Old 18th October 2018, 13:43   #14721  |  Link
Dulus_No
Originally Posted by mkver View Post
You are making presumptions about the aac encoder delay that needn't be true. Not every aac encoder has a delay of 2 frames. The best bet would probably to test Apple's AAC encoder. Or maybe Dulus_No knows a bit more about this?
[Edit]: This and this both suggest 2112 samples which are exactly 44ms. You knew that, didn't you?
[Edit2]: Yes, you did. Of course you did.
The same delay shows up not only on AAC tracks but also on AC3 (video has a +42ms / 1 frame delay). mp4dump of original m4v with drm and decrypted with TunesKit m4v.
Dulus_No is offline
Old 18th October 2018, 14:09   #14722  |  Link
sneaker_ger
Ok, so only one edts/elst with "media time" != 0.
sneaker_ger is offline
Old 18th October 2018, 21:20   #14723  |  Link
arrgh
There are 2 ways to store Dolby Vision. One as SEI messages in the base video stream. On Blu-Ray it seems they use a second "track" instead. As you say there isn't really any way to "properly" copy that into mkv yet.
yes, I see a second Video track...
https://www.bilder-upload.eu/bild-d1...93458.jpg.html
so, that means it is relly a second independant track and not something like a "forced pgs" which sometimes comes as an individual track, sometimes enbedded in a general track where some frames are marked as forced...
or, in other words, the contend of this track is not also included in the first video stream; to maintain the complete data one would need to mux the second track into a container?
there are also no other containers (instead of mkv) which could be used for this and enable rederers like madVR to use the data?
arrgh is offline
Old 18th October 2018, 21:29   #14724  |  Link
sneaker_ger
I don't know any free software that supports Dolby Vision. (This includes madVR.)
Old 30th October 2018, 23:48   #14725  |  Link
killerpot
wav bug in eac3to !! only version 3.24 old one dont bug! HELP PLZ!
eac3to wav to ac3 bug in v3.34 and all other version i try 3.27,3,29,3.30,3.31,3.34 and others all bug
only old one 3.24 not bug!!
bug 3.34 and other give this error: proof here https://puu.sh/BTB58/7697ab92ae.mp4 (3,34 for this example)
aborded at file position 262144 !!! spend 6 hour try fix that nothing work i try all king of thing
different folder location just in case not work and other thing i try PLZ HELP ME SOMEONE!
why eac3to 3.24 work???
eac3to wav to ac3 only work! with v3.24
check the proof here https://puu.sh/BTAUz/8be7a5e60d.mp4
FILE HERE ON GOOGLE DRIVE (FOR TESTING) vff.wav
https://drive.google.com/open?id=1aB..._kJdA4CA_G74Wa
some one can test it and help me plz! i want to know what is the probleme annoy me so much thx!
in 3.34 the only time it's work it's making this line "eac3to vff.wav vff.ac3 -resampleTo48000 -down16
-448" WHY EAC3TO SHOULD WORK WITH 44,1 KHZ RIGHT? it's work in 3.24!
killerpot is offline
Old 31st October 2018, 03:14   #14726  |  Link
tebasuna51
tebasuna51's Avatar
@killerpot
I can reproduce the bug but the Aften encoder included in eac3to is deprecated, use ffmpeg instead without problems:
ffmpeg.exe -i vff.wav -acodec ac3 -center_mixlev 0.707 -ab 448k vff.ac3
tebasuna51 is offline
Old 31st October 2018, 09:20   #14727  |  Link
killerpot
but the problem i hate ffmpeg if you try to encode ac3 in audacity (ffmpeg audacity version) your ac3
will be a shit for shure.and the command are more complicated in ffmpeg.question #1 what this does
-center_mixlev 0.707 (its and 5,1 wav to ac3 i wanna encode)
question #2 no other freeware are better then aften to encode ac3.but a question did ffmpeg use aften in
their thing to encode ac3 ?
question #3 i think in the past eac3to tell he encode with aften my ac3 and now that tell libaften do
you know if it's the case ?
question#4 if it's the case what the difference between aften and libaften ?
Old 31st October 2018, 10:59   #14728  |  Link
tebasuna51
tebasuna51's Avatar
1) By default ffmpeg put in ac3 header a value of -center_mixlev 0.595, the correct default is 0.707 to avoid low dialog volume if downmixed to stereo.
2) The ac3 encoder in ffmpeg is a improved aften encoder (by the same developer Justin Ruggles)
3) eac3to always use libaften.dll to encode ac3, but you can use pipe to encode with aften.exe. Or better use Aften directly:
aften vff.wav vff.ac3
(defaults: -b 448 for 5.1, -cmix 0 [= -3.0 dB = 0.707], -readtoeof 1 only needed if wav > 4 GB, -pad 0 to avoid 5.3 ms of delay)
4) Don't exist differences between aften and libaften, here seems a eac3to bug when call libaften with a 44.1KHz source.
If the command are complicated for you use my UsEac3to GUI and the A/V Recode option to use ffmpeg for ac3 recode directly.
Old 1st December 2018, 01:14   #14729  |  Link
Masutin
To convert to mono, what more options are required to avoid the error 'No channel mapping to AAC defined'?
stdout.wav -mono | QAAC
Masutin is offline
Old 1st December 2018, 02:27   #14730  |  Link
tebasuna51
tebasuna51's Avatar
stdout.wav -mono -simple | QAAC
Work with a simple wav header, with a WAVE_FORMAT_EXTENSIBLE header (default) the channel mask can be other than 4 (mono center channel).
Remember: the undocumented switch "-mono" extract the center channel from a multichannel input or left channel from stereo input, don't make a downmix from input channels.
Old 10th December 2018, 21:11   #14731  |  Link
Lyle_JP
Unreasonable User
Lyle_JP's Avatar
I always use
-dialnorm -27
on my ffmpeg ac3 encodings. Does that do the same thing, or should I also add
Lyle_JP is offline
Old 10th December 2018, 21:38   #14732  |  Link
The "Dialog Normalization" and the "Center Mix Level" are independent parameters.
LigH is offline
Old 10th December 2018, 22:42   #14733  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by Lyle_JP View Post
I always use -dialnorm -27
Always?
Not all sources need that parameter.
My recommendation is let the ffmpeg default -31
or should I also add -center_mixlev 0.707?
Like LigH say is not the same.
Here I recommend use 0.707, default used by Dolby, instead the ffmpeg default 0.595.
Old 11th December 2018, 19:22   #14734  |  Link
Richard1485
Does the appropriate value for -center_mixlev vary from source to source (in the way that -dialnorm does) or is it always a matter of preference?
Old 11th December 2018, 22:20   #14735  |  Link
tebasuna51
tebasuna51's Avatar
Of course if there are options is because it can vary.
I only recommend defaults without analyze the source.
For instance when recode soundtracks from others formats.
Old 12th December 2018, 14:52   #14736  |  Link
Richard1485
Yes, or because there are preferences.
Understood. Thanks, tebasuna!
Old 13th December 2018, 19:35   #14737  |  Link
GCRaistlin
GCRaistlin's Avatar
madshi, can you please take a look at this bug: http://bugs.madshi.net/view.php?id=377
Windows 8.1 x64
Magically yours
Raistlin
GCRaistlin is offline
Old 15th December 2018, 08:03   #14738  |  Link
asarian
Same here:
eac3to.exe valerian.m2ts 2: c:\video\temp.pcm -down6
MKV, 1 video track, 2 audio tracks, 3 subtitle tracks, 2:17:25, 24p /1.001
1: h265/HEVC, 2160p24 /1.001 (16:9), 10 bits
2: TrueHD (Atmos), English, 7.1 channels, 48kHz, 2419ms
   "TrueHD Atmos 7.1"
3: AC3 EX, English, 5.1 channels, 640kbps, 48kHz, 2419ms
   "AC-3 5.1-EX"
4: Subtitle (PGS), English, "English (Forced)"
5: Subtitle (PGS), English, "English (SDH)"
6: Subtitle (PGS), German, "German"
a02 Extracting audio track number 2...
a02 Decoding with libav/ffmpeg...
a02 Applying RAW/PCM delay...
a02 Mixing surround channels...
a02 Swapping endian...
a02 Remapping channels...
a02 Creating file "c:\video\temp.pcm"...
----[truehd @ 026336c0] Lossless check failed - expected 00, calculated c1.
[truehd @ 026336c0] Lossless check failed - expected 00, calculated 46.
[truehd @ 026336c0] Lossless check failed - expected 00, calculated 34.
--[truehd @ 026336c0] Lossless check failed - expected 00, calculated 24.
-[truehd @ 026336c0] Lossless check failed - expected 00, calculated 5b.
[truehd @ 026336c0] Lossless check failed - expected 00, calculated 81.
[truehd @ 026336c0] Lossless check failed - expected 00, calculated 83.
------------[truehd @ 026336c0] Lossless check failed - expected 00, calculated e7.
-[truehd @ 026336c0] Lossless check failed - expected 00, calculated 3b.
--[truehd @ 026336c0] Lossless check failed - expected 00, calculated e2.
-[truehd @ 026336c0] Lossless check failed - expected 00, calculated 96.
[truehd @ 026336c0] Lossless check failed - expected 00, calculated 78.
This is with a brand new Blu-ray (Valerian and the City of a Thousand Planets).
Thing is, I'd love to use ffmpeg directly, but I can't extract the Atmos stream with tsMuxer first (as it doesn't recognize it).
asarian is offline
Old 15th December 2018, 08:32   #14739  |  Link
mkver
But you can use ffmpeg directly. A Bluray contains a slightly modified version of a transport stream that ffmpeg can handle. And if you build ffmpeg with libbluray, it can even parse playlists.
mkver is offline
Old 15th December 2018, 09:00   #14740  |  Link
asarian
Thx.
Hmm, turns out ffmpeg (4.1) yielded the same errors. I can't say I'm hearing any distortion, but still.
asarian is offline
eac3to
