Old 11th November 2019, 14:53   #181  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
ChangeLog for ffhevc 4.0.5 and ffx264 4.0.3
* Added support for the (newer) deblock filter
Old 12th December 2019, 21:44   #182  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.0.6
* Update the default encoding options
Old 14th December 2019, 06:10   #183  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.0.7
* Update default encoding options and CRF value
Old 14th December 2019, 19:04   #184  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.0.8
* Update default encoding options and CRF value; V2
Old 19th December 2019, 15:56   #185  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.0.9
* Update default encoding options, v3
Old 23rd December 2019, 07:28   #186  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.1.0
* Default encoding options tweaks. Add qcomp=0.7 and go back to standard non-hierarchical motion estimation. Also increased tu-{inter,intra}-depth to 4 and reference frames to 5
* Lower default CRF value to 20
NOTE: Currently, Sourceforge has problems and errors out when uploading the new version. Temporarily you can find it at https://ffhevc.teambelgium.net/ffhevc-4.1.0.tar.gz
When SF is fixed again, I'll upload it there.
Old 24th December 2019, 05:30   #187  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.1.1
* Switch to AQ mode 2
* Increase default bframes from 6 to 8
* Keep quantization group size at the same size as the max CTU
Old 24th December 2019, 12:20   #188  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.1.2
* Increase deblocking values from -3,-3 to -1,-1
* Enable strong intra smoothing
* Lower qcomp to its default value of 0.6
Old 25th December 2019, 09:35   #189  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.1.3
* More fine-tuning to the default encoding options that should preserve noise and especially mosquito noise on dark backgrounds while at the same time increasing quality with a slightly higher bitrate cost
Old 28th December 2019, 16:41   #190  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.1.4 and ffx264 4.0.4
* Add support for the noise video filter. Can be beneficial on (very) clean sources by applying some noise to avoid things like color/light banding in the encode
* Fine-tuning to the default encoding options
Old 31st December 2019, 00:18   #191  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.1.5
* psy-rd/psy-rdoq psycho-visual tuning to the default encoding options. Aim is to preserve the energy of the input as much as possible without introducing noticable artifacts such as ringing
Old 31st December 2019, 16:54   #192  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.1.6
* Go back to uniform AQ (mode 1) with a strength of 1.0
* Bump up qcomp to 0.72
* Increase psy-rdoq to 15.0 and psy-rd to 4.0
* Increase reference frames to 5
Old 3rd January 2020, 19:54   #193  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.1.7
* Add option to force signaling of HDR in case max-cll is 0,0
Old 4th January 2020, 21:55   #194  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.1.8
* More psycho-visual tunings
Old 8th January 2020, 16:09   #195  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.1.9
* Rename hdr option to hdr10. Requires latest libx265 compiled from the default branch
* Rename hdr-opt to hdr10-opt. Requires latest libx265 compiled from the default branch
* Support HLG (Hybrid Log Gamma) HDR
* Some minor psy-rd/rdoq tunings
Old 16th January 2020, 16:49   #196  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.2.0
* Minor optimizations to the default encoding options. Lower qcomp to 0.7
Old 23rd February 2020, 15:59   #197  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.2.1 and ffx264 4.0.5
* Use MPlayer for crop detection instead of FFmpeg which seems to have issues with 4k/UHD content
Old 5th March 2020, 22:10   #198  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.2.2 and ffx264 4.0.6
* Go back to FFmpeg for crop detection
Old 9th March 2020, 21:14   #199  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffx264 4.0.7
* Bugfix: missing if conditional in the crop code
Old 21st March 2020, 11:33   #200  |  Link
microchip8
microchip8's Avatar
ChangeLog for ffhevc 4.2.3
