11th May 2015, 17:09 | #13522 | Link |
Reinstall Haali Media Splitter
11th May 2015, 17:12 | #13523 | Link | |
Silent Reader
and reinstall all corresponding (needed) tools too. e.g. Matroska splitter, ffmpeg tryouts, avisynth When there is a new release, why should Atak support old files. Personally I think, there is no problem with Ripbot. Maybe other programms you installed changed default behavior of splitter and filters. |
11th May 2015, 17:37 | #13524 | Link |
@jonah
This encoding client stores encoding summary in ...\jobx\Chunks\DE_Log.txt file. http://www.mediafire.com/view/xy66s7...dingClient.exe example Code:
Node Address : 192.168.1.100:1000 Encoded Chunks : 1 of 3 (33%) Encoded Frames : 1767 Encoding Speed : 270 fps Node Work Time : 00:00:07 ----------------------------------- Node Address : 192.168.1.100:2000 Encoded Chunks : 1 of 3 (33%) Encoded Frames : 1735 Encoding Speed : 273 fps Node Work Time : 00:00:06 ----------------------------------- Node Address : 192.168.1.100:3000 Encoded Chunks : 1 of 3 (33%) Encoded Frames : 3284 Encoding Speed : 330 fps Node Work Time : 00:00:10 -----------------------------------
13th May 2015, 17:36 | #13526 | Link |
Hello Atak
I have new NTSC DVDs that I was trying to upscale to 720p. And every time I run them though Ripbot264 the end result has audio that is severely out of sync. So what I tried is upscalling to 720p, minor noise remomal. I tried just basic deinterlace (TFF). and I tried Inverse Telecine. Every time result has out of sync audio. here is example of one file. Code:
General Unique ID : 56907979353378572519509386968734165968 (0x2AD01401B64ABD4884E1FAB1F7D8EBD0) Complete name : K:\Movies\movie.mkv Format : Matroska Format version : Version 2 File size : 3.74 GiB Duration : 1h 24mn Overall bit rate mode : Variable Overall bit rate : 6 360 Kbps Encoded date : UTC 2014-08-28 03:28:13 Writing application : MakeMKV v1.8.12 win(x64-release) Writing library : libmakemkv v1.8.12 (1.3.0/1.4.1) win(x64-release) Video ID : 1 Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : No Format settings, Matrix : Custom Codec ID : V_MPEG2 Codec ID/Info : MPEG 1 or 2 Video Bit rate mode : Variable Bit rate : 6 042 Kbps Maximum bit rate : 9 800 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Original frame rate : 29.970 fps Standard : Component Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Scan order : Top Field First Compression mode : Lossy Time code of first frame : 01:00:00;00 Time code source : Group of pictures header Language : English Default : No Forced : No Color primaries : BT.601 NTSC Transfer characteristics : BT.601 Matrix coefficients : BT.601 Audio ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : A_AC3 Duration : 1h 24mn Bit rate mode : Constant Bit rate : 192 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : 14ms Stream size : 116 MiB (3%) Title : Stereo Language : English Default : Yes Forced : No Text ID : 3 Format : VobSub Codec ID : S_VOBSUB Codec ID/Info : The same subtitle format used on DVDs Language : English Default : Yes Forced : No Menu 00:00:00.000 : en:Chapter 01 00:08:05.485 : en:Chapter 02 00:16:32.324 : en:Chapter 03 00:19:56.862 : en:Chapter 04 00:23:01.380 : en:Chapter 05 00:31:19.711 : en:Chapter 06 00:37:38.089 : en:Chapter 07 00:42:17.535 : en:Chapter 08 00:45:24.388 : en:Chapter 09 00:49:28.298 : en:Chapter 10 00:55:03.166 : en:Chapter 11 01:00:03.600 : en:Chapter 12 01:07:00.850 : en:Chapter 13 01:10:42.905 : en:Chapter 14 01:18:22.531 : en:Chapter 15 |
13th May 2015, 19:47 | #13527 | Link |
I need 100 mb sample.
15th May 2015, 18:25 | #13528 | Link | |
Ex Code:
video=DirectShowSource("S:\Video\KB\title00.mkv",audio=false,fps=29.97,ConvertFPS=true).ConvertToYV12() |
18th May 2015, 03:46 | #13529 | Link |
Distributed Encoding Control
@Atak_Snajpera
I have been a bit fan and user of ripbot264 for a long time now. Due to the higher demands of HEVC/x265 I have been playing around with Distributed Encoding for the first time and I can say that I am very impressed. One little niggly trouble is that currently I am using 3 computers they are pretty equally spec'ed. Sometimes I just use 3 distributed servers (one on each) and sometimes I use 6 distributed servers (two on each) to max out CPU. But they way the frames are broken up are always in weird groups such as 7, 10 or 11 etc. So I have all three working through quite nicely for the first few frame batches. But near the end, one server can be left with one part to finish by itself, or if am running 2 per computer it can even be left with 2 to finish by itself. Any chance of a future enhancement where there can be a bit more interaction or control of how the frames are broken up. Either something really manual like specifying the frames per batch job. Or something a bit more automatic like specifying the number of total jobs to create or a group multiplier/divisor. Other than that, keep up the great work!!!! |
18th May 2015, 07:00 | #13530 | Link |
Are you using 2-pass mode or CQ?
18th May 2015, 12:28 | #13532 | Link |
In 2-pass mode chunks are longer than in CQ (10min vs 1min) due to how 2-pass mode works. 1 min chunk in 2-pass mode would flatten to much bitrate distribution in video file. Basically you would be wasting bitrate on scenes where it is not necessary. Graph would look like ABR encode a not true VBR. 10 min chunk is just a trade of between quality and encoding efficiency.
18th May 2015, 13:01 | #13533 | Link | |
Thanks for that Atak_Snajpera |
19th May 2015, 09:43 | #13535 | Link |
Yes. It was very easy. I basically forgot to add two short lines of code. My formula was calculating audio using bitrate and audio file size at the same time hence larger file size or smaller video bitrate.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 19th May 2015 at 09:47. |
22nd May 2015, 15:35 | #13537 | Link |
Registered Loser
Trying to encode some UK Doctor Who blu-ray's which are (largely) 25fps VC1/h264 encodes. I want to to use TFF 25->50FPS (Yadif) as a de-interlacing method using CQ 1-pass. Basically RipBot264 is splitting up the chunks wrong in this case - the first 1/2 chunks are fine, the last 1/2 of the chunks are -1 frames and the last chunk is extremely long. The file is corrupt when it is done and the joinchunks fails. See screenshot.
It's certainly something with de-interlacing, because if I turn off de-interlacing (bob), everything is fine. Other things I've tried (just for pure troubleshooting): 1) Tried BFF --> 50FPS - same problem 2) Tried TFF --> 25FPS - it works (but I don't really want to do this...) |
22nd May 2015, 16:19 | #13538 | Link |
Will you be able to send me 10 min sample (original untouched source video file)? I would like to have that file for easier investigation. Use https://mega.co.nz/.
I suppose that encoding client does not work on updated number of frames hence first half is ok but rest is totally wrong.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 22nd May 2015 at 16:26. |
23rd May 2015, 04:10 | #13540 | Link |
I've been investigating the best way to put MakeMKV DVD rips through Ripbot with varied success (for science, I still prefer AnyDVD). If you don't know, MakeMKV just takes the DVD movie and puts it in a mkv container with no real encoding. I wish to share my findings. For this test I chose Crank, as it's got some weird cell protection juju that screws up subtitle timing, even after it's been ripped with AnyDVD. MakeMKV repairs the subtitle timing when it rips.
Problem: Loading as is, the mkv is loaded via DirectShowSource. This results in bad A/V sync. Fix 1: most tests, adding the FPS and ConvertFPS into the DirectShowSource arguements solve this. ex video=DirectShowSource("S:\CrankMakeMKV.mkv",audio=false,fps=29.97,ConvertFPS=true).ConvertToYV12(). This plays the video back at 29.97 without any visible interlacing. Fix 2: MKVExtract or eac3to pre-extract everything. Ripbot reads as m2v, indexes, etc. Sometimes though (and with my samples) it is a FILM type, and I run dgindex manually with Force Film to eliminate interlacing. Original Sample: https://mega.co.nz/#!soNAiCoB!bvQ0OW...geKmN5E4pGt0Hk Sample w/ convertfps added: https://mega.co.nz/#!xosn1I5Z!6KPElN...sEQrYM9ZsiVZKc Sample w/ manual extract: https://mega.co.nz/#!hg9TBZrZ!FFNM2b...k6tiwVvvaF70M8 Sample w/ manual extract and ForceFilm DGindex: https://mega.co.nz/#!o5cX1bDC!4R1uyw...NLBum2aLxpmr6U Personal opinion: I presume Fix 2 would be the more legit way, as the mpeg2 indexer is involved. I figure a slight check during MKVInfo to check if it's mpeg2, extract it with the rest of the tracks, and then load it with indexing. Last edited by Tsusai; 23rd May 2015 at 04:12. Reason: wrong url linked. |
