3rd December 2016, 18:35 | #14621 | Link | |
[QUOTE=ConvertToYV12: invalid "matrix" parameter (RGB data only)
(C:\Temp\RipBot264temp\job1\getinfo.avs, line 2)[/QUOTE] Hi I'm new to this forum. I wish I'd found it sooner. I hadn't used Ripbot264 for about a month. I was on 1.19.4 and it updated to 1.19.5 and I started getting the error. I reverted back to 1.19.4 and then checked each update file until I discovered that is was the Ripbot264.exe (1.19.5) that was causing the problem. I just kept the 1.19.4 version of the file and the program is running fine again. After reading this thread it appears all I needed to do was re-install the codepack. Strangely the core.zip downloads each time I run the program but the Update log says it's corrupt. Quote:
[QUOTE=v1.17.4 Added: Demuxing DTS-MA and TrueHD (for those who really need them in mkv container for some reason)[/QUOTE] |
3rd December 2016, 20:58 | #14622 | Link |
Regarding "invalid matrix parameter (RGB data only)" make sure you have AviSynth 2.6 installed. I suppose you are still on pretty old 2.5.8 version.
CRC32 error was most likely caused by incomplete download (lost connection/aborted). Do not worry about that. Regarding audio topic I will have to check.
5th December 2016, 15:50 | #14623 | Link |
Hello all. I just noticed something when using Distributed encoding. While encoding in the "Ripbot264 Encoding Client" Window, I can not seem to scroll down the chucks section. Encoding works fine but the scrolling either manually(mouse clicking on scroll-bar, or arrows) or using the mouse wheel will not work. All other dialog windows on the PC work fine. I've encoding 5 movies so far with the same issue.
Is anyone else experiencing this issue?? |
5th December 2016, 16:17 | #14624 | Link |
Silent Reader
I did a fresh install of Win10Pro x64 (14393.447),
installed Avisynth 2.60 ffdshow tryouts rev 4533 Haali Media Splitter (MatroskaSplitter) Java (newest 32bit release 8u111) And Ripbot264 (download-link in #1 Post). Updated Ripbot with Autoupdate. After creating a job all wen't fine. Whole movie was encoded (was native 16:9 without cropping). Then I added a movie 2.40:1 and enabled autocrop and resize (1920x800). Preview didn't work. Encoding failed. After I removed ".Sharpen()" behind resize-function, preview and encode worked. I am curious. Isn't "Sharpen()" a buildin-function of avisynth. Function doesn't seem to exists in my Avisynth. (downloaded from Avisynth.org/Avisynth.nl) Last edited by Wishbringer; 5th December 2016 at 16:20. |
5th December 2016, 16:30 | #14625 | Link |
ByteShare
#Deinterlace Loadplugin("C:\RipBot264v1.19.5\Tools\AviSynth plugins\Repair\RepairSSE2.dll") Loadplugin("C:\RipBot264v1.19.5\Tools\AviSynth plugins\RemoveGrain\RemoveGrainSSE2.dll") Loadplugin("C:\RipBot264v1.19.5\Tools\AviSynth plugins\nnedi3\nnedi3.dll") Loadplugin("C:\RipBot264v1.19.5\Tools\AviSynth plugins\masktools\masktools2.dll") Loadplugin("C:\RipBot264v1.19.5\Tools\AviSynth plugins\mvtools\mvtools2.dll") LoadCplugin("C:\RipBot264v1.19.5\Tools\AviSynth plugins\Yadif\Yadif.dll") Import("C:\RipBot264v1.19.5\Tools\AviSynth plugins\Scripts\QTGMC.avs") video=QTGMC(video,Preset="Medium",FPSDivisor=2) |
5th December 2016, 16:32 | #14626 | Link | |
ByteShare
5th December 2016, 16:34 | #14627 | Link |
Silent Reader
Hm, found another odd behavior:
I am encoding with DE. Have 8 Server (E3-1240v5 with 64GB Ram each) When a Encoding server crashes and I close Encoding Server and restart App, I can't enable that Server in central Encoding Client again. It is still disabled till end of whole encode. In next batch it starts as normal enabled. Seems the "On"-Button in Encoding Client doesn't work. Encoding-Client chunks window: I can scroll with middle mouse wheel, but bar and arrows doesn't work. Like mentioned by byteshare and Viper714. Last edited by Wishbringer; 5th December 2016 at 16:38. Reason: Chunks window bug in encoding client added |
5th December 2016, 17:18 | #14628 | Link |
Okay I am not the only one either. Yes, I noticed the same as Wishbriner. None of the ON or OFF buttons work on the Encoding client window. Byteshare, I just tried keeping the window in focus and it does work, but as you said the minute I click outside that window, it looses focus and I can't click on anything else.
Apparently it is loosing focus and can't get it back... |
5th December 2016, 17:33 | #14629 | Link |
What windows version do you use?
I've just checked on my Win7 x64 and scroll bars work during encoding as well as all buttons ON/OFF/Abort.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 5th December 2016 at 18:12. |
5th December 2016, 18:11 | #14631 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 5th December 2016 at 18:14. |
5th December 2016, 20:25 | #14632 | Link | |
E5 2697 v2 @ 3.0GHz on P9X79 Deluxe 24GB Xeon E5-2680 v2 @ 3.1GHz 16GB Sony Vaio VPC-F13Z1E/B |
5th December 2016, 21:34 | #14634 | Link |
[QUOTE=Atak_Snajpera;1788553]Ask almighty M$ programmers. Welcome to Windows 10 Beta Service
Okay, so here is the latest. When the encoding client windows first opens everything works (mouse wheel scroll, scroll-bar [dragging or click outside of scroll bar] ,scroll-bar arrows, ON & OFF buttons). When I click on the Ripbot main window and go back to the encoding window only the mouse wheel scroll works. Nothing else works. Not even the abort button as byteshare & Wishbringer mentioned. Love the picture btw!!! |
5th December 2016, 21:47 | #14635 | Link | |
7th December 2016, 00:33 | #14637 | Link | |
7th December 2016, 20:15 | #14638 | Link |
Ok. I did some testing on Virtual Machine.
Windows 7 with updates -> no lock in encoding client after losing focus Windows 8.1 without updates -> no lock in encoding client after losing focus Windows 8.1 with installed updates -> LOCK ! Windows 10 14393 with installed updates -> LOCK ! Clearly M$ had to push some weird update to 8.1 and 10 somewhere in time.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 8th December 2016 at 14:35. |
8th December 2016, 17:06 | #14639 | Link | |
ByteShare
Any plans to give more queue management? Right now I've been using a turbo mouse to move items around faster. |
24th December 2016, 22:45 | #14640 | Link |
Thank you for creating this software.
I am using 10 machines connected over internet via OpenVPN and after some problems, I am happy with the speed. Quick tip for those who might want to try connecting computers over internet via VPN: On all clients connecting via VPN, edit C:\Windows\System32\Drivers\Etc\hosts file and add at the end: Main_PC_IP Main_PC_NetBiosName example: 192.168.100.15 RipBot264PC If a client connected over VPN cannot resolve the computer name, it will flick from Idle to Encoding because the client is set to work with computer name instead of IP. Of course, 1 Gbps will help a lot. I do not recommend using anything lower with so many computers. |
