Old 19th January 2010, 10:31   #1141  |  Link
katzenjoghurt
Ahhh!
I'll try this out tonight and report.
Thx, MrC.
Old 19th January 2010, 20:21   #1142  |  Link
katzenjoghurt
Yipp.
It's fine now.
I hope the Win7 issue is no too bad news for you, MrC.
At least the workaround for users seems to be simple.
Old 20th January 2010, 13:48   #1143  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@katzenjoghurt
I'm glad to hear that you have fixed it.
I will put this workaround in the FAQ section I'm writing right now.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 25th January 2010, 06:50   #1144  |  Link
QuadraQ
QuadraQ's Avatar
@QuadraQ
Have you tried to analyse the srt file with SubtitlesCreator? Any errors report?
Could you setup CCExtractor to output subtitles in sup format? One conversion is better than two....
The output options in CCExtractor doesn't list sup format. The available options are:
.srt
.sami
.txt (transcript, no timing)
.raw
.dvdraw
.bin (native CCExtractor format)
I don't suppose any of those options would work?
When I open the srt file in SubtitleCreator v2.2 I get an unhandles exceptions with the following details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at SubtitleCreator.Subtitle.RemoveFormatting(String line)
   at SubtitleCreator.PreviewForm.CheckOneSubtitle(ListViewItem lvi)
   at SubtitleCreator.PreviewForm.CheckSub(Int32 Index)
   at SubtitleCreator.PreviewForm.DisplaySubtitles()
   at SubtitleCreator.PreviewForm.OpenSubtitleFile(String FileName)
   at SubtitleCreator.PreviewForm.selectSubtitleFileClick(Object sender, EventArgs e)
   at SubtitleCreator.PreviewForm.selectMySubtitleFileClick(Object sender, EventArgs e)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4200 (NetFxQFE.050727-4200)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
SubtitleCreator
    Win32 Version: 2.0.0.0
    CodeBase: file:///C:/Program%20Files/AVStoDVD/SubtitleCreator/SubtitleCreator.exe
    Win32 Version: 2.0.50727.4016 (NetFxQFE.050727-4000)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
DShowNET
    Assembly Version: 1.0.0.1
    Win32 Version: 1.0.0.1
    CodeBase: file:///C:/Program%20Files/AVStoDVD/SubtitleCreator/DShowNET.DLL
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
ListViewEx
    Assembly Version: 1.0.2297.19690
    Win32 Version: 1.0.2297.19690
    CodeBase: file:///C:/Program%20Files/AVStoDVD/SubtitleCreator/ListViewEx.DLL
SubtitleCreator.resources
    CodeBase: file:///C:/Program%20Files/AVStoDVD/SubtitleCreator/en/SubtitleCreator.resources.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
After I click Continue though everything seems to be in order.
QuadraQ is offline   Reply With Quote
Old 25th January 2010, 10:26   #1145  |  Link
Alba Ra
I just wanted to try AVStoDVD but encountered several hickups that I didn't like that much.
1. When loading an Avisynth script a new script is created. AVStoDVD does not recognize the video as 16:9 so it will add it as 4:3. Switching in Title Edit to 16:9 will automatically add bars (to a 16:9 video stream). So I have to manually change the Resize options (which have been reverted later when I've added an audio stream).
2. I can only add one audio stream!? Is that true?
This audio issue is the real reason I quit the application. Else it looked good especially the (albeit flawed) ability to use Avisynth scripts to feed streams.
Alba Ra is offline   Reply With Quote
Old 25th January 2010, 13:55   #1146  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@QuadraQ
well, if sup is not supported by CCExtracton, then go with srt (as you have done yet).
You have said that after the error msg, SubtitlesCreator loads the srt file. Is it displayed correctly? Can you see all the subs?
@Alba Ra
what is the Display Aspect Ratio (DAR) of your avs file? Remember that AviSynth script does not have any DAR flags, so DAR is equal to clpi.Width/clip.Height.
So far only one audio track is supported. Multi audio tracks feat is in the ToDo list.
Bye
MrC
AVStoDVD Homepage
Old 25th January 2010, 16:28   #1147  |  Link
Alba Ra
I want to create a DVD from the original VC-1 stream (1920x1080). I created (as basically described in this thread by Jeremy Duncan) a Matroska file (with a DAR of 16/9), a Graph file and a AviSynth script. It opens alright in VirtualDub.
For AVStoDVD I tried two ways. First by resizing the HD stream inside of my original script to NTSC values (720x480), then by leaving the HD unchanged in size (i.e. 1920x1080). Both times AVStoDVD adds the video as 4:3. That can fortunately relatively easily be amended by manually editing the internal script used to open AVS files.
As for adding multiple audio tracks: when can that be expected to be implemented. What are you programming with? I see the language is VB6 but what program?
Old 25th January 2010, 17:01   #1148  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
If your script ends with a 720x480 image, then input DAR is 1.5 and output DAR will be 4:3. Letterboxing is added.
If your script ends with a 1920x1080 image, then input DAR is 1.778 and output DAR will be 16:9. No letterboxing.
Why don't you feed directly AVStoDVD with your VC-1 stream?
About multiple audio tracks feat, I hope to implement it by the end of QTR1. Language is VB6. What do you mean by "program"?
MrC
AVStoDVD Homepage
Old 25th January 2010, 18:02   #1149  |  Link
Alba Ra
For some reason I didn't think of feeding the VC-1 stream. In your case this might be just the solution for this.
As for "program" - VB6 needs to be compiled, doesn't it? I mean, you may write the code using Windows' own notepad but in the end it'll have to be compiled. I wanted to know whether you work with an IDE or whether you write the code directly (say, with Notepad++, as I do) and use what compiler!? I haven't used VB yet but this would an as good as any opportunity to learn this language (as I am supposed to be able to)...
Old 26th January 2010, 11:56   #1150  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
I'm using VB internal IDE. I can't imagine the difficulties in using an external editor (even as good as Notepad++) without commands autocompletion and context help...
BTW I suggest you to learn a more modern and complete language (there is the .NET family).
Bye
MrC
AVStoDVD Homepage
Old 26th January 2010, 17:26   #1151  |  Link
Alba Ra
Oh, I do know some C# with .NET (it's this dependency that I don't like but it was part of my training), C++ (but never done GUI programming with that), I'd like to learn Python and Haskell. But it seems that for stand-alone, .NET-independent GUI programming a lot still use VB.
Old 27th January 2010, 15:37   #1152  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Release 2.2.6 is available to download.
Change log:
- Added 'Aften Advanced Configuration' options (Pad, DRC, BWFilter) in 'Title Edit'/'Audio'
- Added FAQ section in Help file
- Added check on durations of output vs input audio/video streams
- Added 'Copy Thumbs Graphic Properties' feature to DVD Menu Editor
- Added 'Acid Compass' DVD Menu template
- Improved support to VFR (Variable Frame Rate) video
- Removed Wave PCM audio stream retaining: too many issues with FFMpeg (de)muxing
- Revised Splash Screen layout
- MediaInfo updated to 0.7.26
Let me know
Bye
MrC
AVStoDVD Homepage
Old 28th January 2010, 09:11   #1153  |  Link
MadRat
MadRat's Avatar
Thanks for the software MrC, I'm looking forward to trying it out.
MadRat is offline   Reply With Quote
Old 28th January 2010, 17:22   #1154  |  Link
jksmurf
Hmm. I get "runtime error '9':" Subscript out of range with 2.2.6 No Installer. 2.2.5 was fine.
jksmurf is offline   Reply With Quote
Old 29th January 2010, 12:42   #1155  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Where/when do you get that error?
Did you use a new folder for 2.2.6 or did you overwrite the old 2.2.5?
Bye
MrC
AVStoDVD Homepage
Old 30th January 2010, 00:18   #1156  |  Link
jksmurf
When I start by clicking the AVStoDVD.exe file.
It's the No_Install version
Did you use a new folder for 2.2.6 or did you overwrite the old 2.2.5?.
I tired both actually. Same error. Is there a log I can pass you to help?
Thanks,
k.
Old 30th January 2010, 09:10   #1157  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@jksmurf
Try to erase the reg key HKLM\Software\AVStoDVD
Do you have same issue using the Installer version?
Can you replicate on another PC?
Any other user is getting the same error?
Bye
MrC
AVStoDVD Homepage
Old 30th January 2010, 10:05   #1158  |  Link
ChickenMan
ChickenMan's Avatar
I installed the Installer version over the top of 2.2.5. Installed fine and working fine here in Windows 7 32bit.
Cheers,
CM
ChickenMan is offline   Reply With Quote
Old 30th January 2010, 12:21   #1159  |  Link
jksmurf
Confirm that does not work
Wiill try other comments.
Cheers,
k.
Old 30th January 2010, 14:39   #1160  |  Link
eSkRo
eSkRo's Avatar
i used AVStoDVD_226_Install.exe
and it installed flawless!
im on XP PRO x86...
-peace-
Tor [anonymity network]
eSkRo is offline   Reply With Quote
[IMG] code is Off
