Old 27th March 2019, 13:49   #3161  |  Link
dr_ml422
All night now and I'm getting that " can not find Title 1 " error. Clean install, opens up in MPC classic etc..., tried w/ and w/out the .srt file and nothing. Everything was well until that file. It's a regular .,mp4 w/aac and etc... Here's the log file.
<3/27/2019 8:01:25 AM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: Burn DVD
DVD Label: 6.THE_WOLVERINE_2013~1
DVD Menu: Static Menu
Output Folder: C:\Users\Noloc42\Videos
Delete Temp Assets Files: Yes
Delete Temp Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Video Source Filter: A2DSource
AVS Audio Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
Frame Adjust Strategy: 0
FPS Hard Conversion: 0
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 0
Video BitRate Min: 2500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 16pt (240,240,240)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: D:\
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Unload ActiveMovie Library: 1
Adjust DirectShow Filters at runtime: 1
Save General Settings: 0
SYSTEM INFO
Processor Name: AMD Athlon(tm) 64 X2 Dual Core Processor 5000+
Operating System: Windows 10 (10.0.17763) 64 bit
User has Admin Rights: YES
Running with Elevated Privileges: YES
Available Output Disc Space: 134 GB
AviSynth is installed: YES (release 2.6.0)
LAV Filters is installed: YES (release 0.74.1)
ffdshow is installed: NO
CODECS REPORT
H.264/AVC: Enhanced Video Renderer
Xvid: Enhanced Video Renderer
DivX 4/5/6: Enhanced Video Renderer
Other MPG4: Enhanced Video Renderer
DV: LAV Video Decoder
MPEG1: LAV Video Decoder
MPEG2: LAV Video Decoder
AAC: LAV Audio Decoder
MP3: LAV Audio Decoder
MP2: LAV Audio Decoder
AC3: LAV Audio Decoder
<3/27/2019 8:01:36 AM>
AVStoDVD Project ended successfully.
Log file created by AVStoDVD Release 2.8.8
It says No FFDshow? I just finished installing the Klite Full Codec pack which I think includes ffdshow if I'm not mistaken.
another one just in case.
<3/27/2019 4:14:52 AM>
START PROCESS
PROJECT SETTINGS
DVD Label: 6.THEWOLVERINE EXTENDED 2013~1
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
DVD Burning Drive: D: HL-DT-ST DVDRAM GH24NSB0 LF00
DVD Burning Speed: 8x
SYSTEM INFO
Running with Elevated Privileges: NO (3)
Available Output Disc Space: 144 GB
LAV Filters is installed: YES (release 0.73.1)
CODECS REPORT
H.264/AVC: LAV Video Decoder
Xvid: LAV Video Decoder
DivX 4/5/6: LAV Video Decoder
Other MPG4: LAV Video Decoder
<3/27/2019 4:15:03 AM>
dr_ml422 is offline   Reply With Quote
Old 27th March 2019, 15:10   #3162  |  Link
manolito
manolito's Avatar
A few remarks about your log files:
Why did you cut out the most relevant parts? Please post the full log file so we can see the error messages.
Codec Packs like K-Lite are evil. AVStoDVD supports LAV Filters and ffdshow as DirectShow Filters. But just one or the other, not both. And then you overlooked the fact that starting with Win7 Microsoft decided that users are not smart enough to decide which DS filters to use, so they created a "Preferred Filters" registry entry (not editable by users without first grabbing the rights), and no matter which different filters a user installs, they won't get used.
The safest way for AVStoDVD is to go to "Codecs -> Preferred Directshow Codecs Setup" and set ALL codecs to LAV Filters. If your LAV Filters were installed by a codec pack you might have the additional problem that the codec pack might have altered the LAV configuration. It looks like for your second log file you did use LAV Filters exclusively, so maybe a codec pack excluded some formats from the LAV configuration.
To rule out all DirectShow related problems you can specify "FFmpegSource" for video and audio under "Preferences -> AviSynth". This will use ffms2 as your source filter bypassing DirectShow completely.
To fully understand your issues please post the full AVStoDVD log file, and a MediaInfo report about your source file would also be very useful.
Old 29th March 2019, 03:13   #3163  |  Link
dr_ml422
I downloaded Klite Full afterwards not before. It uses LAV now and not ffdshow. I made sure all the directshow filters were set to LAV both 32 bit and 64 bit. Should uninstall Klite Full along with MPC HC? This was my first log of that file. I have a more recent one as well that says .Net framework 2 not found on my computer? Something's not right. Worked just fine then all of a sudden all these issues. Here goes:
<3/27/2019 4:04:57 AM>
START PROCESS
PROJECT SETTINGS
DVD Label: 6THEWO~1 EXTENDED 2013
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
SYSTEM INFO
CODECS REPORT
<3/27/2019 4:05:05 AM>
<3/27/2019 4:24:38 AM>
START PROCESS
PROJECT SETTINGS
DVD Output Setup: DVD Folder
DVD Label: 6THEWO~1
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
SYSTEM INFO
CODECS REPORT
<3/27/2019 4:24:47 AM>
<3/27/2019 4:26:22 AM>
START PROCESS
PROJECT SETTINGS
DVD Label: 6THEWO~1
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
SYSTEM INFO
CODECS REPORT
<3/27/2019 4:26:25 AM>
<3/27/2019 4:33:32 AM>
START PROCESS
PROJECT SETTINGS
DVD Label: 6THEWO~1
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
SYSTEM INFO
CODECS REPORT
<3/27/2019 4:33:36 AM>
<3/27/2019 4:41:16 AM>
START PROCESS
PROJECT SETTINGS
DVD Label: 6THEWO~1
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
SYSTEM INFO
CODECS REPORT
<3/27/2019 4:41:18 AM>
<3/27/2019 7:12:34 AM>
START PROCESS
PROJECT SETTINGS
DVD Label: 6THEWO~1
PREFERENCES
MultiThread: 1
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 0
DVD Audio Format: 0
Normalize Audio: 0
Auto Delay Audio: 1
SYSTEM INFO
CODECS REPORT
<3/27/2019 7:12:42 AM>
Old 29th March 2019, 12:29   #3164  |  Link
manolito
manolito's Avatar
All your logs look incomplete. Right after the codecs report comes the message "Project ended successfully", and the time stamp of this message shows only less than 10 seconds after the project start.
Here is my log of a complete short conversion:
<29.03.2019 11:12:04>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: PAL
DVD Size: 266/4450 MB (6%)
DVD Output Setup: MPEG2-Datei
DVD Label: DVD
DVD Menu: No Menu
Output Folder: I:
Post Process Task: Fortschrittsfenster anzeigen (Voreinstellung)
PREFERENCES
MultiThread: 1
AVS UpSize/DownSize Filter: Spline36Resize/Spline36Resize
Frame Adjust Strategy: 1
FPS Hard Conversion: 2
PAL SpeedUp: 1
NTSC SlowDown: 1
Video Resolution: 0
Video Encoder: 0
Video BitRate Min: 2000
Keep DVD Compliant Video: 0
AC3 Audio Encoder: 2
DVD Audio Format: 0
DVD Audio BitRate: 224
Keep DVD Compliant Audio: 0
Normalize Audio: 0
Auto Delay Audio: 1
DVD Audio Language (Primary): DE - German
DVD Subs Language (Primary): DE - German
DVD Burning Drive: H: BENQ DVD DD DW1620 B7W9
Auto Erase DVD RW: 0
Unload ActiveMovie Library: 0
SYSTEM INFO
Processor Name:
Operating System: Windows XP - Service Pack 3 (5.1.2600) 32 bit
Running with Elevated Privileges: NO (-1)
Available Output Disc Space: 43 GB
AviSynth is installed: YES (release 2.6.1)
LAV Filters is installed: YES (release 0.69.0)
TITLE 1 SOURCE FILES
Video: I:\Test.flv
Info: AVC - 400 kbps - 544x408 - DAR 4:3 - 25 fps - Progressive - 7:01 minutes - 10527 frames
Audio 1: I:\Test.flv
Info: AAC LC - 94 kbps - CBR - 2 ch - 44100 Hz - 16 bit - 7:01 minutes (57 ms delay)
[MediaInfoLib - v18.05]
AVISYNTH SCRIPT
Import("E:\Programme\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("I:\Test.flv", CacheFolder="I:", FrameRate=25)
Audio = A2DAudioSource("I:\Test.flv", CacheFolder="I:")
Video = Video.ConvertToYV12()
Video = Video.Spline36Resize(720,576)
Audio = Audio.SSRC(48000)
Audio = Audio.DelayAudio(0.057)
AudioDub(Video, Audio)
DIRECTSHOW AUDIO MIXER OPERATIONS:
No LAV Filters mixer ON/OFF adjustment required at runtime
Video Encoding Profile: FFmpeg CBR 1-pass
Target Video FileSize: 250,9 MB
Encoding Parameters: -i "I:\DVD_Test_1.avs" -threads 1 -aspect 4:3 -c:v mpeg2video -b:v 5000k -minrate 5000k -maxrate 5000k -bufsize 2000k -dc 9 -y "I:\DVD_Test.m2v"
<29.03.2019 11:27:12>
END VIDEO ENCODING OPERATIONS
Video Source Filter: A2DSource - DSS2 mod (LAV Filters on)
Created File: I:\DVD_Test.m2v (213,7 MB)
Ouput Video Info: MPEG-2 Video - 4247 kbps - 720x576 - DAR 4:3 - 25 fps - Progressive - 7:02 minutes - 10550 frames
Avg Video Encoding Speed: 12,4 fps
START AUDIO ENCODING OPERATIONS (Track 1)
FFmpeg Parameters: -i "I:\DVD_Test_1.avs" -threads 1 -y -vn -c:a ac3 -ab 224k "I:\DVD_Test_1.ac3"
<29.03.2019 11:30:28>
END AUDIO ENCODING OPERATIONS (Track 1)
Audio Source Filter: A2DSource - DirectShowSource
Created File: I:\DVD_Test_1.ac3 (11,3 MB)
Output Audio Info: AC3 - 224 kbps - CBR - 2 ch - 48000 Hz - 16 bit - 7:02 minutes (0 ms delay)
START MUXING OPERATIONS
Mplex Parameters: -f 8 -L 48000:2:16 -o "I:\DVD_Test.mpg" "I:\DVD_Test.m2v" "I:\DVD_Test_1.ac3"
<29.03.2019 11:31:08>
END MUXING OPERATIONS
Created File: I:\DVD_Test.mpg (230,2 MB)
Log file created by AVStoDVD Release 2.8.8 Hotfix build 190115
According to your logs AVStoDVD does not even show title information or the created AVS script. Something about your system configuration must be terribly wrong.
I do know that A2D runs under Win10, MrC does test the software under Win10. So I can just guess what is wrong here. Could be the Codec Pack, could be an antivirus software which blocks something important, could be that you tried to update some helper software with newer but incompatible versions. Whatever, if you do not have an image backup made before these problems appeared then the best advice I have is a fresh reinstall of Windows and all your software.
One of the problems about Codec Packs is that you just cannot uninstall them completely. In most cases they leave stuff behind, and oftentimes they have reconfigured other stuff which persists even after uninstalling.
About .Net framework you should read the A2D manual under the FAQ section. NET Framework 2.0 is only necessary for SubtitleCreator. For users who do not need subtitles .NET Framework is not required for using AVStoDVD.
From the A2D manual:
SubtitleCreator requires .NET Framework 2 to run. You can download .NET 2 from Microsoft website. You can also download .NET 3.5 which includes .NET 2 and .NET 3. Unfortunately .NET 4.x packages do not include previous releases libraries, so you have to install either .NET 2 or .NET 3.5.
If you have Windows 10, you can activate .NET 3.5 by following this guide: https://answers.microsoft.com/en-us/...e-78519f36d7a4
Old 29th March 2019, 19:06   #3165  |  Link
dr_ml422
Those are the logs that came up. The issue is something, as AVStoDVD is not the only encoding program installed and working. ConvertXToDVD, ConvertXtoVideo despite it not supporting h.264, DVDFAB, VidCoder, .... I read and installed the .net framework 3.5 just for AVStoDVD as no other needed it to insert subtitles. Matter of fact I'm finishing whatever was done and not done with ConvertXToDVD.
A suggestion would be to concentrate on the newer updated versions of Windows and have the software completely up to date. Let users meet you at the present level. Many don't want to acknowledge the new and prefer to hold on to the past and it causes issues.
Matter of fact even Microsoft decided to concentrate on newer, present level hardware etc... and not support older depecrated hardware, OD, etc... Even yourself got tired of that useless QUenc.
That said with that file and 9 others similar, AVStoDVD couldn't acknowledge the dual Audio. I could care less about the Hindu, it came from land of the files iykwim. Lol...
I had to get rid of 2 perfectly well burners because of Windows 10. Didn't know that they weren't supported until I did research.
Easy does it. I know this is hard work. Especially as a gift from yourself and all others. We'll figure it out. I will definitely have to build me a newer more updated PC, as Windows 10 expects. XP was a God back then, only 1 CD. I still have a disc. 2019 is here.
The internal or even external player won't play unless ffdshow is installed. I'm not going to install it as LAV is doing the necessary work.
Old 29th March 2019, 21:15   #3166  |  Link
manolito
manolito's Avatar
AVStoDVD is written in Visual Basic 6. Very old, only partly supported in Win10, but it sure does work. Only 32-bit helper software is supported, if a user tries to outsmart the author and replace some 32-bit helper software with 64-bit versions then he/she should not complain if it does not work. The same goes for other tools like MediaInfo where the latest versions are not supported.
I do not use Win10 (for me it is evil spyware), technically it has absolutely nothing to offer over Win7. Of course there are (mostly younger) folks who feel that newer is always better, but those folks should not use software like AVStoDVD.
From your log files I can see that your system configuration has huge problems, of course AVStoDVD can work together with other video converters like ConvertXToDVD, ConvertXtoVideo, DVDFAB, VidCoder, but not if you destroyed some basic configuration settings.
I'm out of here, I think you will be better off using other video conversion software than AVStoDVD.
Old 1st April 2019, 20:41   #3167  |  Link
dr_ml422
manolito you don't have to go anywhere. You're you. Only thing is everyone one else and everything else is not. That's all that was needed was to establish the fact that the software really isn't up to date. Please try not to berate new members or their systems, ways, views, etc... If my system is not configured correctly nothing would work, especially Video software. If you want to do something positive then just for the sake of the software bring it up to date. I can't change your view on life, though I can only suggest that you will never, ever beat any establishment, you can only work with it and take what you can and leave the rest. I seriously doubt MS or Apple, or Ubuntu, or anything else running in this present day is going to stop for you or anyone else. Matter of fact the whole USA is behind the times. Most other places have been implementing x64 computing for a while now and as default. It's a great program. Maybe too many individual parts to ever work right all the time even if updated. The probability that something will err out is very high when there's too much not working in sync or at least close to it. It's in your hands. The April 2nd update is here and I doubt it's stopping because of the few. I myself didn't learn to smarten up until recently. I kept trying to get married when the first sin ever recorded for those that follow, was the deception of a woman. So why should I expect anything different now in 2019? Something to think about. Stop being lazy. Grab the bull by the horns and get to work. I wish I could compensate for the hard work no matter you're position. A little something always comes in handy. If one day my fortune changes I'll blow up the donate button and Amazon Gift card. One day is not today. I'm heading to either Amazon, Microcenter, or both to full proof a new build soon. Windows 10 requires updated hardware so I will update it. Simple. Never have I understood why some come to the party and at least don't try to dance.
I've learned that I will never change who I am, though I do my best to change my response to everything. All will work out for the best.
Old 1st April 2019, 22:09   #3168  |  Link
Groucho2004
Maybe you'd be happier with a man? Any recorded sins with that gender?
They don't want to hurt anyone.
Groucho's Avisynth Stuff
Old 7th April 2019, 07:40   #3169  |  Link
dr_ml422
If you don't comprehend what I'm saying then please refrain. Usually those that speak about men are the ones that get with them. This is a forum for knowledge. Not to get off on your plastic ego when no one is in front of you.
Otn. You have to have everything downloaded for this to work properly. Including Java runtime. Now it's working like never.
manolito is a big boy mr. Groucho. He doesn't need to be cuddled by anyone. Especially you. Stop behaving as an emotional 2 year old coming to someone's rescue. Remember please if there's enough space between your ears what happens to volunteers and heroes. You want to be useful? Shut up and fix w/e is still wrong with any freeware. It's free for a reason.
I will definitely hit the donate button for whomever the link to AVStoDVD goes. It's worth it. Again make sure everything is installed, and if the preview window doesn't open the file run the AviSynth tool from the codec option. Also just close it and open it up again. If it goes black your good.
I've had more women than you or anyone you know has ever had! Even if I go right now and you stay I'd have more. If you're one of these puppies that wobble their heads up and down every time your w/e significant other says something, then please refrain from a real man's world. Have a good night. Beware of open subtitles.org, they're messing with the subs and hardcoding them with a sign up message. Screwed me up after a 2 hour encode. Common sense isn't common anymore. Why on earth provide a free service then complain about it. If you want to charge then charge from the beginning.
Old 7th April 2019, 08:05   #3170  |  Link
thescrapyard
thescrapyard's Avatar
Don't use codecs packs, they can and usually do cause more headache than they claim to fix. I tried them a few years back and ended up doing a full system reinstall because of all the drivers they updated or replaced with their own 'optimized' versions and made a right mess
LAVFilters should be good enough for pretty much everything. I use only PotPlayer and its good enough MLC should be even easier. I personally stay away from VLC Player after trying to use a few different times but other love it
I went back to Windows 7 as I got fed up of Windows 10 telling me half my software wasn't doing things the Microsoft way and refusing to play nicely with them
There are 'some' things that CAN be replaced with 64-bit versions in AVStoDVD, BUT make sure its working first THEN replace files. If it breaks then YOU have made the mistake
DO NOT replace FFMPEG with 64bit versions it WILL NOT work, I've tried and it won't. 32bit and 64bit are actually not that much different in speed, more about how much memory then can access
If you think AVStoDVD is outdated, then try looking at DVD Rebuilder. Thats even older and hasn't been updated in years BUT its very very good at what it does and the output quality is better than anything. That also uses HCEnc so the quality is on par
AVStoDVD works great with Avisynth and also now Avisynth+, which is why I use it, some don't work correctly and has difficulties with complex scripts (MeGUI personally is a pain)
My suggestion is to total remove AVStoDVD from your system, and klite codecs pack (if you can remove it ALL). Reinstall AVStoDVD (noinstall is my persoanl choice), install LAVFilters ONLY and try again (Make sure to check the codecs as Microsoft has a habit of refusing to change to anything but theirs ... which suck). If it still fails then you KNOW AVStoDVD is at fault
Dual audio DOES work, BUT some video releases from 'sources' fails to play convert, as I personally, just simply a crap source
thescrapyard is offline   Reply With Quote
Old 7th April 2019, 10:05   #3171  |  Link
Groucho2004
You don't have to pretend to be something you're not. Denial is toxic. Embrace what you are!
Old 7th April 2019, 14:32   #3172  |  Link
manolito
manolito's Avatar
AVStoDVD comes with a very good and comprehensive documentation. These days unfortunately a lot of users think that reading manuals is a waste of time...
From the doc:
Software requirements
· Microsoft Windows 2000/XP/Vista/7/8/10
· Microsoft DirectX 9.0 or higher
· AviSynth 2.6.0 or higher (AviSynth 2.6.0 is included in the installer)
· A good media splitter (LAV Filters 0.73.1 is included in the installer)
· A good 32bit DirectShow codecs/filters suite (LAV Filters is included in the installer, ffdshow is a valid alternative, but do not install both of them)
· Microsoft Windows Common Controls 6.0 ActiveX Library (mscomctl.ocx, included in the Installer, see the NOTE below)
· Microsoft .NET Framework 2 (required to encode and author text-based subtitles)
· Java Runtime Environment (required to encode and author bitmap-based subtitles)
· ImgBurn 2.5.0.0 or higher (not mandatory, but required to build DVD ISO Images and to burn DVDs)
For updating the A2D helper software also have a look at this post:
https://forum.doom9.org/showthread.p...58#post1814958
Cheers
manolito
Old 29th April 2019, 04:06   #3173  |  Link
dr_ml422
Everything seems to be fine now. I downloaded and installed everything including Java Script. Only thing now is a darker output? Was this taken care of previously in an update? I see mention of it in a post, but just an individual adjustment with Lumin Gain or something like that.
Hope anyone who likes it is enjoying "Game Of Thrones". It really is one of the best series all time imho.
How is DVDStyler fairing nowadays? Should I go with the 64 bit build or stay with the 32 bit? Not too many apps I've used in 64 bit have really panned out. Always something going wrong. Looks great!
I'm looking into the AVStoDVD Helper software update now. Thanks.
Be very cautious when using OpenSubtitle as they now are almost demanding support?! When using MPC's auto subtitle option it goes to opensubtitle and it downloads and puts in the subtitle. Only thing it comes with a warning message embedded in all the way through the movie. Or it'll just say it at the end. It totally messed up at least 2 of my movies from AVStoDVD and I had to redo them over from scratch.
Do you highly recommend that flawlessly working FFMS2 C plugin to update the older one? Thanks.
Old 30th April 2019, 19:17   #3174  |  Link
manolito
manolito's Avatar
This should not happen. The most likely reason is that your source uses a different color scheme than your target. Generally you can say that HD content uses Rec709 and SD content is Rec601. But this is not always the case, and AVStoDVD makes no general assumption about the source color format. Only if MediaInfo explicitly reports Rec709 the ColorMatrix filter will be automatically used to convert the color to Rec601.
So if you find a discrepancy between the source and the target, you need to experiment with the ColorMatrix filter in your AVS script. If Colormatrix is present, try to comment it out and see what happens. If it is not there, try to add it right after the source filter.
Compared to AVStoDVD you will get much more elaborate menu creation abilities. For transcoding it only uses FFmpeg (A2D uses FFmpeg only for very high video bitrates, otherwise it uses HCenc). Most people say that HCenc creates slightly better quality encodes than FFmpeg, but when using the right parameters FFmpeg these days certainly delivers very high quality. Since my FFmpeg-VBR plugin has been transparently integrated into DVDStyler the quality may even be higher in some cases than HCenc, at least for low bitrate encodes. You need to test this yourself.
If the 64-bit version of DVDStyler gives you a speed boost mainly depends on how much memory FFmpeg will address when doing an MPEG2 encode. Since the output will be SD and not HD the memory consumption is probably quite limited, so the speed gain will be small or even nonexistent. Personally I only use the 32-bit version of DVDStyler.
See this post:
https://forum.doom9.org/showthread.p...78#post1868878
If you never use high bitdepth sources then you won't be affected, no problem to continue using the version which comes with AVStoDVD.
Cheers
manolito
Old 12th May 2019, 21:19   #3175  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Guys, just to tell you that AVStoDVD is still alive (for the dinosaurs like me that stubbornly use it). A new release will be available soon. Mainly bugfixes (e.g. https://forum.doom9.org/showpost.php...postcount=3151 or https://forum.doom9.org/showpost.php...postcount=3153) and support to HDMV presentation graphics BluRay subs.
Stay tuned.
Bye
P.S. Now is the right time to go out with requests, suggestions and complaints. Not too fanciful, we come from the Jurassic.
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 13th May 2019, 02:55   #3176  |  Link
manolito
manolito's Avatar
This is really good news...
Just when I started to think that this software is no longer maintained. My usual threshold is 6 months. If a software has not been touched by its author for this time then it is normally safe to assume that there will be no further development. Almost 5 months in this case...
I cannot think of too many feature requests, the software is almost perfect in its current state. The bug fixes you already mentioned (of course do not forget to integrate the latest hotfix from 15.01.2019) will be very welcome.
No idea if supporting AVS+ better by adding multithreading automatically would be a good idea. It is not without problems depending on the plugins which are used, so it mght be better to leave it to the users to add the appropriate params to the AVS script. The same goes for the LSMASH source filter. In some cases it gives better results than FFMS2, but the interface is not compatible with FFMS2, and advanced users can easily add it themselves by editing the AVS script.
Alright, these are my 2 cents...
Cheers
manolito
Old 18th May 2019, 15:57   #3177  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
My bad... AVS+ w/ SSRC...
In your knowledge, are there any other classic AVS functions that do not "explicitly" works with AVS+?
Bye
MrC
AVStoDVD Homepage
Old 18th May 2019, 21:11   #3178  |  Link
manolito
manolito's Avatar
Thanks for digging out this 2 year old stuff. It was amazing for me to see how I got carried away quite a bit in my disgust about the AVS+ devs deliberately breaking backward compatibility to classic AVS. But my points are still valid.
And so far (to the best of my knowledge) this is the only occasion where AVS+ is not compatible with classic AVS.
Luckily this has only a minor impact for AVStoDVD. If the selected source filter can output 32-bit float audio then there is no problem if the script contains SSRC. For LAV audio this means that the user should not disable 32-bit float audio in the audio filter setup. For all audio source formats I use LAV audio will output 32-bit float as long as the user has not disabled it.
FFMS2 also outputs 32-bit float audio by default, there is no problem with AVS+.
But integrating AVS+ support into AVStoDVD still can cause problems. Just adding a "Prefetch()" command at the end of the AVS script won't be enough. There are many older AVS plugins which need special treatment when multithreading is enabled.
I had numerous problems with random crashes until almosely posted this:
https://forum.doom9.org/showthread.p...79#post1865279
There are a couple of older filters which need to be run in MT_SERIALIZED mode, sometimes requiring an additional "RequestLinear" command. Colormatrix is one of the problematic filters. After a lot of experimentation I managed to get AVS+ running absolutely stable on my machine, but the speed gain from multithreading is far from spectacular. All the additional AVS+ features like support for high bit depth and fancy color spaces are irrelevant for AVStoDVD since the DVD format only supports 8-bit with 4-2-0 color space (YV12).
So I really do not know if AVS+ support is essential for AVStoDVD. My FF_VBR and HCenc_Mod plugins do support it already, but they require a little bit of effort from the users.
Cheers
manolito
Old 19th May 2019, 21:44   #3179  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Yeah, I got thru the posts your disappontment... it was mine as well.
In case of using LAV Filters or FFMS2 there are no problems, but if using MS filters (like MP3 Decoder DMO, which is not that bad), the output is not float, so AVS+ throws out an error w/ SSRC. Anyway, when AVS+ is detected, I will add a ConvertAudioToFloat function to SSRC.
Thanks for the other hints about AVS+. Nevertheless I'm not willing to add full compliance to AVS+, for now. Simply I do not have the time to do that.
2.8.9 Alpha is almost ready.
Bye
MrC
AVStoDVD Homepage
Old 19th May 2019, 22:22   #3180  |  Link
manolito
manolito's Avatar
This is fine with me. Maybe I will add a small guide how to use AVS+ with my FFmpeg_VBR and HCenc_Mod plugins to my plugin distribution...
Cheers
manolito
[IMG] code is Off
