Old 22nd October 2008, 09:54   #61  |  Link
lobothefoots
I found two problems using this GUI
-when I extract an AC3 stream to WAVS using libvab (not nero) the log say it can't find the withe.noise file.
-I can't extract AC3 to DTS anymore.
the source is a Bluray directory
hope this helps
lobothefoots is offline   Reply With Quote
Old 22nd October 2008, 12:43   #62  |  Link
Greif
1) sounds like a bug with eac3to, do you get the same result when trying the same in a command window? If so, submit a bug on the eac3to thread
2) ahhhh.. due to the filtering of the audio extract types. I will remove this "feature" in the next version
Greif is offline   Reply With Quote
Old 22nd October 2008, 12:45   #63  |  Link
Greif
Originally Posted by nwg View Post
It would be good to have a rebuild/remux feature like in evodemux. While that program is good. It is not possible to find out what the tick boxes are in terms of what languages and subtitles they are very easily. It would be good to be able to select what I want then click on rebuild to create a new evo or m2ts file.
I'm thinking of providing the ability to select single evo/m2ts files in addition to folders. It would bypass the feature grid and just show you the streams contained in your selection.
The goal of this tool is to strictly extract streams, nothing more.
Old 22nd October 2008, 12:45   #64  |  Link
lobothefoots
no I don't have this problem with eac3to 2.69
Old 22nd October 2008, 15:35   #65  |  Link
Greif
Originally Posted by lobothefoots
... the log say it can't find the withe.noise file.
Is that the exact wording from the log? (withe --> white)
I'll try it later today to see if I can reproduce.
Old 22nd October 2008, 16:21   #66  |  Link
lobothefoots
sorry , of course it is white and not withe (typo)
edit: try to check this screen capture at
http cps.tech.free.fr/temp/pb.JPG
Old 22nd October 2008, 17:24   #67  |  Link
Greif
can you provide the entire contents of the log? thanks.
Old 25th October 2008, 07:35   #68  |  Link
TMC
Looks like it would be a nice GUI, but I can't get it to work. As someone else has said, it crashes on selecting an HDDVD feature as soon as "analysing" gets to 100%.
Tried with a BluRay and got an unhandled exception error.
OS = Vista Ultimate. AnyDVD.
TMC is offline   Reply With Quote
Old 25th October 2008, 12:27   #69  |  Link
Greif
Ok I am seriously getting Maybe it's my own discs but I have yet to have it crash on me.
I will release a version with verbose logging. Give it a try with that version on a couple of different discs that you've had issues with. It will be out later today...
That way, I can figure out what the problem is and fix it.
Old 26th October 2008, 07:51   #70  |  Link
lobothefoots
it appears only in your gui, there is nothing in the log;
I guess it is because there is no [a**] tag in front of the line.
I can report as well alot of crashes
With die hard bluray movie, it loads the content but if I try to demux it crashes.
I'll try the verbose version.
Old 26th October 2008, 08:48   #71  |  Link
Kurtnoise
Swallowed in the Sea
Kurtnoise's Avatar
Just copy the log from eac3to here using this command:
eac3to.exe "\Path where is my disc\"
Old 26th October 2008, 15:30   #72  |  Link
nwg
It is working great for me for Blu Rays. However when I use it on a disc with DTS MA audio, I cannot select DTS as the stream type. Do I use RAW? Also what does +options do?
nwg is offline   Reply With Quote
Old 26th October 2008, 22:15   #73  |  Link
azad
azad's Avatar
@nwg
I've the same problem.
@Greif
Great tool! Thanks!
One thing, for all my DTS-MA streams the file extension is ".dtshd". But since Stream Extractor uses ".dts" as file extension for DTS-MA streams, I've to rename all the audio streams manually. That's a lot of work and I'm quite lazy , so it would be nice to have an additional file extension for DTS-MA streams and not only ".dts".
Agent 47: "Eat your sandwich, I need to get some sleep."
azad is offline   Reply With Quote
Old 27th October 2008, 01:04   #74  |  Link
Greif
For those having problems with loading features, here is a debug version. This version has some extra logging and will create a log file named HdBrStreamExtractor.txt in the same directory.
If you are having issues, please run this version and upload the log file to http://pastebin.com/ so I can review. Thanks.
@azad: I need to clean up some of the audio extract types. It should be done soon.
Old 27th October 2008, 01:12   #75  |  Link
Greif
@nwg/@azad: could either of you show me the output of the discs you are trying to extract from (with DTS HD MA)?
Show me the result of this:
eac3to.exe [disc location]
ex. eac3to.exe f:
And then show me the result of the stream listing for the selected feature:
eac3to.exe [disc location] [stream#]
ex. eac3to.exe f: 1)
Old 27th October 2008, 15:37   #76  |  Link
Anacletus
Anacletus's Avatar
Hi Greif, i tried to use your app, but the result was this when trying to analize the godfather
caused this error:
Any toughts?
Anac
Anacletus is offline   Reply With Quote
Old 27th October 2008, 18:57   #77  |  Link
Greif
Originally Posted by Anacletus View Post
Any toughts?
Show me the result of the stream listing for the selected feature:
eac3to.exe "c:\Moviez-HD\The Godfather" 1)
Old 27th October 2008, 19:47   #78  |  Link
Anacletus
Anacletus's Avatar
here it is:
Old 27th October 2008, 22:26   #79  |  Link
Greif
@Anacletus: can you use the debug version posted above and show me the log file?
I'll look into it using your screenshot in the meantime.
Old 28th October 2008, 12:22   #80  |  Link
Anacletus
Anacletus's Avatar
here's the log produced by the debug version:
[12.19.55] Retrieving features
[12.19.55] Arguments: "C:\Moviez-HD\The Godfather"
[12.19.57] Feature Retrieval Completed
[12.19.57] Retrieving streams
[12.19.57] Arguments: "C:\Moviez-HD\The Godfather" 1) -progressnumbers
[12.20.22] M2TS, 1 video track, 6 audio tracks, 16 subtitle tracks, 2:57:09
eac3to, hdbrstreamextractor
