Old 14th January 2019, 21:49   #54281  |  Link
tp4tissue
tp4tissue's Avatar
for best results you should always send RGB if possible.
madVR doesn't care about the output of the GPU it just send images the driver which is always RGB.
sorry to hear that. AMD needs 10 bit output from madVR or the AMD HDR API will not work.
the rest doesn't change. you should not go over 10 bit on AMD use the chance of 10 bit RGB on them for a at least in theory untouched output.
So... got my rx580.
How do I get madtpg to kick into HDR mode, during displaycal.
It seems that -unlike- nvidia, the madtpg won't kick into hdr mode at all ?
I can play an hdr movie, and the regular player will go into amd-hdr mode, and so will the tv.
I've tried both, 09214 and 09217..
This is so confusing
I did, 10bit in display, d3d11, fullscreen in madtpg, win10 hdr OFF
Ghetto | 2500k 5Ghz
Old 14th January 2019, 22:53   #54282  |  Link
Asmodian
You probably need to have it fullscreen so madVR enables 10-bit. This means the TV will go into HDR only when displaying patches.
madVR options explained
Old 14th January 2019, 23:13   #54283  |  Link
tp4tissue
tp4tissue's Avatar
I've tried this, displaycal is launching the madtpg process in fullscreen, and the patches are all displayed full screen.
The setup is still not kicking into HDR.
Ghetto | 2500k 5Ghz
Old 15th January 2019, 00:00   #54284  |  Link
Originally Posted by glc650 View Post
How does a GTX 1060 6GB compare to a Radeon 580 8GB?.
It's quite a bit faster with NGU. If The 1060 6GB is all you can afford just do it its not like you have a lot of options.
Old 15th January 2019, 10:35   #54285  |  Link
mrmojo666
just saying, in the last months i noticed that sometimes ddu doesn't clean well amd drivers, so after and ddu and driver installation i got no hdr switching, at that point a ddu clean in safe mode + ddu clean in normal mode and then driver installation solved the issue, pay also attention that amd driver must set up to 10/12 bit to get hdr switch working. no need of FSE for HDR with AMD.
bye
AMD Ry 1500x - 8GB - RX460 4GB
TV Philips 55pus6501+ Marantz 1608 avr
WIN10(1903) 4K/444RGB
Mediaportal - Mpc-hc
MADVR-D3D11/10bit
Old 15th January 2019, 11:08   #54286  |  Link
ileile
wrong edid and multiple identifications
It seems that madVR can't properly read the edid of my monitor. the manufacturer name, the native resolution, etc, all of them are wrong, they looks like NVIDIA defaults, but not read from the device. But other software could read correct values.
And madVR generates many identifications, it may always consider the monitor connected with a new and different configuration when the player runs, so a new entry is added (with same defaults values) and being active (old ones never be active again) every time.
edid data read by madVR:
00 FF FF FF FF FF FF 00 3A C4 00 00 00 00 00 00
00 00 01 04 95 00 00 78 EC 91 A3 54 4C 99 26 0F
50 54 00 20 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 94
02 03 12 71 45 10 04 03 01 00 23 09 07 07 83 01
00 00 02 3A 80 18 71 38 2D 40 58 2C 45 00 B8 6F
21 00 00 1E 56 5E 00 A0 A0 A0 29 50 30 20 35 00
58 54 21 00 00 1A 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 CB
and the screenshot.
ileile is offline   Reply With Quote
Old 15th January 2019, 11:29   #54287  |  Link
tp4tissue
tp4tissue's Avatar
bye
For me Madvr playback DOES kick into HDR mode.
However, MADTPG, during displaycal, EVEN in fullscreen mode, will not kick into HDR.
What do you mean amd driver set up 10-12 bit, in the AMD [Display] menu ?.
I will try DDU though, thanks for the suggest.
Ghetto | 2500k 5Ghz
Old 15th January 2019, 12:47   #54288  |  Link
mrmojo666
Yes display settings
MADVR-D3D11/10bit
Old 15th January 2019, 13:17   #54289  |  Link
jmonier
This sounds exactly like the problem I've seen with my LG 34WK95U when connected via the Displayport. (It's fine via HDMI.) I've reported it as a bug and madshi said he'll try to investigate it when he has time.
What monitor and connection do you have?
jmonier is online now   Reply With Quote
Old 15th January 2019, 13:24   #54290  |  Link
Charky
I had the same issue.
I toggled HDR in the Win 10 display options.
Charky is offline   Reply With Quote
Old 15th January 2019, 15:29   #54291  |  Link
madjock
Unsure if it is madVR or my TV, but I have had to reset my TV settings to get the HDR to toggle back on. Even did a full 8.1 install then 10 again.
Was not till I reset the TV that it worked again, no idea if its a driver issue or the TV, just so many variables it is hard to pinpoint, especially when it can work one day and then you have to mess with madVR another day for some reason.
At least if the TV is back at default you can work backwards, bloody annoying as I wish I had done that first.
Old 15th January 2019, 16:47   #54292  |  Link
tp4tissue
tp4tissue's Avatar
Just tried,
Safemode,
DDU,
adrenaline 18.5.1 (older driver),
Displaycal 3.3.5.0 (old dispcal),
Madtpg still will not kick into HDR, even launched at fullscreen
Again, Regular madvr AMD HDR playback works fine.
Ghetto | 2500k 5Ghz
Old 15th January 2019, 17:44   #54293  |  Link
madjock
Just tried,
Safemode,
DDU,
I have the opposite in a way, it enables with a 4K HDR film in KODI/Dsplayer and does not go off till I come out of KODI, seems to be new things every day
Old 15th January 2019, 17:50   #54294  |  Link
tp4tissue
tp4tissue's Avatar
Does your player render through OS-HDR or AMDHDR or NV HDR.
Ctrl-J, top left.
I think I read that if something goes through OSHDR, it can not auto pop-out
I'm on MPCHC, so it renders through AMD HDR.
Ghetto | 2500k 5Ghz
Old 15th January 2019, 18:00   #54295  |  Link
madjock
Ctrl-J, top left.
All good on the desktop side with MPC-HC and MPC-BE, I use NV HDR and its all good, just recently started in KODI no ideas why, but its better than your scenario as at least it works for the most part.
Old 15th January 2019, 21:16   #54296  |  Link
Asmodian
Does it go into HDR in a windowed mode? In the past, on Nvidia, I was able to use a video playing in MPC-HC to trigger HDR as a workaround for madTPG not triggering HDR.
Old 15th January 2019, 21:25   #54297  |  Link
tp4tissue
tp4tissue's Avatar
On my ATI card, it will only HDR on fullscreen for playback, madtpg doesn't HDR at all.
My nvidia works fine, hdr triggers on windowed , but unnecessary because the madtpg will trigger nv hdr as well.
Ghetto | 2500k 5Ghz
Old 15th January 2019, 23:27   #54298  |  Link
XMonarchY
I can select 12 bit in NVCP panel in 1809 but obviously cant get it to stick in a custom res in the NVCP.
I am using 416.34.
Yeah, same, I really hope madshi still looks at these forums and maybe next madVR version will have custom display mode with color bit depth settings.
Old 16th January 2019, 00:16   #54299  |  Link
albur
I'm close to give up with madvr, i have my computer and when i make a change in madvr i can see the diference in mpc hc paused. When i do the same in my htpc it does nothing with the same configuration, madvr is running because hdr to sdr is working
What can be the issue? The only difference is that one has monitor and the other a projector and the pc has a amd and the htpc a nvidida
albur is offline   Reply With Quote
Old 16th January 2019, 00:29   #54300  |  Link
Warner306
There probably is a difference, but you can't perceive it on that display. What setting are you referring to?
