10th February 2019, 12:14 | #461 | Link |
Do you still have the intermediate "G:\BDRB_Work\btc4rech.pqp\00000.mkv" file MeGUI created? Open that in MKVToolNix GUI, go to "Output" tab, "Split mode": "by parts based on timestamps" and set "-01:00" (without quotes). You can deactivate all tracks except video. Then click "Start Multiplexing" on the bottom. Upload the created file to e.g. sendspace.com and post the link here.
10th February 2019, 12:43 | #462 | Link |
As I'm experiencing the same problem, here is the first minute of the videostream from "Feinde - Hostiles" demuxed with eac3to.
https://www.sendspace.com/file/4051vp |
10th February 2019, 12:53 | #463 | Link | |||
The intermediate file 00000.mkv was created by eac3to with:
10th February 2019, 13:19 | #465 | Link |
Niet Schieten m2ts file created with CloneBD (uncompressed) https://www.sendspace.com/file/ma3gub
Maybe it has something to do with eac3to. MeGui does use this for bluray folder and not for mkv. With mkv's @ 24fps there is no problem. Last edited by Glarioo; 10th February 2019 at 13:23. |
10th February 2019, 13:29 | #466 | Link | |
With the pommesmatte sample all soft (eac3to, MediaInfo, MkvInfo) show fps 24 but the .dgi show 24000 / 1001 The same with Glarioo sample converted to mkv by eac3to or MkvToolNix (is not a problem of eac3to, Haali muxer). But the Glarioo sample m2ts indexed by DGDecNV show the correct fps 24 / 1
BeHappy, AviSynth audio transcoder. Last edited by tebasuna51; 10th February 2019 at 13:41. Reason: Add info |
10th February 2019, 13:41 | #467 | Link |
@tebasuna51
I don't have DGDecNV. Can you check what it says for the following sample: https://www.sendspace.com/file/g22pnh |
10th February 2019, 13:47 | #468 | Link | |
10th February 2019, 13:49 | #469 | Link | |
Works fine:
10th February 2019, 13:51 | #470 | Link |
Ok, thx. It's basically the same sample but muxed with mkvmerge. Somehow eac3to doesn't write all SPS VUI parameters into mkv CodecPrivate. And the SPS looks strange anyways. I'm wondering if this is also in the original m2ts.
But either way it shouldn't result in detection as 23.976 fps. |
10th February 2019, 14:16 | #471 | Link |
The difference between 24.000fpsSample.mkv in mkv header is the:
Default duration (number of nanoseconds per frame) : 41666666 (24.000000384000006144000098304002 fps) In mkv created by eac3to or MkvToolNix from the m2ts, or in pommesmatte sample: Default duration (number of nanoseconds per frame) : 41666667 (23.999999808000001535999987712 fps) It can be the problem videoh?
10th February 2019, 15:55 | #474 | Link |
Useful n00b
Thank you for the streams and analysis, guys. The problem is indeed in DGIndexNV. It's caused by the frame rate normalization code I added to be compatible with Vapoursynth. It's a simple fix already tested locally. I will release a slipstream later today.
