Old 2nd February 2019, 04:52   #28341  |  Link
AmigaFuture
AmigaFuture's Avatar
...since 2014, I believe.
Not the SSE4 version!! Haaa!!! Beliefs... Wink!
Old 2nd February 2019, 04:56   #28342  |  Link
AmigaFuture
Originally Posted by Ch3vr0n View Post
When he and it's ready to do that, not a moment sooner.
Verstuurd vanaf mijn Nexus 6P met Tapatalk
YEAH! Foot stomp!!!
Wow...beat Lathe... It's...it's...it's a mmm..mmm...mnm..nope, not a word I'll use...ever.
Old 5th February 2019, 21:47   #28343  |  Link
hobi2000
FRIMDecode crashes BDRebuilder
Hi folks, cant use BDrebuilder anymore as when Reencoding starts FRIMdecode.exe crashes.
Any help?
For more details see enclosed crash pictures and logs down here
Thanks Chris
[01.30.19] BD Rebuilder v0.60.04
[19:04:41] Source: GOOSE_3D_00001
- Input BD size: 32,89 GB
- Approximate total content: [01:43:16.189]
- Target BD size: 22,95 GB
- Windows Version: 6.2 [9200]
- MOVIE-ONLY mode enabled
- Quality: High Quality (Default), ABR
- MVC 3D Output Mode enabled
- Decoding/Frame serving: FRIMDecode
[19:04:41] PHASE ONE, Encoding
- [19:04:41] Processing: VID_00340 (1 of 1)
- [19:04:41] Extracting A/V streams [VID_00340]
- [19:14:00] Reencoding video [VID_00340]
- Rate/Length: 23,976fps, 148.560 frames
- Bitrate: 27.735 Kbs
- Using FRIMEncoder for MVC encoding
- [19:14:00] Reencoding: VID_00340, Pass 1 of 1
[19:50:28] - Failed video encode, aborted
Here Frimdecode crashes
Solution:
Thanks to worknstiff your reply solved the problem and all is running well now
FRIM_SW_DECODE= 0/1 - if set to 1 (default), FRIMDecode uses software decoding, 0 uses automatic detection
and:
FRIM_SW_ENCODE= 0/1 - if set to 1 (default), FRIMEncode uses software encoding, 0 uses automatic detection
Solved when both are set to "1".
hobi2000 is offline   Reply With Quote
Old 5th February 2019, 21:55   #28344  |  Link
worknstiff
You can always play around with:
and:
Based on whether or not you can get your intel cpu to work and if you can get hardware mode to work without creating artifacts.
Old 6th February 2019, 05:53   #28345  |  Link
AmigaFuture
Any help?
Thanks Chris
[..snip..]
Check hard drive free space as well as suggested before this.
Old 12th February 2019, 16:02   #28346  |  Link
Mark_Venture
Not a bug so much as a question....
I generally use Alt-Movie Only, MKV 1920x1080 intact audio as my output...
I've always used bluray as the source. As I start buying more 4K/UHD discs, I've been sticking with using the included bluray as source because its "comfortable" and works...
Now I'm wondering if I might get better output starting with the higher resolution source... but I've been concerned about possible HDR/DV on the 4K discs, so I've not tried yet.
Old 13th February 2019, 18:33   #28347  |  Link
MalibuDave42
Easy question for all you experts... The log says "Reencoding audio to AC3" yet I checked the Setup option "Do not convert DTS to AC3" What am I missing?
MalibuDave42 is offline   Reply With Quote
Old 13th February 2019, 19:02   #28348  |  Link
If you are outputting to ALTERNATE or are outputting to BD-5/9 that flag doesn't apply. Is that the case?
Old 13th February 2019, 19:23   #28349  |  Link
MalibuDave42
Movie only -- no alternate. Yes outputting to BD-5/9. Got it.
Old 13th February 2019, 19:24   #28350  |  Link
AmigaFuture
Have you converted a Blu-ray to DVD-9 720x480 at best quality? It looks like a DVD-9... The logic wouldn't suggest UHD to Blu-ray is going to make the BD look better, but rather have the same quality as BD. Just stay with best quality or default. All that's happening is resizing, and the resize method matters. Same logic is applied when taking a large digital picture and resizing it to smaller.
Old 13th February 2019, 21:45   #28351  |  Link
hobi2000
FRIMDecode crashes BDRebuilder Solved
and:
and:
Old 14th February 2019, 19:37   #28352  |  Link
Lathe
Lathe's Avatar
x264 error...
This has happened the last few times I've used BDRB. I've left it to encode overnight and I have this error:
This has happened with two completely unrelated BD's. I pretty much always do the same thing with a movie only file of this size: Fast settings, 2-Pass, same x264 Tweaks that I always use.
It's almost like the x264.exe has become corrupt somehow... (you know, women, drugs, money, rock 'n roll, the usual...)
I checked, and there is plenty of room on the target drive.
Here are the logs:
[Status]
LABEL=__BDRB
VERSION=v0.50.25
SOURCE_SIZE=26819973120
SOURCE_VIDEO_SIZE=26819973120
TARGET_SIZE=24641536000
REDUCTION=.918775566617719
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=-1
SUBS_TO_KEEP=eng;
BACKUP_MODE=1
MOVIEONLY_TYPE=0
USE_LAVF=-1
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=1.5
[00000]
AUDIO=11
PGS=111
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=24641536000
RATE=25952
SPLITS=1
[02/13/19] BD Rebuilder v0.50.25
[20:55:23] Source: __BDRB_00000
- Input BD size: 24.98 GB
- Approximate total content: [01:46:42.479]
- Target BD size: 22.95 GB
- Quality: Good (Very Fast), Two Pass
- X264 Tweak(s) enabled
- Audio Settings: AC3=0 DTS=0 HD=1 Kbs=192
[20:55:23] PHASE ONE, Encoding
- [20:55:23] Processing: VID_00000 (1 of 1)
- [20:55:23] Extracting A/V streams [VID_00000]
- [20:57:16] Reencoding video [VID_00000]
- Rate/Length: 23.976fps, 153,506 frames
- Bitrate: 25,952 Kbs
- [20:57:16] Reencoding: VID_00000, Pass 1 of 2
- Encode failed. Aborting.
- BD-Rebuilder v0.50.25
- Working Path Free Space: 90.26GB
- AVISYNTH Version: 2.6.0.6, Ok
- LAVFILTERS: Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[10:23:29] - Failed video encode, aborted
Old 14th February 2019, 20:56   #28353  |  Link
Lathe
Lathe's Avatar
Hmmm, that's interesting... So, I just tried simply to run a CMD line using x264 to render the file, and darn if I didn't get the same prompt as show above. The x264.exe that I'm using comes from an older version of BDRB 5023. I THOUGHT that that is what JD did in his more recent updates because x264 was for some reason running slow, so in the newer versions doesn't he use an x264.exe from an older version that is faster? This is the one I've always used when using the CMD line.
I guess I will try again, but this time choose another version of BDRB's x264.exe
Weird...
Old 14th February 2019, 20:59   #28354  |  Link
Lathe
Lathe's Avatar
Well, just to be clear, I'm using the x264L-64.exe from BDRB's 5023 folder. But, hmmm... in using the current version of BDRB, wouldn't it have used the CURRENT version of x264L.exe though...? So, I wonder why BOTH would fail?
DAMN weird...!
Old 14th February 2019, 21:35   #28355  |  Link
Lathe
Lathe's Avatar
FWIW, I DL'd the newest version of x264 for Windows 64 and used it in the CMD line to see what would happen. It is running just fine, BUT, for some odd reason this version in the CMD window does NOT show the cumulative percentage of the file being created (which gives me some idea as to the resulting file size) and it does NOT show the estimated time left for encoding.
Soooo... I know THIS post is not BDRB specific, my apologies, but it would be kind of nice to know why this new version of x264 does not show these two very important parameters. If anyone knows, that would be great, thanks!
Old 15th February 2019, 02:43   #28356  |  Link
Lathe
Lathe's Avatar
Well, the new version of x264 crashed too. Sure is strange... I did find out though that to show the progress and time left, you need to add the --frames [number of frames] to the CMD line.
But, I sure wish I knew why EVERY version of x264 is crashing on me. Nothing from the logs above...???
Old 15th February 2019, 13:05   #28357  |  Link
gonca
Did you try a different decoder?
Old 15th February 2019, 18:18   #28358  |  Link
Lathe
Lathe's Avatar
Oh, you mean like Direct Show instead of the internal LAV ones? No, that is a good suggestion, but then why would the .exe alone in the CMD line do the same thing?
I'm starting to think that it might be a heat issue??? Didn't JD mention something like that before when someone had the encode crash and there was an x264 error for no 'apparent' reason?
Old 15th February 2019, 21:27   #28359  |  Link
gonca
Just looked at your log again, if I read it right the encode failed 13 1/2 hours in?
Might be heat, clean up your bunnies and reconsider your tweaks, anal or otherwise, to ease up on your CPU.
Or just get a decent CPU
Last edited by gonca; 15th February 2019 at 23:23. Reason: more time, better cpu needed
Old 16th February 2019, 01:18   #28360  |  Link
Lathe
Lathe's Avatar
Yeah, I think you are right... My system has been on extreme borrowed time for the last few years now. Many times it will just freeze up and I hafta restart it a number of times, and then it will seemingly run just fine for quite a while, weeks sometimes, or even a month or two.
I use speccy to check the CPU temperature, although it almost always shows it much higher than other apps do, including my bios. It used to crank out these encodes over night every day without any trouble, but it could be getting worse now. I'll hafta wait until I can hopefully get the drop on some unsuspecting senior citizen right after they have cashed there Social Security check. THEN I could see about buying a new system. I've already looked into the CPU / MOBO / Memory. I already have 2 SSD drives and a new stronger PSU that I THOUGHT would help, but it doesn't really. I just need to get the stuff above and a nice new trick case and then that should hopefully do it.
