176 Avg QP:14.30 size: 42437
---[Information] [9/02/2019 9:27:26] x264 [info]: consecutive B-frames: 4.6% 2.9% 4.5% 88.0%
---[Information] [9/02/2019 9:27:26] x264 [info]: mb I I16..4: 48.6% 0.0% 51.4%
---[Information] [9/02/2019 9:27:26] x264 [info]: mb P I16..4: 30.9% 0.0% 0.0% P16..4: 42.2% 0.0% 0.0% 0.0% 0.0% skip:26.9%
---[Information] [9/02/2019 9:27:26] x264 [info]: mb B I16..4: 9.8% 0.0% 0.0% B16..8: 32.1% 0.0% 0.0% direct:18.8% skip:39.4% L0:34.6% L1:33.6% BI:31.8%
---[Information] [9/02/2019 9:27:26] x264 [info]: final ratefactor: 13.83
---[Information] [9/02/2019 9:27:26] x264 [info]: direct mvs spatial:99.7% temporal:0.3%
---[Information] [9/02/2019 9:27:26] x264 [info]: coded y,uvDC,uvAC intra: 79.3% 66.7% 45.7% inter: 29.6% 25.7% 3.4%
---[Information] [9/02/2019 9:27:26] x264 [info]: i16 v,h,dc,p: 32% 16% 34% 19%
---[Information] [9/02/2019 9:27:26] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 24% 19% 15% 7% 7% 8% 6% 7% 7%
---[Information] [9/02/2019 9:27:26] x264 [info]: i8c dc,h,v,p: 54% 18% 23% 5%
---[Information] [9/02/2019 9:27:26] x264 [info]: Weighted P-Frames: Y:1.2% UV:0.7%
---[Information] [9/02/2019 9:27:26] x264 [info]: kb/s:12003.01
---[Information] [9/02/2019 9:27:26] encoded 200413 frames, 193.29 fps, 12003.01 kb/s
--[Information] [9/02/2019 9:27:26] Postprocessing
--[Information] [9/02/2019 9:27:26] Job completed
-[Information] Log for job4 (video, NIET_SCHIETEN_00000.avs -> 00000_Video.264)
--[Information] [9/02/2019 9:27:26] Started handling job
--[Information] [9/02/2019 9:27:26] Preprocessing
--[Information] [9/02/2019 9:27:26] AviSynth input script
---[NoImage] #crop
--[Information] [9/02/2019 9:27:27] resolution: 1920x1080
--[Information] [9/02/2019 9:27:27] frame rate: 24000/1001
--[Information] [9/02/2019 9:27:27] frames: 200413
--[Information] [9/02/2019 9:27:27] length: 02:19:18.892
--[Information] [9/02/2019 9:27:27] aspect ratio (avs): 16:9 (1.778)
--[Information] [9/02/2019 9:27:27] color space: YV12
--[Information] [9/02/2019 9:27:27] Job command line: "C:\Users\Gebruiker\Documents\Blu Ray\MeGUI-2896-64\tools\x264\x264.exe" --level 4.1 --preset slow --pass 2 --bitrate 12073 --stats "G:\BDRB_Work\btc4rech.pqp\00000_Video.stats" --keyint 240 --min-keyint 24 --vbv-bufsize 50000 --vbv-maxrate 50000 --me umh --sar 1:1 --frames 200413 --output "G:\BDRB_Work\btc4rech.pqp\00000_Video.264" "G:\BDRB_Work\btc4rech.pqp\NIET_SCHIETEN_00000.avs"
--[Information] [9/02/2019 9:27:28] Process started
--[Information] [9/02/2019 9:27:28] Standard output stream
--[Information] [9/02/2019 9:27:28] Standard error stream
---[Information] [9/02/2019 9:27:34] avs [info]: 1920x1080p 1:1 @ 24000/1001 fps (cfr)
---[Information] [9/02/2019 9:27:34] x264 [info]: using SAR=1/1
---[Information] [9/02/2019 9:27:34] x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
---[Information] [9/02/2019 9:27:34] x264 [info]: profile High, level 4.1, 4:2:0, 8-bit
---[Information] [9/02/2019 11:00:56] x264 [info]: frame I:2477 Avg QP: 9.23 size:234026
---[Information] [9/02/2019 11:00:56] x264 [info]: frame P:56760 Avg QP:12.73 size:104594
---[Information] [9/02/2019 11:00:56] x264 [info]: frame B:141176 Avg QP:14.42 size: 43166
---[Information] [9/02/2019 11:00:56] x264 [info]: consecutive B-frames: 4.6% 2.9% 4.5% 88.0%
---[Information] [9/02/2019 11:00:56] x264 [info]: mb I I16..4: 29.1% 55.6% 15.3%
---[Information] [9/02/2019 11:00:56] x264 [info]: mb P I16..4: 2.8% 18.8% 2.2% P16..4: 23.6% 16.8% 8.1% 0.0% 0.0% skip:27.7%
---[Information] [9/02/2019 11:00:56] x264 [info]: mb B I16..4: 0.7% 3.6% 0.5% B16..8: 31.9% 10.4% 2.3% direct: 9.8% skip:40.7% L0:45.7% L1:38.9% BI:15.4%
---[Information] [9/02/2019 11:00:56] x264 [info]: 8x8 transform intra:75.0% inter:51.6%
---[Information] [9/02/2019 11:00:56] x264 [info]: direct mvs spatial:96.7% temporal:3.3%
---[Information] [9/02/2019 11:00:56] x264 [info]: coded y,uvDC,uvAC intra: 80.6% 76.3% 58.5% inter: 29.8% 31.3% 6.2%
---[Information] [9/02/2019 11:00:56] x264 [info]: i16 v,h,dc,p: 41% 15% 19% 25%
---[Information] [9/02/2019 11:00:56] x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 17% 12% 24% 7% 8% 9% 7% 9% 8%
---[Information] [9/02/2019 11:00:56] x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 22% 17% 19% 6% 8% 8% 7% 6% 6%
---[Information] [9/02/2019 11:00:56] x264 [info]: i8c dc,h,v,p: 53% 20% 20% 7%
---[Information] [9/02/2019 11:00:56] x264 [info]: Weighted P-Frames: Y:1.3% UV:0.7%
---[Information] [9/02/2019 11:00:56] x264 [info]: ref P L0: 54.2% 9.4% 24.5% 11.4% 0.5% 0.0%
---[Information] [9/02/2019 11:00:56] x264 [info]: ref B L0: 84.8% 12.0% 3.3%
---[Information] [9/02/2019 11:00:56] x264 [info]: ref B L1: 94.7% 5.3%
---[Information] [9/02/2019 11:00:56] x264 [info]: kb/s:12068.95
---[Information] [9/02/2019 11:00:56] encoded 200413 frames, 35.78 fps, 12068.94 kb/s
--[Information] [9/02/2019 11:00:56] Final statistics
---[Information] [9/02/2019 11:00:56] Video Bitrate Desired: 12073 kbit/s
---[Information] [9/02/2019 11:00:56] Video Bitrate Obtained (approximate): 12068 kbit/s
--[Information] [9/02/2019 11:00:56] MediaInfo
---[Information] File: G:\BDRB_Work\btc4rech.pqp\00000_Video.264
----[Information] FileSize: 12610375979
----[Information] FrameRate: 23.976
--[Information] [9/02/2019 11:00:56] Postprocessing
--[Information] [9/02/2019 11:00:56] Job completed
-[Information] Log for job5 (mux, 00000_Video.264 -> NIET_SCHIETEN_00000.mkv)
--[Information] [9/02/2019 11:00:56] Started handling job
--[Information] [9/02/2019 11:00:56] Preprocessing
----[Information] [9/02/2019 11:00:56] The language information is not available for this track. The default MeGUI language has been selected.
---[Information] File: G:\BDRB_Work\btc4rech.pqp\00000 - [1][1] Dutch.sup
----[Information] FileSize: 1368266
---[Information] File: G:\BDRB_Work\btc4rech.pqp\00000 - [2][0] Dutch.sup
----[Information] FileSize: 30482138
Old 9th February 2019, 11:49   #447  |  Link
Glarioo
Log Part 3
--[Information] [9/02/2019 11:00:57] Job command line: "C:\Users\Gebruiker\Documents\Blu Ray\MeGUI-2896-64\tools\mkvmerge\mkvmerge.exe" --output "G:\04_FILMS\NIET_SCHIETEN_00000.mkv" --engage keep_bitstream_ar_info --default-duration 0:24000/1001fps --video-tracks 0 --no-audio --no-subtitles --no-chapters "G:\BDRB_Work\btc4rech.pqp\00000_Video.264" --language 0:dut --audio-tracks 0 --no-chapters --no-video --no-subtitles "G:\BDRB_Work\btc4rech.pqp\00000 - [1][0] Dutch_audio.ac3" --language 0:dut --track-name "0:PGS-Origineel" --default-track 0:yes --forced-track 0:no --subtitle-tracks 0 --no-video --no-audio "G:\BDRB_Work\btc4rech.pqp\00000 - [1][1] Dutch.sup" --language 0:dut --default-track 0:no --forced-track 0:no --subtitle-tracks 0 --no-video --no-audio "G:\BDRB_Work\btc4rech.pqp\00000 - [2][0] Dutch.sup" --chapters "G:\04_FILMS\NIET_SCHIETEN_00000_chptmp.txt" --engage no_cue_duration --engage no_cue_relative_position --ui-language en
--[Information] [9/02/2019 11:00:57] Process started
--[Information] [9/02/2019 11:00:57] Standard output stream
---[Information] [9/02/2019 11:00:57] mkvmerge v30.1.0 ('Forever And More') 64-bit
---[Information] [9/02/2019 11:00:57] 'G:\BDRB_Work\btc4rech.pqp\00000_Video.264': Using the demultiplexer for the format 'AVC/h.264'.
---[Information] [9/02/2019 11:00:57] 'G:\BDRB_Work\btc4rech.pqp\00000 - [1][0] Dutch_audio.ac3': Using the demultiplexer for the format 'AC-3'.
---[Information] [9/02/2019 11:00:57] 'G:\BDRB_Work\btc4rech.pqp\00000 - [1][1] Dutch.sup': Using the demultiplexer for the format 'PGSSUP'.
---[Information] [9/02/2019 11:00:57] 'G:\BDRB_Work\btc4rech.pqp\00000 - [2][0] Dutch.sup': Using the demultiplexer for the format 'PGSSUP'.
---[Information] [9/02/2019 11:00:57] 'G:\BDRB_Work\btc4rech.pqp\00000_Video.264' track 0: Using the output module for the format 'AVC/h.264 (unframed)'.
---[Information] [9/02/2019 11:00:57] 'G:\BDRB_Work\btc4rech.pqp\00000 - [1][0] Dutch_audio.ac3' track 0: Using the output module for the format 'AC-3'.
---[Information] [9/02/2019 11:00:57] 'G:\BDRB_Work\btc4rech.pqp\00000 - [1][1] Dutch.sup' track 0: Using the output module for the format 'HDMV PGS'.
---[Information] [9/02/2019 11:00:57] 'G:\BDRB_Work\btc4rech.pqp\00000 - [2][0] Dutch.sup' track 0: Using the output module for the format 'HDMV PGS'.
---[Information] [9/02/2019 11:00:57] The file 'G:\04_FILMS\NIET_SCHIETEN_00000.mkv' has been opened for writing.
---[Information] [9/02/2019 11:00:57] 'G:\BDRB_Work\btc4rech.pqp\00000_Video.264' track 0: Extracted the aspect ratio information from the MPEG-4 layer 10 (AVC) video data and set the display dimensions to 1920/1080.
---[Information] [9/02/2019 11:02:22] The cue entries (the index) are being written...
---[Information] [9/02/2019 11:02:24] Multiplexing took 1 minute 27 seconds.
--[Information] [9/02/2019 11:00:57] Standard error stream
--[Information] [9/02/2019 11:02:24] MediaInfo
---[Information] File: G:\04_FILMS\NIET_SCHIETEN_00000.mkv
----[Information] FileSize: 13294417175
----[Information] PlayTime: 02:19:18.892
----[Information] Duration: 02:19:18.892
----[Information] Default: Yes
----[Information] StreamOrder: 1
----[Information] CodecID: A_AC3
----[Information] StreamOrder: 2
----[Information] CodecID: S_HDMV/PGS
----[Information] CodecIDInfo: Picture based subtitle format used on BDs/HD-DVDs
----[Information] Title: PGS-Origineel
----[Information] 00:00:00.000: en:Chapter 1
----[Information] 00:13:27.890: en:Chapter 2
----[Information] 00:34:47.626: en:Chapter 3
----[Information] 00:55:19.732: en:Chapter 4
----[Information] 01:15:59.721: en:Chapter 5
----[Information] 01:36:10.806: en:Chapter 6
----[Information] 01:56:48.001: en:Chapter 7
----[Information] 02:15:23.406: en:Chapter 8
----[Information] 02:19:18.850: en:Chapter 9
--[Information] [9/02/2019 11:02:25] Postprocessing
--[Information] [9/02/2019 11:02:25] Job completed
-[Information] Log for job6 (cleanup, NIET_SCHIETEN_00000.mkv -> )
--[Information] [9/02/2019 11:02:25] Started handling job
--[Information] [9/02/2019 11:02:25] Preprocessing
--[Information] [9/02/2019 11:02:25] Delete Intermediate Files option set: False
--[Information] [9/02/2019 11:02:26] Postprocessing
--[Information] [9/02/2019 11:02:26] Job completed
-[Information] [9/02/2019 11:02:56] Shutdown initiated
Old 9th February 2019, 11:51   #448  |  Link
sneaker_ger
On the top it says source is 24.000 fps. But near bottom it says 24000/1001 fps.
Old 9th February 2019, 11:54   #449  |  Link
Glarioo
Audio out of sync
After a quick test with One Click Encoder(I always use this).
The problem occurs when I use Video Imput Select Folder (Blu Ray). No problem so far with Video Imput Select File (MKV).
Old 9th February 2019, 12:05   #450  |  Link
Glarioo
It is a 24.000 fps movie.
Old 9th February 2019, 12:34   #451  |  Link
pommesmatte
I also noticed, that 24.0 fps movies are not properly handled. But changing fps while muxing with mkvmerge is my workaround.
pommesmatte is offline   Reply With Quote
Old 9th February 2019, 12:39   #452  |  Link
sneaker_ger
So the problem is in DGDecNV? Maybe you can ask the author if fps detection can be improved.
Workaround would be to add
AssumeFPS(24, 1, false)
to the end of the script.
Old 9th February 2019, 14:17   #453  |  Link
Glarioo
Audio out of sync
From the same Bluray folder, ripped with AnyDVD, I made an mkv file with MakeMKV. Audio is in sync and 24fps.
Problem is only there with a 24 fps movie ripped to Bluray folder.
Workaround: rip to .mkv instead to folder?
Old 9th February 2019, 14:19   #454  |  Link
videoh
Useful n00b
With MKVs there can be the case where the elementary stream specifies one frame rate and the container specifies a different one. The most recent DGDecNV should prefer the container rate for MKVs. If that is not happening, then please link me to an MKV that behaves that way. For an M2TS there is only the elementary stream value for DGDecNV to know. If you have an M2TS that you claim is 24 but is being detected as 23.976, then please link me to an M2TS that behaves that way.
Also, there is a bug in cropping in DGDecNV 165. I will slipstream a fix for that later today.
Old 9th February 2019, 14:20   #455  |  Link
Glarioo
Where can I find that script file?
Old 9th February 2019, 14:29   #456  |  Link
Glarioo
First film with a sync problem is "Niet Schieten", The second "Piercing". Both 24fps.
Movies ripped to folder and than through MeGUI = audio out of sync.
Make an MKV from the same folders with MakeMKV and than through MeGUI = audio in sync.
https://www.imdb.com/title/tt7534314/
https://www.imdb.com/title/tt6516314/
Old 9th February 2019, 15:15   #457  |  Link
pommesmatte
Last Movies for me were "Hostiles" and "Keepers".
MKV with videostream demuxed reported 24.000 fps vie MediaInfo yet DGIndexNV detects 24000/1001.
Old 9th February 2019, 18:06   #458  |  Link
videoh
Useful n00b
I can't help you without the stream samples I asked for. In any case, sync is not controlled by DGDecNV, it's your process or your third-party app.
Old 10th February 2019, 09:21   #459  |  Link
Glarioo
Deleted my old MeGUI folder and re-downloaded MeGUI. Audio out of sync with 24fps bluray folder is still there.
Old 10th February 2019, 09:31   #460  |  Link
Glarioo
I wish I knew how to do that.
That stream is 21,7GB.
[MODERATOR EDIT]
Your mediainfo image was deleted because is usseless.
We already know than MediaInfo (in MeGUI log) detect 24 fps, we need the full mkv to help videoh.
Of course you can't upload it because size and copyrigth limitations.
See next post.
