Old 16th January 2018, 13:29   #641  |  Link
sneaker_ger
For me ASS style export doesn't work at all (latest beta). It creates an ASS file but the line for the style is missing.
Workaround:
Just open actual ASS subtitle file with the styles you want to use and delete all lines (or import on it).
Apart from not working at all the export function is tedious because it seems you can only select one style. Same for import. ASS files often have many styles.
Old 16th January 2018, 18:42   #642  |  Link
Nikse555
@von Suppé/sneaker_ger: I've updated the beta, to handle multi import/export - https://github.com/SubtitleEdit/subt...leEditBeta.zip
How does that work?
Also, is that bug regarding not saving new styles fixed sneaker_ger?
Old 16th January 2018, 19:02   #643  |  Link
sneaker_ger
Partly. Exporting styles that have spaces in their name doesn't work.
Old 16th January 2018, 19:46   #644  |  Link
Nikse555
@sneaker_ger: thx for testing
Beta updated: https://github.com/SubtitleEdit/subt...leEditBeta.zip
Old 16th January 2018, 19:53   #645  |  Link
sneaker_ger
Looking good. Thx.
Old 17th January 2018, 14:00   #646  |  Link
von Suppé
von Suppé's Avatar
How does that work?
Running a few first fast tests, I can confirm it works like a charm. Thank you, will test further of course.
Old 17th January 2018, 14:42   #647  |  Link
von Suppé
von Suppé's Avatar
xml/png export timings issue
The issue I mentioned earlier here https://forum.doom9.org/showthread.p...56#post1820856 still exists in latest beta.
Now, the srt file attachments in mentioned post still await approval(??) but thing is that, when wanting to create xml/png I first have to export as SUP, thereafter convert with BDSup2Sub.
As said, this tool (BDSup2Sub) has a sort-of frame-timings issue/bug, in that sense, that you have to specifically check the "Change frame rate" box and state both FPS Source and FPS Target rates, if a framerate other than 23.976 is used in both source and target fps.
If you are using BDSup2Sub internally in SE for xml/png export, can you "force tell" the tool to use this FPS Source/Target setting?
Old 18th January 2018, 22:39   #648  |  Link
Nikse555
@von Suppé: SE does not use BDSup2Sub internally for xml/png export. SE (nearly) always write in "real time" and not "media time/drop-frame" - but I've made a test version here with a "Use media time (df)" check box: https://github.com/SubtitleEdit/subt...leEditBeta.zip
How does that work?
Old 19th January 2018, 13:18   #649  |  Link
von Suppé
von Suppé's Avatar
...I've made a test version here with a "Use media time (df)" check box: https://github.com/SubtitleEdit/subt...leEditBeta.zip
How does that work?
Will go test.
Thank you for fast respons :-)
Edit: First quick tests show XML/PNG output is still faulty, whether I choose df or not...
Old 27th January 2018, 16:53   #650  |  Link
Zetti
Thanks for new release:
https://github.com/SubtitleEdit/subt...ases/tag/3.5.5
Old 31st January 2018, 11:45   #651  |  Link
von Suppé
von Suppé's Avatar
Hi Nikse 555
When I preview subtitles for 4K video (4K video opened in SE, settings --> videoplayer 'mpv' with 'mpv handles preview text' checked) the subtitles don't scale in proper ratio to the video. They seem twice as big.
With 1080 I don't have this issue. Can you do something about that? You must know that I am previewing on a 1920x1080 monitor.
Old 31st January 2018, 13:31   #652  |  Link
von Suppé
von Suppé's Avatar
Hi Nikse555,
Another thing I noticed. While your new import & export for ASS styles work like a charm now, I encounter this issue.
For example,
If I create a style in Aegsub, I can set the bottom offset to let's say 288. I want this for 4K video with a 2.40 movie aspect ratio, so the subtitles are shown above the black bar (which itself is 280 pixels in this case, I add 8 to lift it slightly extra).
This ASS style I can directly import in SE and it reacts well on this offset. I can see that in the SUP export window, where - eventhough "Bottom margin" is greyed out - it says 288. And off course, checking the output in BDSup2Sub, the result is okay.
Creating an ASS style in SE, in the style properties window, the bottom offset is represented by the box "Margin vertical". However, I can't get the value higher than 250.
Is there a specific reason why you implemented this maximum and is it possible to take it away, or at least increase that value?
Old 3rd February 2018, 12:15   #653  |  Link
Nikse555
@von Suppé: I've upped the margin max size to 500, is that enough?
I don't know about the preview - it should just use the "Subtitle preview font size" from Options -> Settings -> Video player.
Old 4th February 2018, 11:07   #654  |  Link
von Suppé
von Suppé's Avatar
That should be enough.
Thanks Nikse555
Old 6th February 2018, 13:55   #655  |  Link
von Suppé
von Suppé's Avatar
The margin max size is enough, it works. Thanks.
I think I found a bug.
During editing of a *.ass file, when applying 'Tools --> Dialogues - remove hyphen in first line of dialogues...' (it's a plugin) all styles are vanished from the styles list.
Old 6th February 2018, 21:35   #656  |  Link
Nikse555
Thx
Plugin updated. Go to File -> Plugins to update.
Old 7th February 2018, 14:56   #657  |  Link
varekai
@ Nikse555
Hello!
Thanks for Subtitle Edit, it's one-of-a-kind!
Really enjoy making my own subtitles for my projects.
One thing I've been thinking about is the space below the second subtitle row.
It cuts the bottom of the subtitle and it would be great if it could have the same space as the first row have.
Maybe there are some settings for this but I can't find any.
Here's a screenshot:
https://frupic.frubar.net/shots/36437.png
Best regards
Old 7th February 2018, 15:45   #658  |  Link
von Suppé
von Suppé's Avatar
Thanks Nikse555
@ varekai,
When I see your picture I think it is because you didn't choose your player to be full screen. Or the interface is over the subs. I highly doubt if SE will chop off the lower part of any sub as shown.
You can also tell your player to show the subs a bit higher in settings.
Old 7th February 2018, 16:23   #659  |  Link
varekai
Thanks Nikse555
@ varekai,
Hmm... I don't understand what you mean?
Here's what I do:
Open subtitle (srt)
Video --> Open video file (m2ts)
If I chose "Un-dock video controls" I get the same result.
DirectShow is the "player" and I don't know how to change "player" to full screen.
It looks like the "player" window/bar doesn't adapt to 2 subtitle rows?
Screenshot of single subtitle row:
https://frupic.frubar.net/shots/36438.png
Edit: Well... guess I'll have to set "Subtitle preview font size" to 17 to fit, although the small size does hurt my eyes...
Wish it could be set to bigger size and still keep it viewable inside DirectShow window.
Regards
Old 8th February 2018, 12:58   #660  |  Link
von Suppé
von Suppé's Avatar
@ varekai
Aahh I see now. It's the preview of SE's chosen videoplayer itself. Sorry for the misinterpretation.
What you can do is in settings, choose mpv as videoplayer (you have to click download button). And then also set "mpv handles preview text.
MPV will show all subtitles above the interface.
cheers
