Old 13th October 2019, 19:04   #17521  |  Link
mparade
May I ask where? In batch window I have found this option but nowhere else, please help.
Thank you in advance.
Edit: just found it...sorry for the question
Old 13th October 2019, 19:08   #17522  |  Link
mparade
Sometimes I have problems with dtsma sources.
Sometimes they recognized with faulty channel numbers, sometimes they are demuxed and after being chosen from the list relevant parameters and even profiles are not loaded at all. So I have to ignore them as a source stream. Is there a solution for this yet?
Old 13th October 2019, 21:42   #17523  |  Link
SKPN
Originally Posted by Pauly Dunne View Post
Well, as I said, I'd like to have my 4K's at a "standard" of 60Mps, and again, as I've said, some have lower than that, some are higher, so for that I need to run them thru RB, even if it's video only.
This part makes no sense. You shouldn't be aiming for a specific bit rate unless you have a limited amount of space, and even then, should only mean lowering the bit rate. Encoding at a higher bit rate than the source video won't increase the quality, so there is no point in doing so; all you're doing is wasting space.
One thing I would like to get around to doing is upscaling some 1080p to 4K, but do any filtering, etc, still @ 1080p, then once satisfied, do a 4K HEVC encode, and see how it turns out.
This is not a good idea. The more you encode a video, the worse the quality will be. So if you take the 1080p source, apply filters and encode it, then take the encoded video and encode it again at 4K, it will look worse than doing both the upscale and filters in a single encode. Every time you re-encode a video, you're losing data.
SKPN is offline   Reply With Quote
Old 16th October 2019, 01:27   #17524  |  Link
Pauly Dunne
Grumpy Old Man.
Pauly Dunne's Avatar
I noticed another small auto update today (just core.exe). A change to the command script, cmd features/control.
A lot of time seems to be getting spent on this script for when a job is completed...I for one don't really get the idea behind this, I think someone requested a feature for deleting completed jobs.....
If that's basically what it's for, I would prefer to do it manually !!
And what of my simple feature request, on RB gui's main window, the current core version/build is displayed (for quick reference)
Live every day like it's your last, because one day, it will be !! (M$B)
Old 16th October 2019, 04:58   #17525  |  Link
Pauly Dunne
Grumpy Old Man.
I will dig out a "crappy ssd", and try a "big ass 80Gb" encode, with the latest build of RB, and see just how long it does take....
If it still takes long time then I will rethink your request. Just give me some hard numbers.
Just a little update on my "big ass" encode....
I was only about an hour from it starting the muxing process, and the SSD I was using for the Temp files, ran out of space.
It was "only" 120Gb, and with the ONE movie to process, filled it up
So will have to re-think the setup, and start all over again
Regardless of that problem, I noticed that earlier on during the chunks being processed, that randomly a chunk would just "reset", and start again from 0%, so all it had processed up to that point, was lost.
So I turned off the re connect option, and it seemed to be OK, so something in the workings of that, seems to create a problem, unless there's a brief hiccup in the network connection.
Old 16th October 2019, 05:07   #17526  |  Link
Pauly Dunne
Grumpy Old Man.
Remote Server shut down option from main client..
Would it be too much to ask if you could implement an option where you could send a shut down/kill command thru to an individual server's IP address, when ever you wanted or needed to ??
Preferably within the Encoding Client window/screen.
Very handy when the servers are elsewhere !!
Separate to the shut down options at the end of an encode.
Old 16th October 2019, 19:37   #17527  |  Link
byteshare
ByteShare
byteshare's Avatar
For what I want & need to do to audio, can be dealt with other app's, as too, the subtitles.
I have to agree, I don't like grain either, but fortunately most 4K's aren't very "noisy", so not a lot of filtering required.
I know I need to try a few different options, but it's the time factor that's my main concern...imagine doing a high bitrate 4K HEVC, on a Slow preset, using MDGrain2....day's even with my "farm".
But the other time waster is between when the encode is completed, and the start of the next job in queue...meaning the muxing, etc...it leaves a lot of resources doing nothing. , but having said that, I am yet to test this again, after putting some SSD's in the mix.
But just imagine the time & resources involved when 8K is a lot more common place.
You'd want to look at some of the advanced x265/HEVC commands to preserve detail but you should still be able to reduce size while it being near same quality.
Personally I go for looks 95% precieved quality, so I don't have any good settings for you to start with.
That said, if you are using filters like MDGrain2, IMO you shouldn't worry about the bitrate because you're going to be chopping out a lot with that so you should just use CRF12 or so from what it I'm guessing you like. If you are using constant bitrate with MDegrain2 and it is set higher/same as source you're wasting bits.
If you're going to use constant bitrate without filters I'd set it a little lower than source at least and do 2pass and you'll likely get something 99.9999% the same if you can even see a difference (depending on your settings). Some HEVC settings do bluring, slight denoise/dehalo type stuff so if it isn't looking close to the source your settings are the issue.
From the sounds of it you need a bigger SSD, guessing at least 500GB or more.
As for upscaling the way you want to do it isn't a problem since you'd do the filters either before or after the upscale and upscale all in one job, then encode.
I just got a chance to use the new update and it is great for me. Really reduced my manual tasks.
You can do a lot with it besides deleting source files.
Also, made sure when a lot of jobs fail my drives won't fill up.
Is it possible to have jobs deleted automatically after they are completed successfully? (Not in batch mode)
Settings > [uncheck] Keep jobs after successful conversion
Old 16th October 2019, 19:41   #17528  |  Link
Dhry
Dhry's Avatar
Okay, so today Ripbot updated core (2019.10.15), tried an encode of an MP4 file via adding to batch, but all it does is show "Waiting for file..." in the main window and nothing happens after that. Usually this is the point at which it demuxes etc. I tried it on multiple mp4s, always the same. Looking at the temp folder, the job1 folder is created but no work files are added to it.
Dhry is offline   Reply With Quote
Old 16th October 2019, 20:01   #17529  |  Link
Waiting for file... means in practice waiting for file to be accessible. Are you sure nothing is blocking your files? I've just tested on my machine and everything works fine. Besides I didn't touch anything in code regarding this issue.
Old 16th October 2019, 22:00   #17530  |  Link
Dhry
Dhry's Avatar
Definitely not. I thought the same thing as well, and used Unlocker on each file to make certain that something had not blocked access to them. They were not opened for reading or writing by anything. I'll reboot my machine in a little while and will try again. Cheers!
Old 16th October 2019, 22:53   #17531  |  Link
byteshare
ByteShare
byteshare's Avatar
Did you make the job after the update, or before?
If before try deleting the job and remaking it.
After the reboot, if you're still having issues try posting the media info.
Old 17th October 2019, 06:53   #17532  |  Link
Dhry
Dhry's Avatar
Job was made after the update, with the shared job folder completely and absolutely empty. Deleted job and remade it, same issue. Deleted job, deleted job1 folder in temp folder, created again, same. Ripbot has worked in this configuration through multiple updates, but this last update is broken somehow. I started a batch encode and added a single file, this time from a completely different folder, absolutely nothing locking the file. Even if I click Abort Job Creation, it tells me "please wait.. aborting" and that never ends. I'm using a test mp4 file from one of my video cameras. Media info is as follows, hope this is the format you're asking for:
General
Complete name : K:\test.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 28.7 MiB
Duration : 39 s 0 ms
Overall bit rate mode : Variable
Overall bit rate : 6 166 kb/s
Encoded date : UTC 2018-08-04 00:02:07
Tagged date : UTC 2018-08-04 00:02:07
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 1 frame
Format settings, GOP : M=1, N=30
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 6 162 kb/s
Maximum bit rate : 30.7 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 30.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.099
Stream size : 28.6 MiB (100%)
Color range : Full
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Codec configuration box : avcC
Screenshot of my batch settings attached.
EDIT: I added this file as normal (ie not through the Batch mode) and it worked. Normal add probes, demuxes, indexes etc as normal. Distributed encoding works great. Problem seems to be within the batch functionality.
Old 17th October 2019, 12:57   #17533  |  Link
Pauly Dunne
Grumpy Old Man.
OK, here we go, this is what I observed, when encoding my "big ass" 4K, 60Mb/s bitrate encode.
Now I know a lot here cannot understand why I'm doing this the way I'm doing, (but that's my choice) so with that aside, what I have documented could impact nearly anyone that is doing 4K HEVC encodes, using Distributed Encoding.
So first things, I had an approx 65Gb, @ approx 65Mb/s bitrate movie (John Wick 3).
I queued it up, the initial demuxing & indexing of the file, took 27 minutes, using Lsmash.
Then the next day, when I started the job, it took a further 15 minutes, before it started encoding, and initiating the DE Servers, and I am ONLY doing the video.
So over the next 3 days (3 different encoding session's), probably turned out to be around 12 - 14 hour's using varying different server's in the "encoding farm".
Just a foot note, I have a lot of Solar Panels on the roof, and I won't do any long term processing jobs unless I can get it for "free", so that can change from day to day.
So, finally, late today, the chunks were all done.
So I got the phone out, and started the stop watch, and the combining of the chunks took 10 minutes 30, then the muxing process took a further 15 minutes 30, using SSD's for the Temp folder & where the encode is compiled.
I would suggest that this time would be shorter if the bitrate wasn't as high as I had it (1 Pass @ 60,000kb/s), ended up being 59.6Mb/s (Mediainfo).
I am yet to mux back in the audio (which I have changed from TrueHD to DTS-MA), and a subtitle track (.srt)
So, getting back to a question raised a week or so ago, to have RB to start the next job in the queue, whilst it is combining the chunks, and the final muxing. (Is muxing a single threaded process ?)
So observations of "my" process, there is approx 45 minutes where NONE of the DE Server's are being used, when starting a new 4K job, from scratch....then of course the DE Server's are going flat out 'til all the chunks have been completed.
Then, hopefully the Client PC is the one left doing the final combining & muxing, which leaves ALL the DE Servers doing nothing for a further 25 or so minutes. So they could be turned off until the next job has actually start encoding, for just over an hour. (Between jobs)
So as great as DE is, there can be a LOT of time that the servers aren't doing anything..so if there was a way to have RB to at least start the next job, once the chunks of the previous job were completed, that could save a reasonable amount of time, and power.
OR,
if there was someway for RB to start the DE servers once the job is about to start encoding, (when the chunks are being created) and maybe shutdown the DE servers once the chunks are done, instead of once the full encode was completed.
OR,
some option to manually turn the remote DE servers on & off from the Client pc.
Old 17th October 2019, 13:25   #17534  |  Link
~100 MiB/s copy speed on SSD<->SSD? Are you using TLC SSD? I'm asking because direct write to TLC NAND is around that level. QLC is even worse (~75MiB/s)
Old 17th October 2019, 14:00   #17535  |  Link
Pauly Dunne
Grumpy Old Man.
WD Greens in Raid 0 for Temp, some Chinese SSD for the Encodes.
That's all I had, spare.
Old 17th October 2019, 14:18   #17536  |  Link
Ryushin
Ryushin's Avatar
Use MakeMKV?
Why not just use MakeMKV. Make a MKV with just the video and the audio you want. Then extract the subtitles out, OCR and convert them to SRT/ASS/etc, mux them back in, and your done. Your video quality will be exactly the same as the source. Most smaller than 60Mb/s and some a bit larger. Your finished file will done quicker than ever having to encode. From what I understand, unless you need to degrain, there is no need to re-encode the source.
When I encode, I use CRF18 for x265 and I cannot tell the difference between the original source and my output. Some 4K sources that have a huge amount of grain such as Blade Runner, come out looking far better than the original when using MDegrain2/3.
Old 17th October 2019, 15:49   #17537  |  Link
Could you test your SSD/HDD in my benchmark tool?
http://www.mediafire.com/file/i630b6...Tester.7z/file
Results on my 5 years old 120GB SSD (MLC)
It is a command line tool. Use these switches
IOSpeedTester.exe --test-location "X:\" --transfer-size 120GIB --log-file "C:\users\%username%\Desktop\MyLog.csv"
Where X is a drive letter of your drive.
Upload MyLog.csv somewhere.
full help
IOSpeedTester v1.0 by Atak_Snajpera
Syntax: IOSpeedTester [options]
Options:
    --help                       Show this help text and exit
    --test-location <string>     Folder where test files will be stored
    --threads <1..64>            Number of working threads. [1]
    --buffer-size <1KiB..64MiB>  Write/Read buffer size. [16MiB]
    --transfer-size <integer>    Amount of bytes to transfer. [1GiB]
    --buffered-io                Enables IO buffering in RAM. [Unbuffered]
    --log-file <string>          Log information to specific file. [None]
    --write-only                 Performs write test only. [Write+Read]
Example usage:
    Sequential Test with logging to a file
        IOSpeedTester --test-location "%temp%" --log-file "MyLog.csv"
    MIN IOPS Test
        IOSpeedTester --test-location "%temp%" --buffer-size 4KiB
    MAX IOPS Test
        IOSpeedTester --test-location "%temp%" --buffer-size 4KiB --threads 64
Old 17th October 2019, 17:30   #17538  |  Link
byteshare
ByteShare
byteshare's Avatar
Batch function is working for me on 2 different systems...I'm not sure what is happening for you. I'll try to think on it.
Old 17th October 2019, 19:08   #17539  |  Link
byteshare
ByteShare
byteshare's Avatar
I was trying to encode some HDR and I normally don't define the colorprim, transfer, or colormatrix. I also don't use the tone mapping.
I'm getting the error:
x265 [error]: invalid argument: transfer = bt.2020
With tone mapping I don't, as I'd expect.
I tried defining the colorprim, transfer, and colormatrix:
--colorprim bt2020 --transfer bt2020-12 --colormatrix bt2020c
Because it looked like RB was doing it wrong (media info at the bottom), with instead:
--colorprim bt2020 --transfer bt.2020 constant --colormatrix bt2020c
But I'm seeing both RB and my settings in the the Encoding Client:
Encoding started...
""\\SERVER\Ripbot264temp\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "\\SERVER\RipBot264temp\job36\Chunks\1.avs" -strict -1 -f yuv4mpegpipe -
| "\\SERVER\Ripbot264temp\tools\x265\x265_x64.exe" --seek 0 --colorprim bt2020 --transfer bt.2020 constant --colormatrix bt2020c --crf 22 --fps
 24000/1001  --min-keyint 24 --keyint 240 --frames 1405 --sar 1:1 --profile main10 --output-depth 10 --colorprim bt2020 --transfer bt2020-12
 --colormatrix bt2020c --aq-mode 3 --ctu 64 --y4m --pools "+" --output "\\SERVER\RipBot264temp\job36\Chunks\1.265" -"
Is this a RB thing or what am I doing wrong?
Media Info:
Video
Format                      : HEVC
Format/Info                 : High Efficiency Video Coding
Format profile              : Main 10@L6@Main
Codec ID                    : V_MPEGH/ISO/HEVC
Duration                    : 48 min 21 s
Bit rate                    : 64.5 Mb/s
Width                       : 4 096 pixels
Height                      : 2 304 pixels
Frame rate                  : 23.976 (24000/1001) FPS
Color space                 : YUV
Bit depth                   : 10 bits
Bits/(Pixel*Frame)          : 0.285
Stream size                 : 21.8 GiB (100%)
Writing library             : x265 2.4+27-e9e574bbed93:[Windows][GCC 6.3.0][64 bit] 10bit
Encoding settings           : cpuid=1173503 / frame-threads=2 / numa-pools=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 /
 input-csp=1 / input-res=4096x2304 / interlace=0 / total-frames=69568 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance
 / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / bframes=8 /
 b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / no-intra-refresh / ctu=64 / min-cu-size=8 / rect
 / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip
 / nr-intra=0 / nr-inter=0 / no-constrained-intra / no-strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 /
 merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=-3:-3 / no-sao / no-sao-non-deblock / rd=4 / no-early-skip
 / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / rdpenalty=0 / psy-rd=0.30 / psy-rdoq=2.50 / no-rd-refine / analysis-mode=0
 / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=16.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30
 / aq-mode=3 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / sar=0 / overscan=0
 / videoformat=5 / range=0 / colorprim=9 / transfer=15 / colormatrix=10 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 /
 max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / opt-qp-pps / opt-ref-list-length-pps / no-multi-pass-opt-rps
 / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / no-hdr-opt / no-dhdr10-opt / refine-level=5 / no-limit-sao / ctu-info=0
Default                     : Yes
Forced                      : No
Color range                 : Limited
Color primaries             : BT.2020
Transfer characteristics    : BT.2020 (12-bit)
Matrix coefficients         : BT.2020 constant
(added linebreaks for scrolling reduction)
Old 17th October 2019, 19:13   #17540  |  Link
Send me 100MiB sample with that BT.2020 (12-bit) transfer characteristics.
