30th June 2013, 01:15 | #12522 | Link |
Hi Atak_Snajpera,
I wanted to try your RipBot264 software ... just to play around, but I decided to run the Zipped folder thru VirusTotal.com before trying them ... Well, I ran versions 1.16.4, 1.16.5 and 1.17.4 and they all came back with 1 or 2 Warnings ... and Not all of the Virus Scanners returned results ... so out of the 42 Available Scanners something between 27 to 38 returned results. Can you or anyone else comment on this ... why VirusTotal is tagging the Zipped files as containing some Trojan or Worm!?!? Things like "Win32/PrcView", "MadCodeHook". Thanks, G! |
30th June 2013, 03:35 | #12523 | Link | |
MadCodeHook: http://www.madshi.net/madCodeHookDescription.htm I couldn't find where within Ripbot this is detected. Win32/PrcView is found in Ripbot264\Tools\Process\process.exe and it is a command-line process viewer, available from http://retired.beyondlogic.org/consulting/processutil/processutil.htm |
30th June 2013, 07:13 | #12526 | Link | |
I was actually running a little low on space on that drive, and now with your explanation, I'll know why, in the future I thought I'd ask, and I got the answer I needed. So thanks for that, I thought it might have been something wrong with the file being encoded. Cheers |
30th June 2013, 12:19 | #12527 | Link |
@burt123 vjoin does not care what kind of file since it basically does a copy /b. I have not put any error handeling into it when running low on space, that will probably be added in the next version.
Cheers Trayman |
2nd July 2013, 06:22 | #12530 | Link |
Silent Reader
@meshaun:
Several month ago, I used Komisars builds for updating Ripbot each time a new revision of x264 came out. they worked fine with no problems. Then Komisar decided to implement some cosmetic CLI progress patches in his custom builds and encoding progress in Ripbot wasn't shown properly anymore. Encodes were fine, it was only a "transmitting problem of progress informations to GUI". Vanilla builds should still be fine, custom builds should still essentially work, but since then I don't know if Komisar or Atak have changed anything to be better interoperable. Last edited by Wishbringer; 2nd July 2013 at 06:25. Reason: typos |
2nd July 2013, 14:29 | #12531 | Link | |
http://www.microsoft.com/en-us/downl....aspx?id=30679
2nd July 2013, 21:22 | #12533 | Link | |
Hi stylez82, Thanks for taking the time to reply, I bet Atak_Snajpera was laughing his head off at my Totally Newbie Q. Anyway, my gooogling must stink ... because after I ran VirusTotal, I googled the items noted and came back with scare comments (to me anyway) on prcview ... but same result as you did on madCode. So, since I trust Doom9 and everything that Doom9 Regulars offer ... I wanted to verify that VirusTotal results might be Wrong (btw, the major companies ... did NOT report any of the anomolies ... it was the AV companies that I had never heard of) ... anyway, I tried MetaScan but it refused to Scan since it claimed that the 7z file expands to 100MB and their limit is 40 or 60MB I believe ... so then I tried Jotti's ... but it has only 20 Scanners which are almnost similar to VT ... That is when I decided to post my Q to Atak_Snajpera and you folks ... I am Glad at least you reposnded ... helped me and may be will reassure somebody else if have the similar Q. Thanks again! G! |
3rd July 2013, 02:01 | #12534 | Link |
I have 1.17.4, with 40 or 50 rips done since the last install. I am trying to rip The Prophecy, The Prophecy II and The Prophecy III. On all three I get error messages:
First I get a pop-up window title "Haali Media Splitter" with the error: "Error: Can't open file. The system cannot find the file specified." Hit OK and that pops up a couple more time. Then I get a Demuxing Error pop-up: eac3to v3.27 command line: "C:\Program Files\RipBot\Tools\eac3to\eac3to.exe" "E:\BDRips\The.Prophecy\" 1) 2: "e:\Temp\RipBot264temp\job7\video.mkv" -seekToIFrames 4: "e:\Temp\RipBot264temp\job7\audio_English.dtsma.w64" -down16 5: "e:\Temp\RipBot264temp\job7\5_subtitles_Spanish_1080.sup" 1: "e:\Temp\RipBot264temp\job7\chapters.txt" -progressnumbers -log="e:\Temp\RipBot264temp\job7\demuxlog.txt" ------------------------------------------------------------------------------ M2TS, 1 video track, 2 audio tracks, 1 subtitle track, 1:37:58, 29.131p 1: Chapters, 15 chapters 2: h264/AVC, 1080p24 (16:9) 3: DTS Master Audio, Spanish, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 16 bits, 1509kbps, 48kHz) 4: DTS Master Audio, English, 5.1 channels, 16 bits, 48kHz (core: DTS, 5.1 channels, 16 bits, 1509kbps, 48kHz) 5: Subtitle (PGS), Spanish [v02] The video framerate is correct, but rather unusual. <WARNING> Creating file "e:\Temp\RipBot264temp\job7\chapters.txt"... [s05] Extracting subtitle track number 5... [v02] Extracting video track number 2... [a04] Extracting audio track number 4... [v02] Muxing video to Matroska... [a04] Decoding with ArcSoft DTS Decoder... [a04] Writing W64... [a04] Creating file "e:\Temp\RipBot264temp\job7\audio_English.dtsma.w64"... [a04] The ArcSoft DTS Decoder reported an error while decoding. <ERROR> Aborted at file position 14491648. <ERROR> Any help would be appreciated. Let me know if there's other info that's needed. |
3rd July 2013, 10:08 | #12535 | Link |
decrypt your movies again with latest anydvd hd. those errors could be caused by bad rip.
6th July 2013, 16:05 | #12537 | Link |
@Atak_Snajpera: I am trying to DE a video with 60fps but it's divided into 4 chunks only, is there anyway to increase the chunk amount?
Inside the meta file: Code:
"E:\Cut\RipBot264\tools\avs2yuv\avs2yuv.exe" "E:\Temp\RipBot264temp\job1\job1.avs" -o - | "E:\Cut\RipBot264\tools\x264\x264_x64_10bit.exe" --pass 1 --bitrate 1424 --stats "E:\Temp\RipBot264temp\job1\job1.stats" --fps 60000/1001 --force-cfr --min-keyint 60 --keyint 600 --frames 155112 --sar 1:1 --profile high10 --level 4.0 --preset ultrafast --tune film --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --b-pyramid none --stdin y4m --output NUL - "E:\Cut\RipBot264\tools\avs2yuv\avs2yuv.exe" "E:\Temp\RipBot264temp\job1\job1.avs" -o - | "E:\Cut\RipBot264\tools\x264\x264_x64_10bit.exe" --pass 2 --bitrate 1424 --stats "E:\Temp\RipBot264temp\job1\job1.stats" --fps 60000/1001 --force-cfr --min-keyint 60 --keyint 600 --frames 155112 --sar 1:1 --profile high10 --level 4.0 --preset ultrafast --tune film --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --b-pyramid none --stdin y4m --output "E:\Temp\RipBot264temp\video.264" - |
6th July 2013, 16:25 | #12538 | Link |
use CQ mode instead of 2-pass
6th July 2013, 19:00 | #12539 | Link |
Thanks, got it to split the video into more chunks. May I sugguest a feature on the next version? That is the ability to change the server amount. I have access to a computer lab and 8 is a little small.
Seem like you are defining static server allocations on the Encoding Client UI, you can reuse that by reading server list from the EncodingClient.ini, grouping the servers by group of 8 (only show 8 at a time), server1 - server8 will be in page 1, server9 - server17 will be in page 2, etc. And there will be nav button "Previous Page", "Next Page", and also a ComboBox for quick nav. When user selects Server 9 for example from the list and press "Go to Server", the UI will change to page 2. Below is how it would look like: Well, this is only my suggestion and how I imagine it. Heck, you might think of an even better way to implement it. Also, how about DE over NAT/VPN, there is netAvs2Yuv by sh0dan to get the source from network, and it is possible to share folder over VPN (NetBIOS over TCP is possible too). Finally, I want to thank you for making such an amazing program. Last edited by Hero1711; 8th July 2013 at 04:17. |
7th July 2013, 12:01 | #12540 | Link |
DVD Chapters?
Been using RipBot264 latest, to rip my blu-rays with no problems.
Just tried to rip my first dvd,and it looks good but no chapters. I look on the settings everywhere but the word chapter is'nt there. How do i encode a dvd and keep the chapters,or can't it be done. |
