Old 20th June 2019, 15:49   #56641  |  Link
mambans
You need profiles set up.
Turn off superRes, try Bicubic 150 as a downscaler, better?
Didn't help much, but I totally forgot about profiles. Can play around with that instead and set a different profile for my HDR (4k) content.
mambans is offline   Reply With Quote
Old 20th June 2019, 16:11   #56642  |  Link
mambans
Originally Posted by el Filou View Post
Also sharpen edges and soften edges enabled at the same time sound counter-intuitive to me, and if using the AR filter integrated with some upscalers you shouldn't need to activate anti-ringing in refinement.
Anyway, rendering times of 24 ms for 24 fps movie shouldn't cause any problems so I'm wondering why it "lags".
I'm not that good with Madvr but I have now turned of soften edges and anti-ringing
And I just found out what caused the 'lagging', it was 'reduce compression artifact's under artifact removal.
Btw, just found out about Profiles. Is there anyway to see that profiles is activated? and will this auto profile work:
if (HDR) or (srcWidth >= 3840) "Profile 2"
else "Profile 1"
Thanks so far and in advance.
Old 20th June 2019, 16:21   #56643  |  Link
madjock
https://forum.kodi.tv/showthread.php...942#pid2238942
A wealth of info here
Windows 10-1909 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 430.64 | Pioneer VSX-534 | Philips 65PUS6703 - 65"
Old 20th June 2019, 16:32   #56644  |  Link
mambans
Originally Posted by madjock View Post
Thanks, will definitely read trough it. I was just skimming through it about profiles but found nothing about seeing the activated profile.
Old 20th June 2019, 17:39   #56645  |  Link
el Filou
el Filou's Avatar
No way to see it in the OSD (yet), but if you open madVR settings during playback, the folder(s) associated with the active profile will be in bold
Old 20th June 2019, 18:48   #56646  |  Link
mambans
Ah oke, that works. Thanks!
Old 20th June 2019, 19:13   #56647  |  Link
Djfe
madVR sadly doesn't seem to support 1440p and 120Hz for 3D playback, yet.
(and the display mode settings don't seem to honored, it switches to 1080p60 and doesn't return to the original display setting once I leave fullscreen; my settings set/unset display mode upon entering/leaving fullscreen, since the display still stays in 1080p60 upon leaving fullscreen, it doesn't reset to original display mode upon leaving the application either :/ ; I might actually report that as a bug later on)
Are there any infos why 3D is limited to 1080p60? Displayport/Nvidia 3D Vision definitely support 3D for more than 1080p and 60Hz (unlike HDMI maybe)
Is there any interest in working on supporting side-by-side/top-bottom/field-sequential/frame-sequential 3D? (I have mostly seen the first two so far)
3D channels on broadcast I have access to are only side-by-side and I don't know of any MVC encoder that is freely available sadly. (If you know of one that is free or has a fair price, pls tell me)
The only way to watch these movies for me so far, is the NVIDIA 3D Vision Video Player. (I'm actually unsure whether I can combine the player with madVR, I'll take a look at this now and update this post later)
Anyways I'm very greatful for madVR, I just started using it and I'm amazed at the results I'm getting on my 1440p monitor, especially the scaling looks way better now!
Djfe is offline   Reply With Quote
Old 20th June 2019, 19:29   #56648  |  Link
Asmodian
-madVR's 3D support is currently limited to 1080p23.
It has been this way for a while now too. I do not expect madVR to improve its 3D support anytime soon. With 3D being removed from recent Nvidia drivers and the last few generations of TVs it seems like the user base for improved 3D will only decrease in the future. Sorry.
Originally Posted by oldpainlesskodi View Post
MS just pushed out build 18922 on fast-ring, and banding errors are gone (on my rig), without having to use the workaround.
This is really good news! Now to decide if I should install the fast ring...
madVR options explained
Old 20th June 2019, 20:42   #56649  |  Link
Djfe
cool, thx for the info and linking me to your options thread. My searches didn't bring it up.
What leaves me wondering/confused: Nvidia's control panel shows, that (madVR) set my display to 60Hz (not 23,xxx) and mpc-hc shows with STRG+J that my display runs at 100Hz and everything is synced to 49,xxx
But atleast it works ^^
It's kinda sad to me that 3D is dying but it is how it is.
Though 3D might not be completely dead because you can watch 3D with VR headsets and use madVR for that.
Though only mvc or side-by-side would work. Other 3D formats (like the ones I mentioned) wouldn't work with madVR, yet.
Old 20th June 2019, 20:55   #56650  |  Link
Alexkral
Correct me if I'm wrong, but I think 3D Vision is limited to 1080p@24hz or 720p@60hz, although there are some solutions like an EDID override to get 1080p@60hz, but no more.
There's FRIM, I use FRIM source to encode MVC to 3D over-under and it works flawlessly.
https://forum.doom9.org/showthread.php?t=169651
Old 20th June 2019, 22:28   #56651  |  Link
Alexkral
Sorry, I had completely forgotten about these things since I'm not very interested in playing lately. I can definitely play at 4k@60hz with a custom EDID override.
That should be pretty trivial for SBS/OU, but given the nonsense against 3D and the endless development of tone mapping I don't think you can expect it.
Old 20th June 2019, 23:25   #56652  |  Link
toki
someone, please tell me there's a way to fix stutter on panning shots with 4k content
toki is offline   Reply With Quote
Old 21st June 2019, 00:04   #56653  |  Link
It'll very likely be backported to the next Cumulative Update. I wouldn't bother going to an insider version for a bugfix. It'll result in far more issues in the longrun.
Old 21st June 2019, 00:56   #56654  |  Link
SamuriHL
SamuriHL's Avatar
^^^^ this. It's going to be October before that build is official. That's a LOT of bug fixing between now and then to wade through just for one fix. I can't wait to get my 2070 back on Monday. That took forever.
Old 21st June 2019, 03:36   #56655  |  Link
XTrojan
Quick question, I been reading around that letting MadVR handle HDR is better than using "passthrough HDR". Is this true, and if it is how do I really start, is expensive HDR calibration needed?
XTrojan is offline   Reply With Quote
Old 21st June 2019, 07:38   #56656  |  Link
svengun
Fast ring isn't always 'open to join' You can apply but can take a while...
Livingroom: Ryzen 7 1700@3.9ghz - Win Insiders Fast Ring - MSI RTX 2700 Gaming - Philips 65OLED803 | Bedroom Ryzen 3 1200 - Win 8.1 - GTX1060 - LG OLED EG920V 55" > All with MadVR latest test build
svengun is offline   Reply With Quote
Old 21st June 2019, 09:40   #56657  |  Link
chros
chros's Avatar
If you have HDR capable TV I'd go for "just" passthrough. But just try out on yours. No, no calibration/profiling is required although it's preferred
Old 21st June 2019, 10:11   #56658  |  Link
if it is 18922 it already has installation files so no wait what so ever.
Old 22nd June 2019, 03:32   #56659  |  Link
XTrojan
3D dying was obvious ever since it was said that UHD BD won't support 3D. Today you gotta choose between HDR 4k picture quality (UHD BD) or 3D depth (Normal BD with 3D).
The death of 3D was the issue of setting it up, it practically was dead on arrival, the 3D BD players being horrible didn't help either. Even today you got issues like 3D subtitle depth.
I would hoped for enhanced 3D with more realistic depth that doesn't create those retarded "four-eye" scenarios and much more ease of use, but it never happened.
What's even worse is 3D settings for most TVs are horrendous, many TVs force you to keep interpolation on when 3D is on.
The technology is just badly adapted, it's nowhere near Theater 3D or IMAX 3D Theater for that matter.
Old 22nd June 2019, 14:14   #56660  |  Link
tp4tissue
tp4tissue's Avatar
Also, 8bit RGB 2160p60 is better quality than 12 bit YCbCr 4:2:2. This is not true if watching via a bluray player but it is when using madVR. I use 8bit RGB 2160p60 most of the time, over HDMI 2.0, on a LG C7 and now a C9.
HDMI 2.1 allows RGB 2160p120, which I am very much looking forward to when a GPU with HDMI 2.1 comes out.
How is 10 bit achieved on these panels, is it through a high precision voltage controller or frc/ spatial dithering ?
Unless it's the former, I don't think 10bit will ever be better, because madvr already essentially does the latter.
Ghetto | 2500k 5Ghz
