Old 22nd May 2020, 19:07   #2181  |  Link
Yups
I note they don't list bit depths for AV1. Does that imply 8-bit only? They don't list it for AVC either, does Intel support >8-bit AVC decode, or only with more advanced codecs.
There are bit depths listed but it's not clear to me. One the left it says profile0 (8 bit and 10 bit 4:2:0) 4k60 video, 16K still. The text on the right side is confusing. Intel only supports 8 bit for AVC by the way.
Yups is offline   Reply With Quote
Old 22nd May 2020, 19:37   #2182  |  Link
hajj_3
Looks like a good media unit for a non-discreet GPU. I think 12-bit HEVC decode is new as well. I wonder what use cases the 12-bit support is; NVidia has had it for a few years as well. I can see it being used for high-bitrate mezzanine files or something. Can't imagine a 12-bit VP9 scenario, though.
12bit av1 with rocket lake, tiger lake and their standalone graphics card:
Old 22nd May 2020, 19:50   #2183  |  Link
Yups
This is an RKL-S slide, you can never know if there is a newer decoder build in for RKL-S because it comes about half a year later than TGL-U. Also this slide isn't as detailed as today's leak, it could be a mistake there. 12 bit HEVC but not for AV1, it could be.
Old 22nd May 2020, 20:41   #2184  |  Link
Yups
10 bit sure but do we really need 12 bit?
Old 23rd May 2020, 00:09   #2185  |  Link
Beelzebubu
Originally Posted by GTPVHD View Post
it would be disappointing if they didn't support 8K, 12-bit and 4:4:4 like VP9 hardware decoder does in Gen12/Xe.
It says profile 0 only, which is 4:2:0 and 8+10bit only. 4:4:4 is profile 1, 12-bit is profile 2 (along with 4:2:2 for 8+10bit).
Beelzebubu is offline   Reply With Quote
Old 23rd May 2020, 01:43   #2186  |  Link
benwaggoner
Dolby Vision is internally 12-bit, and does tricks with dual layers or a non-backwards compatible base layer and metadata to reconstruct the video in an internal 12-bit format. If we had 12-bit decoders when DoVi was coming out, we'd probably just have a HDR-12 base layer + metadata.
Only current use of 12-bit for anything I can think of is in intermediate post production or high end mezzanine formats like J2K IMF.
Ben Waggoner
My Compression Book
Old 23rd May 2020, 08:10   #2187  |  Link
soresu
Isn't all this pointless when hardly any TVs actually support 12 bit though?
soresu is offline   Reply With Quote
Old 23rd May 2020, 12:25   #2188  |  Link
Yups
Even in this leak there is a discrepancy. In the table there is 10 bit for video but the text says it's 8 bit for video. I'm keen to believe the table in this case but not sure. In the RKL-S slide there is 12 bit AV1, it could be just a mistake (confused with 12 Bit HEVC), it could refer to still image or it could be that the Gen12LP in RKL-S uses a newer decoding unit than TGL-U.
Old 23rd May 2020, 19:50   #2189  |  Link
Beelzebubu
I think you're misreading a table converted to text. The table says "profile 0 (8-bit and 10-bit 4:2:0) 4k60 video, 16k still (HW decode)". The text says "AV1 codec support<newline>Profile 0 (10-bit 4:2:0)<tab>16k (still picture)<newline>Profile 0 (8-bit 4:2:0)<tab>4k x 2k (video)". I inserted the <tab> because it matches what the table says: 4k60 (4k x 2k) video, 16k still (picture) and each supporting profile 0 (8-bit & 10-bit, 4:2:0).
Old 23rd May 2020, 20:41   #2190  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
aomenc --denoise-noise-level= does the same as a FFT denoiser + examples/noise_model + aomenc --film-grain-table=.
Well seem not work. I have denoise but seem not have FGM in output.
You have command line exemple?
Le Sagittaire ... ;-)
1- Ateme AVC or x264
2- VP7 or RV10 only for anime
3- XviD, DivX or WMV9
Sagittaire is offline   Reply With Quote
Old 23rd May 2020, 20:54   #2191  |  Link
Beelzebubu
Please show your commandlines.
Old 23rd May 2020, 21:15   #2192  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
for exemple.
aomenc.exe -o ToS-1000.ivf C:\ToS_1920x800_xdither.y4m --ivf --i420 --width=1920 --height=800 --fps=25000/1000 --passes=2 --pass=1 --fpf=stats.log --target-bitrate=960 --maxsection-pct=4000 --buf-sz=12000 --buf-initial-sz=8000 --buf-optimal-sz=10000 --end-usage=vbr --cpu-used=3 --verbose --tune=ssim --psnr --q-hist=30 --bit-depth=10 --bias-pct=75 --kf-max-dist=120 --aq-mode=2 --test-decode=fatal --limit=1332 --skip=214 --denoise-noise-level=25
aomenc.exe -o ToS-1000.ivf C:\ToS_1920x800_xdither.y4m --ivf --i420 --width=1920 --height=800 --fps=25000/1000 --passes=2 --pass=2 --fpf=stats.log --target-bitrate=960 --maxsection-pct=4000 --buf-sz=12000 --buf-initial-sz=8000 --buf-optimal-sz=10000 --end-usage=vbr --cpu-used=3 --verbose --tune=ssim --psnr --q-hist=30 --bit-depth=10 --bias-pct=75 --kf-max-dist=120 --aq-mode=2 --test-decode=fatal --limit=1332 --skip=214 --denoise-noise-level=25
the noise is dithering. Perhaps not adapted denoising value for that? I try with --denoise-noise-level=5,10,50 and no result.
Old 24th May 2020, 03:42   #2193  |  Link
Beelzebubu
for exemple.
Dithering should be fine. Does --help include a description for --denoise-noise-level? It might be built without CONFIG_DENOISE (in which case the --help output will be missing also). Otherwise I'm not entirely sure, it has worked fine for me. Does it work on 8-bit material?
Old 25th May 2020, 23:58   #2194  |  Link
Sagittaire
Testeur de codecs
Sagittaire's Avatar
well seem work only if you have noise_model.exe in same directory than aomenc.exe ... ?
Old 26th May 2020, 01:50   #2195  |  Link
benwaggoner
Certainly for the moment, yes. Perhaps 12-bit could become a default with VVC or AV2.
Ben Waggoner
My Compression Book
Old 26th May 2020, 17:42   #2196  |  Link
soresu
Oh man, the new Cortex X1 CPU core has twice the NEON units of the A78 and previous Axx cores.
At 4x 128 bit units that's some real grunt for an off the shelf design, should be noice for encoding.
Old 17th June 2020, 09:41   #2197  |  Link
mzso
What kind of beast of a computer would you need to play 8k AV1?
I wanted to check out a few 8k videos on Youtube, but I accidentally downloaded AV1 streams, and the videos ate up my R5 1600. Even VP9 did...
I wonder if any mere mortal will have such a machine in the next decade.
Old 17th June 2020, 11:28   #2198  |  Link
ChaosKing
Beast machine? You used the wrong player!
In my browser it is almost smooth, with some dopped frames
In mpv it is perfect with ~ 55% cpu
My pc: ryzen 2600 (no oc) + gtx 1070
8K Video: https://www.youtube.com/watch?v=ChOhcHD8fBA
ChaosKing is online now   Reply With Quote
Old 17th June 2020, 11:36   #2199  |  Link
your GPU can decode this video...
Old 17th June 2020, 12:58   #2200  |  Link
ChaosKing
gtx 1070 does not have a HW AV1 decoder...
And mpv uses the dav1d decoder which works on cpu only.
