Old 4th January 2018, 16:30   #14561  |  Link
sneaker_ger
No one. Just wondering...
sneaker_ger is offline
Old 4th January 2018, 23:58   #14562  |  Link
Adding eac3to features to other tools will not be very easy as long as eac3to stays closed-source. That's no complaint, just my thoughts...
LigH is offline
Old 7th January 2018, 19:18   #14563  |  Link
AYColumbia
AYColumbia's Avatar
@madshi,
I noticed that the haali splitter URL is outdated in the -test info and is now located at the link below if you want to update it.
https://haali.su/mkv/
AYColumbia is offline
Old 7th January 2018, 19:24   #14564  |  Link
The whole Haali Media Splitter software as such is outdated. There are fortunately not many usage cases left where parts of it can still be useful...
LigH is offline
Old 10th January 2018, 04:05   #14565  |  Link
Bandits
When demuxing a UHD disc I got an audio file with DELAY -5ms in the filename.
- Does this mean there was a delay placed on the file so it would line up correctly when remuxed?
- Does this mean I need to place a delay on the file when remuxing?
- Is there a way to stop eac3to.exe from changing the output filename when a delay is encountered?
A different disc has an issue with the video.
First pass:
1) 00000.mpls, 00001.m2ts, 2:13:12
- Chapters, 16 chapters
- h265/HEVC, 2160p24 /1.001 (16:9)
- DTS Master Audio, English, multi-channel, 48kHz
- AC3, Spanish, multi-channel, 48kHz
- AC3, French, multi-channel, 48kHz
- AC3, English, stereo, 48kHz
- DTS, English, stereo, 48kHz
Second pass:
M2TS, 1 video track, 5 audio tracks, 5 subtitle tracks, 2:13:12, 11.987p
1: Chapters, 16 chapters
2: h265/HEVC, unknown parameters
3: DTS Master Audio, English, 7.1 channels, 24 bits, 48kHz
(core: DTS, 5.1 channels, 1509kbps, 48kHz)
4: AC3, Spanish, 5.1 channels, 640kbps, 48kHz
5: AC3, French, 5.1 channels, 640kbps, 48kHz
6: AC3 Surround, English, 2.0 channels, 224kbps, 48kHz
7: DTS, English, 2.0 channels, 768kbps, 48kHz
8: Subtitle (PGS), English
9: Subtitle (PGS), French
10: Subtitle (PGS), English
11: Subtitle (PGS), French
12: Subtitle (PGS), Spanish
For some reason it cannot understand the video track on the second pass and will result in a corrupt file if demuxed. I get same result pointing straight at the M2TS also. Using version 3.34.
Blu-Ray Ripper 0.112c/0.21a
Bandits is offline
Old 10th January 2018, 11:21   #14566  |  Link
tebasuna51
tebasuna51's Avatar
- eac3to can't apply delay only in TrueHD tracks, and add the string "DELAY -5ms" (I don't know how change this) to remember you add the delay when remux.
With other tracks, not TrueHD, eac3to cut audio frames or add silent audio frames. then can't be always exact, and show the remaining delay in log without modify the track name.
BTW delays smaller than a video frame duration (~40 ms) can be safely ignored.
- The problem with the video track with parameters detected in mpls but not in m2ts seems:
a) If the m2ts play fine maybe it is not supported by eac3to. Cut a sample and upload it to http://eac3to.bugs.madshi.net
b) Or maybe it is corrupt.
tebasuna51 is offline
Old 10th January 2018, 21:00   #14567  |  Link
Bandits
Loading the mpls or the m2ts gives same result for the video file.
I will send a sample. What tool can cut the m2ts correctly?
Bandits is offline
Old 10th January 2018, 22:40   #14568  |  Link
Music Fan
Probably ffmpeg (in command line), and maybe TsMuxer.
Music Fan is offline
Old 11th January 2018, 01:45   #14569  |  Link
MeteorRain
結城有紀
I tend to hard cut m2ts using a binary file cutter -- it preserves the file structure.
You can just cut, for example, 200 megabytes from the beginning, reproduce against it and then upload.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline
Old 11th January 2018, 02:37   #14570  |  Link
hubblec4
Matroska find' ich toll
DGSplit is for me the best binary cut tool.
hubblec4 is offline
Old 22nd January 2018, 20:06   #14571  |  Link
rco133
Hi.
This is a general eac3to question, but also has to do with audioconversion.
I am using eac3to 3.34 and am trying to demux a disk with several audiotracks like this:
8: E-AC3, Czech, 7.1 channels, 768kbps, 48kHz, dialnorm: -27dB
(core: AC3, 5.1 channels, 448kbps, 48kHz, dialnorm: -27dB)
When I do "eac3to 1) -demux" it says:
a08 Applying (E-)AC3 delay failed.
Seems like eac3to can't demux audio streams like that. Maybe because it is 7.1?
I would then like to demux all other tracks than the e-ac3 tracks. Is there anyway to tell eac3to to ignore some tracks when using -demux? There is 20 subtitles or so on the disk, so making a manual command line including all tracks but the e-ac3 tracks is quite cumbersome.
When I have to name the tracks manually like 15: English.sup I also Loose all the information that eac3to usually uses for the filename. Number of subs in track, and if there is any forced subs in the track.
Any help will be much appreciated.
Thanks in advance.
rco133
rco133 is offline
Old 22nd January 2018, 22:51   #14572  |  Link
tebasuna51
tebasuna51's Avatar
Yes, is a bug already reported here: http://bugs.madshi.net/view.php?id=450
More info: https://forum.doom9.org/showthread.p...43#post1821743
I don't know how help you.
Old 23rd January 2018, 17:58   #14573  |  Link
AlvoErrado2
Is it possible to change the "framerate" for eac3 audio without converting to ac3 using this tool??
AlvoErrado2 is offline
Old 23rd January 2018, 18:08   #14574  |  Link
sneaker_ger
No, changing speed requires re-encoding and eac3to can only encode to the following formats:
(1) RAW, (L)PCM
(2) WAV (PCM only), W64, RF64, AGM
(3) WAVs (multiple mono WAV files, PCM only)
(4) AC3
(5) DTS
(6) AAC
(7) FLAC
You can output to WAV and encode that to eac3. But be aware there are different eac3 "flavors": https://forum.doom9.org/showthread.php?t=174418
Old 23rd January 2018, 18:14   #14575  |  Link
Video is a discrete medium, frames appear at specific times and stay for a specific while, therefore you can change quite easily their display duration; but audio is a rather continuous medium, changing the playing time (with or without preserving the pitch doesn't matter much) is always a substantial change of the whole content, usually requires decoding, resampling, and new encoding. There may be a quite simple AC3 encoder in eac3to, but E-AC3 is not supported, AFAIK.
LigH is offline
Old 24th January 2018, 12:37   #14576  |  Link
r0lZ
PgcEdit daemon
r0lZ's Avatar
MkvMerge can shrink or stretch the audio streams by a specific factor without re-encoding. I don't know how it does it, and if the quality of the audio is less good after the operation. I suppose that it changes just the sampling rate (and therefore also the pitch), but I'm not sure.
r0lZ
r0lZ is offline
Old 24th January 2018, 12:44   #14577  |  Link
sneaker_ger
MkvMerge simply stretches/compresses the timecodes. In the end you either have all frames slightly overlapping with each other or tiny gaps between all of them. Players may react badly to this so I don't recommend it. Better to change video fps in case re-encoding is not desired.
Old 24th January 2018, 14:11   #14578  |  Link
tebasuna51
tebasuna51's Avatar
100% agree
Old 24th January 2018, 19:57   #14579  |  Link
AlvoErrado2
Thank's all for your answers!!
I understood what I need to do, thank you one more time.
Old 27th January 2018, 23:43   #14580  |  Link
Eseninzhiv
can extract Dolby Atmos master file (.atmos) with eac3to from an audio file Dolby Atmos/TrueHD Audio (BluRay)?
Eseninzhiv is offline
eac3to
