Old 25th February 2019, 17:00   #16761  |  Link
Ryushin
Ryushin's Avatar
That intermediate step would only kill any time savings in DE mode... In that case I would just use regular mode on the fastest machine in the house.
The lossless conversion really did not take very long. Takes a lot longer to suck in a 4K then for it to do a lossless conversion. The advantage is that DE is still running why the VC-1 source is being demuxed and converted to lossless.
I suppose I can use that one fast machine in the house to do the VC-1s or I can just convert it to lossless myself for those sources. Once I convert video.mkv, can I delete the video.mkv.ffindex* files and will the index be built automatically when the job starts?
Old 25th February 2019, 17:07   #16762  |  Link
If you remove video.mkv.ffindex then Encodingclient will automatically reindex video.mkv.
I've updated my post
https://forum.doom9.org/showthread.p...70#post1866770
Old 25th February 2019, 17:22   #16763  |  Link
katodevin
Originally Posted by pepeq View Post
I see the same problem in my DE-environment, too.
Atak_Snajpera- just hoping you saw that some of us were having issues with distributed encoding on the latest release. Has to do with the files within the script being referenced in a local manner rather than in the shared format.
See post #16742 for details.
katodevin is offline   Reply With Quote
Old 25th February 2019, 17:23   #16764  |  Link
Ryushin
Ryushin's Avatar
I'll try that new version of ffms. I assume I can just delete the ffindex files. I'll try that one job, and if it works, I'll nuke the ffindex files for the 60 or so jobs I have in the cue.
Old 25th February 2019, 17:34   #16765  |  Link
For testing purposes use some low resolution (720p) to speed up whole process. I just need to know that everything is correctly encoded at stitches.
Old 25th February 2019, 18:24   #16766  |  Link
Ryushin
Ryushin's Avatar
I probably won't be able to get back with you about this for a few hours. Have to take care of something else right now.
Old 25th February 2019, 18:32   #16767  |  Link
No problem. My current testing shows that latest version of ffms2 is NOT frame accurate for AVC! (new chunk does not start from correct frame) VC1 seems to be ok despite detecting all frames as I-frame.
Old 25th February 2019, 19:49   #16768  |  Link
Latest ffms2 also is not frame accurate for HEVC! (some frames are missing at joining point).
Old 25th February 2019, 21:38   #16769  |  Link
Ryushin
Ryushin's Avatar
The VC-1 source I used tested out great. Too bad it's broken for everything else.
VC-1 is just a pain. Back to making h.264 lossless before the conversion for me.
Old 26th February 2019, 13:38   #16770  |  Link
Do not worry. I will be using different version for different codecs.
ffms2 2014 -> AVC
ffms2 2017 -> HEVC
ffms2 2019 -> VC1 and rest
Old 26th February 2019, 14:42   #16771  |  Link
Ryushin
Ryushin's Avatar
ffms2 2014 -> AVC
ffms2 2017 -> HEVC
Let me know when this is implemented and I will start adding the vc1 jobs.
Old 26th February 2019, 17:15   #16772  |  Link
byteshare
ByteShare
byteshare's Avatar
Originally Posted by defalopii View Post
so x265 will die soon also? today is streaming age, encoding x265 with powerful DE in this app is a little less benefit if it cant be streamed online
x265 is already used to stream. Netflix uses it if your device supports it.
Most likely h.266/VVC or AV1. VP9 will die soon.
Is H.266 supposed to come out soon?! It seems 264 still hasn't completely been replaced by 265 yet.
Old 26th February 2019, 17:25   #16773  |  Link
pepeq
The workaround described in post #16742 works, but remember to create a network connection to your movie-source, which is valid from an elevated shell also.
If you create a network connection (or do a 'net use') with your ordinary user-rights, the workaround does not work.
Reason: RipBot264 runs in Administrator-mode and therefore the movie-source has to be accessable with elevated (Administrator-) rights.
Hope that helps.
pepeq is offline   Reply With Quote
Old 26th February 2019, 17:36   #16774  |  Link
Now !
Old 26th February 2019, 21:25   #16775  |  Link
slalom
slalom's Avatar
A problem with version 1.24.1
Although starting and stopping on DE was fixed, if you abort a job and try to restart it, the problem re-appears
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
Old 26th February 2019, 22:03   #16776  |  Link
slalom
slalom's Avatar
I restarted all PCs
Only one server working in DE (the one with the jobs). All the others are starting and stopping
Old 26th February 2019, 22:45   #16777  |  Link
Ryushin
Ryushin's Avatar
Now !
Thank you Atak. You are the greatest.
Old 27th February 2019, 03:36   #16778  |  Link
Ryushin
Ryushin's Avatar
Afraid I'm in the same boat now. None of my DE jobs are running now. Restored from backup, turned off auto updates, and everything is working again.
Old 27th February 2019, 09:07   #16779  |  Link
pepeq
see post #16773, this may help until Atak has fixed it.
Old 27th February 2019, 12:09   #16780  |  Link
Use latest version only if you have no old jobs in queue. Old jobs may not start due to incompatibility with ffms2.dll and old .index file.
You may try to manually fix this by editing each jobx.avs file.
If your source video is not AVC or VC1 then change ffms_latest to 2017 in line below #VideoSource
#VideoSource
LoadPlugin("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\ffms\ffms_latest\x64\ffms2.dll")
#VideoSource
LoadPlugin("C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\AviSynth plugins\ffms\2017\x64\ffms2.dll")
notepad++ should be able to do that in batch.
