Old 19th February 2014, 20:48   #19301  |  Link
Stigmatta
Bah, ya i just found out its not freeware lol
Well im gonna try again with dvd-9 and a few other changes, see how it goes...
Stigmatta is offline   Reply With Quote
Old 19th February 2014, 20:58   #19302  |  Link
I just completed one of the STNG series discs and it works fine as well (although the quality is pretty poor having put more than 4 hours of HD video on a BD-9).
Old 19th February 2014, 22:15   #19303  |  Link
Stigmatta
Interesting...well i have one bluray going atm, probably be done a bit later when i get home.
One question, is it best to delete the ANY! and ANYVM folders when done? Ive never deleted them in the past but if its best to do so, then i will from now on.
Old 19th February 2014, 23:01   #19304  |  Link
DoctorM
I'll look at it. But I don't get what you're saying. The input size is the size before removal or reencoding -- thus the name "Input Size". It includes everything except files that will be copied intact (full backup mode).
The determination as to whether it is kept intact is made when the file is extracted. If the video + kept-audio + kept-subtitles are small enought to hit the target without encoding... then encoding is avoided.
Thank you. I know it seems ridiculous, but a good test is a movie only where video plus all audio tracks is oversized and Video minus most audio tracks fits on a BD25.
When I did this BD-RB started re-encoding, but running the same thing through tsmuxer with a BD output the final disc was undersized.
To be fair the source disc had a LOT of audio tracks.
Old 19th February 2014, 23:36   #19305  |  Link
The number of tracks really doesn't matter. BD-RB accounts for the audio size when it does it's processing. Can you give me a specific title with which you are having problems?
Old 20th February 2014, 00:27   #19306  |  Link
Jake802
Any Ideas as to what I am doing wrong.....
[02/19/14] BD Rebuilder v0.46.13 (beta)
[01:48:21] Source: MARVELS_THOR_THE_DARK_WORLD_3D_01800
- Input BD size: 37.89 GB
- Approximate total content: [01:52:03.299]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
- MOVIE-ONLY mode enabled
- Quality: Highest (Very Slow), ABR
- MVC 3D Output Mode enabled
- Decoding/Frame serving: FRIMDecode
- Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448
[01:48:22] PHASE ONE, Encoding
- [01:48:22] Processing: VID_00800 (1 of 1)
- [01:48:22] Extracting A/V streams [VID_00800]
- [02:05:27] Reencoding video [VID_00800]
- Rate/Length: 23.976fps, 161,198 frames
- Bitrate: 21,326 Kbs
- Using FRIMEncoder for MVC encoding
- [02:05:28] Reencoding: VID_00800, Pass 1 of 1
- [18:14:59] Video Encode complete
- [18:14:59] Processing audio tracks
- Track 4353 (eng): Keeping original audio
[18:14:59]PHASE ONE complete
[18:14:59]PHASE TWO - Rebuild Started
- [18:14:59] Rebuilding BD file Structure
- Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta
[18:25:51] - Failed to REBUILD
Jake802 is offline   Reply With Quote
Old 20th February 2014, 00:28   #19307  |  Link
Jake802
NVM I think I ran out of Space!
Old 20th February 2014, 00:33   #19308  |  Link
omegaman7
omegaman7's Avatar
I thought Jdobbs, setup code to prevent that kind of error. Or at least warn you prior to running the job??
Old 20th February 2014, 00:44   #19309  |  Link
gonca
I think it might be for the next version. I guess he's got to make sure we don't hurt ourselves to badly with self inflicted wounds
Old 20th February 2014, 00:52   #19310  |  Link
Stigmatta
Nope, tried again this time with DVD-9 settings and still wont play in my bluray player or Powerdvd. Here are the files if you wanna check it out.
Old 20th February 2014, 01:00   #19311  |  Link
No. But the error output and INSPECT report now shows the amount of space available.
Old 20th February 2014, 01:02   #19312  |  Link
Post the contents of BDREBUILDER.INI and I'll try a job with your settings. Any possibility your player has had an update lately?
Did you reinstall everything as I suggested?
It's also possible that your burner has gone bad.
Old 20th February 2014, 01:29   #19313  |  Link
gonca
Rip to HDD and try it that way
Old 20th February 2014, 02:53   #19314  |  Link
Ch3vr0n
No need to either manually remove the folders not do to HDD. There is a setting in bdrb to do just that, ignore ask covers but the bdmv and certificate folders.
Verstuurd vanaf mijn Nexus 7 met Tapatalk
Old 20th February 2014, 05:00   #19315  |  Link
Sesselmarder
I am having some issues when trying to rebuild any of the 5 discs of "Games of Thrones S1" to BD25. All other movies run without any issues.
After I start the rebuild process, BD Rebuilder just stops working/reencoding at a random spot. When I abort and restart the session, it will eventually stop again, but at a different spot.
Has anybody seen this before? Any help is appreciated!
[02/19/14] BD Rebuilder v0.46.07 (beta)
[19:28:03] Source: GAMEOFTHRONES_D1
- Input BD size: 43.94 GB
- Approximate total content: [04:20:38.346]
- Target BD size: 23.93 GB
[19:28:03] PHASE ONE, Encoding
- [19:28:03] Processing: VID_00002 (1 of 54)
- [19:28:03] Extracting A/V streams [VID_00002]
- [19:33:50] Reencoding video [VID_00002]
- [19:33:50] Reencoding secondary video [TRK_02] <<<<<<< stops here
Sesselmarder is offline   Reply With Quote
Old 20th February 2014, 06:23   #19316  |  Link
DrinkLyeAndDie
DrinkLyeAndDie's Avatar
I'd recommend updating to the BD Rebuilder 0.46.13 beta to start with. Update and then see how things go.
DrinkLyeAndDie is offline   Reply With Quote
Old 20th February 2014, 07:57   #19317  |  Link
Sesselmarder
Just updated to version v0.46.13 and tried again, but still having the same problem.
Reencode stops after a few minutes...
[22:45:56] Source: GAMEOFTHRONES_D1
- Auto Quality: Good (Very Fast), Two Pass
[22:45:56] PHASE ONE, Encoding
- [22:45:56] Processing: VID_00002 (1 of 54)
- [22:45:56] Extracting A/V streams [VID_00002]
- [22:51:40] Reencoding video [VID_00002]
- [22:51:40] Reencoding secondary video [TRK_02] <<<<<< stops here
Old 20th February 2014, 09:15   #19318  |  Link
setarip_old
setarip_old's Avatar
@Jake802
Hi!
Marvel's "Thor: The Dark World" is now available on Digital 3D and Digital HD, and you can pre-order the film on Blu-ray 3D Combo Pack, Blu-ray and DVD before it hits shelves February 25.
Perhaps there will be some changes/fixes on or before the official release date...
Old 20th February 2014, 10:33   #19319  |  Link
DoctorM
To eliminate my PC's old CPU as the issue I rolled back my calendar and reloaded v45.05.
Tested again with the Tinker Bell movie. Movie only, one audio track (DD 640kbps) and found the same results. I checked the .INF file that is created instantly when 'Backup' is clicked:
[Status]
LABEL=TINKTEST
VERSION=v0.45.05 (beta)
SOURCE_SIZE=25539293184
SOURCE_VIDEO_SIZE=25539293184
TARGET_SIZE=24641536000
REDUCTION=.964848001957923
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
SSIF_MODE=0
QUICK=0
[00000]
AUDIO=010000000
PGS=1000000000000000000
I see the Source_Size is identical to the Source_Video_Size. Shouldn't one of those numbers represent the size without the disabled tracks or something?
The actual size of video track alone is 16,875,900,586 bytes (found after manually demuxing with txMuxeR). Adding a plain old DD track to that shouldn't exceed a BD25.
Tested another BD out of curiosity and again saw that the SOURCE_SIZE and SOURCE_VIDEO_SIZE are identical numbers.
v46.13 works identically.
Old 20th February 2014, 15:08   #19320  |  Link
Stigmatta
Well, ive tried everything and nothing works...All my other movies play and rip fine on my computer and bluray player, just these series discs just dont wanna work for some reason.
heres the INI file
[Status]
LABEL=SIMPSONS_S13_D2
VERSION=v0.46.13 (beta)
SOURCE_SIZE=45223997719
SOURCE_VIDEO_SIZE=44940490752
TARGET_SIZE=8422162432
REDUCTION=.181098500012215
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=all
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=33
REBUILD_COMPLETE=1
[00011]
AUDIO=1
PGS=
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=3023122
RATE=2007
SPLITS=1
NSTART=27000000
NEND=27405405
NSIZE=3065856
FLINK=0
MLINK=0
[00020]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=30878795
RATE=2768
SPLITS=1
NSIZE=30007296
FLINK=-1
MLINK=-1
[00021]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=11250198
RATE=2774
SPLITS=1
NSIZE=10795008
FLINK=-1
MLINK=-1
[00022]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
RATE=2774
SPLITS=1
NSIZE=10795008
FLINK=-1
MLINK=-1
[00122]
AUDIO=1
PGS=
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=3729667
RATE=2256
SPLITS=1
NSTART=27000000
NEND=27499248
NSIZE=4048896
FLINK=0
MLINK=0
[00123]
AUDIO=
PGS=
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=7320251
RATE=3576
SPLITS=1
NSTART=27000000
NEND=27685059
NSIZE=7280640
FLINK=0
MLINK=0
[00301]
AUDIO=1
PGS=
MSCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=2217550
RATE=801
SPLITS=1
NSTART=27000000
NEND=27710209
NSIZE=2291712
FLINK=0
MLINK=0
[00302]
AUDIO=1
PGS=
MSCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=2800588
RATE=887
SPLITS=1
NSTART=27000000
NEND=27828828
NSIZE=2893824
FLINK=0
MLINK=0
[00303]
AUDIO=1
PGS=
MSCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=3766385
RATE=901
SPLITS=1
NSTART=27000000
NEND=28100599
NSIZE=3883008
FLINK=0
MLINK=0
[00304]
AUDIO=1
PGS=
MSCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=4417297
RATE=928
SPLITS=1
NSTART=27000000
NEND=28261260
NSIZE=4466688
FLINK=0
MLINK=0
[00306]
AUDIO=1
PGS=
MSCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=2119635
RATE=820
SPLITS=1
NSTART=27000000
NEND=27666666
NSIZE=2217984
FLINK=0
MLINK=0
[00307]
AUDIO=1
PGS=
MSCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=2217550
RATE=767
SPLITS=1
NSTART=27000000
NEND=27734233
NSIZE=2267136
FLINK=0
MLINK=0
[00308]
AUDIO=1
PGS=
MSCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=9122775
RATE=1105
SPLITS=1
NSTART=27000000
NEND=29262760
NSIZE=9259008
FLINK=0
MLINK=0
[00309]
AUDIO=1
PGS=
MSCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=6275454
RATE=1025
SPLITS=1
NSTART=27000000
NEND=28654653
NSIZE=6457344
FLINK=0
MLINK=0
[00310]
AUDIO=1
PGS=
MSCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=3716315
RATE=982
SPLITS=1
NSTART=27000000
NEND=28015014
NSIZE=3796992
FLINK=0
MLINK=0
[00311]
AUDIO=1
PGS=
MSCAN=2
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=6755015
RATE=1033
SPLITS=1
NSTART=27000000
NEND=28770268
NSIZE=6875136
FLINK=0
MLINK=0
[00312]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=36537831
RATE=462
SPLITS=1
NSTART=27000000
NEND=44313796
NSIZE=38406144
FLINK=0
MLINK=0
[00313]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=12310572
RATE=990
SPLITS=1
NSTART=27000000
NEND=30339336
NSIZE=12625920
FLINK=0
MLINK=0
[00314]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=4565282
RATE=1152
SPLITS=1
NSTART=27000000
NEND=28094593
NSIZE=4632576
FLINK=0
MLINK=0
[00315]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=3020897
RATE=1095
SPLITS=1
NSTART=27000000
NEND=27755254
NSIZE=3115008
FLINK=0
MLINK=0
[00316]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=3575006
RATE=1164
SPLITS=1
NSTART=27000000
NEND=27849849
NSIZE=3692544
FLINK=0
MLINK=0
[00317]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=18739574
RATE=1146
SPLITS=1
NSTART=27000000
NEND=31513509
NSIZE=18991104
FLINK=0
MLINK=0
[00318]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=19717611
RATE=1226
SPLITS=1
NSTART=27000000
NEND=31490986
NSIZE=19961856
FLINK=0
MLINK=0
[00319]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=4523000
RATE=471
SPLITS=1
NSTART=27000000
NEND=29118616
NSIZE=4749312
FLINK=0
MLINK=0
[00322]
AUDIO=1
PGS=
MSCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=56267681
RATE=844
SPLITS=1
NSTART=27000000
NEND=44313796
NSIZE=57735168
FLINK=0
MLINK=0
[00800]
AUDIO=1000
PGS=111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=989486691
RATE=3670
SPLITS=1
NSTART=27000000
NEND=87992806
NSIZE=972552192
FLINK=0
MLINK=0
[00801]
AUDIO=1000
PGS=111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=993049458
RATE=3690
SPLITS=1
NSTART=27000000
NEND=88039728
NSIZE=977977344
FLINK=0
MLINK=0
[00802]
AUDIO=1000
PGS=111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=991591861
RATE=3688
SPLITS=1
NSTART=27000000
NEND=88064127
NSIZE=976551936
FLINK=0
MLINK=0
[00803]
AUDIO=1000
PGS=111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=991406046
RATE=3675
SPLITS=1
NSTART=27000000
NEND=88030344
NSIZE=975544320
FLINK=0
MLINK=0
[00804]
AUDIO=1000
PGS=111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=990432460
RATE=3678
SPLITS=1
NSTART=27000000
NEND=88041605
NSIZE=974696448
FLINK=0
MLINK=0
[00805]
AUDIO=1000
PGS=111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=951800586
RATE=3677
SPLITS=1
NSTART=27000000
NEND=85554746
NSIZE=937826304
FLINK=0
MLINK=0
[00806]
AUDIO=1000
PGS=111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=990957640
RATE=3687
SPLITS=1
NSTART=27000000
NEND=87977791
NSIZE=975611904
FLINK=0
MLINK=0
[00807]
AUDIO=1000
PGS=111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=969812475
RATE=3667
SPLITS=1
NSTART=27000000
NEND=86804744
NSIZE=951484416
FLINK=0
MLINK=0
